Author Topic: [IC] Future Mekanisk Group Buy's  (Read 153531 times)
Offline Atredl
Re: [IC] Future Mekanisk Group Buy's
« Reply #50 on: Thu, 15 June 2017, 21:36:31 »
run em all people will buy them
don't run fjell in a size other than 60 though, it'll look weird
also i don't like fjell pro, i think it goes against the look of normal fjell
I'm curious why you think the pro would look different than the normal fjell. The Fjell Pro has both full 60% and HHKB layouts, albeit with different tops.
Does regular Fjell have HHKB layout?
Also screw holes.
I think those are both "me" things though.
My point is that the Fjell pro has a non-HHKB version. Regular Fjell and Fjell pro non-HHKB should look the same from the outside.
Screw holes are a valid complaint though. I didn't think about that.
« Reply #51 on: Thu, 15 June 2017, 21:43:36 »
non HHKB is fine
but screw holes on the bottom are worth noting
Offline SpectreiiI
  • Scribe
« Reply #52 on: Thu, 15 June 2017, 22:03:51 »
I'm a bit new to this market, but I have researched just about every custom case that has ever been made. Less than a week after I launch my top mounted HHKB case IC, this pops up...
Offline Cobertt
    • Control on Caps
« Reply #53 on: Thu, 15 June 2017, 22:10:04 »
Count me in on a Fjell R2 Case  :thumb:
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline drbobbybones
« Reply #54 on: Thu, 15 June 2017, 23:33:26 »
I would buy a R2 Fjell in a heartbeat.
Offline amnesia0287
  • Formerly Amnesia
« Reply #55 on: Thu, 15 June 2017, 23:38:39 »
I'd definitely buy a fjell or pro... Probably one of the aluminum ones too, though maybe not at the same time :D.
Offline shinz0
  • i was told there would be cake
« Reply #56 on: Thu, 15 June 2017, 23:58:38 »
Interested in r2 and pro!
Offline inosint
« Reply #57 on: Fri, 16 June 2017, 00:42:05 »
Can't wait for dat Fjell pro!
Offline E3E
« Reply #58 on: Fri, 16 June 2017, 01:50:42 »
Of course the FJELL PRO is what people want. I can dig it. Maybe one in dark grey this time around!
Offline Tally810
« Reply #59 on: Fri, 16 June 2017, 02:07:47 »
Top Mount fjell fasho
Sent from my SM-G928V using Tapatalk
Offline moecoffee059
« Reply #60 on: Fri, 16 June 2017, 02:17:29 »
hope 75% in the future,
Offline h3xadat
« Reply #61 on: Fri, 16 June 2017, 03:13:22 »
I'm down for the FJELL Classic and the FJELL Pro!
Offline Myan
« Reply #62 on: Fri, 16 June 2017, 07:46:09 »
Awwww , give me the puple FJELL HHKB!
Please do not limit, I am so excited! :thumb:
Offline robotsokk
« Reply #63 on: Fri, 16 June 2017, 10:33:31 »
Much hype! At minimum I'd want a Fjell Pro (normal/non-HHKB).
Really hoping to participate as I wasn't aware of R1 until well after it already closed.
@home      @work Swapping out boards... coming soon     wtb
Offline johuu
« Reply #64 on: Fri, 16 June 2017, 12:20:46 »
Interested in the FJELL HHKB PRO kit.
Offline DanielT
« Reply #65 on: Fri, 16 June 2017, 12:29:29 »
I'd be in for a simple one  :cool:
Offline AlexG
« Reply #66 on: Fri, 16 June 2017, 12:54:57 »
I would buy a pro instantly
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #67 on: Fri, 16 June 2017, 15:18:02 »
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #68 on: Fri, 16 June 2017, 15:22:45 »
I cast my vote for the Simple once again.
That's a good looking case.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Marutks
« Reply #69 on: Fri, 16 June 2017, 15:29:27 »
I want FJELL R2 case!    Is it going to be on massdrop.com?    Where can I sign up?
Offline TheNamesTy45
« Reply #70 on: Fri, 16 June 2017, 15:45:34 »
Fjell Pro HHKB. Yes please. I want.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #71 on: Fri, 16 June 2017, 15:52:45 »
I am not going to launch it on Massdrop, but you can join my newsletter on mekanisk.co :)
Thanks for your interest.
Offline jihadu
« Reply #72 on: Fri, 16 June 2017, 15:57:23 »
Will you sell the simple case as a standalone or just as a kit?
I've been looking to replace my GH60s plastic case for a while now.
Enviado do meu SM-A520F através de Tapatalk
Offline mtzgr
    • My youtube
« Reply #73 on: Fri, 16 June 2017, 17:12:45 »
Would really like to snag the MKSC, looks so clean.  :thumb:
« Reply #74 on: Fri, 16 June 2017, 19:03:37 »
That HHKB is nice.
Offline SixtyLife
« Reply #75 on: Fri, 16 June 2017, 19:25:47 »
what is the case on the right? I can see "hhkb" in the corner but I've never seen an hhkb case like this
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline oatmicro
« Reply #76 on: Fri, 16 June 2017, 19:31:54 »
Must be HHKB Professional BT(Bluetooth) for sure.
Offline SixtyLife
« Reply #77 on: Fri, 16 June 2017, 19:36:01 »
ahh I see, thanks!
Offline Pwner
  • soon™
« Reply #78 on: Fri, 16 June 2017, 19:46:39 »
I slept on r1 of the Fjell but after seeing all the builds.. I have to get in on r2.
Offline quantan267
« Reply #79 on: Sat, 17 June 2017, 01:24:44 »
Count me in on the simple case  ;D so damn sexy, simple classic thing is always the best
« Last Edit: Sat, 17 June 2017, 01:29:36 by quantan267 »
ZZ96 - Lightsaver V3 -  Jetfire(incoming)
Offline DanielT
« Reply #80 on: Sat, 17 June 2017, 01:32:31 »
The simple case is just what I need. You have my vote for this one again.
Offline Quakemz
« Reply #81 on: Sat, 17 June 2017, 05:54:45 »
I don't think I've supported anything in my life as much as I want to support all of these amazing projects. Beyond amazing work, my friend.  :thumb:
Offline IAmPyhrra
« Reply #82 on: Sat, 17 June 2017, 08:32:37 »
I would be in for the Simple case as well as Fjell classic/Pro. These are without a doubt some of the cleanest 60% cases.
« Last Edit: Sat, 17 June 2017, 08:47:27 by IAmPyhrra »
Offline Define
« Reply #83 on: Sat, 17 June 2017, 11:47:29 »
Down for any HHKB case
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #84 on: Sat, 17 June 2017, 13:01:06 »
FJELL is unreal. Gorgeous and right up my alley. I don't know if I'm alone but I would have a keeb heart attack if you offered this case in a slightly lower profile. I'm not big on the steep angle and never use keyboard legs when typing.
Anyone else second this? It would be my dream :)
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Auk
« Reply #85 on: Sat, 17 June 2017, 13:18:49 »
...not big on the steep angle... ....Anyone else second this?...
If it's possible to make the FJELL style flat and with adjustable feet, but without compromising the look, the result could be very compelling :)
Offline Doluded
  • road to black star
« Reply #86 on: Sat, 17 June 2017, 13:24:59 »
Very... comfjelling
Offline robotsokk
« Reply #87 on: Sat, 17 June 2017, 13:40:13 »
Hi LeandreN,
Is the idea that the case colors would be the same as R1, or are there colors you were considering adding/removing? The purple and grey cases are my favorite (grey w/red plate would be a great pairing).
« Reply #88 on: Sat, 17 June 2017, 13:47:00 »
Day 2 since seeing the fjell pro hhkb:
Dear Diary,
I still want this. Working on a way to distort time to hasten my acquisition of this case. Two failed prototypes, but I'm hoping I have a breakthrough soon. Still keeping hold of sanity, but it's becoming increasingly difficult to do so. Will report back tomorrow. End entry.
Offline jenggo
« Reply #89 on: Sat, 17 June 2017, 13:54:49 »
aaaaand i'm still waiting for my fjell r1 to be shipped ._.
Filcos | JD40 | Planck | FJELL | Jetfire | Weaven | GON 60 | BWU | DasKeyboard | PokerII | Strafe | Octagon v2 | TX 1800 | TXCP | Realforce 104UB | KMAC 1 | TXPad | DC60 | Ergos
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #90 on: Sat, 17 June 2017, 14:13:47 »
Nothing will start here before you have FJELL r1 in your hands!
Sent fra min D6603 via Tapatalk
Offline Jedi
« Reply #91 on: Sat, 17 June 2017, 17:05:35 »
+1 for any news on a round6 for plates and pcb. Those of us with R1 envy that lost are forever interested in this upcoming GB. Excellent work LeandreN
Offline kekstee
« Reply #92 on: Sat, 17 June 2017, 17:15:28 »
The simple one is something I would really consider.
Offline PotatoTM
« Reply #93 on: Sat, 17 June 2017, 18:38:43 »
Can anyone post their pictures of their black and/or gray FJELL(s) I'm trying to decide which one I like more!
Offline N0GLUT0N
« Reply #94 on: Sat, 17 June 2017, 20:22:38 »
In the hhkb fjell
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #95 on: Sat, 17 June 2017, 21:13:32 »
*drolls*
i want that fjell or fjell pro ..
on the second thought, i don't want that. i need that to stop my drools.
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline goodeyesniper85
  • clickityclack
« Reply #96 on: Sun, 18 June 2017, 11:09:03 »
All the interest. Would also love to see the brass plates be a regular a la carte item as well. Possibly add custom engraving (for an additional cost obviously and time frame). Looks great!
Offline malattia
« Reply #97 on: Sun, 18 June 2017, 21:49:29 »
Interested in the R2. I'd certainly get one, maybe even two.
Offline Manticzeus
« Reply #98 on: Mon, 19 June 2017, 08:17:04 »
I'm so interested I made an account for this.
Offline DanielT
« Reply #99 on: Mon, 19 June 2017, 11:38:03 »
Will the simple case have a weight? That would be sick!  :cool:
