Author Topic: [GB] Green Train - Cherry profile 5 side dye-sub keycap set  (Read 12331 times)
Offline sennin32
    • Doyu Studio
« on: Thu, 24 August 2017, 12:03:07 »
We're Doyu Studio!
This a group buy for Cherry profile keycap set - Green Train.
Group buy link : https://shopkey.doyustudio.com/0umcap012
Price : $95 not include shipping
It will include following caps:
ANSI 104
1u mod keys
1.5u Alt and Ctrl
2.25u, 2.75u, 3u, 6u, 6.5u and 7u spacebar
2.25u enter
3800 caps lock
ISO enter and "|\"
Other extras (see pic below)
All pics :
http://imgur.com/a/St6Ja
This is a Cherry profile keycaps with all side (5 side) dye-sub set.
GB deadline will be Sep 10ths, 2017
Leading time is around 2 months.
Estimate shipping date is early Nov, 2017.
And MoQ is 150 sets.
For any question. Please :
1. send message to https://www.facebook.com/douystudio/
2. send message to sy_yang@doyustudio.com
3. leave comment below!
« Last Edit: Sat, 26 August 2017, 10:02:01 by sennin32 »
Offline sennin32
    • Doyu Studio
Re: [GB] Sadness Train - Cherry profile 5 side dye-sub keycap set
« Reply #1 on: Fri, 25 August 2017, 05:17:23 »
Keep for Updates :
After discuss, we decided use the same name :)
« Last Edit: Sat, 26 August 2017, 10:02:29 by sennin32 »
Offline holtenc
« Reply #2 on: Fri, 25 August 2017, 13:09:56 »
I like this set. Has great compatibility. Wish it had a 2.0 R1 spacebar in green, however.
Offline Delirious
« Reply #3 on: Fri, 25 August 2017, 13:20:26 »
There are a few things I like to point out:
- 1u SHIFT key.
- CONTROL and CTRL, just pick one please.
- 1u BACKSPACE, can we just use the arrow instead.
- 1.25u TAP key
also go Oregon Ducks
« Last Edit: Fri, 25 August 2017, 13:26:58 by Delirious »
Offline JDragon
« Reply #4 on: Fri, 25 August 2017, 17:27:27 »
Is this PBT?
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #5 on: Fri, 25 August 2017, 17:45:34 »
All aboard the sadness train!
Offline zoomwalt
« Reply #6 on: Fri, 25 August 2017, 17:45:43 »
Why is it called sadness train?
Offline sennin32
    • Doyu Studio
« Reply #7 on: Sat, 26 August 2017, 04:00:55 »
This is from the origin concept.
I think the designer got some inspiration while he's traveling in the countryside
They've change the name in Chinese.
But I decide to use origin name, it fit the concept more.
Offline njbair
    • nickbair.net
Re: [GB] Green Train - Cherry profile 5 side dye-sub keycap set
« Reply #8 on: Sat, 26 August 2017, 12:00:20 »
How are you going to dye-sub yellow legends onto dark green keys?
My boards:
Offline sennin32
    • Doyu Studio
« Reply #9 on: Sat, 26 August 2017, 12:18:51 »
This is covered dye-sub.
Means the green is also made by dye-sub on white caps.
Offline njbair
    • nickbair.net
« Reply #10 on: Sat, 26 August 2017, 12:24:33 »
Oh wow, I didn't even know that was a thing. Thanks for the quick reply.
My boards:
Offline heavyheaded
« Reply #11 on: Mon, 28 August 2017, 21:54:04 »
What's the difference between the stepped caps-locks? What's so special about the 3800?
Offline ye_cole
« Reply #12 on: Mon, 28 August 2017, 21:59:47 »
:( am sad.
Offline sennin32
    • Doyu Studio
« Reply #13 on: Tue, 29 August 2017, 04:10:35 »
It is stepped looking.
And the stem mounting position is different.
Cherry stepped caps' stem position is off center.
