Author Topic: [IC] The DO60 PCB - update 2018 Jan 23  (Read 67746 times)
Offline pomk
Re: [IC] The DO60 PCB - update 2017 DEC 11
« Reply #100 on: Thu, 28 December 2017, 18:36:50 »
Did you measure it?
It fits tight on a 1.6mm pcb. No rattle.
Offline cdn-mini
« Reply #101 on: Thu, 28 December 2017, 18:45:18 »
GEEZUS why dont you two exchange numbers and talk? Get off the IC!
Offline duynguyenle
  • Personal text? What personal text???
« Reply #102 on: Thu, 28 December 2017, 19:30:14 »
Did you measure it?
Measuring is irrelevant, here's the official spec sheet: http://switches-sensors.zf.com/wp-content/uploads/2012/07/Keymodule_MX_EN.pdf
The stabiliser expects a 1.5mm PCB with a bilateral tolerance band of 0.14mm either way. Maximum expected PCB thickness is 1.64mm
For what it's worth, the samples I have on hand have 1.67mm clearance between the bottom face of the stabiliser body and the clip retention. This really isn't going to fit anything thicker than Cherry spec. If the Uniqey keyboard has PCB any thicker, they are either milling slots down to specified thickness at the clip locations or are using non-standard stabilisers.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Giorgio
« Reply #103 on: Fri, 29 December 2017, 08:47:28 »
It's not irrelevant.
Offline duynguyenle
« Reply #104 on: Fri, 29 December 2017, 10:24:55 »
Make it to spec or stabilisers won't fit. Is that irrelevant or are you just thick? (pun not intended)
Offline merlin64
    • MechMerlin
« Reply #105 on: Tue, 02 January 2018, 23:20:52 »
Where is this PCB actually manufactured? China or Taiwan?
Offline Ponkan
« Reply #106 on: Thu, 04 January 2018, 20:25:14 »
Any updates?
Offline sennin32
    • Doyu Studio
« Reply #107 on: Thu, 04 January 2018, 20:31:27 »
China.
Any updates?
Modified sample will finish today.
We ordered some black this time.
Offline sennin32
    • Doyu Studio
« Reply #108 on: Mon, 08 January 2018, 05:40:48 »
Sample delayed T_T
Offline Ponkan
« Reply #109 on: Tue, 09 January 2018, 00:53:57 »
Sample delayed T_T
Q.Q
I'm excited for the GB tho! Gotta make myself, my bro and my friends some keebs
Offline sennin32
    • Doyu Studio
« Reply #110 on: Tue, 09 January 2018, 01:27:51 »
Sample delayed T_T
Q.Q
I think just few days delay haha
Offline madn3ss795
« Reply #111 on: Tue, 09 January 2018, 03:58:01 »
Will you guys supply 3u stab wire too?
Offline sennin32
    • Doyu Studio
« Reply #112 on: Tue, 09 January 2018, 04:14:43 »
Sure
Offline Giorgio
« Reply #113 on: Tue, 09 January 2018, 07:44:35 »
Sure
Did you contact GMK about manufacturing 3u spacebars? Thanks
Offline iFreilicht
« Reply #114 on: Tue, 09 January 2018, 11:47:38 »
In case that's not happening, you can get good 3u PBT spacebars on Aliexpress that are easy to dye and apparently fit the GMK profile perfectly.
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
Offline Giorgio
« Reply #115 on: Tue, 09 January 2018, 12:08:54 »
Thank you :-)
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #116 on: Tue, 09 January 2018, 13:51:16 »
Thank you :-)
Vincent who runs the store in that link also has light and darker gray 3u spacebars as well.
I've already bought 2 of each of those colours already.
Enjoypbt also make 3u spacebars for those who want an exact colour match with their sets.
« Last Edit: Tue, 09 January 2018, 13:57:36 by gok101 »
Offline FailureToLoad
« Reply #117 on: Wed, 10 January 2018, 07:52:55 »
Does Enjoypbt have a storefront or site anywhere? I only ever see their products hosted/sold by other stores.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #118 on: Wed, 10 January 2018, 13:18:22 »
I don't think so. I contacted KBDfans about it and they support it through sets like this: https://kbdfans.cn/products/pre-orderenjoypbt-black-japanese-dye-sub-keycaps
I've also asked them for an additional 3u spacebar so that I can use it with this PCB/ 60% case by Doyu Studio.
Offline unluckygamer
« Reply #119 on: Fri, 12 January 2018, 02:03:43 »
Would this pcb support holtites?
Offline jmdaly
« Reply #120 on: Fri, 19 January 2018, 14:44:42 »
Looks really nice! Will the PCB work in a USB-C to USB-C configuration, as on new MacBooks, without the need for a USB OTG adapter?
Offline Ponkan
« Reply #121 on: Mon, 22 January 2018, 14:38:41 »
Any news?
Offline ZayaCaps
    • Instagram
« Reply #122 on: Mon, 22 January 2018, 23:07:15 »
Definitely interested in this PCB. Can't wait to hear more about it.
Offline sennin32
    • Doyu Studio
« Reply #123 on: Tue, 23 January 2018, 03:40:30 »
GB launched!
Geekhack link : (Waiting for approve)https://geekhack.org/index.php?topic=93685.0
GB Link : https://shopkey.doyustudio.com/001pcb60s
Offline bluesclera
Re: [IC] The DO60 PCB - update 2018 Jan 23
« Reply #124 on: Tue, 23 January 2018, 03:59:38 »
what plate option do i select for this layout?
Offline sennin32
    • Doyu Studio
« Reply #125 on: Tue, 23 January 2018, 08:02:29 »
For some position, it might not a good idea cause the pad will be cut.
But basicaly, it is okay.
Offline sennin32
    • Doyu Studio
« Reply #126 on: Tue, 23 January 2018, 08:04:08 »
I think those adapters is just change theUSB type.
It should support, but I didn't try it since there's too few computer has it.
Offline sennin32
    • Doyu Studio
« Reply #127 on: Tue, 23 January 2018, 08:05:16 »
ANSI & ISO w/ Arrow : https://goo.gl/RGCTYW
Offline bluesclera
« Reply #128 on: Tue, 23 January 2018, 08:08:53 »
That gives me the split Backspace & split Left Shift?
Offline cdn-mini
« Reply #129 on: Tue, 23 January 2018, 08:11:47 »
Nevermind....didnt scroll down.
« Last Edit: Tue, 23 January 2018, 08:14:45 by cdn-mini »
Offline kiettv12
« Reply #130 on: Tue, 23 January 2018, 09:55:48 »
with usb c
all i need is a single cable if i use this with macbook pro 2016?
Offline dr-slump
« Reply #131 on: Tue, 23 January 2018, 10:26:11 »
I'd prefer your photoshopped layout with the 1U LSHIFT over the 1.25u LSHIFT. That means 15 1U keys in the second row. :thumb:
Hope it'll be available that way!
Waiting for GMK Miami Dolch ISO . . .
Looking for: Titainium Spacebar 6.25
Offline sennin32
    • Doyu Studio
« Reply #132 on: Tue, 23 January 2018, 13:48:57 »
Sure, check this one : Shifted ZXCVB Universal ANSI : https://goo.gl/57AkTc (PCB stabs)
Offline sennin32
    • Doyu Studio
« Reply #133 on: Tue, 23 January 2018, 13:50:55 »
with usb c
I never tried cause my mac is old ver, but I think yes, adapters just change the type of USB!
Offline jmdaly
« Reply #134 on: Tue, 23 January 2018, 17:42:14 »
with usb c
For a USB type C device, it must be explicitly designed so that it supports direct USB-C to USB-C connections. In particular, the correct arrangement of pull up and pull down resistors must be in place so that a device functions in this configuration. See the following document: http://www.ti.com/lit/wp/slly017/slly017.pdf
From that document: "Noticeably absent from the USB Type-C receptacle is the ID pin. The determination of host or peripheral functionality is handled differently in Type-C. Here, the host or peripheral detection is done through monitoring channel configuration (CC) pins (CC1/CC2) while toggling at a specific interval between a pull-up resistor and pull-down resistor. Depending on the voltage level detected on the CC pins after a defined de-bounce time, the device becomes either a host or a peripheral."
I'm curious to know if the DO60 is designed with the correct pull up/down resistors to determine that it will be a peripheral in a USB-C to USB-C configuration?
Offline Unforgivable
« Reply #135 on: Tue, 23 January 2018, 19:54:31 »
Hi guys!
We're  we're Doyu Studio and I'm sennin32.
We're too busy to launch this project this year although we've already edited it.
Support layouts : http://www.keyboard-layout-editor.com/#/gists/a1bef8bf2784f5d009c96665a19bfc5e
Update 2018 Jan 23 :
GB Launched!
Pic of prototyping :
More pics : https://imgur.com/a/Rb8hf
end of Update 2018 Jan 23 :
Update 2017 DEC 11 :
We found ws2812b is too sensitive to temperature.
First sampling is using normal setting while smt processing.
Makes the failure rate too high.
We're going to make second batch and change the setting.
end of Update 2017 DEC 11 :
Do your own GH60 now! if you never have one before.
IC Link : https://goo.gl/forms/yZyEVn9wiEkqli392
This will be the layout support by final design
We'll also make aluminum plate with anodized.
Makes your project colorful.
Features:
1. Available for standard arrows
2. Keep Shift on the right hand
3. Won't change alpha layout
4. USB Type C
5. RGB underglow LEDs presoldered
6. Both work with ANSI and ISO
7. Switches light support
8. Gold plated soldering pads
9. Split spacebar, support both Filco type 3u Spacebar and 2.75u Keycap
10. SMD parts pre-soldered
11. 3u sacebar*2, use them evenly.
12. QMK ready
13. alpha shifted support
Processing:
Plate Prototyping Processing
add one more extra keys on the right of sapce bar, let 6.25u with arrow
PCB Prototyping Finished, https://geekhack.org/index.php?topic=91773.msg2531169#msg2531169
Manufacturer Plate
Manufacturer PCB
Case design Check it out here : https://geekhack.org/index.php?topic=92790.0
About manufacturing:
Takes around 2 months to manufacture
Pricing:
PCB : $30 Looking for higher quantity, and make the price as low as $25
Plate : $17 each Hope we can do it with only $12 after higher quantity
Stabilizer : $6 each for 7*2u and 1*6.25u
Not sure if I missed it, but how is the PCB programmed?
I would’ve liked the screw hole areas as an oval shape instead of circles, as some cases are a bit funky with placement (Like the Tina with the older Bfake PCB’s).
Anyway, great price I will probably join.  :thumb:
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #136 on: Tue, 23 January 2018, 20:15:40 »
Hi guys!
GB Launched!
Features:
4. USB Type C
12. QMK ready
Processing:
Manufacturer Plate
Manufacturer PCB
Pricing:
It will run QMK. Regarding the screw holes, from Doyu's GB page, it has been stated that they will do exactly this!
« Reply #137 on: Tue, 23 January 2018, 21:32:13 »
Hi guys!
GB Launched!
Features:
4. USB Type C
12. QMK ready
Processing:
Manufacturer Plate
Manufacturer PCB
Pricing:
Sweet! Thank you so much for the info!!
Offline sennin32
    • Doyu Studio
« Reply #138 on: Tue, 23 January 2018, 22:04:52 »
with usb c
Hi,
The schematic is unconnected for cc pins.
Cause 32u4 support only usb2.0.
The features in 3.1 is not useful for the chip right now.
Why usb-c?
It will become more popular in the future.
If we change the chip for supporting more features in the future, it might become useful.
And most important!! It doesn't care direction, you will use it without annoying while plug it.
Offline sennin32
    • Doyu Studio
« Reply #139 on: Tue, 23 January 2018, 22:17:32 »
QMK for now.
And we're working on how to program qmk without any command line.
The screw hole is what we're going to change.
We found the issue you mentioned as well.
Some cases is not able to use for circles drill.
Offline dr-slump
« Reply #140 on: Wed, 24 January 2018, 10:54:38 »
with usb c
Thank you for the fast response. I'll get the Shifted ZXCVB ISO.  :thumb:
Cheers!
Offline jmdaly
« Reply #141 on: Wed, 24 January 2018, 13:38:39 »
Hi,
Why usb-c?
Thank you for your thorough reply, and letting me know about the schematic, I really appreciate it. I agree, it's awesome to see more PCBs with USB-C, and I'm glad you are using it.
Unfortunately, even though it's a USB 2.0 device, if the CC pins are floating, I don't believe it will work in a direct USB-C to USB-C configuration (i.e. you would need a USB-C to USB-A cable, then an OTG adapter with USB-A female on the computer with the USB-C port). Even thought it's USB2.0, the CC pins need pull-down resistors to allow USB-C to USB-C connections. It would be really cool to see this, maybe in a rev. 2 of the board!
Offline sennin32
    • Doyu Studio
« Reply #142 on: Tue, 30 January 2018, 07:45:57 »
Hi,
Why usb-c?
I'm checking this these days.
If cc pins have to connect to GND with pull down resistors.
We'll modify it this time.
Offline jmdaly
« Reply #143 on: Wed, 31 January 2018, 08:28:15 »
Thanks for looking into this! I'm looking forward to hearing about your findings.
Offline jmdaly
« Reply #144 on: Wed, 31 January 2018, 09:48:16 »
Just to add some info, the following application note might be helpful. I know it deals with a different microcontroller, but it describes in general what is required for a legacy USB device in terms of the resistors on the CC lines when using a USB Type-C connector. In particular, there's a schematic on pg. 16 that might help.
http://www.st.com/resource/en/application_note/dm00235987.pdf
« Reply #145 on: Thu, 08 February 2018, 04:16:33 »
I see that there is a header in the middle of the keyboard. Is that something that I could use for maybe adding extra keys or LEDs?
« Last Edit: Thu, 08 February 2018, 04:33:00 by Findecanor »
Offline sennin32
    • Doyu Studio
« Reply #146 on: Thu, 08 February 2018, 06:32:36 »
No,
It is for testing.
We'll remove it :)
« Reply #147 on: Thu, 08 February 2018, 09:16:46 »
No,
It is for testing.
Ah. Nah, well. That's what I thought anyway. Thanks for answering.
« Reply #148 on: Thu, 08 February 2018, 12:03:55 »
Whoops, wrong thread!
« Last Edit: Thu, 08 February 2018, 12:14:06 by Unforgivable »
Offline sennin32
    • Doyu Studio
« Reply #149 on: Mon, 12 February 2018, 00:24:18 »
Hi,
Thank you, we've solve the issue by add resistors.
And it works with nex Mac pro type-c now.
