Author Topic: [IC] Future Mekanisk Group Buy's  (Read 153000 times)
Offline forevermadrigal
Re: [IC] Future Mekanisk Group Buy's
« Reply #150 on: Tue, 27 June 2017, 19:58:41 »
This is the one I need
Offline Hund
    • WWW
« Reply #151 on: Tue, 27 June 2017, 20:03:27 »
The black version of the Simple case have slightly rounded corners and edges. Is that specific to the HHKB-layout or will it be available for the regular version as well?
« Last Edit: Tue, 27 June 2017, 20:07:30 by Hund »
Change is not always progress.
Offline Atredl
« Reply #152 on: Tue, 27 June 2017, 20:10:12 »
The black version of the Simple case have slightly rounded corners and edges. Is that specific to the HHKB-layout or will of be available for the regular version as well?
That's not a HHKB-simple case. That's an actual HHKB Pro 2. Zoom in on the photo and you can see the print.
Offline Unforgivable
« Reply #153 on: Tue, 27 June 2017, 20:14:18 »
Just to clarify what everyone is seeing here, the FJELL HHKB's plate seems to be Case mount. There are grooves within the inside edges of the case for the plate to rest on, while the tabs are to hold it in place.
Think of Kin's TX boards. If you have one, you'll know how solid of a typing experience it is.
At first I thought it was only held by the 6 tabs too, until LeandreN pointed out the inside edges of the case.
I don't think there will be any ping at all with the case.  :thumb:
If im incorrect LeandreN, please correct me!
Edit: Overall, this will be the ''must get!" of 2017. Amazing work, LeandreN!  :thumb:
« Reply #154 on: Tue, 27 June 2017, 20:16:30 »
Looks nice, but are you sure 4 mounting points will be enough? That's why the pingmaster is so loud.
I think there are 6 mounting points (one on each side) but this is still a good point. I was wondering if a seamless side would be possible.
It is 6, I was wrong. I'd go for 8 personally, but 1) I'm not designing this board and 2) I don't know much about designing boards in the first place.
« Reply #155 on: Tue, 27 June 2017, 20:22:11 »
It's a case mounted plate, so it should be fine. Similar to the TX board plate style.  :thumb:
The 6 tabs are just to hold it in place, I'd assume.
Offline Hund
    • WWW
« Reply #156 on: Tue, 27 June 2017, 20:43:27 »
Oh. I'm on my phone, so I can't see anything but a thumbnail. Thanks!
Offline ipreferpie
« Reply #157 on: Tue, 27 June 2017, 22:44:04 »
Any chance the FJELL plate can accommodate split space bars? And perhaps even a dxf file for ALPS also?
Offline ctrl
« Reply #158 on: Sat, 01 July 2017, 18:07:38 »
Really interested in a dark blue Fjell Classic or Mekanisk Simple Case! They look amazing!
Offline ArchDill
« Reply #159 on: Sat, 01 July 2017, 19:29:20 »
I really hope that I have money when that "simple" case drops.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #160 on: Sat, 01 July 2017, 19:29:50 »
Thanks for the suggestions folks. Soon ready to prototype the top mounted "HHKB"-style FJELL. I will probably start working on making the simple case available, I don't want to limit it, so I will do a small design update and then get it out for people to get their hands on, how I will do that is still in the works.
Thanks.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #161 on: Sat, 01 July 2017, 19:41:05 »
And we need a name for the "simple" case. The current name is boring
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #162 on: Sat, 01 July 2017, 20:03:02 »
Offline kmba
  • Formerly tameone
« Reply #163 on: Sat, 01 July 2017, 21:30:34 »
fjord
keyboards.
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #164 on: Sat, 01 July 2017, 22:56:52 »
The F-taking all my money
Offline johuu
« Reply #165 on: Sun, 02 July 2017, 01:29:28 »
Laks
Offline TalkingTree
    • My projects
« Reply #166 on: Sun, 02 July 2017, 02:13:20 »
Elv.
Offline ctrl
« Reply #167 on: Sun, 02 July 2017, 03:38:43 »
Offline mkarlsson
« Reply #168 on: Sun, 02 July 2017, 06:18:05 »
Basix60 ?
Enviado desde mi iPhone utilizando Tapatalk
Offline DreLLin
« Reply #169 on: Sun, 02 July 2017, 07:11:46 »
That Pro looks awesome. Definitely in for one.  :thumb:
Offline wholypantalones
  • text and icon mods plz.
« Reply #170 on: Sun, 02 July 2017, 07:23:30 »
As if it needs to be said, also in for a simple case.  :thumb:
Offline ns90
« Reply #171 on: Sun, 02 July 2017, 13:25:56 »
Fjell Pro Lite
Offline duynguyenle
  • Personal text? What personal text???
« Reply #172 on: Sun, 02 July 2017, 13:51:45 »
fjord
Fjord has a nice ring to it, the river to the Fjell's mountains  :))
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline OneNightFriend
« Reply #173 on: Sun, 02 July 2017, 14:14:38 »
fjord
+1. Keep it in the fj's  ^-^
Offline Vigrith
« Reply #174 on: Sun, 02 July 2017, 17:03:26 »
Fjǫr is a cool sounding word that could be used as a name - mostly means "life" in Old Norse but I guess the added complexity of the caudata on the "o" might be unnecessary stress for people when trying to google or search for the case unfortunately.
Fjord is a little too uninspired, in my opinion.
Offline Applet
« Reply #175 on: Sun, 02 July 2017, 17:15:49 »
Fjǫr is a cool idea, they will probably find the case if they google fjor case :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #176 on: Sun, 02 July 2017, 17:18:41 »
I personally kind of like "Elv" and "Laks", since I have another project under Fjord and Fjor is very similar naming wise.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #177 on: Sun, 02 July 2017, 17:19:42 »
I might just go for "Fjøl" though 😂
Offline avid
« Reply #178 on: Sun, 02 July 2017, 18:13:53 »
hytte!
Offline kmba
  • Formerly tameone
« Reply #179 on: Sun, 02 July 2017, 18:49:43 »
damn I thought maybe if my name was selected I'd get a discount  :p
keyboards.
Offline MeloDet
« Reply #180 on: Sun, 02 July 2017, 19:58:48 »
Ooh, Elv gets my vote.
Offline amnesia0287
  • Formerly Amnesia
« Reply #181 on: Sun, 02 July 2017, 21:13:49 »
Any plans for a 65%? I'm totally planning to buy all 3 styles cause why not (perhaps not at once lol).... but a 65% would be choice :D
Offline numerofour
« Reply #182 on: Sun, 02 July 2017, 23:29:21 »
Will there be holes for the USB ports as well for the HHKB style case?
Offline duynguyenle
« Reply #183 on: Mon, 03 July 2017, 02:21:31 »
Its not meant to be a replacement case for your actual hhkb, it's still going to be a 60% case for Cherry MX PCBs, just with blocked corners so you can use the HHKB layout
Offline numerofour
« Reply #184 on: Mon, 03 July 2017, 02:46:35 »
Oh thanks for the heads up! I was looking for a HHKB replacement case and thought this would be great.
Offline quantan267
« Reply #185 on: Mon, 03 July 2017, 11:03:58 »
I love the first version of Simple case at #1. Would be really happy if it becomes real  :thumb:
ZZ96 - Lightsaver V3 -  Jetfire(incoming)
Offline get_weird
« Reply #186 on: Fri, 07 July 2017, 18:34:37 »
The simple looks awesome. Can it take any PCB or is there only a certain one that will fit?
Offline Nas
« Reply #187 on: Sat, 08 July 2017, 05:34:49 »
Any unique colours for the simple case LeandreN?
Offline DanielT
« Reply #188 on: Sat, 08 July 2017, 14:09:39 »
Any standard 60% will fit, like any GH60 compatible, Poker etc...
Offline oli
« Reply #189 on: Sun, 09 July 2017, 16:06:28 »
"Kvasir" as in the Norse god of inspiration. Or "Njord" because it's close to Fjord but you mentioned you already had an upcoming project under that name.
Offline OnceSavedGaming
« Reply #190 on: Sun, 09 July 2017, 16:11:22 »
is there a set fate on round 2 yet? my paypal is ready and willing haha :p
Offline JFKroflcopter
« Reply #191 on: Tue, 11 July 2017, 23:54:07 »
Can't wait for a chance to grab a FJELL or FJELL Pro (or both...).
Will you be offering the same colors for round two, or are you considering a wider selection?
I'd kill for a blue-gray FJELL case  :D
Offline mypainishurt
« Reply #192 on: Thu, 13 July 2017, 19:34:59 »
Count me in for the next round of Fjell!
Offline cruk
  • :> keys
« Reply #193 on: Thu, 13 July 2017, 20:25:50 »
This looks so good! If only there's a similar case for 80% (Filco)
Offline hq
« Reply #194 on: Fri, 14 July 2017, 04:39:42 »
Do you have an rough ETA for the pro normal case?
Offline Pepe_Silvia
« Reply #195 on: Sat, 15 July 2017, 16:32:31 »
I'd be in for the simple case. Will the pcb sit lower in the case so the keycaps look more tucked like on the fjell?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #196 on: Sat, 15 July 2017, 16:37:34 »
The idea is to have this case higher profile than other cases so you cant see the gap.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #197 on: Sat, 15 July 2017, 17:35:59 »
I really like the idea of the high quality 60% kit if it is something you will be keeping in stock. It would be very nice to see a premium kit available in perpetuity for those in need of it quickly or if there isn't any good GBs going on. The Fjell V2 is looking just as amazing as the original, really hoping I can get in on one if my finances line up with the GB. Also if the HQ 60% kit is something that is regularly available I'm sure I'll end up picking up 1 or 2 of them down the road. Thanks for the update LeandreN & keep up the good work!
Oh, BTW the 2nd shipment of krytox mix made it to me. I sent you an email to let you know. Still a no go on the original package unfortunately, pretty sure that one is just straight up lost at this point. Probably stuck under the seat of a mail truck or something stupid like that I bet. :mad: If it does show I will let you know. :thumb:
Offline Pepe_Silvia
« Reply #198 on: Sat, 15 July 2017, 19:14:35 »
Excellent, I only ask because in the 3rd pic the gaps are quite visible on both cases.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #199 on: Sun, 16 July 2017, 13:28:48 »
