Author Topic: KIRA keyboards  (Read 348270 times)
Offline Darknight00z
Re: KIRA keyboards
« Reply #300 on: Wed, 26 December 2018, 07:31:51 »
Is there a pricing estimate for the Kira60, trying to decide between Fjell and Paradox.
200-300 or 300-400?
Offline rondg
Re: KIRA keyboards
« Reply #301 on: Tue, 01 January 2019, 22:49:41 »
Was there already a GB for the Kira75/Mir75? I need it in my life. :(
Offline Brammm87
Re: KIRA keyboards
« Reply #302 on: Tue, 08 January 2019, 02:50:23 »
I took over a spot in the Kira80 GB. Is there an update for that somewhere?
pls gief bbv2
Offline forevermadrigal
Re: KIRA keyboards
« Reply #303 on: Tue, 08 January 2019, 12:45:59 »
https://geekhack.org/index.php?topic=96381.0 last update is on there. Apparently they should be shipping very soon.
Offline Brammm87
Re: KIRA keyboards
« Reply #304 on: Fri, 11 January 2019, 14:29:24 »
Derp, didn't see separate thread, thanks friend!
pls gief bbv2
Offline thesiscamper
    • Keyrenders
Re: KIRA keyboards
« Reply #305 on: Thu, 14 February 2019, 21:34:37 »
If anyone is interested in a polycarbonate KIRA60 v2, here's an ic form:
https://goo.gl/forms/oKwbYXuENBMnZ4in1
« Last Edit: Thu, 14 February 2019, 21:54:55 by thesiscamper »
"haters are confused admirers"
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: KIRA keyboards
« Reply #306 on: Thu, 14 February 2019, 22:59:10 »
Filled out. Depending on timing, final quote, and additional details -- photos of prototype, plate/PCB/case/weight details -- I could be interested in joining. I like this case, but would definitely want to know of what it looks and sounds like, as there already seems to be a prototype available.
    • Keyrenders
Re: KIRA keyboards
« Reply #307 on: Fri, 15 February 2019, 01:39:17 »
https://www.instagram.com/p/BpnINuQgHyg/?utm_source=ig_share_sheet&igshid=15o4w452271jq
The plate mounting points have changed, so the sound probably changed too from this early prototype.
Offline mudcakehoney
Re: KIRA keyboards
« Reply #308 on: Fri, 15 February 2019, 19:56:37 »
Couldn't be happier.
    • Keyrenders
Re: KIRA keyboards
« Reply #309 on: Mon, 18 February 2019, 08:16:57 »
Planning to do another compact 1800, since this is the layout I use most of the time.
213157-0
Offline Furikurichemy
Re: KIRA keyboards
« Reply #310 on: Mon, 18 February 2019, 09:42:22 »
Definitely interested in one these!
That side profile is  :thumb:
Offline hokie_programmer
Re: KIRA keyboards
« Reply #311 on: Tue, 19 February 2019, 16:30:57 »
Definitely interested in a compact 1800 too!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: KIRA keyboards
« Reply #312 on: Thu, 28 February 2019, 11:01:46 »
What are the new mounting points?
    • Keyrenders
Re: KIRA keyboards
« Reply #313 on: Thu, 28 February 2019, 22:25:19 »
I simply meant I added a screw and they moved a bit.
    • Keyrenders
Re: KIRA keyboards
« Reply #314 on: Tue, 05 March 2019, 21:17:42 »
Some recent renders I did for upcoming projects:
214356-0
214362-1
« Last Edit: Tue, 05 March 2019, 21:21:06 by thesiscamper »
Offline p_blaze
Re: KIRA keyboards
« Reply #315 on: Tue, 05 March 2019, 21:23:21 »
It would be cool to see the iconic KIRA angles on the flat part of the side profile, its looks a little uninspired
    • Keyrenders
Re: KIRA keyboards
« Reply #316 on: Tue, 05 March 2019, 21:26:52 »
Fair enough, but I'd say adding more is too much already.
Offline Telstar
Re: KIRA keyboards
« Reply #317 on: Sun, 24 March 2019, 13:05:13 »
Yes, please do :)
    • Keyrenders
Re: KIRA keyboards
« Reply #318 on: Sun, 07 April 2019, 16:55:48 »
Upcoming projects, hopefully I/we can have prototypes made soon™.
Split TKL (unnamed collab with infiniti)
216797-0
Primus, a 75% gasket-mounted board
216799-1
Kai, a new TKL project
216801-2
216803-3
Offline mkarlsson
Re: KIRA keyboards
« Reply #319 on: Mon, 08 April 2019, 08:30:12 »
Looking good...
Offline p_blaze
Re: KIRA keyboards
« Reply #320 on: Mon, 29 April 2019, 11:24:23 »
does the split have a sideglow strip or just in the part that comes apart?
    • Keyrenders
Re: KIRA keyboards
« Reply #321 on: Wed, 01 May 2019, 20:51:36 »
No planned side glows, infiniti and I are not huge LED fans.
Offline p_blaze
Re: KIRA keyboards
« Reply #322 on: Wed, 01 May 2019, 22:41:13 »
So the clear-ish looking bit where the board splits is supposed to be aluminum? I was confused as to what it is supposed to be/why it is rendered differently
    • Keyrenders
Re: KIRA keyboards
« Reply #323 on: Thu, 02 May 2019, 02:45:45 »
Sorry, by side glows I meant the sides, front and rear. I forgot to mention the inner sides where the splits meet can possibly be plastic.
    • Keyrenders
Re: KIRA keyboards
« Reply #324 on: Thu, 02 May 2019, 17:21:26 »
218492-0
218494-1
218496-2
218498-3
218500-4
Offline p_blaze
Re: KIRA keyboards
« Reply #325 on: Wed, 22 May 2019, 22:39:44 »
Any updates on that sweet split tkl?
    • Keyrenders
Re: KIRA keyboards
« Reply #328 on: Mon, 10 June 2019, 22:11:07 »
Upcoming GBs for these boards:
220916-0
220922-1
220918-2
220920-3
Offline Brammm87
Re: KIRA keyboards
« Reply #329 on: Tue, 11 June 2019, 01:56:13 »
pls gief bbv2
    • Keyrenders
Offline nickaster1
Re: KIRA keyboards
« Reply #331 on: Tue, 11 June 2019, 02:10:49 »
Does the KN210 have internal weight to them? Will there be more info on them soon?
Offline Aerizu
  • Professional Lurker
Re: KIRA keyboards
« Reply #332 on: Tue, 11 June 2019, 06:14:09 »
Can't wait! Hopefully it will not be too expensive.
Offline p_blaze
Re: KIRA keyboards
« Reply #334 on: Tue, 11 June 2019, 17:24:23 »
Will either of these go through beamingrobot's manu? I love the finish and color on all of the KIRA boards that went through him.
Also gonna ask for some updates on that split tkl again because that's my endgame
    • Keyrenders
Re: KIRA keyboards
« Reply #335 on: Tue, 11 June 2019, 20:11:42 »
To clarify, it’s not “beamingrobot’s manu” because I introduced him to the factory, and I was intorduced to this factory by another designer. The KIRA60 will be made by the same manufacturer that made the v1 and EXS, and most of my other prototypes. The KN2.10 will be made by a different manufacturer.
For the split TKL we’re waiting on the PCB designer so I can finalize the case. Yes it’s going to be made by the same manufacturer that made the KIRA60s, EXS and other prototypes.
Offline cyyz
Re: KIRA keyboards
« Reply #336 on: Tue, 11 June 2019, 21:50:15 »
Any news on the  fullsize/CP board? Would it be possible in 2019?
Offline p_blaze
Re: KIRA keyboards
« Reply #337 on: Wed, 12 June 2019, 02:26:20 »
My bad with the manu, I wasn't sure how else to point out the maker of the board. I'm happy to see these great designs move closer to GB!
Offline cspirou
Re: KIRA keyboards
« Reply #338 on: Wed, 12 June 2019, 10:56:15 »
The Kai looks really nice. Do you think you'll have a matching numpad like the Kira S?
Offline appaboy
Re: KIRA keyboards
« Reply #339 on: Wed, 12 June 2019, 11:10:43 »
Mir80 by thisiscamper with OG Pom caps
220981-0
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
    • Keyrenders
Re: KIRA keyboards
« Reply #340 on: Thu, 13 June 2019, 20:54:16 »
Yes I can make a matching numpad, I’ll ask the vendor if he wants to offer that.
Curious how you got hold of this, from down under perhaps? The name has changed a few times, at the moment I call that design the Namo.
Offline appaboy
Re: KIRA keyboards
« Reply #341 on: Sat, 22 June 2019, 11:58:12 »
I got it from beamingrobot
HASRO keycaps
OG POM keycaps
Scarface Fn blank
Offline Tekniqs
Re: KIRA keyboards
« Reply #342 on: Sat, 20 July 2019, 23:03:22 »
will there be a PC option for the kira60 v2?
Re: KIRA keyboards
« Reply #343 on: Sun, 21 July 2019, 00:14:36 »
Definitely not mine, I still use mine daily and love it!
Offline OnceS
Re: KIRA keyboards
« Reply #344 on: Sat, 27 July 2019, 01:51:41 »
Kira EX or TX CP?
E6 | Kira60 | R60 | HHKB Carbon
IG: https://www.instagram.com/onces1314/
Re: KIRA keyboards
« Reply #345 on: Sat, 27 July 2019, 02:06:39 »
Kira EX or TX CP?
Namo
Re: KIRA keyboards
« Reply #346 on: Sat, 27 July 2019, 08:54:00 »
Kira EX or TX CP?
Wait for the new 1800 ;D
Offline Bubblegum
Re: KIRA keyboards
« Reply #347 on: Sun, 25 August 2019, 16:57:16 »
Is Kira60 v.2 still happening or did I miss it? :)
Offline Henrythewound
Re: KIRA keyboards
« Reply #348 on: Tue, 10 September 2019, 18:40:19 »
Kira EX or TX CP?
what is the new 1800? I am very interested in a compact 1800 board but am getting ready to settle for a nice 96
Offline kevinanggara
Re: KIRA keyboards
« Reply #349 on: Sun, 21 August 2022, 23:10:03 »
Still have to find a suitable PCB for the compact 1800, but here's my other design for a 60%, The KIRA60 FE. These photos were taken from the factory, and hopefully I will receive the board tomorrow or the next day.
Excited to see this board in person, hopefully all my measurements are correct (again)  ;D
