Author Topic: where to get a cheap shotgun in canada?  (Read 4456 times)
Offline ANightOnCloudNine
« on: Fri, 23 June 2017, 13:06:01 »
question is the subject
Re: where to get a cheap shotgun in canada?
« Reply #1 on: Fri, 23 June 2017, 13:18:27 »
 :confused:
« Reply #2 on: Fri, 23 June 2017, 13:26:56 »
Offline atarione
« Reply #4 on: Fri, 23 June 2017, 15:43:49 »
Offline mrduul
« Reply #5 on: Fri, 23 June 2017, 21:37:15 »
wat r u goin tu du wit it.
 :p
Offline ander
  • I type, therefore I am
« Reply #6 on: Fri, 07 July 2017, 17:07:17 »
If you want to shoot a moose, you should know that Canadian moose are so polite, all you have to do is ask them and they'll gladly lie on the top of your car and let you tie them down and drive off to the butcher's. They'll apologize for scratching your paint, too.
« Reply #7 on: Sun, 09 July 2017, 23:13:42 »
and they def will not charge you :^)
« Reply #8 on: Sun, 09 July 2017, 23:34:02 »
What size of shotgun
« Reply #9 on: Sun, 09 July 2017, 23:35:08 »
barrel length or shell? or like the gauge? either way i want the mossberg 590a1
« Reply #10 on: Sun, 09 July 2017, 23:36:07 »
I meant gauge. I like little pew pew 410s. I've got an old one and it's like a damn toy, so small and cute.
« Reply #11 on: Sun, 09 July 2017, 23:40:29 »
12 gauge
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #12 on: Mon, 10 July 2017, 08:31:17 »
You should get a Benelli M4 instead. It's like three times the price but it's semi-auto  :-X
« Reply #13 on: Wed, 12 July 2017, 16:18:17 »
lol my friends got one, i dont have the money for one. im in a lower middleclass family
