Author Topic: [IC] GMK Big Ass Enter Pack - Prep Work in Progress- Poll SOON  (Read 69499 times)
Offline jihadu
Re: [IC] GMK Big Ass Enter Pack - Prep Work in Progress- Poll SOON
« Reply #100 on: Tue, 13 October 2020, 11:08:46 »
VT is just a proposal. I happened to have that board and caps laying around in my Solidworks files from when I started the project
Enviado do meu SM-A505FN através do Tapatalk
Offline jihadu
« Reply #101 on: Tue, 13 October 2020, 11:09:38 »
There was a time when I was very interested in this. Now my layouts have moved to ANSI. Still, I use one with ISO Enter. The ANSI has the advantage that it can have a short backspace on top of it, instead of the big ass.
This is my upcoming build. My own interpretation of an International Danish layout.
Very nice. You could almost say it's not ide(o)us
Offline ideus
  • Björkö.
« Reply #102 on: Tue, 13 October 2020, 14:54:25 »
Offline tyan
« Reply #103 on: Tue, 13 October 2020, 16:22:27 »
jihadu, thanks for renders!
As for me, I don't really care for colors.
For start I'd love to get several solid-color BAEs (black is the first choice with white/no caption) of different profiles (OEM+cherry).
Offline Anomeat
  • But what if we made Navies heavier?
« Reply #104 on: Wed, 14 October 2020, 02:00:15 »
I thought this project already went to GB/Necro!
I'm really happy to see this project still alive.
I've currently designing a 60% keyboard that uses the BAE.
If this is going to become a reality, I will definitely go with the ISO stab enter, because up until now, I've been designing around the Tai Hao BAE, which they reference as 6Gv2 Enter.
The weird stabiliser needed for it has been really difficult to source, so all the more for this project to succeed.
Offline BirgusLatro
Re: [IC] GMK Big Ass Enter Pack - New poll is up
« Reply #105 on: Mon, 23 November 2020, 13:03:17 »
No. I mean this enter key:
That's nice. I haven't seen one. What keyboard is that?
That's a G80-0778.  Sorry for the tardy reply
Offline ideus
  • Björkö.
« Reply #106 on: Mon, 23 November 2020, 14:17:14 »
That's a very insteresting layout. Thank you for the reply.
Offline BirgusLatro
« Reply #107 on: Thu, 26 November 2020, 15:27:56 »
So what's the next step here?  It seems like you were in touch with GMK but the entire first post is stricken through, so can we just get a dimensioned drawing of their keycap and order a sample in any color and figure out if it will work ???
Offline Howgii
« Reply #108 on: Thu, 26 November 2020, 17:45:57 »
I’m also interested!
Offline tyan
« Reply #109 on: Tue, 19 January 2021, 08:30:38 »
So did somebody ask GMK about this?
Offline atxk
« Reply #110 on: Tue, 25 May 2021, 15:44:01 »
Here's a board I built with a set of DCS keycaps that had a BAE, if it's possible I think it would be alot easier to reach MOQ if the keycap could be tooled to use ANSI Enter stabilizer positions, with a stem in the spot of the Pipe key for a dummy switch at the top half of the keycap - that would allow alot of non-ISO boards to use the BAE, and also allow for easy switching back to ANSI enter. My opinion is that if you're already using an ISO enter, there's no real need to change to a BAE, but if you're using ANSI enter, a BAE would be a fun way to get ISO-esque aesthetic without having to rebuild your keyboard (or buy a new PCB/Plate in the case of boards that don't support ISO)
269144-0
269146-1
Offline ideus
  • Björkö.
« Reply #111 on: Thu, 27 May 2021, 21:18:27 »
This is a very interesting idea. Switching between ANSI-Enter and BAE would be a terrific way to have fun and to experience something different, from time to time.
Offline udller
« Reply #112 on: Fri, 28 May 2021, 01:17:33 »
yeah that would make it alot easier to use on customs with fixed plate layouts
Offline Xury46
« Reply #113 on: Sat, 20 November 2021, 16:58:44 »
I need this in my life.
It would be fantastic if there was an easy way to convert ISO or ANSI boards into BAE boards without the need for special stabilizers.
Offline bairghrem
« Reply #114 on: Sun, 05 March 2023, 03:30:49 »
Hey, I just want to add my two cents. I was looking to support the ISO BAE in my build. I included some pictures, especially the one from the Keyboard Layout Editor shows perfectly how the position is off by a few mm. It was already said, but a more clear visualisation:
« Last Edit: Sun, 05 March 2023, 03:55:33 by bairghrem »
