Author Topic: Split Space Bars?  (Read 37740 times)
Offline Zobeid Zuma
Split Space Bars?
« on: Fri, 14 July 2017, 15:14:21 »
I've really got a strong -- some might say irrational -- desire for a split space bar.  I want to use the right half to space and the left half to backspace, instead of reaching my pinky finger waaay up to the corner.  I think every keyboard in the world should be made this way, but it seems that split space bars have never really caught on.
All the split space bars that I've seen have either been teensy 40% keyboards, too small for me, or else they've been fully split keyboards, which is something else I'm not looking for.  I'd like a conventional layout somewhere in the 60% to 80% range, except with a split space bar, but I'm just not sure what's the best path for me to get there.
Are there PCBs or kits that support this?  Or could I get components for a split keyboard and simply build them into a single case?  Or do I need to look into a custom plate, custom PCBs, or even hand-wiring?
Am I alone, or has anybody else done this before?
Offline Auk
Re: Split Space Bars?
« Reply #1 on: Fri, 14 July 2017, 15:26:30 »
You're not alone!
BananaSplit60 looks great. GB is over but I'm hoping for another round when the case is finalized: https://geekhack.org/index.php?topic=89896.0
Katana60 is a bigger change in layout, an attempt to be more ergonomic. It's still at IC but very promising: https://geekhack.org/index.php?topic=88719.0
Clueboard is going to be on Massdrop again, check out the website: https://clueboard.co/support/clueboard-66-aluminum-layouts and sub forum: https://geekhack.org/index.php?board=183.0
I'm sure there are others that will be suggested, in the meantime hunt through the IC and GB pages and look at the supported layouts of the various custom projects.
« Last Edit: Fri, 14 July 2017, 15:28:59 by Auk »
Offline Zobeid Zuma
« Reply #2 on: Fri, 14 July 2017, 15:42:18 »
Erm.  I looked at that, but every layout option I see divides the space bar into three parts, and it looks like one of my thumbs would naturally go right into the "crack" between part 1 and part 2 or between part 2 and part 3.  Awkward.  Not sure what the designer was thinking.
That's pretty eccentric, I'll have to ponder that a bit.
That looks promising.  I'll research it further.  Thanks!
Offline chuckdee
« Reply #3 on: Fri, 14 July 2017, 15:50:34 »
It divides it into three so that you can use standard keycaps to fill the spacebar, I think.
Offline Eszett
« Reply #4 on: Fri, 14 July 2017, 16:03:40 »
What kind of split space do you have in mind? There aren't so many options what is feasable with the keycaps of a standard keycap set. My current project has 2 x 1.5u split space. If you are in Europe I could send you a prototype, but I don't ship overseas.
Offline Skull_Angel
« Reply #5 on: Fri, 14 July 2017, 21:40:23 »
The current KBDfans 75% kit on Massdrop has split-spacebar option (according to Wei through email).
It's something I've been craving as well for my end-game layout; split/mini spacebar, ISO left-shift, attached F-row, compact layout, programmability.
Keycaps can be an issue, but many full GMK sets will support these weird layouts to a degree (may need to use shift keys for space) and Signature Plastics has many options (add-on kits and blanks).
« Last Edit: Fri, 14 July 2017, 21:43:07 by Skull_Angel »
Offline ojrask
  • juuh elikkäs
« Reply #6 on: Sat, 15 July 2017, 15:34:16 »
Have a Banana Split coming up someday. I'm still wondering how to wire up the split space (and the 1u in between). Space backspace would be nice, then I would need to find usages for the split backspace at R1.
Current:
Coming up:
IC/GB:
Offline N0GLUT0N
« Reply #7 on: Sat, 15 July 2017, 15:37:34 »
https://geekhack.org/index.php?topic=90194.0
I agree with you, split space is <3
Offline ojrask
  • juuh elikkäs
« Reply #8 on: Sat, 15 July 2017, 17:09:38 »
Got me interested. Thanks for linking. :)
Current:
Coming up:
IC/GB:
Offline clickityClackity
« Reply #9 on: Sat, 15 July 2017, 17:50:27 »
Split spacebar? Check. Any love for a non-split, split keyboard? My recently re-outfitted Clueboard: I call it The Fault Line.
To stay on topic, the Clueboard is awesome because you have virtually unlimited options as far as layout.
Offline davkol
  •  Post Editing Timeout
« Reply #10 on: Sat, 15 July 2017, 18:39:24 »
Indeed, Clueboard—and Phantom—have probably the most layout options out there, at least as far as conventional form factors and staggered layouts go.
Typed on my 7bit Phantom.
Offline Zobeid Zuma
« Reply #11 on: Sat, 15 July 2017, 21:29:21 »
Just had a passing thought. . .  At the beginning I dismissed all those 40% or 45% teensy keyboards like the Carpe, Minivan, Vortex Core, but it occurs to me that one of those paired with a standard numeric keypad accessory might make a pretty decent combo?
Offline yensteel
« Reply #12 on: Sun, 16 July 2017, 07:58:18 »
I remember seeing the 0.01 Z70 in Massdrop, and I think its suitable for you. It costs $160 the last time it aired.
edit:
I just found a youtube video of it:
« Last Edit: Sun, 16 July 2017, 07:59:56 by yensteel »
Offline Zobeid Zuma
« Reply #13 on: Sun, 16 July 2017, 18:30:15 »
OK, that looks exactly like what I had in mind!  I have placed my request.    :thumb:
Offline chuckdee
« Reply #14 on: Sun, 16 July 2017, 20:53:40 »
I will warn you- I got it.  It's a pretty solid keyboard, and I liked it better than the whitefox because the screws were on the bottom.  But I ended up returning it because the assembly service sucked.  My A and L keys had to be hit hard to actuate them, and the space bar stabs sucked.  I'd get it without assembly service if you can do so.  It also uses USB-C, which I thought wouldn't be a big deal, but it was to me in practice.
Offline yensteel
« Reply #15 on: Sun, 16 July 2017, 22:39:06 »
Aw, shucks.
« Last Edit: Sun, 16 July 2017, 22:58:43 by yensteel »
Offline Zobeid Zuma
« Reply #16 on: Sat, 09 September 2017, 16:26:26 »
KBD66 is now up on Massdrop.  See here --> https://www.massdrop.com/buy/kbd66-mechanical-keyboard-kit
Looks similar to a Clueboard, but with an option of two 2.75x spacebars.  But, but, but. . .   There's a catch.  It looks like the PCB supports split spacebars, but the plate it comes with does not!  What the hey?   :mad:
So, either build it with no plate and everything PCB mounted, or have your own custom plate made?  I'm almost to the point where I'd consider it.  How much does it cost to have a plate water-cut?
I'm also taking another look at the Banana Split.  Although I dismissed it because of the extraneous key in the middle, now I'm feeling more like I should give it a try, and it might even be convenient.  So, I'll be watching for whenever the next batch of those kits come out.
As I've pondered what I really want in a keyboard, the things I keep coming back to are a fully programmable pcb and split space bars.  So, I'm going to keep hammering away at this problem until I am satisfied.
Offline roteiche
« Reply #17 on: Sun, 10 September 2017, 22:45:46 »
May I ask what was the issue you experienced with USB-C? I haven't personally used a device with USB-C ports so I'm not sure what problems they can pose.
Offline chuckdee
« Reply #18 on: Mon, 11 September 2017, 14:59:40 »
It was a combination of things, and not really a fault of the standard, just adjustment and quality of life.
Offline Zobeid Zuma
« Reply #19 on: Tue, 12 September 2017, 07:37:01 »
I notice that a lot of folks seem to be using Shift keycaps on their split space bars.  But...  A "real" spacebar has a different shape, it's convex.
You can get 3.0x true spacebars.  I gather they're used in Minila keyboards, they're used on the Mistel Barocco, and replacements for those are available on eBay.
2.25x and 2.75x spacebars (as such) are a lot harder, but they do exist, I've seen photos of them.  I guess they were produced for some of those funky Korean keyboards, I dunno?  Somewhere out there in the world (presumably in China) there is somebody who already has the tooling to produce them.  It might be an interesting exercise to track down the source of those and get a production batch.
And then there's the possibility of 3D printing.  I'm skeptical about 3D printed keycaps, but I'd be wiling to hazard the experiment.
« Reply #20 on: Tue, 12 September 2017, 10:31:01 »
Been using split space almost daily for 2+ years, having shift and enter on the 2 "spacebars" has never bothered me.
As soon as you start moving towards fully custom or weird layouts you need to give up a bit of keycap/ keyset compatibility.
Offline Harmvdw
« Reply #21 on: Tue, 12 September 2017, 13:26:50 »
I'm lurking for a while now, still have to introduce myself properly.
But was searching something else and saw this, https://www.aliexpress.com/item/xda-blank-convex-spacebar-grey-1-75u-2u-2-25u-2-75u-3u-4-5u-5/32827099386.html?spm=a2g0s.13010208.99999999.279.7hYxgp so short spacebars do exist(only in grey)
Offline OhManIAmWorried
« Reply #22 on: Tue, 12 September 2017, 13:37:21 »
With fn key between two spacebars. Very comfortable, just saying. ;D
APC F-21 "Clicker" Drevo71 Delux M-618 DataComp dfk102
NTC 74% cut
Offline Zobeid Zuma
« Reply #23 on: Tue, 12 September 2017, 15:16:27 »
Woohoo!  Grey is fine, thanks.    :thumb:
EDIT:  It's hard to be sure from the photos, they might actually be white.
« Last Edit: Tue, 12 September 2017, 15:23:20 by Zobeid Zuma »
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #24 on: Wed, 13 September 2017, 02:54:50 »
I bought two of the 2.75u variety and the same seller's XDA Planck set yesterday for my upcoming Let's Split build (custom plate). I would have preferred 3u but I'm too lazy to bend my own 3u Costar wires :P Anyway, I'll let you know how those spacebars/caps turn out :D
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Rodde
« Reply #25 on: Mon, 18 September 2017, 22:40:50 »
I've been seeing lots of split spacebar mentions over the past few days. Don't remember much of it last time I actively looked into mechanical keyboards (2-3 years ago). Is this a recent trend?
Offline Zobeid Zuma
« Reply #26 on: Wed, 04 October 2017, 19:31:14 »
Has anyone tried using blank G20 profile 2.25 and 2.75 keys as spacebars?  It seems to me like they'd work pretty well since they don't really have sharp edges—the main thing that bugged me about using shift keys.  And they're easy to get from SP.
« Reply #27 on: Wed, 04 October 2017, 19:36:00 »
I was actually using a G20 set on a KB although split space bars, but had a normal shift. I always put it backwards and have enjoyed it, but you may be onto something here...
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #28 on: Wed, 04 October 2017, 19:54:36 »
I am using split spacebars: 2.75u - 1.25u - 2.25u, respectively: Space - Fn - right Shift
usually, my right thumb does nothing, it has become more useful since I put right Shift there.
179607-0
My board actually has 2 right Shift (another 1.75u right Shift), but there is no confusion (I just use whichever Shift key I can reach).
Offline Diserasta
« Reply #29 on: Thu, 05 October 2017, 01:00:26 »
I totally agree with you. Split spaces provide so much flexibility. I find I rarely use the other thumb if I don't have one.
To add my stake to the game, I'm currently running an IC/Feedback for a 65% with a split spacebar. Link is in my sig.
Offline rich1051414
« Reply #30 on: Thu, 05 October 2017, 01:59:25 »
I own a keyboard like this. It looks wavy like the windows logo and I hated it from day one, but it does have a split space bar with the backspace on the left. It's a microsoft board but I don't remember the model.
Offline Zobeid Zuma
« Reply #31 on: Thu, 05 October 2017, 06:24:50 »
That would be an Erase-Eaze™ keyboard, I'm sure.  More info here: https://deskthority.net/wiki/Backspace_key#Erase-Eaze
This is most likely the reason why split space bars haven't become more popular and widely used.  Quote, "Erase-Eaze is a trademark of Keyboard Advancements, Inc. and is covered in US patent 5711624 filed in 1996."  That patent is obvious BS that should never have been issued (and symptom of a much larger problem with the patent office).  It doesn't make any sense to issue a patent every time somebody alters a keyboard layout or moves a key to a more convenient location.  However, it would seem that nobody wanted to spend the truckloads of money that are required to challenge even the most ridiculous patent in court.
The good news is that patents expire after 20 years.  Regardless of whether it was bogus or legit, it's history now.
Offline rich1051414
« Reply #32 on: Thu, 05 October 2017, 07:20:19 »
Sculpt Comfort was what it was called. I don't recommend, I couldn't get used to the curved layout.
Offline davkol
« Reply #33 on: Thu, 05 October 2017, 12:00:18 »
Sculpt Ergo is an excellent keyboard for something in the mass market; the only major downside is the wireless implementation.
Offline Blazestorm
« Reply #34 on: Fri, 06 October 2017, 00:54:02 »
http://www.lfkeyboards.com/lfk-tkl.html This TKL PCB has split spacebar support, but I don't know of where you can get plates. You can contact him though as I think he cuts some custom VA68 plates, he might be able to do a TKL.
I used the Phantom plate w/ my builds using this PCB, but those plates don't support split iirc.
Offline Zobeid Zuma
« Reply #35 on: Fri, 06 October 2017, 09:59:08 »
This morning's mail finally brought me samples of those XDA profile mini spacebars from AliExpress.
http://zobeid.zapto.org/image/keeb/mini_spacebars_01.jpg
http://zobeid.zapto.org/image/keeb/mini_spacebars_02.jpg
Yes, they are most definitely GRAY.  You can see how the profile compares with OEM parts and with the lime green G20 keycap.  You may also note they are symmetrical, so flipping them isn't even a thing.
Seller says they are PBT, and they sink in a glass of water, so I guess they are PBT.
If you are okay with GRAY and with waiting on the slow boat from China, these seem like the best option right now.  Otherwise, I still think the G20 caps from SP would work just fine too, and either way is better than using shift keys.
Offline jcoffin1981
« Reply #36 on: Wed, 18 October 2017, 18:40:25 »
Reaching for backspace with my ring finger is so second nature it may be weird to use my left thumb.  An advantage would be I think the space bar having less wobble and rattle and feel more solid.
Offline PopTart
« Reply #37 on: Fri, 25 May 2018, 15:48:26 »
I've got an Alps MGM-106 keyboard in great condition. It's got a split spacebar, integrated trackpad, and Alps White switches (not sure if damped or not). https://deskthority.net/wiki/Alps_MGM-106
Send a message if you're interested in a trade!
EDIT: The wiki says that most of them were Mac keyboards. The one I have has Windows keys.
« Last Edit: Fri, 25 May 2018, 16:00:30 by PopTart »
Offline johngodsmith
« Reply #38 on: Thu, 07 June 2018, 04:54:53 »
Want to try split space again but I'd like it to be split in two keys instead of three if that's even possible
Think I had the 2.25u x 1.25u x 2.75u layout before
Offline jackcauliflower
« Reply #39 on: Thu, 07 June 2018, 12:44:03 »
How’s the learning curve when it comes to split space bars? I feel like it would ruin my typing since I primarily use my right thumb to hit the space bar.
« Reply #40 on: Thu, 07 June 2018, 13:33:49 »
Should be alright. I’m like that too. I just always found my left thumb in between the 2.25u and the 1.25u and it got kinda annoying
Offline 89sec
« Reply #41 on: Fri, 08 June 2018, 21:55:53 »
You could always keep the right half as a spacebar and program the left half to something that you will frequently use.
Sent from my ASUS_Z01HD using Tapatalk
Offline rich1051414
« Reply #42 on: Sat, 09 June 2018, 05:52:05 »
Personally I also primarily use my right thumb, but I still found it extremely frustrating to use a split space bar, mostly because of WHERE I hit the space bar, which depends on the last key I hit with my right hand. I suppose a better positioned split would fix my issue, but split down the middle didn't work, as I normally hit anywhere from the left or right of the center of the spacebar.
