Author Topic: I like KeyTronic Foam and Foil  (Read 5952 times)
Offline OldIsNew
« on: Sun, 17 September 2017, 21:28:08 »
First of all I'll mention that I'm really big on IBM BS boards, but in the last few months I've gotten into looking for older spherical key boards - because they just look so cool. It seems a not small percentage of the boards I've come across are older KeyTronic foam and foil.
 I understand some people just don't like linear switches but beyond that there seems to be some special hate for KeyTronic foam and foil. Yes, they are a pain in the arse initially because, as many have noted, the foam has usually turned to brown gunk and has to be replaced - but once its done, I've found them to be rather nice switches. I'm not claiming a lot of experience since I've only rebuilt three of these boards (a Tandem 6530, a Westinghouse W1642A and a TRS-80 Model II) but I really like all three. I did complete foam and foil replacement and xwhatsit Model F to USB on the Westinghouse and TRS-80 Model II (the Tandem didn't need new foam) and I think they're nice, rather smooth linear switches - and I love the keycaps and the sound they make when typing.  I really don't find them "mushy" either - the springs seem to dominate the feel of the switches in my opinion.
So there I've said it - I like KeyTronic foam and foil.
Offline klennkellon
  • I like bottoming out
Re: I like KeyTronic Foam and Foil
« Reply #1 on: Mon, 18 September 2017, 05:31:54 »
you should try getting yourself a BTC foam and foil, then you'll have MX compatible caps.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Mon, 18 September 2017, 08:51:08 »
If you have the older KT linear boards, like the ones OP seems to mention, they'll likely have caps WAY better than anything MX mount ;) . Say what you want about KT, they knew their way around keycaps.
Offline dante
« Reply #3 on: Mon, 18 September 2017, 12:49:26 »
How does KeyTronic Linear compare to Fujutsu Leaf Spring?
Offline OldIsNew
« Reply #4 on: Mon, 18 September 2017, 14:30:23 »
The funny thing is I don't actually have any MX/MX compatible boards.
I'm sure chyros could speak better to this, but I do have one Fujitsu 3rd gen leaf spring board - it is smoother than any of the KeyTronics I have. Still, I just like the look and feel of the old KeyTronic boards.
« Last Edit: Mon, 18 September 2017, 14:36:51 by OldIsNew »
Offline dubious
  • 쏘쿨
« Reply #5 on: Mon, 18 September 2017, 15:08:42 »
in good condition, the feeling is quiet nice
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Wed, 20 September 2017, 14:05:20 »
FLS is virtually unbeatable for smoothness in my experience, which includes KT vintage foam and foil.
Offline ander
  • I type, therefore I am
« Reply #7 on: Wed, 20 September 2017, 18:40:06 »
I've often admired how great the old F&F boards looked, but assumed there'd be no point in trying to use any of them—after all, "foam and foil" sounds über-cheap, like "smoke and mirrors". But it's actually a doable thing, you say. Whoa! A new challenge to my marriage has just appeared on the horizon.
Offline OldIsNew
« Reply #8 on: Wed, 20 September 2017, 19:20:50 »
It's definitely doable. Replacing the foam and foil is tedious but not difficult, and the xwhatsit Model F to USB has really worked well on the two boards I've used it on. I put some more pics and info here:
https://deskthority.net/workshop-f7/westinghouse-w1642-keytronic-foam-foil-xwhatsit-model-f-conversion-t17294.html
and here:
https://geekhack.org/index.php?topic=91650.0
Offline ander
« Reply #9 on: Wed, 20 September 2017, 20:07:07 »
Nice! Those keys are unparalleled.  :?)
Offline OldIsNew
« Reply #10 on: Sat, 28 October 2017, 22:55:06 »
I'm posting to this thread again because I came across a board that I think explains why so many people hate KeyTronic foam and foil. I have several F&F boards with what I've seen generally referred to as "vintage" KeyTronic F&F switches, and I really like them:
181080-0          181082-1           181090-2
I recently acquired a a TRS-80 Model 12 keyboard that is a KeyTronic F&F with the switches pictured below. Fortunately, I didn't pay much for the board. The springs seem to be glued on and are quite flimsy. The cases are unbranded with short stems:
181084-3          181086-4          181088-5
The keycaps feel cheap and the switches are about the worst feeling switches I've ever tried. I thought these must be newer, cheapened version KeyTronic F&F, but the PCB is dated April 1983 so I'm not sure what to think. If I had to guess I'd say these would be called "low profile" versions, but whatever the reason for them, they are awful! So if you're interesting in trying KeyTronic F&F, I'd say be sure to look for the "old school" tall, branded switches for sure!
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Sun, 29 October 2017, 02:33:14 »
Is the PCB marked KT? There were several clone manufacturers of switches that looked like that. Not saying KT is better...
Offline OldIsNew
« Reply #12 on: Sun, 29 October 2017, 12:36:21 »
Yes, it's KT.  A disappointment, because I really am a fan of the tall stem version of their F&F switches. The short switches on this board are another story.  I was surprised to see a 1983 date on this PCB - when I saw the switches I was expecting something from the 90's.
181117-0          181119-1
Offline chyros
  • a.k.a. Thomas
« Reply #13 on: Sun, 29 October 2017, 16:41:48 »
Interesting. The plot thickens.
Offline invariance
  • ...here with all the other boson's
« Reply #14 on: Sun, 29 October 2017, 17:45:52 »
Possibly same pcb for different manufacturers requirements, ie cheaper switches?
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
