Author Topic: [IC] The DO60 PCB - update 2018 Jan 23  (Read 67749 times)
Offline jmdaly
Re: [IC] The DO60 PCB - update 2018 Jan 23
« Reply #150 on: Mon, 12 February 2018, 08:03:28 »
Hi,
Thank you, we've solve the issue by add resistors.
And it works with nex Mac pro type-c now.
Great! I'm really glad to hear that. Thank you for doing the work to ensure it's compatible in a USB-C to USB-C configuration. I think that really adds a lot of value to your PCB. Really looking forward to getting my DO60s :)
Offline merlin64
    • MechMerlin
« Reply #151 on: Mon, 12 February 2018, 09:30:15 »
I'm checking this these days.
If cc pins have to connect to GND with pull down resistors.
We'll modify it this time.
Thanks for looking into this! I'm looking forward to hearing about your findings.
This is good work here. Thank you sennin.
Just to add some info, the following application note might be helpful. I know it deals with a different microcontroller, but it describes in general what is required for a legacy USB device in terms of the resistors on the CC lines when using a USB Type-C connector. In particular, there's a schematic on pg. 16 that might help.
http://www.st.com/resource/en/application_note/dm00235987.pdf
Hi,
Offline Tobai
« Reply #152 on: Wed, 28 February 2018, 04:21:09 »
Is 1.5--1--1.5--3--3--1.5--1--1--1.5 supported?
The link with all supported layouts says it is, but looking at the photo of the PCB, I can't spot the corresponding switch / stabilizer holes.
Offline sennin32
    • Doyu Studio
« Reply #153 on: Wed, 28 February 2018, 22:32:20 »
cause it will happen after v0.2.8.
Does not offer in 0.2.7
Offline gok_nz
  • Enjoy your PBT
    • Website
Re: [IC] The DO60 PCB - update 2017 DEC 11
« Reply #154 on: Fri, 02 March 2018, 11:53:29 »
Did you measure it?
If it is too long, the stabiliser will rattle because there would be too much free space so it wouldnt be able to accommodate thick and thin pcb at the same time. I can imagine screw in stabs working though.
Offline bepbeplettuc
« Reply #155 on: Sat, 17 March 2018, 11:20:14 »
I bought one about 2 weeks ago and am super excited for it!
When will the PCB ship, though?
Offline bluesclera
« Reply #156 on: Sat, 17 March 2018, 11:40:54 »
I think its been more than 2weeks.
Offline Liam
« Reply #157 on: Sun, 18 March 2018, 17:56:45 »
This is from Discord: "We found manufacturer modify our file manually, and that makes 2 component inverse. That causes light problem, we’ve ask them to process exactly as our pos file"
IBM Model M - Leopold 750r - Custom Numpad
Offline bluesclera
« Reply #158 on: Sun, 18 March 2018, 17:59:05 »
Thanks for the update.
Offline sennin32
    • Doyu Studio
« Reply #159 on: Mon, 19 March 2018, 10:40:06 »
Damn,
They ask for extra charge for new sample even the issue is because of them  >:D
Offline _ODIN_
« Reply #160 on: Sat, 26 May 2018, 06:44:31 »
will you make a rerun?
Offline thread
« Reply #161 on: Sun, 03 June 2018, 19:03:21 »
Yes, please. I need me some, too. Especially if that USB C to USB C works!
Offline sennin32
    • Doyu Studio
« Reply #162 on: Sun, 15 July 2018, 05:57:37 »
Hi,
Guys we've sent all the orders except 3.
They didn't reply me about the color issue (We miscalculate the color, so black one is not enough :confused:)
If you guys haven't received your pcb, please tell me :)
Offline duynguyenle
  • Personal text? What personal text???
« Reply #163 on: Sun, 15 July 2018, 19:03:42 »
Hi,
Can confirm I have received mine about a week ago.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline dr-slump
« Reply #164 on: Mon, 16 July 2018, 11:52:22 »
I didn't receive mine yet (2 PCBs & 2 universal shifted ZXCVB ISO plates in grey) nor did I get a shipping notification
Order # 000002148
Waiting for GMK Miami Dolch ISO . . .
Looking for: Titainium Spacebar 6.25
Offline sennin32
    • Doyu Studio
« Reply #165 on: Sat, 15 September 2018, 06:20:37 »
Hi,
The Group has ended several months ago.
We got some extra PCBs.
If you missed this groupbuy but still want to get one.
Check it here : https://shopkey.doyustudio.com/001pcb60
