Author Topic: [IC] GMK Pure  (Read 8525 times)
Offline Jmeferlater
[IC] GMK Pure
« on: Sun, 23 July 2017, 11:34:55 »
Hey guys,
I'm happy to introduce you to my newly designed GMK set,
GMK Pure
Based on the Pure Syntax theme for the Atom text editor (found here: https://github.com/nkpfstr/pure-syntax)
The focus of the set is the dark purple for the background and the bright pinks and whites as text.
The set will also include white alphas to use instead of the dark, but I believe the dark purple alphas should be included as the base
and the white alphas should be an extra addon. This could definitely change if the light version is more popular though
The Kits:
So, I'm still fairly unfamiliar with how GMK kits work, so let me know if I'm missing keys or need to make some changes.
Base:
Light Alphas:
Possibly some novelties/Syntax pack for different colored mods? Let me know what you think
GMK Pure Dark:
GMK Pure Light:
If there's enough interest, I'll be getting proper renders done for both colorways
Thanks for looking, feedback/criticism is welcome  :thumb:
Offline RevoTeam
Re: [IC] GMK Pure
« Reply #1 on: Sun, 23 July 2017, 11:37:24 »
I perfer the light Alphas... looks neat...good work man.
Offline Dr_Alphabet
Re: [IC] GMK Pure
« Reply #2 on: Sun, 23 July 2017, 11:46:44 »
+1 for the white alphas.
Look at me. Look at me. Look what I can do. I'm amazing - Peter Gabriel
Offline TalkingTree
    • My projects
Re: [IC] GMK Pure
« Reply #3 on: Sun, 23 July 2017, 11:49:33 »
Yellow and orange match the scheme well, why getting rid of them?
Offline Jmeferlater
Re: [IC] GMK Pure
« Reply #4 on: Sun, 23 July 2017, 11:53:59 »
Will definitely be swapping them to the base kit if this becomes consensus
Offline Jmeferlater
Re: [IC] GMK Pure
« Reply #5 on: Sun, 23 July 2017, 11:56:47 »
I had them in my first design, but I felt like the pink just fit better and I didn't want to take away from that.
However, orange and yellow mods could definitely be included in a separate 'Syntax' pack, if there's interest
Offline atomicus
Re: [IC] GMK Pure
« Reply #6 on: Sun, 23 July 2017, 12:41:12 »
This is nice. What might be the release time frame?
Offline JMD
  • All we want is happiness.
    • Mech Keys
Re: [IC] GMK Pure
« Reply #7 on: Sun, 23 July 2017, 13:16:24 »
Ooh very interesting!
- mechkeys - ca -
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
Re: [IC] GMK Pure
« Reply #8 on: Sun, 23 July 2017, 13:48:55 »
Interested, +1 for pure dark
Offline poolside
Re: [IC] GMK Pure
« Reply #9 on: Sun, 23 July 2017, 18:04:11 »
Nice to see another purple set.  :thumb:
I prefer the dark version too. I would also get the white alphas if these were offered as an add-on, though.
Edit: the render includes R2 and R3 PgUp keycaps but it looks like it is missing the matching R3 and R4 PgDown caps.
« Last Edit: Sun, 23 July 2017, 18:06:16 by poolside »
Offline pixelpusher
Re: [IC] GMK Pure
« Reply #10 on: Sun, 23 July 2017, 18:52:42 »
Would have to see a real sample.  That dark of a purple is probably going to turn out almost black. Similar to what happened with the dark blue on GMK penumbra.  Maybe brighten it up just a bit and desaturated ever so slightly?
Offline polentA
  • Formerly withoutrulers
  • GMK plz
Re: [IC] GMK Pure
« Reply #11 on: Sun, 23 July 2017, 20:37:32 »
Having that option would be great, this set's looking good so far.
Offline Giorgio
Re: [IC] GMK Pure
« Reply #12 on: Mon, 24 July 2017, 09:53:31 »
Please take a look at my thread for alphas pricing.
(74 pcs.) including n.3 spacebars (6u, 6.25u, 7u) should cost about 50 eur. I suggest you to add some keys to your alpha, so it will be more desirable: everyone will want one, and the price will increase only a little. That's how gmk pricing works.
https://geekhack.org/index.php?topic=85593.0
I'm not sure about the super high contrast legends (is it black on white?). Perhaps grey on light grey-beige would be nicer?
174071-0
« Last Edit: Mon, 24 July 2017, 09:55:44 by Giorgio »
Offline Jmeferlater
Re: [IC] GMK Pure
« Reply #13 on: Mon, 24 July 2017, 18:04:23 »
I'll check that out
Would that be mainly for people who are only interested in the alpha kit and would be pairing them with mods they already own from other sets?
And the Pure Light alphas are the dark purple on white, reverse of the alphas from the base kit
Offline Giorgio
Re: [IC] GMK Pure
« Reply #14 on: Tue, 25 July 2017, 08:19:20 »
I'll check that out
The alphas must target anyone, but this is necessary, because I higly doubt that you can achieve the MOQ or 150 by targeting only those who bought the main set. Dark purple on white seems nice, but dark purple on gray or very light beige could be nicer.
« Last Edit: Tue, 25 July 2017, 08:26:28 by Giorgio »
Offline pixelpusher
Re: [IC] GMK Pure
« Reply #15 on: Tue, 25 July 2017, 09:05:29 »
Are the modifiers the same as laser?
Offline Jmeferlater
Re: [IC] GMK Pure
« Reply #16 on: Tue, 25 July 2017, 17:50:08 »
Unless his are the exact color codes used in the Pure Syntax theme, I believe not.  :rolleyes:
Offline palindrome
Re: [IC] GMK Pure
« Reply #17 on: Wed, 26 July 2017, 01:01:30 »
Pure Light looks brilliant.
OG KBC Poker X (Brown)     Leopold FC660M (Brown)
Offline Jmeferlater
Re: [IC] GMK Pure | More color options
« Reply #18 on: Sat, 29 July 2017, 12:20:45 »
In an attempt to differentiate this set more, and to include more colors used in the syntax theme, I've made three different versions that would replace the full dark keys in the base kit
1.
2.
3.
Feedback on which one people prefer would be helpful
With this change I'll be moving the dark alphas to a separate kit
Offline Giorgio
Re: [IC] GMK Pure
« Reply #19 on: Sat, 29 July 2017, 13:04:50 »
I don't like pink  ^-^
Offline poolside
Re: [IC] GMK Pure
« Reply #20 on: Sat, 29 July 2017, 14:52:18 »
I like #1.
Nice to see that the dark alphas are still there.  :thumb:
Offline palindrome
Re: [IC] GMK Pure
« Reply #21 on: Mon, 31 July 2017, 00:05:50 »
I actually really like the simplicity of the original "GMK Pure Light" you have in the OP but out of the 3 above, I like #1 the best.
Offline gutsack
Re: [IC] GMK Pure
« Reply #22 on: Fri, 18 August 2017, 14:55:20 »
Interested!
