Author Topic: HHKB vs FC660C -Battle of the ultimate Topre  (Read 31995 times)
Offline Duckyreddy
  • Better skadoodle, poodle.
« on: Wed, 27 September 2017, 00:58:34 »
Hello people  :D
What do you guys think of the HHKB Pro 2 and the FC660C?
How do these two stack up against each other in terms of build and the Topre experience?
Are there any reasons why I should choose one over the other?
Please and thank you~
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline yuppie
Re: HHKB vs FC660C -Battle of the ultimate Topre
« Reply #1 on: Wed, 27 September 2017, 01:45:45 »
660C's switches feel better, it's heavier and more "sturdy". I think they different in plate vs. PCB mount or just plastic plate vs. steel/alum plate.
HHKB is a lot nicer to look at, but I can't live without arrow keys. Either way, lube your topre switches!
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline Duckyreddy
« Reply #2 on: Wed, 27 September 2017, 01:57:55 »
I can't live without my arrows either!
I am considering to lube my switches and I like both the stock caps for them, I've heard good things about both of them and really just wanted to ask people who have tried both!
Cheers for the input  :thumb:
Offline stoic-lemon
« Reply #3 on: Wed, 27 September 2017, 02:53:15 »
Always interested to hear thoughts from those who have tried both.
Offline Lazylewis
« Reply #4 on: Wed, 27 September 2017, 04:42:39 »
I have both and they're completely different in feel and layout that they don't have much in common. I like both of them for different reasons.
Offline kmba
  • Formerly tameone
« Reply #5 on: Wed, 27 September 2017, 07:11:58 »
These are my primary two boards. I switch back and forth every few weeks. 660c is more solid feeling, heavier and snappier domes, and more thocky sounding. Hhkb is lighter domes, softer landing, and still good sounding. I will admit I had to lube and silence my hhkb because I couldn't stand the upstroke noise, whereas it's not that bad on the 660c. Moot issue though since both are getting rf purple sliders soon. Layout on the hhkb is superior, even without arrows (you get used to arrow layer). Had to get a controller for my 660c to swap backspace.  Overall though I prefer my 660c due to the solid feel and and the heavier/snappier domes.
keyboards.
Offline shadowku
« Reply #6 on: Wed, 27 September 2017, 10:25:46 »
I have both.
My HHKB is hypersphere'd and my 660 is stock.
As others here have said, the 660 is snappier and feels more solid, likely because the 660 has a metal plate while the HHKB is all plastic inside and out.
There's essentially 3 embodiments of Topre: HHKB, Leopold (FC660C, FC980C), and RealForce (55g, 45g uniform, variable). And there's people who change the domes on various boards.
I think the choice of which keyboard to get really depends on how you're going to use them. If you use arrows a lot, you may want to get the 660 because always having to access arrows via a modifier can be troublesome sometimes. If you're fine without them, then I think its a matter of preference.
Personally, I favor my HHKB because the default layout and dip switches on the 660 annoy me. I prefer the back space being on top of the Return key, and I've swapped the Caps lock and the left Control with the dip switches, but I keep accidentally hitting the new Capslock now. I want absolutely no Capslock on my board. Rather than getting a Hasu, I'm probably going to sell it.
Other than the layout, I still prefer my HHKB, because when Hypersphere'd, or if you get the Type-S, it's likely the quietest keyboard. It's even quieter than the Apple chiclet keyboards all my coworkers use. I prefer the softness and the hallow thocky sound of the HHKB more as well.
HHKB Pro2      FC660C
Offline Duckyreddy
« Reply #7 on: Wed, 27 September 2017, 13:33:46 »
Thank you, How are the stock caps may I ask? ;D
I have both.
Oh sweet! Everyone I've talked to that owns and loves their HHKB has said that they absolutely adore it but they would like to see a metal backplate for a change because the entire thing is plastic fantastic? Correct?
The layout of the HHKB looks quite nice to me and I don't see a problem with me switching to it, I'm not a big "caps" fan my self either and I like the simple look of the blank HHKB's, I can see myself leaning towards the HHKB side.
Thank you :)
« Last Edit: Wed, 27 September 2017, 13:39:52 by Duckyreddy »
Offline wishful_cynic
« Reply #8 on: Wed, 27 September 2017, 13:56:59 »
I bought my first topre board earlier this year and chose the 660c due to: (1) the superior build quality; (2) the dedicated arrow cluster and delete key, which I use every day in the office for writing; and (3) my experience with other Leopold boards, which has always been excellent.
I like the way the HHKB looks, I think it's a great design, and it's an iconic board in this community.
People love both of these boards.  If build quality and dedicated arrow keys are more important to you, go with the 660c.  If looks and history are more important to you, go with the HHKB.
Offline shadowku
« Reply #9 on: Wed, 27 September 2017, 14:27:38 »
The stock keycaps on both keyboards are decently thick PBT, except for the space bar, so they're definitely more than good enough if you're not a keycaps fanatic.
The keycaps on my HHKB have been dyed purple and I bought a blue PBT space bar from MassDrop, so it looks like a Super Nintendo (see sig).
I've considered swapping the sliders to either the NovaTouch sliders or JTK sliders so I can use GMK caps, but it doesn't feel worth it because you'd be sacrificing some of the Topre feel.
I've heard people say that a few times, but personally I do not wish for a metal plate. A part of the HHKB's feel is the plastic frame which gives it its more hallowed thock sound. It's a nice characteristic that I enjoy. The keyboard overall is flimsier than the 660, and there is a bit of creaking when you twist the keyboard, but it still feels like a very high quality board.
Another thing is that I carry my HHKB to and from the office everyday, so keeping it light is a plus. I have the official PFU HHKB carry-case so it works quite well for me. Another thing people complain about is that the feet on the HHKB  are not very effective. This is true - there's only 2 rubber feet at the bottom, with two plastic dome feet at the top and so the keyboard slides easily. But, in an effort to make it quieter, I've since bought large desk mats for my desk at work and at home which prevents the sliding anyway, so it doesn't really matter to me.
HHKB Pro2      FC660C
Offline Duckyreddy
« Reply #10 on: Wed, 27 September 2017, 14:32:22 »
That is beautifully summed up, I appreciate it~
Thank you, sir  :thumb:
Offline Duckyreddy
« Reply #11 on: Wed, 27 September 2017, 14:39:38 »
Wowow, That's a pretty HHKB!
Yea I guess some appreciate the light weight of it and the lower thock (which I love) they both look like solid options.
The rubber feet thing is a common complaint, I think, but I have a large mat for my desk too so that shouldn't be too concerning.  :D
Thank you~
Offline kmba
  • Formerly tameone
« Reply #12 on: Wed, 27 September 2017, 16:13:12 »
The stock caps are very good aside from the spacebar, and every other cap just doesn't feel right on topre.. aside from hi pro topre caps.  mx sliders & mx caps aren't as nice and you sacrifice feel for aesthetics.  But, you absolutely need to swap the spacebars for PBT.
With some ingenuity, you can get some interesting looking layouts too.  Here's mine.
keyboards.
Offline jerue
  • (Whenever that happens :P)
« Reply #13 on: Wed, 27 September 2017, 17:23:10 »
The FC660c can adapt to more working environments, but the HHKB is a better board overall. It is more satisfying to use and the keycaps (though thin) are good. HHKB doesn't really need anything either, it's great out of the box. I do not feel that is the case with FC660c. It feels a bit more dull, about 3g heavier than 45g Topre, and it uses two left shifts.
If you want to get into modding, the best FC660c I have used is with the sliders from HHKB Type-S. Better feeling than Realforce with Type-S sliders, so best plate-mount Topre board is FC660c with HHKB Type-S sliders.
But the ultimate Topre keyboard has to be HHKB with Realforce purple sliders, and lubed.
Offline strigif0rm3s
« Reply #14 on: Wed, 27 September 2017, 17:33:05 »
Fc660c hands down.
Source: I'm a topre fanatic
Sent from my Nexus 6P using Tapatalk
Offline Duckyreddy
« Reply #15 on: Wed, 27 September 2017, 17:54:01 »
Those are beautiiifullll, I'll definitely go with a PBT spacebar if I do get one
Thank youuu  :thumb:
Offline Duckyreddy
« Reply #16 on: Wed, 27 September 2017, 18:01:09 »
So the sliders impact the feel quite a lot, What's different between the Type-S and the stock HHKB sliders?
Thanks~
Offline jerue
« Reply #17 on: Wed, 27 September 2017, 18:48:14 »
Thanks~
this thread has some good documentation. the main thing with the Type-S sliders is they are longer than either purple sliders or stock sliders. This extra length along with the Type-S design, I find, works better in a plate-mount board like the FC660c than top-case mount like HHKB.
« Last Edit: Wed, 27 September 2017, 18:49:45 by jerue »
« Reply #18 on: Wed, 27 September 2017, 19:54:31 »
I think they are both exceptional, the one I enjoy typing on more is the HHKB2 for the louder thock (IME there is no Topre keyboard that sounds and feels like the HHKB) and more organic feel and the HHKB is the one I more often rotate into my listening room where I type up many paragraphs on my classical listening notes. YMMV as sound is of high importance to me! I sold an SKCM blue keyboard in an aftermarket case because it just didn't sound like the old fashioned stock cases they come in whereas others would have preferred the superior layout of my aftermarket.
« Last Edit: Wed, 27 September 2017, 19:59:02 by directheatedtriode »
Offline Polymer
« Reply #19 on: Thu, 28 September 2017, 03:42:47 »
I haven't seen people say this...in the closest thing to this when someone created an aluminum case for the HHKB, it basically ruined feel and sound.  You also can't put a plate into the HHKB without gutting the whole thing..part of the switch is actually built into the case itself.  I think people have thought about what it might feel like with a plate but this isn't like MX switches where overwhelmingly people seem to prefer plates...To me it would complete gut the feel of the HHKB which has great thock and a much more organic feel compared to other Topres...
The reason the 660c has a stiffer feel isn't because a RF has a plate and it is the least thocky and lightest of the three at the same weight (45g).
Offline Hordak
« Reply #20 on: Thu, 28 September 2017, 11:24:01 »
Oh, I'm facing the same "dilemma". The Topre keycaps are very nice. To be supreme, they could be thicker is my feeling - but that's just a guess. They are very good and nothing to worry about.
Reposting this from another thread:
I recently got a Realforce 45g after 3 years of training on HHKBs. First impression, the keys felt real mushy. After a while - an hour or so typing on keybr.com - I unexpectedly got to preferring the RF's 45gs. Strange that the switches grew that much on me. The "mushy feeling" made way to the pure pleasure of a pronounced, contained, precise key stroke. Oh.. the echoing feedback of a metal plate... pure bliss. That made me curious though: I have a 55g incoming. Hard to pre-judge, but I suspect the weight will be too much for me.
But - and it's a BIG but - the HHKB layout is still much superior. In comparison, the Realforce's TKL arrangement feels totally unergonomic. The arrow keys and backspace are just too damn far away, as is the mouse. That's why now, I also got a FC660C incoming - yes, you heard that right, stupid ****ing empty wallet! I SO hope it will be the perfect blend of the two, but, I know the keeb gods won't allow that to happen. Endgame is like plugging in a USB cable - no matter how confident your are, it's always the wrong direction.
Offline shadowku
« Reply #21 on: Thu, 28 September 2017, 13:00:09 »
I think you're going to have to rotate between the 3 Topre boards you have. You'll never feel "satisfied".
Also, new RFs coming out next year.
HHKB Pro2      FC660C
Offline Polymer
« Reply #22 on: Thu, 28 September 2017, 13:21:40 »
It does feel a bit mushier..there is less thock to it and it seems like they're lighter than on the HHKB.
The less thock and less general noise as well which is why might feel it is more precise....
For me I like the HHKB because of the layout but I also enjoy the sound...I also enjoy RF as well...It is also why silenced RFs are fine but I prefer a normal HHKB vs. type S...
Offline Duckyreddy
« Reply #23 on: Thu, 28 September 2017, 13:23:09 »
It is weird, The low pitch Thock comes from the plastic backplate so I'm not sure why they'll want to get rid of that.  :p
« Reply #24 on: Thu, 28 September 2017, 14:19:55 »
I have wanted to try the 55g Realforce but worried about the weighting as well. Please do share what you think of the weight compared to HHKB when you get it.
Offline thebabyparrot
« Reply #25 on: Thu, 28 September 2017, 17:07:55 »
In my opinion, as a person who owns multiple Topre keyboard and has tried almost very variation in existence;
The best out of the box Topre keyboard is the FC660C.  Here's why:
1. The switches on the FC660c is more tactile than the stock HHKB AND Realforce 45G.
2. The keyboard has a heft and build quality that the HHKB lacks.  It's one of the best built keyboards you can buy through a retail chain.
3. The keycaps on the white model are luscious and are one of a kind in the Topre world. I know ysers who have actually bought the White ANSI FC660C just to transplant the keycaps alone.
4. The arrow cluster is available by default.  Depending on who you are, between the two mini Topre boards, the arrow cluster is a make it or break it sort of ordeal.  While some people are willing to accomodate to the shortcuts of the arrow cluster, for me- it's absolutely necessary.
This is just my opinion, and I'm sure others will disagree but the TL;DR is:
The FC660C is more tactile, has a better build quality, and an arguably better layout thanks to the arrow cluster.
Offline Hordak
« Reply #26 on: Fri, 29 September 2017, 06:33:43 »
No way I'm keeping three. That's just too lavish. I'll probably keep one HHKB and one of RF or 660c .
Yeah, I've seen the new RF pictures. Not sure why you'd want that over a RF1... I think its kinda ugly tbh.
Sure buddy. I just got the RF 55g. Will begin testing today or tomorrow.
Offline shadowku
« Reply #27 on: Fri, 29 September 2017, 07:55:27 »
I'm curious about the features. If there's detachable cable then maybe there's a case for the TKL.
I'm still secretly hoping for a TKL version of the RGB to either gut for sliders or to just use to sport keycaps.
On another note, last night while doing some work with the 660, I realize that I use  "~" and "`" more than I realized, and combined with the position of the backspace, I really can't use a small keyboard without a split backspace.
I have a NightFox on the way, and while I was really looking forward to the Halo True switches, it's still the best 65% keyboard I can easily get. I'm most likely going to keep a HHKB (or two) and the NightFox as my main drivers.
HHKB Pro2      FC660C
Offline kmba
  • Formerly tameone
« Reply #28 on: Fri, 29 September 2017, 07:57:49 »
I have an rf87 55g coming soon..  I will be swapping between three  :p  and my two alps boards.. and my zanda board.  and my kailh box boards.  hrm.  and my model F.  oh jeez I have a problem.
keyboards.
Offline Hordak
« Reply #29 on: Fri, 29 September 2017, 08:27:19 »
Oh I though they were already set on non-detachable cable. At least from the pictures...
What is so special about the RGB sliders? for a non-RGB keyboard?
Agreed. I miss the split blackspace from my HHKB on the RF too. The layout is simply superior.
The first step in solving a problem is denial ;D
« Reply #30 on: Fri, 29 September 2017, 10:33:38 »
Any links to the new Realforce? The only one I know of is the RGB full size.
Offline Hordak
« Reply #32 on: Fri, 29 September 2017, 11:04:49 »
https://geekhack.org/index.php?topic=91649.0
That looks awful.  I don't like the existing model, I think the fat back bezel looks out of place with the rest of the board being pretty skinny around the edge, but this is a step backwards in design.
Offline millifoo
« Reply #33 on: Fri, 29 September 2017, 11:26:29 »
I'm curious - are the keycaps on the white model of different build quality and/or feel than the ones on the dark gray model?  I have the dark gray, love the keycaps, but have not had a chance to try the white model.
« Reply #34 on: Fri, 29 September 2017, 11:31:14 »
They're the same caps other than color, PBT with dyesub legends.  The texture is excellent.
Offline millifoo
« Reply #35 on: Fri, 29 September 2017, 11:34:17 »
Cool... means I don't have to hunt down a white model to compare :-).   Agreed, the feel is superb - best I have.
Offline shadowku
« Reply #36 on: Fri, 29 September 2017, 12:50:44 »
The RGB RF uses MX compatible sliders. I hear the RGB doesn't feel as good as traditional RFs as a result, but it still seems like one of the better ways to get some MX keycaps on a Topre board.
HHKB Pro2      FC660C
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #37 on: Fri, 29 September 2017, 13:06:49 »
You mean this ?
179257-0
It's coming out next year.
It not only feels sub par; it sounds god awful too. Modding the keyboard with Silence-X rings and lubing the stabilizers helps a lot, but for the price that should not be requirement on the part of the end user IMO.
« Reply #38 on: Fri, 29 September 2017, 13:25:13 »
I've tried JTK and Novatouch sliders and both detracted from the feel substantially.  I'm sticking with topre caps.
Offline Duckyreddy
« Reply #39 on: Sat, 07 October 2017, 20:04:15 »
Right now I am down to two choices, HHKB Pro 2 and Type-S  ;)
Offline kmba
  • Formerly tameone
« Reply #40 on: Sat, 07 October 2017, 21:49:04 »
Type s. I think hhkbs really need silencing and aftermarket silencing rings just aren't as good. Unless the price difference really bites you, you could do pro 2 and kbdfans silencing rings.
keyboards.
Offline Duckyreddy
« Reply #41 on: Sat, 07 October 2017, 21:57:51 »
I am leaning towards the type-S, I will most likely keep it stock if I do go for one, most I'll do is cut some dampening foam for the case and the rubber feet mod.
If anyone here has experience with the Type-S and Dentalbanded/modded Pro 2, I would appreciate it if someone shares their thoughts! Thank you~ :thumb:
Offline kmba
  • Formerly tameone
« Reply #42 on: Sat, 07 October 2017, 22:03:34 »
Dental bands are way too thick.  Hyperspheres are a bit too thick and also reduce tactility. Kdbfans rings are the thinnest.
keyboards.
Offline Duckyreddy
« Reply #43 on: Sat, 07 October 2017, 22:11:10 »
I've heard "hypersphere" quite a lot, the price for a set of 63 is around $80 shipped to my house, for that cost would I be better off getting a Type-S?
What do you use on your Topres?  ;D
Thanks for the quick explanation too  :thumb:
Offline jerue
« Reply #44 on: Sat, 07 October 2017, 22:25:29 »
If you're just going to silence a regular HHKB anyways, get a stock HHKB BT (or a Pro 2 if you want to save $), then take the savings and hunt for some Realforce purple sliders.  Otherwise just get Type-S, break it in for a month or so, then use lube on the sliders/housing if you want. It will feel almost as good with much less effort.
Offline Duckyreddy
« Reply #45 on: Sat, 07 October 2017, 22:33:09 »
Wise... Seems like the smartest thing to do, If I do in fact go with a stock Pro 2, I can then use that money for a Hasu controller and even Purple sliders as you mentioned, I've been told to lube purple sliders but I will try stock and make changes as I go along the way.
Or just go type-S hehe, then lube later.
Offline Hordak
« Reply #46 on: Sun, 08 October 2017, 00:08:08 »
I have hypersphered my HHKB and didn't like the outcome. You loose too much key travel, makes it feel weird. I also have the kdbfans rings here, but unfortunately did not get around to installing them yet.
Lubing makes the keyboard a bit quieter too and on top feel much smoother. My lubed, hypersphered Pro 2 is quieter than my Type-S.
Offline Duckyreddy
« Reply #47 on: Sun, 08 October 2017, 00:14:01 »
If you do get around installing the KBDfans rings, please share with us!  :thumb:
I don't want to lube straight away, perhaps I could let the board run in for a month or two and decide if I like the feel then decide...
I have no experience in Lubing Topre, What lube have you used? Thin or Thick? I heard really thick lube can ruin the feel by a quite a bit.
Thankss  :)
Offline Hordak
« Reply #48 on: Sun, 08 October 2017, 00:49:13 »
Sure I'll share. It might just take a while till I find motivation to deal with the mess that will be removing the silencing rings of lubed hhkb.
If you're new to HHKB/Topre, you'll be good. I typed on my Type-S for three years before lubing, so that should tell you how good it is stock. And I used it all day at the office. It's just that I got a bit bored of it lately, so I wanted to try something new. I also got Realforce 45/55g ;)
For the lubricant I used Krytox GPL 205, which is rather thick. It does not feel like I lost anything, but I have no comparison to other lubes. One downside is that the lube will slowly drip down onto the domes, so it's a bit messy and will require more care. The best lube is supposed to be a mix that was found my mkawa. You can get it here.
Offline Duckyreddy
« Reply #49 on: Sun, 08 October 2017, 01:01:45 »
That's great to know that you find the stock Type-S stock, Thank you for linking the Lube, I will definitely have a look around and when it's time to lube, I definitely will do it!  :D
