Author Topic: [IC] Noxary 268.1  (Read 35065 times)
Offline xondat
  • i'm not a star
[IC] Noxary 268.1
« on: Sun, 17 September 2017, 15:05:02 »
This is my 2nd creation following on from X60. Everything is different if I compare the two boards directly, but the philosophy is still the same: 8 degrees angle, top mount, and a simple silhouette. I started with two main goals of decreasing the bezel size and making the plate lower to the desk. I believe I've gone to the maximum that's possible with the material, and not much could be improved without sacrificing structural integrity. Hopefully it's worth the hundreds of hours that's gone into this project.
The buy will begin shortly after I receive the sample (about 3 weeks away).
Case Information:
  • 6061 Aluminum
  • 8 Degrees Angle
  • Brass Weight with Engravings
  • Thinnest Top Mount Bezels (4.6/3mm)
  • Lowest Plate to Desk (7.7mm)
  • Optional .5u Blocker
Supported Layouts:
68 key may change. To put it simply, it will be the layout I want to use.
Plates:
  • Top Mounted Plate with Switch Opening
  • Universal or 68 Key Plate
  • Clear Polycarbonate, Anodized Aluminum, or Polished Brass
  • Partial Polycarbonate 68 Key Available
PCB:
  • Custom QMK PCB by Rozakiin
  • Presoldered Controller, Diodes & Resistors
  • Mini USB
  • Interchangable For winkeyless.kr 22mini
268 AG:
  • Limited to 22 Units
  • Anodizing or Cerakoting
  • Brass Through Weight with Individual Numbering
  • Polycarbonate, Brass, or Aluminium Plate
Cerakoting is likely to add $50 or so to the case price.
268:
  • 20 Units
  • Dark Gray or Silver Case
  • Polycarbonate, Brass, or Red Aluminium Plate
Price (excluding fees + shipping):
  • Case (Top/Weight/Bottom) - $320
  • Plate - $30
  • PCB - $30
Shipping:
I'll be shipping with DHL Express again, with most packages taking 1-3 days for a good price. I'll be shipping from the United Kingdom; local taxes and fees apply. Estimates for shipping are as follows: United States - $40; United Kingdom - $20; Europe - $30-35; Asia - $50-60.
Deadline & Lead Times:
I'll allow 1 week after starting for payment. After this, the order can be submitted to the factory and will take about 6-8 weeks to arrive.
Thanks for reading. If you have any questions, please feel free to ask them. Thanks.
« Last Edit: Thu, 16 May 2019, 10:41:30 by xondat »
Offline gnmar2723
Re: [IC] Noxary 268
« Reply #1 on: Sun, 17 September 2017, 15:07:42 »
2017 sure is the year of the 65%  :)
Best of luck on this Xondat! I really like the style of your other boards  :thumb:
Offline avid
Re: [IC] Noxary 268
« Reply #2 on: Sun, 17 September 2017, 15:08:50 »
Yeah this layout seems super popular now!
Offline joey
Re: [IC] Noxary 268
« Reply #3 on: Sun, 17 September 2017, 15:10:18 »
Looks nice, good luck! :thumb:
Offline amnesia0287
  • Formerly Amnesia
Re: [IC] Noxary 268
« Reply #4 on: Sun, 17 September 2017, 15:22:36 »
Ooo. Doo want. FCFS or Raffle? I want AG but would buy either. Been dying for a nice 65%.
Offline hayt
Re: [IC] Noxary 268
« Reply #5 on: Sun, 17 September 2017, 15:26:43 »
Looks great Xondat! Love this layout, I'm very tempted :D
Offline pixelpusher
Re: [IC] Noxary 268
« Reply #6 on: Sun, 17 September 2017, 15:26:48 »
Looks great.  Interested in that Cerakote.  Any more info about the colors available?
Offline VicareyG
  • Vendor - Optic Boards
    • Optic Boards
Re: [IC] Noxary 268
« Reply #7 on: Sun, 17 September 2017, 15:37:30 »
I Need this! It looks so nice :D
Offline tireddoctor
Re: [IC] Noxary 268
« Reply #8 on: Sun, 17 September 2017, 17:15:48 »
A million times Yes! But I hope it is done in large enough quantity so some of us can get in.
Offline poolside
Re: [IC] Noxary 268
« Reply #9 on: Sun, 17 September 2017, 17:22:28 »
Nice weight design on the AG  :thumb:
Oh and filleted edges. They feel smoother under the finger.
Will brass plates be offered in future rounds of the L? Gotta be quick if you want one.
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #10 on: Sun, 17 September 2017, 17:40:07 »
Thanks for the support everyone :thumb:
I will probably do FCFS, not sure there is enough demand to bother with raffle.
Plan to offer as many colors as possible with the AG, I want to offer lots of freedom with the builds.
Well now there are 42, which might be enough. If not, I can do more runs of 268L.
Thanks! Yeah it should feel smoother. I think it looks nicer and makes it look even thinner.
Not too sure. I might offer it for this round, but still have to consider costs and ultimately whether it's different enough from aluminum. I'll build identical boards, just different plate material, and see whether it's worth it.
Offline nmur
  • ಠ_ಠ
Re: [IC] Noxary 268
« Reply #11 on: Sun, 17 September 2017, 17:44:46 »
awesome brass weight design dude
Offline skidude9678
Re: [IC] Noxary 268
« Reply #12 on: Sun, 17 September 2017, 17:50:04 »
Count me in
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: [IC] Noxary 268
« Reply #13 on: Sun, 17 September 2017, 17:54:49 »
Interested
Offline frostbyte-gaming
Re: [IC] Noxary 268
« Reply #14 on: Sun, 17 September 2017, 18:29:45 »
Definitely interested, love the 68 key and I have been interested in trying out a polycarbonate plate. Also will we be able to order extra plates and pcbs to go with the case?
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #15 on: Sun, 17 September 2017, 18:32:49 »
Of course. Prices are listed separately so that you can work it out depending on what you'd want :-*
Offline tuba section
Re: [IC] Noxary 268
« Reply #16 on: Sun, 17 September 2017, 18:45:43 »
Really looking forward to this! Love the thin bezels and the AG weight design. Most of all I love the simplicity of the Noxary boards so far. Great stuff Xondat
Offline breckstar
Re: [IC] Noxary 268
« Reply #17 on: Sun, 17 September 2017, 19:31:36 »
Cerakoting white? In for sure if possible :)
Offline ns90
Re: [IC] Noxary 268
« Reply #18 on: Sun, 17 September 2017, 19:42:20 »
I keep saying I don't need more 65% boards since I prefer 60%, but then I keep seeing these beautiful boards, so I guess I'm in!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: [IC] Noxary 268
« Reply #20 on: Sun, 17 September 2017, 23:01:23 »
Looking good boi, gl
If I didn't already have 65% I'd be all over it!
Offline Delirious
Re: [IC] Noxary 268
« Reply #21 on: Sun, 17 September 2017, 23:49:14 »
If that is indeed the pcb I'll be in for alps. Will you release the plate dimension and such so I can design my own alps plate?
Offline RevoTeam
Re: [IC] Noxary 268
« Reply #22 on: Mon, 18 September 2017, 00:00:41 »
This is looking good. Good luck,man
Offline Strontaap
Re: [IC] Noxary 268
« Reply #23 on: Mon, 18 September 2017, 00:09:57 »
Oh, snap. Yes please!
M65-A | COD67
Offline ArchDill
Re: [IC] Noxary 268
« Reply #24 on: Mon, 18 September 2017, 00:54:33 »
Offline marre259
Re: [IC] Noxary 268
« Reply #25 on: Mon, 18 September 2017, 04:29:54 »
Just want to confirm this doesn't support 1.25 1.25 1.25 6.25 1.5 1.5 bottom row?
Edit: nvm i'm dumb
Offline Calza
Re: [IC] Noxary 268
« Reply #26 on: Mon, 18 September 2017, 05:08:21 »
Count me in!
Offline finalarcadia
Re: [IC] Noxary 268
« Reply #27 on: Mon, 18 September 2017, 07:00:38 »
Count Me In
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #28 on: Mon, 18 September 2017, 07:09:36 »
Thanks again for the support, can't wait to receive and show the prototype to everyone.
Very interested. When?
Shortly after I receive the sample which will be in 2.5-3 weeks.
I'm not sure I'd officially support it, but I'd be happy to work with someone in getting an Alps plate if they really wanted it.
Edit: nvm i'm dumb
It does :))
Offline avid
Re: [IC] Noxary 268
« Reply #29 on: Mon, 18 September 2017, 07:26:22 »
Curious what's happening with the super fast GBs. Normal seems at least +6 months. Is 6-8 weeks to arrive for completed keyboard?
Is it because you already done prototype? Also curious about the anodization, will it look simular to x60 boards?
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #30 on: Mon, 18 September 2017, 07:49:19 »
6-8 weeks is the time I'm allowing for the manufacturer to make and ship. Using the lead times on the quotes, and how long the sample will take, it should be plenty. Of course I can't predict the future, but the design is set and it will be a case of asking for x numbers of parts and waiting.
The sample already being in production, and not starting the buy before receiving it will make the wait look quite a bit shorter for participants, so I guess it helps.
Anodizing should be like the Fjell and Klippe. Anodizing does vary per batch, but the factory have shown good work so far. There are many great pictures of the Fjell around, and hopefully the Klippe soon. Here are a couple:
Credit to leandren and fausuto.
Offline hayt
Re: [IC] Noxary 268
« Reply #31 on: Mon, 18 September 2017, 08:03:54 »
Wow, that is one badass chamfer!  :thumb:
Offline Murrellz
Re: [IC] Noxary 268
« Reply #32 on: Mon, 18 September 2017, 09:11:19 »
After missing out on the TGR910-CE, I'm definitely interested in this!
Offline Softkore
Re: [IC] Noxary 268
« Reply #33 on: Mon, 18 September 2017, 10:39:57 »
I am extremely interested in this beautiful case... Would look lovely alongside my Fjell R1.
Offline jerue
  • (Whenever that happens :P)
Re: [IC] Noxary 268
« Reply #34 on: Mon, 18 September 2017, 18:41:53 »
This looks wonderful, I hope I am able to get a 268L during the initial run!
Offline ctzn_voyager
Re: [IC] Noxary 268
« Reply #35 on: Mon, 18 September 2017, 19:17:25 »
YES
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #36 on: Tue, 19 September 2017, 10:25:07 »
What do people think of cerakoting? I want to offer it but I think it'll be too complex, and of course it's added choice as it's not done at the factory.
I'll also post a pre-engraving picture of the 268L weight later :p
« Last Edit: Tue, 19 September 2017, 10:28:17 by xondat »
Offline pixelpusher
Re: [IC] Noxary 268
« Reply #37 on: Tue, 19 September 2017, 10:40:33 »
I wanted cerakote so I could get beige.  I've always wanted a high quality beige case. But if you don't have a manufacturer who you know can do a great job, we'd probably be safer to go without the option.
Why don't people make nice quality custom ABS cases?  Still hoping one day someone will  :(
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #38 on: Tue, 19 September 2017, 10:59:50 »
Oh that's a good point.
When I said too complex, I mean logistically. I think it'd probably be worth it for those that want it? The quality looks good, I'll have to try and get some pictures.
Offline Harms
Re: [IC] Noxary 268
« Reply #39 on: Tue, 19 September 2017, 18:16:56 »
The silver case with brass plate would look amazing.
Offline euphxenos
Re: [IC] Noxary 268
« Reply #40 on: Tue, 19 September 2017, 23:44:28 »
Is there any chance you could offer it in navy blue (whether that's anodized or cerakote)?  I'm looking for a navy blue 65% to go with GMK Nautilus.
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
Re: [IC] Noxary 268
« Reply #41 on: Wed, 20 September 2017, 06:41:01 »
Eoww! I want one. It seems incredible!
Filco TKL Ninja Blues / CODE Greens / Pok3r Clears / HHKBpro2 / RF 87U 55g / Novatouch TKL / KC60 Clears / SSK and also regular Model M
Offline Marutks
Re: [IC] Noxary 268
« Reply #42 on: Wed, 20 September 2017, 06:48:36 »
I am in!  I want Dark Gray or black case.  I would be interested in NAVY BLUE, too.
« Last Edit: Wed, 20 September 2017, 06:56:15 by Marutks »
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #43 on: Wed, 20 September 2017, 07:03:58 »
Well you're in luck because I'd also like a navy blue case. I'll be trying to organize it when it's time :)
Thanks :-*
I agree. I haven't tried brass as a plate yet, so looking forward to that too.
Minor update today; Rozakiin received the first revision PCBs and will be sending one to me soon for test fitting. I'll get a couple pictures up when I can.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
Re: [IC] Noxary 268
« Reply #44 on: Wed, 20 September 2017, 08:06:28 »
Looks very appealing! Shame I missed your last GB and couldn't really get my hands on an unbuilt kit. Hopefully I'll make it this time :)
Offline skidude9678
Re: [IC] Noxary 268
« Reply #45 on: Wed, 20 September 2017, 19:59:32 »
South facing LEDs, correct? If I'm lucky enough to get one I'd like to put tealios and zealencios with a GMK set on this.
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #46 on: Wed, 20 September 2017, 20:29:46 »
Yup, on the south side!
Offline ihalatch
Re: [IC] Noxary 268
« Reply #47 on: Wed, 20 September 2017, 22:14:37 »
Is it possible to put a very thin acrylic diffuser in the seam between the tot and bottom parts for those who wishe?  In my opinion it looks better, somehow masking the tiny gap.
Offline amnesia0287
  • Formerly Amnesia
Re: [IC] Noxary 268
« Reply #48 on: Wed, 20 September 2017, 22:28:17 »
Sooooo... when can I give you money :D
Offline xondat
  • i'm not a star
Re: [IC] Noxary 268
« Reply #49 on: Thu, 21 September 2017, 08:19:43 »
Nope. Since the PCB is attached to the top piece, and the USB hole is on the bottom piece, any added thickness would mean they don't line up. Besides that point, diffusers and LEDs are ugly :'(
8th of October or so? ;D
