Author Topic: KIRA keyboards  (Read 174909 times)
Offline thesiscamper
    • Keyrenders
KIRA keyboards
« on: Sat, 22 July 2017, 07:00:07 »
Boards made/planned and current status:
KIRA : 96-key being developed by Input Club, kickstarter goal reached
KIRA EX : 96-key layout with spacing between arrow keys and numpad, 2nd prototype done, shelved.
KIRA EXS : KIRA EX with Slimmer bezels, prototypes finished, fulfillment
KIRA75: 75% keyboard, prototypes done and PCB prototypes currently being redesigned for qmk. Renamed to MiR75
KIRA60: group buy kits shipped out, v2 CAD done and sent to shop for quote
KIRA80 and KIRA S : GB cancelled, picked up by zFrontier
LXV : prototypes in production
Old Stuff
KIRA EXS PHOTOS:
Hi guys, just wanted to share this personal project of mine that has kept me busy for weeks. So it all started when I did the first "KIRA" renders, a 96-key as some people might know. I liked the idea of a full size keyboard in a compact layout, so the 96 seemed like the perfect layout for me. I bough a b.mini EX X2 which is similar, and then a ZZ96 and I was happy, at first anyway. Then I realized that I had a hard time finding the arrow keys because there's no spacing between the alphas and arrow keys. That led me to trying out the 1800, which while great since it's kinda shorter, still takes up a lot of space. I am currently using a TX-1800 at home, it's a great keyboard but I still want to try what is basically a compact 1800 like the LZCP and the TXCP. Which led me to my first custom.
So here it is, the first prototype of what is basically a 96-key layout grouped into alphas, arrows and numpad. Big thanks to riotonthebay and Input Club's Brandon for all the advice and help they provided, It would've taken me too long to do this without their awesome help. I would also like to thank forevermadrigal, geckt, rainb1ood, gatix, krytone and livingspeedbump for being so supportive of my designs. I don't expect a lot of people to like it, but your enthusiasm with what I do already makes it worth it.  :thumb:
I call it the KIRA EX.
PHOTOS:
Old Photos
So, the next steps. I'm trying to find someone who can design the PCB for me. I've already talked to Leeku and a friend, and I just need to decide how to go about it. I only just checked the spacing with GMK 9009 and I'm happy to know that my CAD and measurements weren't an epic failure. I've already updated the design too, to reduce the gap of the bezel from the caps, reduce the top bezel width, and add some polish to the corners and edges. I've also designed a weight insert since the bottom of the first prototype was really bare (did it to reduce the cost in case it was a **** up).
Thanks for reading, and I'll be updating this as the project develops  :thumb:
Also, the title is "KIRA keyboards" because I have other layouts planned, and this GH60 case is probably next:
The KIRA60 FE
« Last Edit: Tue, 28 August 2018, 10:21:54 by thesiscamper »
"haters are confused admirers"
    • Keyrenders
Re: KIRA keyboards
« Reply #1 on: Sat, 22 July 2017, 07:00:19 »
Things To Do as of 20170722:
  • find a PCB guy
  • acquire funds for second kit (lol)
  • maybe search for some manufacturer options
Changes made [CAD changes for now]:
  • reduced gap between bezel and caps
  • reduced top bezel
  • thicker inserts
  • added some chamfers and fillets to some corners and edges
  • designed a weight insert
« Last Edit: Sat, 22 July 2017, 07:16:33 by thesiscamper »
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: KIRA keyboards
« Reply #2 on: Sat, 22 July 2017, 07:01:45 »
asdf
Looking forward to watching this progress
Looks great and thanks for sharing
    • Keyrenders
Re: KIRA keyboards
« Reply #3 on: Sat, 22 July 2017, 07:04:24 »
asdf
Thanks Bunny!
Also I forgot to mention, the inserts are supposed to be either metal or acrylic, but I just tried to screw them together. In the new design I have it thicker, but realized doing two-tone inserts might be great for accent. :D
Offline simonyunhe
Re: KIRA keyboards
« Reply #4 on: Sat, 22 July 2017, 07:21:29 »
Like the idea, but I perfer to have saparate F roll.
从我的 iPhone 发送,使用 Tapatalk
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline Geckt
Re: KIRA keyboards
« Reply #5 on: Sat, 22 July 2017, 07:29:47 »
The point of a compacted F-row here I think in my point of view is the overall decrease in the size of the keyboard.
Edit: this is purely my own views, I do not affect any of the preference made by the designer for the kira 96.
« Last Edit: Sat, 22 July 2017, 07:32:41 by Geckt »
    • Keyrenders
Re: KIRA keyboards
« Reply #6 on: Sat, 22 July 2017, 07:32:08 »
Thanks! I already have a TX-1800 and a ZZ96 so I'll be trying something of a hybrid. When I have the PCB made and actually used it for a several weeks, I will know if the layout is good for me. :)
Here are images of the current progress:
Weight cutout
Weight cutout
Weight insert
The current weight design will add another 1 Kg to the case if brass is used, compared to Aluminum.
0.497 Kg for Aluminum weight
1.546 Kg for Brass weight
1.454 Kg for Steel weight
« Last Edit: Sat, 22 July 2017, 08:19:57 by thesiscamper »
Offline Gatix
  • #!/bin/sh
  • console.log
Re: KIRA keyboards
« Reply #7 on: Sat, 22 July 2017, 09:14:44 »
This gets me wet every time I see it
Offline xtrafrood
  • formerly csmertx
  • KA2 touchpad on top
    • csmertx.com
Re: KIRA keyboards
« Reply #8 on: Sat, 22 July 2017, 10:33:44 »
F Row! Love your work and look forward to more updates :)
Offline kmba
  • Formerly tameone
Re: KIRA keyboards
« Reply #9 on: Sat, 22 July 2017, 15:41:10 »
Sorta like a TX-CP, but different enough due to the F row without gaps.  With reduces bezels (especiallyat the top) you have yourself a winner.  I was looking forward to the KIRA 96key but I already have a board in that layout, but no compact 1800 style board so I'd probably be in!
keyboards.
    • Keyrenders
Re: KIRA keyboards
« Reply #10 on: Sat, 22 July 2017, 19:07:20 »
Ask and ye shall receive xD
Thanks man, I'm definitely excited to finish this project :D
I'm glad you like it! I used to scoff at big bezels, but after a while I started thinking thin bezels look so generic when looking straight down on it (IMO). Maybe it's because I'm currently using a TX-1800, but I don't think it will look as good with thin bezels. Anyway, I reduced the top bezel by 4mm, and I think it fits the necessary bottom bezel (because of the arrow keys offset).
Offline infiniti
  • I <3 KB
  • Bob was here
Re: KIRA keyboards
« Reply #11 on: Sat, 22 July 2017, 19:53:58 »
I'm really digging that insert design! :thumb: :thumb:
Offline Nonster
  • Lo-Ki Studios
Re: KIRA keyboards
« Reply #12 on: Sat, 22 July 2017, 20:06:48 »
This looks so clean, very excited to see where this goes!  :thumb:
Offline kmba
  • Formerly tameone
Re: KIRA keyboards
« Reply #13 on: Sat, 22 July 2017, 22:07:14 »
The updated CAD drawings look nice.  I think the bezels are spot on there.
keyboards.
    • Keyrenders
Re: KIRA keyboards
« Reply #14 on: Sun, 23 July 2017, 11:39:38 »
The idea came from Krytone  :thumb:
Thanks! Hopefully a working PCB by August so I can start using it! I'll probably go for a black one for the next kit  :D
Good to know that it's a step in the right direction, thank you.
    • Keyrenders
Re: KIRA keyboards
« Reply #15 on: Tue, 25 July 2017, 08:54:26 »
New photos uploaded! My friend finally had the time to take tons of photos, unfortunately he hasn't seen a numpad for years and I was busy ordering pizza and gaming on my phone so... there's a little mistake in the layout.  :p
Offline Pwner
  • soon™
    • Ion Keyboards
Re: KIRA keyboards
« Reply #16 on: Tue, 25 July 2017, 09:22:26 »
Cool to see you moving over to custom boards.  1800 is great, looking forward to seeing more of that!  :thumb:
Offline rioc
Re: KIRA keyboards
« Reply #17 on: Tue, 25 July 2017, 10:04:10 »
well, I'm watching this to see what comes out :)
    • Keyrenders
Re: KIRA keyboards
« Reply #18 on: Tue, 25 July 2017, 10:16:02 »
Thanks man, and your project is looking great :thumb:
Hopefully something I can use in the near future  ;D
Offline rioc
Re: KIRA keyboards
« Reply #19 on: Tue, 25 July 2017, 10:18:55 »
I'm pretty sure of it, seeing that the Kira 96 isn't that far off into the future anymore... :)
Offline redbanshee
  • actually Dade Murphy
Re: KIRA keyboards
« Reply #20 on: Tue, 25 July 2017, 10:31:28 »
into this for sure! lookin good! also Skullydaze from clueboard also does PCB's, he might be able to help you out
Offline HouseofSuffering
Re: KIRA keyboards
« Reply #21 on: Tue, 25 July 2017, 10:48:50 »
Nice! I really like this layout.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: KIRA keyboards
« Reply #22 on: Tue, 25 July 2017, 23:46:31 »
i'm super excited for this kit... probably buy 2, one for the wife and one for work!
-Dana
Offline kokokoy
Re: KIRA keyboards
« Reply #23 on: Wed, 26 July 2017, 00:20:05 »
unfortunately he hasn't seen a numpad for years:p
and "Z" and "X" :D
But looks really great. Watching to see how that proto 2 turns out, specifically that weight design!
    • Keyrenders
Re: KIRA keyboards
« Reply #24 on: Wed, 26 July 2017, 06:39:59 »
Thanks man, Skully said he can design PCBs so I hope it works out!  :thumb:
Sounds great! Glad you guys like it :)
and "Z" and "X" :D
Damn I missed that too  :))
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
Re: KIRA keyboards
« Reply #25 on: Wed, 26 July 2017, 18:20:25 »
I am waiting for KIRA to have my first 96key keyboard. I am IN.
Filco TKL Ninja Blues / CODE Greens / Pok3r Clears / HHKBpro2 / RF 87U 55g / Novatouch TKL / KC60 Clears / SSK and also regular Model M
Offline Miotch92
Re: KIRA keyboards
« Reply #26 on: Wed, 26 July 2017, 20:56:34 »
This looks perfect! Can't wait for it to come to fruition!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: KIRA keyboards
« Reply #27 on: Wed, 26 July 2017, 21:10:37 »
Gimme gimme
Offline saucybulgogi
Re: KIRA keyboards
« Reply #28 on: Wed, 26 July 2017, 21:12:30 »
 Looks great dude! Should this ever get to a group buy stage I’d love a black version with green accents to go with my Terminal set.
Offline redbanshee
Re: KIRA keyboards
« Reply #29 on: Thu, 27 July 2017, 12:18:26 »
If he does in fact produce the PCB design, TAKE HIS MANUFACTURING ADVICE. Do not pull a sentraq and order complete **** PCB's from some back alley fab house.
Offline pixelpusher
Re: KIRA keyboards
« Reply #30 on: Thu, 27 July 2017, 12:29:51 »
I like my s60x PCB.  It doesn't look perfect, but it works flawlessly :)
    • Keyrenders
Re: KIRA keyboards
« Reply #31 on: Thu, 10 August 2017, 07:09:16 »
Still have to find a suitable PCB for the compact 1800, but here's my other design for a 60%, The KIRA60 FE. These photos were taken from the factory, and hopefully I will receive the board tomorrow or the next day.
Excited to see this board in person, hopefully all my measurements are correct (again)  ;D
Offline rioc
Re: KIRA keyboards
« Reply #32 on: Thu, 10 August 2017, 07:12:28 »
SWEET!!!
love the angles and the weight design... when, where and how much?
    • Keyrenders
Re: KIRA keyboards
« Reply #33 on: Thu, 10 August 2017, 08:50:25 »
SWEET!!!
I'd like to build a working prototype first before I start thinking about that :)
Offline rioc
Re: KIRA keyboards
« Reply #34 on: Thu, 10 August 2017, 08:52:51 »
SWEET!!!
options for just the case too?
    • Keyrenders
Re: KIRA keyboards
« Reply #35 on: Thu, 10 August 2017, 09:18:02 »
SWEET!!!
Not really planning to offer a 60% PCB, which is why I shifted my focus to this for now, since the PCB and the plate can be acquired just about anywhere.
Offline rioc
Re: KIRA keyboards
« Reply #36 on: Thu, 10 August 2017, 09:36:01 »
SWEET!!!
great. makes total sense :)
Offline chuckdee
Re: KIRA keyboards
« Reply #37 on: Thu, 10 August 2017, 10:10:02 »
I don't see an area for underglow like with the Kira.  Is that just for the renders or does this one not have it?
    • Keyrenders
Re: KIRA keyboards
« Reply #38 on: Thu, 10 August 2017, 10:14:47 »
No underglow for this  :)
Offline redbanshee
Re: KIRA keyboards
« Reply #39 on: Thu, 10 August 2017, 10:21:35 »
60% BAD
96key GOOD
 :p :thumb:
just kidding obviously haha do what you what but dat 96 key : :thumb:
« Last Edit: Thu, 10 August 2017, 10:23:21 by redbanshee »
Offline chuckdee
Re: KIRA keyboards
« Reply #40 on: Thu, 10 August 2017, 10:43:28 »
Same for my s65x PCB :)
    • Keyrenders
Re: KIRA keyboards
« Reply #41 on: Thu, 10 August 2017, 20:25:36 »
60% BAD
96key GOOD
  :thumb:
Haha, the 60% might be the thing that helps the EX along :)
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
Re: KIRA keyboards
« Reply #42 on: Fri, 11 August 2017, 16:30:08 »
WTB 1800 <3
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Data
Re: KIRA keyboards
« Reply #43 on: Fri, 11 August 2017, 19:20:59 »
Just curious, what will become of the "original" KIRA?  Are there any plans to develop that?
    • Keyrenders
Re: KIRA keyboards
« Reply #44 on: Fri, 11 August 2017, 22:26:56 »
Input Club is developing it at the moment, and most of the legwork will come from them. I still have some ideas so I'm just making things I want.
Offline Data
Re: KIRA keyboards
« Reply #45 on: Sat, 12 August 2017, 10:47:11 »
Nice.  I thought I'd heard that but I couldn't remember and didn't want to assume anything.
Offline chuckdee
Re: KIRA keyboards
« Reply #46 on: Sat, 12 August 2017, 11:44:16 »
Are they developing it in conjunction with MD? Or is this going to be completely I:C?
Offline Hexterdude
  • I have a problem when it come to artisans
Re: KIRA keyboards
« Reply #47 on: Sat, 12 August 2017, 11:48:40 »
not gonna lie, those pictures are beautiful
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
Re: KIRA keyboards
« Reply #48 on: Sat, 12 August 2017, 12:43:44 »
Can I please throw my money at you now? Violently?
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
Re: KIRA keyboards
« Reply #49 on: Sat, 12 August 2017, 12:44:48 »
Side question here...
Is there a way to setup an RSS so that you never miss when group buys go live? I would love to get into RSS feeds but I don't know how.
