Author Topic: [GB] E6-V2 Custom 60% Keyboard - INVOICED  (Read 338049 times)
Offline ptiede
Re: [GB] E6-V2 Custom 60% Keyboard - INVOICED
« Reply #600 on: Sun, 12 November 2017, 21:19:45 »
Finally I got brass weight
But I have a question what is kind of treatment it should be
Keep it real or sanding blasting  ,
pvd I think not better it will make weight  thicken that may can't put in bottom
what is u guys opinion there only choose one road
Shiny is best option, if possible...
I'd also like shiny but what would sand blasted look like?
Offline BAS1C
« Reply #601 on: Sun, 12 November 2017, 21:20:49 »
Would prefer shiny.
Sent from my SM-G935F using Tapatalk
Dang. Not sure then :( probably sandblasted then?
Offline Oscar2177
« Reply #602 on: Sun, 12 November 2017, 21:22:48 »
Sandblasted brass.
Offline excluisve
  • Making & Thinking.
« Reply #603 on: Sun, 12 November 2017, 21:45:28 »
Here is the pictures is real
sanding blasting is like prototype .
sanding blasting is have a shortcoming  when u touch it ,will leave u fingerprint :-\ but it can antirust
Offline Oscar2177
« Reply #604 on: Sun, 12 November 2017, 21:52:21 »
Is the last picture sandblasted as well? It looks nice
Offline excluisve
« Reply #605 on: Sun, 12 November 2017, 21:53:50 »
yea,but cant touch by u hand need glove maybe ..... :-X :-X :-X
Offline ptiede
« Reply #606 on: Sun, 12 November 2017, 21:59:51 »
I'm definitely in the sandblasted group then. Cleaning finger prints is way easier than rust. Plus it looks great!
Offline excluisve
« Reply #607 on: Sun, 12 November 2017, 22:01:02 »
finger prints cant be removed i will post a picture
Offline Oscar2177
« Reply #608 on: Sun, 12 November 2017, 22:02:39 »
If they can't be removed then no sandblasting for me. I will definitely touch is a lot.
Offline excluisve
« Reply #609 on: Sun, 12 November 2017, 22:04:07 »
So. plz choose it keep it-   raw or sanding blasting
 let me know thanks
Offline ptiede
« Reply #610 on: Sun, 12 November 2017, 22:07:16 »
 let me know thanks
Maybe making a poll would be a good idea.
Offline Peiweisgreat
« Reply #611 on: Sun, 12 November 2017, 22:17:12 »
So we can't clean off the fingerprints at all?
Offline Oscar2177
« Reply #612 on: Sun, 12 November 2017, 22:20:36 »
I'll go raw, for sure.
Offline amnesia0287
  • Formerly Amnesia
« Reply #613 on: Sun, 12 November 2017, 22:23:51 »
You guys are mixing up concepts. PVD is a coating, but it’s like microns thick unless I’m missing something. Regardless we don’t need PVD. Brass can still be polished without PVD. Not the end of the world if it’s not, but I’d prefer something polished, so it can be cleaned more easily (cause smooth). If brass is not sealed it WILL tarnish and thus it will need to be cleaned.
With the sandblasted finish, are you sure the fingerprints aren’t just tarnishing? Have you tried using something acidic to clean it? Like vinegar & baking soda or salt?
Sent from my iPad using Tapatalk
Offline ptiede
« Reply #614 on: Sun, 12 November 2017, 22:30:57 »
Ya I just looked at it as well, would microns really cause the weight to not fit? Seems kind of crazy to me. But ya if that's the case then I'll do raw as well. I'll just polish the weight every once in a while. Only annoying part will be polishing the mid piece and the plate. Although I guess I'd never really see the plate so who cares if it tarnishes.
Offline Kafka
  • i like clean things
« Reply #615 on: Mon, 13 November 2017, 09:37:38 »
Just make the weight match the plate/mid piece finish
Offline excluisve
« Reply #616 on: Mon, 13 November 2017, 09:39:49 »
I will make a sure then let u guys know it
Wait it .
Offline Kafka
« Reply #617 on: Mon, 13 November 2017, 09:47:26 »
Here is an imgur album of some weights, some raw/some sandblasted
https://imgur.com/gallery/SrVCV
Offline BAS1C
« Reply #618 on: Mon, 13 November 2017, 09:49:30 »
Wait it .
Is just the weight that you cannot do PVD?
If mid & plate is not PVD, I don’t want the brass :(
Offline Kafka
« Reply #619 on: Mon, 13 November 2017, 09:50:55 »
Wait it .
Have you ever had brass with PVD? I have and it scratches and attracts a lot of grime... at least shiny pvd does. I would much rather have it raw/sandblasted
Offline BAS1C
« Reply #620 on: Mon, 13 November 2017, 09:53:01 »
Wait it .
Yes I have. I am not too worried about that. My desk stays very clean and I don’t plan to carry this one around.
Offline Kafka
« Reply #621 on: Mon, 13 November 2017, 10:10:19 »
@exclusive
I think sandblasted is best, but it should be a light sandblast not heavy. Old OTD is lightly sandblasted and looks great, and light should help with clean ability. Think the prototype pic you have has too hard of a sandblast so it doesn't look as good. My opinion anyway, light sandblast.
« Reply #622 on: Mon, 13 November 2017, 10:26:50 »
Depends on the board, Kafka. Some are brushed.
Offline Kafka
« Reply #623 on: Mon, 13 November 2017, 14:39:10 »
Where were you when I asked in Discord bruv. Also I think one of the otd weights I linked is brushed aswell, so yea depends.
« Reply #624 on: Mon, 13 November 2017, 15:53:43 »
i haven't been in that discord for weeks
Offline kawasaki161
« Reply #625 on: Mon, 13 November 2017, 19:53:58 »
It would be really great if there was some kind of protective coating on the plate to prevent tarnishing, it's really hard to clean the plate when the board is assembled.
As long as the weight is lightly sandblasted it's fine for me, if the front face was polished it would probably be even easier to clean off tarnish, but I can live with a light sandblast.
Offline ptiede
« Reply #626 on: Mon, 13 November 2017, 19:57:31 »
I'm basically in that camp as well. The plate being coated would be really nice because that's the only part I'd have a hard time polishing.
« Reply #627 on: Mon, 13 November 2017, 20:11:39 »
the whole reason brass parts are so popular in the first place is tarnishing
you can buy a can of brass lacquer if you don't want that to happen
Offline amnesia0287
  • Formerly Amnesia
« Reply #628 on: Mon, 13 November 2017, 20:17:29 »
I don’t think tarnishing is the reason, but I did plan to play with aging for kicks.
That said, brass is so easy to finish yourself, as long as it looks good, I don’t really care which they pick. I’ll be happy with whatever the choice is lol.
Offline kawasaki161
« Reply #629 on: Mon, 13 November 2017, 20:38:02 »
If it arrived clean that would work for me, but every untreated brass part I ever got arrived with at least some tarnish, a coating from the factory will always turn out better because they can apply it directly after surface finishing.
Like I said, basically everything works for the weight or middle piece, those flat front surfaces are rather easy to clean up too,  but a coating on the plate would be very nice, because a plate is a pain to clean even if it's not even assembled yet because of all the holes.
Offline kuang2
« Reply #630 on: Mon, 13 November 2017, 23:18:01 »
today I and exclusive have a lesson
Offline amnesia0287
  • Formerly Amnesia
« Reply #631 on: Mon, 13 November 2017, 23:20:23 »
I'm guessing you are just packing them, but you could be coating them. I can't tell :P
Offline Oscar2177
« Reply #632 on: Mon, 13 November 2017, 23:27:06 »
What lesson did you get? A little confused.
Offline Kafka
« Reply #633 on: Mon, 13 November 2017, 23:30:16 »
OTD Mini weight?
Offline gaiden
« Reply #634 on: Mon, 13 November 2017, 23:43:03 »
I think if the weight match the same style as the brass mid section and is sealed to prevent tarnish and such (low maintenance) that would be great for me. I just didn't want to receive it and then having to do extra things to prevent tarnish and what not. My 2 cents.
Offline excluisve
« Reply #635 on: Wed, 15 November 2017, 23:00:20 »
All parts done ,but left port plate have some problem
So I am fix it  and re make it
Here is the pic also wait to anodizing
Offline BAS1C
« Reply #636 on: Wed, 15 November 2017, 23:04:46 »
OMG :O :D
Offline excluisve
« Reply #637 on: Wed, 15 November 2017, 23:06:20 »
About brass i am testing .will find a best way to deal it .
Offline BAS1C
« Reply #638 on: Wed, 15 November 2017, 23:10:00 »
Ok, thanks :) looking forward to it.
Offline amnesia0287
  • Formerly Amnesia
« Reply #639 on: Wed, 15 November 2017, 23:12:03 »
Those gaps look naisu.
You still thinking you are on track to ship this month? I am giddy to get mine.
Offline Kafka
« Reply #640 on: Wed, 15 November 2017, 23:22:01 »
Hype Hype
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #641 on: Wed, 15 November 2017, 23:35:40 »
yeesssssssssssssssssssssssssssssssssssssssssssssssssssss
looks great, thanks exclusive!
Offline Oscar2177
« Reply #642 on: Wed, 15 November 2017, 23:58:49 »
I read on the E8-V1 group buy chat that SA profile was an issue due to the small gap or something. Will we have an issue with that, I joined a sa group buy in august just for this board.
Offline kuang2
« Reply #643 on: Thu, 16 November 2017, 06:42:59 »
No, E6 do not have problem with that block.
here is E8
and E6
Offline excluisve
« Reply #644 on: Sat, 18 November 2017, 21:16:19 »
Pcb backlight testing
« Reply #645 on: Sat, 18 November 2017, 23:24:24 »
From the looks of it, it's bright enough with solid keys over it, but how is the transition of the colors? Is it a smooth transition or should we be expecting a little bit of visual lag? Honestly I wouldn't care too much about it since RBG isn't really my thing, but it's always better to be informed.
Offline Oscar2177
« Reply #646 on: Sun, 19 November 2017, 00:03:22 »
What other things are needed to finish testing Exclusive, everything looks amazing so far.
Offline excluisve
« Reply #647 on: Sun, 19 November 2017, 01:32:30 »
Two version so i need test much things ensure things on track. :(
Offline BAS1C
« Reply #648 on: Mon, 20 November 2017, 14:12:06 »
hnnnnnng i cannot wait
Offline Kafka
« Reply #649 on: Mon, 20 November 2017, 14:52:44 »
End up picking a brass finish Exclusive?
