Author Topic: [IC] Future Mekanisk Group Buy's  (Read 153046 times)
Offline Strontaap
Re: [IC] Future Mekanisk Group Buy's
« Reply #300 on: Wed, 13 September 2017, 10:00:02 »
Fjell HHKB sounds great!
M65-A | COD67
Offline threatdisplay
« Reply #301 on: Thu, 14 September 2017, 01:58:11 »
In for FJELL r2 for the AEK64 I'm building! I signed up to geekhack just to be sure I don't miss it!
Offline kawasaki161
« Reply #302 on: Thu, 14 September 2017, 04:59:54 »
That sentence makes no sense at all.
Offline smithyithy
  • a l p s
« Reply #303 on: Thu, 14 September 2017, 07:47:04 »
The user is pre-committing himself to the yet-to-be announced second round (R2) of the Fjell case, which he plans to use for his AEK64 custom keyboard build.
The user registered to the Geekhack forum for the sole purpose of keeping up to date with any new Fjell news, in the hopes of not missing the announcement of a second round.
KBD75; Alps64 trio; some other stuff
Offline shekki
« Reply #304 on: Thu, 14 September 2017, 11:44:22 »
Excellent deduction, sir
Offline duynguyenle
  • Personal text? What personal text???
« Reply #305 on: Thu, 14 September 2017, 18:48:02 »
This guy knows what's up
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline amnesia0287
  • Formerly Amnesia
« Reply #306 on: Fri, 15 September 2017, 04:00:56 »
These people right here... make sense. alot of sense. like, a really obvious amount of sense. i'm not exaggerating.
This guy...
Offline kawasaki161
« Reply #307 on: Fri, 15 September 2017, 06:28:31 »
This guy...
Damn, you must be having a really great morning, lol
But seriously, how will you build an AEK64 (which is a case) with a Fjell (which is also a case)?
« Last Edit: Fri, 15 September 2017, 06:33:11 by kawasaki161 »
Offline amnesia0287
  • Formerly Amnesia
« Reply #308 on: Fri, 15 September 2017, 06:33:30 »
This guy...
https://github.com/dennistimmermann/aek64
Sent from my iPad using Tapatalk
Offline kawasaki161
« Reply #309 on: Fri, 15 September 2017, 06:36:32 »
Oh, that kinda makes sense, who would have thought that there are many different things that are named the same, I was thinking about this case with integrated plate:
https://imgur.com/a/wCXv1
Offline avid
« Reply #310 on: Fri, 15 September 2017, 06:47:32 »
Will the Pro be more expensive?
tray vs top-mount:  Top-mount is superior in every way - right?
Offline duynguyenle
« Reply #311 on: Fri, 15 September 2017, 07:25:47 »
This guy...
He meant Alps64 PCB, not AEK64 the stainless steel case
Offline smithyithy
  • a l p s
« Reply #312 on: Fri, 15 September 2017, 10:59:31 »
Ah, I see what he meant (kinda), and I kinda expected this.
AEK64 is a layout. It's a 60% board based on the old Apple AEK boards, but in a 60% size. Most of the time using Hasu's Alps64 PCB, and whatever case you want (Fjell, for example).
Someone recently ran a closed group buy of a 60% case, called the AEK64, which I think is where the confusion came from - I've seen this a few times already, actually - after seeing that new steel case, because the case is named after a layout that already existed..
ETA: that is to say, one could build a an 'AEK64' keyboard, with or without the new 'AEK64' steel case, and it would still be an AEK64 keyboard. If that makes sense Kawasaki?
« Last Edit: Fri, 15 September 2017, 11:02:16 by smithyithy »
Offline Atredl
« Reply #313 on: Fri, 15 September 2017, 15:54:26 »
It's pretty certain the Pro will be more expensive.
Whether it's superior depends on the traits you view as more important.
Top-mounted cases tend to feel more solid since the plate is attached to the case. Though if it is improperly designed it can also have pinging issues when the plate transfers the keystroke to the case. They are also capable of coming in the HHKB layout with Universal PCB's (GH60). They also tend to be more expensive since the multiple parts makes it more complicated to produce.
Tray-mounted cases offer a different feel since the PCB is attached to the case instead of the plate. IMO this gives the keyboard a softer feel. This completely avoids the pinging issue that improperly designed Top-mounted cases can have. Tray-mounted cases can also be easily swapped because they use universal plates. While Top-mounted cases use plates that are specific to them. They also tend to be cheaper because they can be made in one piece.
One isn't better than the other. There is only the one that best fits what you want out of a keyboard.
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #314 on: Fri, 15 September 2017, 23:30:38 »
Yeah he said somewhere the pro would be more than the Classic case.
Offline Kafka
  • i like clean things
« Reply #315 on: Fri, 15 September 2017, 23:37:33 »
1up sure is taken their time
Offline reidd
« Reply #316 on: Sun, 17 September 2017, 19:25:29 »
Yeah, I hope it happens this week...
Offline funkybeat7
« Reply #317 on: Sun, 17 September 2017, 20:52:12 »
My body is ready for a Fjell R2, I really want a purple one!
Offline kmba
  • Formerly tameone
« Reply #318 on: Sun, 17 September 2017, 21:24:19 »
What's the height on the front face of the klippe?  How about the fjell?
keyboards.
Offline ibakey
« Reply #319 on: Wed, 20 September 2017, 22:28:38 »
My wallet have never been more ready for the Fjell R2.
Offline MeloDet
« Reply #320 on: Thu, 21 September 2017, 18:56:43 »
Klippe is up on 1upkeyboard btw
Offline Rumblehotep
« Reply #321 on: Thu, 21 September 2017, 18:59:57 »
Purple at the bottom of the page.
I would be all over this if I hadn't ordered two Rev60s
Offline funkybeat7
« Reply #322 on: Thu, 21 September 2017, 19:01:10 »
Holding out for fjell r2 over here :D
Offline OnceSavedGaming
« Reply #323 on: Thu, 21 September 2017, 19:06:27 »
Already ordered the revo otherwise I'd be on the grey one for sure
Sent from my SM-G920V using Tapatalk
Offline reidd
« Reply #324 on: Thu, 21 September 2017, 19:10:36 »
Klippe is live on 1up! Already ordered mine in grey : )
Offline MeloDet
« Reply #325 on: Thu, 21 September 2017, 19:32:01 »
Picked up the purple myself :) Looks soo good.
Offline lunr
« Reply #326 on: Thu, 21 September 2017, 19:37:07 »
huh i would think silver would be in there. oh well.
Offline Softkore
« Reply #327 on: Thu, 21 September 2017, 19:44:14 »
Just picked up a purple Klippe! It was hard to choose between purple or black, but I have a black Fjell. Does anyone know approximately when the Fjell R2 and Fjell Pro buys will be? If they're going to be simultaneous I want to make sure I'm prepared...
Offline dodgeyhack
« Reply #328 on: Thu, 21 September 2017, 19:55:15 »
Urgh $50USD shipping.
Anyone else in Australia (preferably Sydney) want to combine an order?
Offline pixelpusher
« Reply #329 on: Thu, 21 September 2017, 21:08:31 »
Purple is sold out.  Wow. That was quick. You did say you planned to keep manufacturing these, correct?
Offline amnesia0287
  • Formerly Amnesia
« Reply #330 on: Thu, 21 September 2017, 21:18:47 »
What he said^
Offline Softkore
« Reply #331 on: Thu, 21 September 2017, 21:20:39 »
What he said^
From what I've seen, he said they'll be available on 1up first, with more retailers and/or group buys possible in the future.
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #332 on: Thu, 21 September 2017, 22:15:15 »
Try asking in the Auskey's Discord
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #333 on: Thu, 21 September 2017, 23:19:38 »
I knew this **** was going to happen!  Only black cases left (no thank you).
Would have loved for this to be a normal GB  :(
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline jihadu
« Reply #334 on: Fri, 22 September 2017, 04:30:35 »
This. I have been waiting for ages for the announcement, only for them to announce the sale and run out of them while i'm sleeping.
Offline lanyusea
« Reply #335 on: Fri, 22 September 2017, 04:45:37 »
wait, where is the announcement?
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline smithyithy
  • a l p s
« Reply #336 on: Fri, 22 September 2017, 05:08:38 »
Too late :/
Offline Athlio
« Reply #337 on: Fri, 22 September 2017, 06:00:00 »
Yep, a bit of advance notice on when the sale was going to go live would have been fantastic  :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #338 on: Fri, 22 September 2017, 06:01:56 »
I had no idea when it was going to go live sorry
Offline wholypantalones
  • text and icon mods plz.
« Reply #339 on: Fri, 22 September 2017, 08:00:24 »
Don't worry, you'll more than likely be able to pick them up on mechmarket for a significant markup in the next week or so.
Offline Athlio
« Reply #340 on: Fri, 22 September 2017, 08:03:15 »
100% not your fault, that was intended for the vendor.
« Reply #341 on: Fri, 22 September 2017, 08:38:32 »
If they are being sold through a vendor and not a gb then more should be added to the site as they become available from the manufacturer.
Offline MeloDet
« Reply #342 on: Fri, 22 September 2017, 08:53:05 »
As unfortunate as it is for some, it's still pretty impressive how quickly those sold out. You must've done a good job designing LeandreN :P
Offline planetsiah905
« Reply #343 on: Fri, 22 September 2017, 17:46:55 »
So, sad. Been checking 1up for weeks and the one day I don't check, they launch and I missed it. Group Buy still planned for the klippe? Pleease?
Offline midnight2903
« Reply #344 on: Sat, 23 September 2017, 08:27:39 »
Any news on FJELL HHKB/Pro? Really interested in that.
Offline Softkore
« Reply #345 on: Sat, 23 September 2017, 09:42:00 »
I managed to snag a purple Klippe, but may end up selling/trading it in an attempt to get a UK78
« Last Edit: Sat, 23 September 2017, 09:48:27 by Softkore »
Offline TheEv0
« Reply #346 on: Sat, 23 September 2017, 19:10:08 »
WTF They already sold out?! I was waiting to hear some sort of announcement... Fking christ.
Offline Athlio
« Reply #347 on: Mon, 25 September 2017, 15:49:45 »
Has anyone's Klippe shipped yet? Asking for a friend.
Offline Softkore
« Reply #348 on: Mon, 25 September 2017, 15:50:42 »
Not yet!
Sent from my Pixel using Tapatalk
Offline JFKroflcopter
« Reply #349 on: Mon, 25 September 2017, 15:56:10 »
Got a notification a couple hours ago that mine has shipped  :D
