Author Topic: [GB] GMK Solarized Dark - COMPLETE  (Read 623108 times)
Offline forevermadrigal
Re: [GB] GMK Solarized Dark
« Reply #50 on: Thu, 29 June 2017, 03:02:10 »
Interesting lighting you are choosing there.
Do you have examples that are different? If I'm wrong I'd love to be corrected. I just googled photos. I don't own plum and my hydro hasn't shown up yet.
Your response makes it out like you think I'm trying to win an argument. Just to be clear... I am not.
I could care less which one of us is correct. I just have seen nothing that would lead me to trust the GMK renders. If I'm lacking information, I'd love to know. Rather than just saying it's wrong, I'd love to know what specifically you think is wrong. Which render. What is wrong with the render? Etc.
I'm not trying to invalidate your opinion, just understand where it comes from.
Sent from my iPad using Tapatalk
All I said was interesting lighting and renders are renders. It's just something I have noticed. I'm not dissing thesis cause I love his renders and his upcoming boards, but his renders aren't always accurate. I don't have pictures as I don't need them cause I own the sets.
Offline kmba
  • Formerly tameone
« Reply #51 on: Thu, 29 June 2017, 06:40:31 »
You're nuts if you think gmk renders are more accurate than thesiscampers. Nuts I tell ya! But yes, sets will not look exactly like the renders because many sets today is custom colors (hydro, plum, etc) which aren't going to be reproduced with 100% accuracy.
keyboards.
Offline Kavik
« Reply #52 on: Thu, 29 June 2017, 09:28:22 »
 :-\ It's just especially confusing in this instance because, if it ends up looking like the GMK render, I'm not interested at all, but, if it looks like ThesisCamper's renders, then it's awesome and I want it. I guess I'll think about it some more.
Offline TalkingTree
    • My projects
« Reply #53 on: Thu, 29 June 2017, 09:41:39 »
Hopefully GMK Skeletor renders should clear your mind.
GMK render
thesiscamper's render
Actual product
« Reply #54 on: Thu, 29 June 2017, 10:13:51 »
GMK render
Actual product
Huh. GMK renders are getting better. The original render is a lot closer to the actual product than thesis'.
Offline Arallu
« Reply #55 on: Thu, 29 June 2017, 10:39:52 »
Putting an order in for this one, for the SINGLE simple fact that it has barred F/J keys.
Offline kmba
  • Formerly tameone
« Reply #56 on: Thu, 29 June 2017, 10:55:51 »
GMK render
Actual product
Disagree. The lighting in that actual picture is horrible and does not allow for accurate representation. The white balance is way off. Sekeletor uses standard yu2 and DY which more closely resemble the non gmk render. That render is a little "bright" but still more accurate.
keyboards.
Offline amnesia0287
  • Formerly Amnesia
« Reply #57 on: Fri, 30 June 2017, 05:20:53 »
GMK render
Actual product
This is a quick photo of my skeletor from my iPad. No correction. Using flash in a dark room. Thesiscamper render is spot on. At least in real life. (I can't see them side by side yet)
Offline amnesia0287
  • Formerly Amnesia
« Reply #58 on: Fri, 30 June 2017, 05:24:42 »
Same keyboard. Under white light (Philips hue) again untouched just no flash this time
Thesis:
Moral of the story is light color temp is super important to color.
« Last Edit: Fri, 30 June 2017, 05:29:46 by Amnesia »
« Reply #59 on: Fri, 30 June 2017, 14:02:02 »
It should be common knowledge at this point that renders will not match up perfectly with the final product.
Generally they're pretty close, but I always try to reserve judgement until I have product in hand.
Offline jchan94
  • Keyclack Inc
  • * Moderator
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #60 on: Fri, 30 June 2017, 15:30:27 »
Last example. But I hope we can steer away from the render accuracy.
Renders are what we want the set to look like. Not all renders will be reflective of the end set. Thesiscamper, the render genius, has made a huge effort in making sure his renders are really accurate and they're the closest thing we'll get to the real deal imo.
Here's one more example
GMK Render
Thesiscamper Render
Actual Keycaps
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline kmba
  • Formerly tameone
« Reply #61 on: Fri, 30 June 2017, 15:35:19 »
And I fully believe the designer are anal enough that they will ensure gmk matches the desired color accurately. They will get samples, and they can reject samples.
Anyway, numbers looking great for not even being half way through the buy period.
keyboards.
Offline Auk
« Reply #62 on: Fri, 30 June 2017, 15:49:06 »
I hope we can steer away from the render accuracy...
Agreed, maybe I can ask a couple of questions and request an update:
  • Are any of the sets looking like meeting a price break when the proxy numbers are added?
  • I'm curious about the HJKL keys with cursor legends, are those specifically for 40% boards, or are they for some other layouts?
  • I've just noticed the standard modifier color cursor keys are all row 4, yet the accent set appears to have the up arrow on row 3? is that just an error on the layout drawing or is that actually how it will be produced?
« Last Edit: Fri, 30 June 2017, 15:55:12 by Auk »
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #63 on: Fri, 30 June 2017, 17:01:37 »
1. Mods should be close, and spacebars I think
2. Those are known as vim caps.
Offline Draic
« Reply #64 on: Sat, 01 July 2017, 05:50:24 »
split spacebar is not really interesting for most keyboards other than 40% which are not supported. Strange decision
Offline Auk
« Reply #65 on: Sat, 01 July 2017, 06:01:57 »
what about all the 60%-65% that allow flexible bottom row layouts?
Offline OneNightFriend
« Reply #66 on: Sat, 01 July 2017, 15:12:39 »
This is my first keyset group buy and I am really looking forward to it! Great job on this set so far guys!
Offline euphxenos
« Reply #67 on: Sun, 02 July 2017, 13:32:21 »
Hi JC, rain1blood, and thesiscamper,
Is it possible to include colored 1U Alt and 1U Crtl? Thank you.
Modify message
I talked to jchan and he said it's possible, will update everyone when we clear all these additional keys up.
I don't think I saw a follow-up to this -- did the extra key requests get resolved or is that still pending?  I had requested a R3 PgUp and R4 PgDn for 65% near the end of the IC thread.
Offline Arallu
« Reply #68 on: Sun, 02 July 2017, 14:33:43 »
Modify message
Maybe the layout is incorrect, but it looks like the only 65% right side column they're supporting for 65% is DEL/HOME, PGUP, PGDN, END since the only R3 key is PGDN and the only R4 key is END.
Don't know what the other R1 PGDN(a 96% keyboard), R1 END (an 1800 keyboard?), and duplicate R1 HOME keys are for.
« Last Edit: Sun, 02 July 2017, 14:38:39 by Arallu »
Offline kmba
  • Formerly tameone
« Reply #69 on: Sun, 02 July 2017, 18:46:46 »
Home, pgup, pgdn, end isn't unheard of for 65% support.  Personally prefer pgup, pgdown, home, end, but honestly it's of little importance.
keyboards.
Offline amnesia0287
  • Formerly Amnesia
« Reply #70 on: Sun, 02 July 2017, 22:11:11 »
Modify message
I'd assume they are for TKL if you want both rows to be R1 (similar to how people will do all arrows R4)
I do think it needs an R3 Home and an R4 green up arrow though. R3/R4 Page Up/Page down would be nice, but less important. (I DO agree with euphxenos that they SHOULD be added, but they wouldn't stop me. I'm not sure I could deal with home/pgup/pgdwn/end. Either home/end/pgup/pgdwn or pgup/pgdwn/home/end are fine though. I would prefer both options, but as long as ONE of them is available it works for me.
But yeah, no R3 home just seems like a mistake when there are 3 rows to do pgUp/pgDwn with.
My guess is the duplicate R1 Home is supposed to be R3. Otherwise I think you are right, it makes no sense.
Offline thesiscamper
    • Keyrenders
« Reply #71 on: Mon, 03 July 2017, 01:47:41 »
It's not easy to add keys after the pricing has been released and the GB has started. That's why there was an IC. We try to support the most popular layouts, but can't support each and every personal preference people have on how they arrange their keys.
"haters are confused admirers"
Offline amnesia0287
  • Formerly Amnesia
« Reply #72 on: Mon, 03 July 2017, 06:32:26 »
So having 2 R1 Home and no R3 Home is intentional? Does changing the row actually effect pricing? I don't see why that key WOULDN'T be converted to R3 unless there is some keyboard with double home keys that I'm not aware of.
« Last Edit: Mon, 03 July 2017, 06:33:59 by Amnesia »
    • Keyrenders
« Reply #73 on: Mon, 03 July 2017, 06:38:52 »
The duplicate is not intentional, but the R3 home and any other additional keys will have to be discussed with jchan, since we can't just raise the prices.
Offline Auk
« Reply #74 on: Mon, 03 July 2017, 07:04:20 »
I think this got overlooked when I queried it earlier, so could one of the designers clarify? Is the row 3 teal arrow key intentional and actually row 3, or will it be a row 4 when manufactured? Thanks!
172241-0
    • Keyrenders
« Reply #75 on: Mon, 03 July 2017, 08:33:18 »
Regarding the duplicate R1 Home and the R3 Up arrow, I was told these issues have been fixed (KLE Render). We haven't requested new renders from GMK yet since they take too long and we're still discussing which keys we can add.
Offline Auk
« Reply #76 on: Mon, 03 July 2017, 10:39:56 »
Regarding the duplicate R1 Home and the R3 Up arrow...
Thanks for the update. I really wasn't sure if I was unaware of a layout the arrow was part of, so I am grateful for the clarification  :)
    • Keyrenders
« Reply #77 on: Mon, 03 July 2017, 10:47:58 »
No problem  :thumb:
As for the accuracy of the renders, I missed the earlier discussions. All the images you see, be it renders or photos are affected by lighting. I try to make it as close as possible to what the designer wants, and only send the final renders when the designer approves.
So the workflow is: designer's idea > I try to make it as close as possible to what he/she wants > designer approves > set is made.
Offline Auk
« Reply #78 on: Mon, 03 July 2017, 14:51:10 »
As for the accuracy of the renders, I missed the earlier discussion...
That probably got a little out of hand, but I do agree with one of the early observations - your render appears darker, more gray and less green than the color specification would indicate, the modifiers actually look dark grey, almost charcoal on my screen (which is a TV, 4:2:2 color depth only and not calibrated i.e. pretty bad for comparison like this.)
I did a screen grab of the various images next to each other. Only because I wanted to try it out, the bottom middle with random characters is Solarized Dark in gedit:
172286-0
I'm hoping the manufactured article tends toward the greener and lighter overall, but I can't obsess about the variations between the different renders and the physical for the reasons already pointed out: GMK color will not match exactly, lighting, color temperature and physical texture will have a very significant effect on the perception. However, while we are looking at the renders, is there a color space issue that might be amplifying the difference on some screens?
EDIT: and as I perceive them, GMK renders tend to look a bit pale and washed out.
« Last Edit: Mon, 03 July 2017, 15:19:17 by Auk »
Offline Arallu
« Reply #79 on: Mon, 03 July 2017, 15:02:38 »
I'm hoping the manufactured article tends toward the greener and lighter overall ...
+1
    • Keyrenders
« Reply #80 on: Mon, 03 July 2017, 18:29:48 »
The three of us all agreed to make it as close to my latest renders as possible.
« Last Edit: Mon, 03 July 2017, 19:18:20 by thesiscamper »
Offline xantiema
« Reply #81 on: Mon, 03 July 2017, 19:21:57 »
Which renders are the latest ones?
Offline Petch
« Reply #82 on: Wed, 05 July 2017, 06:26:51 »
Since I can't get a response from jchan, why isn't there a 1.25u fn key? This is pretty standard
Offline Draic
« Reply #83 on: Wed, 05 July 2017, 06:33:46 »
because the set was rushed
Offline kmba
  • Formerly tameone
« Reply #84 on: Wed, 05 July 2017, 07:14:43 »
Actually, designers frequently opt for a menu key over a 1.25 fn key with Gmk sets. Honeywell, muted, this set, pnumbra, Miami, Miami nights, sky dolch, cyan, mint chocolate, ocean dolch just to name a few recent sets.....
keyboards.
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #85 on: Wed, 05 July 2017, 07:16:08 »
There will be, if you notice there's a duplicate 1u fn key, it should be 1.25u. We'll be releasing an official final update in a day or two.
Offline Petch
« Reply #86 on: Wed, 05 July 2017, 09:34:39 »
Honeywell had code buttons in addition to windows, so I just used a 1.25u 'code' button as fn. This set just has shebang (no code or windows)
I see little point in having R3 control without good fn options
« Last Edit: Wed, 05 July 2017, 09:38:30 by Petch »
Offline Auk
« Reply #87 on: Wed, 05 July 2017, 10:08:13 »
I must admit this makes me a little uneasy, given the colors are specified precisely by the values stated. I anticipated the end result being somewhere between the renders with just a little deviation from the color values (because GMK aren't likely to 100% matched.) A lot of people love the render, so it won't be the end of the world to sell the set unused, anyone who is disappointed should easily find a buyer.
That the designers prefer the slightly darker/grayer over the lighter/greener is fine in itself. What I wish is that your intentions were clearer, especially on the product pages - it's the ambiguity that's the problem here, not the final choice you made.
« Last Edit: Wed, 05 July 2017, 10:20:29 by Auk »
    • Keyrenders
« Reply #88 on: Wed, 05 July 2017, 10:38:57 »
I understand your concern, and here's why we decided to change it: the solarized theme looked good on screens, but we felt the contrast between the mods and the alphas was lacking in caps. If you can find the earliest renders, there's almost no point in using different colors when they're almost indistinguishable from each other. For the most recent renders, I tried to introduce more contrast into the set, and the three of us liked it and it got good feedback, so we went with it. As for the color codes, it was a mistake on our part that we weren't clear enough, I just assumed everyone was in sync but we weren't.
For the mistake in keys, it's mostly misunderstanding again. I apologize on behalf of my friends, but we're trying to fix it but decided not ask for an updated GMK renders until we're sure we have the keys locked. The KLE is the most updated one.
Offline Draic
« Reply #89 on: Wed, 05 July 2017, 11:13:27 »
But solarized dark is meant to be a low contrast theme, so I can't say I like the decision to increase the contrast :/
    • Keyrenders
« Reply #90 on: Wed, 05 July 2017, 11:16:28 »
You can continue using it on your text editor and ignore this set. It doesn't have support for 40% anyway.
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #91 on: Wed, 05 July 2017, 11:40:30 »
Here's the final mockup of all the keys that will be included in each set. Apologies for the KLE mockup, GMK takes a while to re-render and we don't really want to bother them that much.
Just to summarize, here are the changes since the GB launch:
Base Kit
- Added 6u centered stem spacebar
- Replaced R4 1u Fn to R4 1.25u Fn
- Removed duplicate R1 Home
- Fixed R3 accent arrow up that should be R4
Colored Mods
- Added 1u ctrl and alt
Spacebar Kit
- Added barred J vim key
- Added 6u accent centered stem spacebar
Offline Petch
« Reply #92 on: Wed, 05 July 2017, 11:49:24 »
Okay, looks great now  :thumb:
Offline Auk
« Reply #93 on: Wed, 05 July 2017, 11:55:52 »
Here's the final mockup...
Base Kit
- Added 6u centered stem spacebar...
If you can add it on the image I would be suggest stating that the 6u spacebar is centered stem, it seems to be asked endlessly on Massdrop keyset discussion (along with "is there a 2u shift?")
Since they're no longer defining the palette, I would remove the hex color codes as well. If possible tweak the overall color of this mockup to be closer to what you think the final set will be like.
« Last Edit: Wed, 05 July 2017, 12:13:39 by Auk »
Offline Auk
« Reply #94 on: Wed, 05 July 2017, 14:02:06 »
...As for the color codes, it was a mistake on our part that we weren't clear enough, I just assumed everyone was in sync but we weren't.
It really didn't register with me until now. I do drift in and out of discussions and the group buy for Solarized starting when it did caught me by surprise - I think I'd decided the colors here were good, and rainb1ood said the modifiers would be text, which was perfect, so I focused my attention on ICs where I wanted to offer my $0.02. In my mind Solarized was a set I was satisfied I wanted, so I left it to the more experienced hands to figure the kit breakdowns and coverage. As a result I missed any talk about using the renders as the reference point for the final colors.
Rookie error I guess from my side, but it doesn't hurt me because I have belatedly become aware of the design evolution before being locked into a purchase.
...the contrast between the mods and the alphas was lacking in caps...
The colorway is based on Solarized Dark so I think anyone would expect some reasonable latitude has to be allowed in the transfer from 2D to physical object. The only issue now is for a few buyers the product advertised on the buy pages is not quite the product being produced.
I don't expect huge amounts of flak will be directed at jchan/Keyclack. Many people will look at your renders and expect or want exactly those, but jchan's rep might be dinged a little by those who wanted and expected the more literal Solarized Dark colors. Being able to sell the set for ~$150 or more should take the sting out of any disappointment.
Live and learn...
« Last Edit: Wed, 05 July 2017, 14:36:08 by Auk »
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #95 on: Wed, 05 July 2017, 15:57:16 »
hi everyone,
Just to clarify some things about the color codes: yes, they are hex color codes. however, we have to match them to pantone in order to review them thoroughly and make sure they are accurate.
Hex codes vary a lot between screen and screen, IPS..TN panels... 8bit...10 bit, etc, but we'll make sure to lock down the pantones and that will be a process we'll undergo with GMK as we commence with the color matching.
Hope that's good for everyone, cheers.
Offline kmba
  • Formerly tameone
« Reply #96 on: Wed, 05 July 2017, 21:24:12 »
IDGAF just gimme dis set  :p
keyboards.
« Reply #97 on: Thu, 06 July 2017, 01:55:59 »
Offline yokken
« Reply #98 on: Thu, 06 July 2017, 09:38:06 »
Great to see barred F and J. Was sad to see those missing from Nautilus, I guess they tried too hard to work Euro keys into the base kit at the expense of something I think more people would like. Gonna have to forget about this set for a while so I don't die of anticipation!
Offline Arallu
« Reply #99 on: Thu, 06 July 2017, 22:51:54 »
hi everyone,
I'm confident you'll find the right colors since you'll need to verify the samples.
I think a lot of us are just wary after seeing for example gmk penumbra, where the expectation was to compare it to the SA version and when it finally landed, it was a little lacking, imo.
« Last Edit: Thu, 06 July 2017, 23:18:50 by Arallu »
