Author Topic: [GB] DO60 60% PCB RGB Underglow w/ Split Spacebar & Arrows  (Read 39447 times)
Offline sennin32
    • Doyu Studio
« on: Tue, 23 January 2018, 03:29:28 »
GB link : https://shopkey.doyustudio.com/001pcb60s
FAQs : https://geekhack.org/index.php?topic=93685.msg2552722#msg2552722
We also provide other options, ie. keycap, switches, plate...etc.
This GB will end on Feb 04, 2018
All item will ship around Mid March, 2018.
Features:
  • Available for standard arrows
  • Keep Shift on the right hand
  • Standard Alpha / Shifted Alpha
  • USB Type C
  • 20 RGB underglow LEDs presoldered
  • Both work with ANSI and ISO
  • Switches light support
  • Gold plated soldering pads
  • Split spacebar, support both Filco type 3u Spacebar and 2.75u Keycap
  • SMD parts pre-soldered
  • 3u spacebar*2, use them evenly.
  • QMK ready
  • All switch LEDs with same direction, more even light
« Last Edit: Thu, 25 January 2018, 21:42:02 by sennin32 »
Offline Photoelectric
Re: [GB] DO60 60% PCB RGB Underglow w/ Split Spacebar & Arrows
« Reply #1 on: Wed, 24 January 2018, 21:11:49 »
Approval bump.  As always, Caveat Emptor.
Offline wixxzblu
« Reply #2 on: Wed, 24 January 2018, 23:01:14 »
What is the shipping to EU?
Offline LifeZ
  • LifeZone
« Reply #3 on: Wed, 24 January 2018, 23:58:03 »
Im in. and 4order(2bk, 2wk and s/w)
Thanks
LZ Limited
Offline sennin32
    • Doyu Studio
« Reply #4 on: Thu, 25 January 2018, 00:12:28 »
Around 6~8
You can check it by add it into cart, and it will shows up before check out :)
Offline quaddepos
« Reply #5 on: Thu, 25 January 2018, 05:55:51 »
Does it support holtites? If so which ones?
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #6 on: Thu, 25 January 2018, 06:03:37 »
This is tempting =).
I already have a Southpaw 65 project on the way. Dare I start a 60% too? ;P
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline sennin32
    • Doyu Studio
« Reply #8 on: Thu, 25 January 2018, 21:41:24 »
FAQs :
Which plate fit my layout? PCB or plate mount?
Default Layout : https://goo.gl/hctK64  (Plate stabs)
ANSI & ISO w/ Arrow : https://goo.gl/RGCTYW (PCB stabs)
Universal ANSI : https://goo.gl/yLtRxF (PCB stabs)
Universal ANSI & ISO : https://goo.gl/VjNXUB (PCB stabs)
Shifted ZXCVB Universal ANSI : https://goo.gl/57AkTc (PCB stabs)
Shifted ZXCVB Universal ANSI & ISO : https://goo.gl/TzVWFH (PCB stabs)
Holtites
https://www.reddit.com/r/MechanicalKeyboards/comments/7seqfj/gb_do60_pcb_for_60_rgb_underglow_mechanical/dt466fh/
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #9 on: Fri, 26 January 2018, 09:14:02 »
Is there a carbon fiber plate option for split spacebar available here or in existence period?
Offline sennin32
    • Doyu Studio
« Reply #10 on: Fri, 26 January 2018, 12:44:23 »
For now, we don't have it, but maybe in the future if many people want it.
Offline wixxzblu
« Reply #11 on: Fri, 26 January 2018, 14:21:54 »
It would be much more awesome of you to release FR4 and/or polycarb plate.
Offline Oscarv77
« Reply #12 on: Sat, 27 January 2018, 00:08:26 »
What about the case? Will it fit a standard 60% USB type C case?
Offline sennin32
    • Doyu Studio
« Reply #13 on: Sat, 27 January 2018, 14:01:56 »
I think it is rare for 60% case on market support only type-c.
Most of them are universal @@
« Reply #14 on: Sat, 27 January 2018, 14:06:24 »
Most are mini-B. Type C is wider than mini-B and therefore there aren't many cases that actually support it.
If the USB port is in the standard configuration, it should work with any type-c compatible case.
Offline LifeZ
  • LifeZone
« Reply #15 on: Sun, 28 January 2018, 20:13:57 »
I sent email. plz, check.
LZ Limited
Offline sennin32
    • Doyu Studio
« Reply #16 on: Mon, 29 January 2018, 11:20:57 »
Offline iFreilicht
« Reply #17 on: Tue, 30 January 2018, 06:09:57 »
There were pictures in the IC. The C-Plug just about fits into a regular case, it's very close though.
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
Offline sennin32
    • Doyu Studio
« Reply #18 on: Tue, 30 January 2018, 07:52:07 »
Yup.
Most of cases' cut out of port is not fit mini port perfectly.
So it should fit for most cases.
But there's some cases are design for only mini port.
Offline Theconejo
« Reply #19 on: Tue, 30 January 2018, 10:38:48 »
Any pictures of the brass plate that could be added on with the pcb?
Offline stryker09
« Reply #20 on: Wed, 31 January 2018, 10:16:23 »
Signed up to say that I signed up for the case IC and will be taking the plunge on this shortly!
Great work on the pricing that includes the top plate too. Will this be making it to retail on your store eventually?
Offline iFreilicht
« Reply #21 on: Wed, 31 January 2018, 16:50:46 »
Just bought my stuff, super excited to see this happening!
Offline stryker09
« Reply #22 on: Wed, 31 January 2018, 21:30:36 »
will there be an option to get a pcb without the website link? i think it looks really clean without it, at least shrink the link to a corner or somewhere less distracting?
Offline Ponkan
« Reply #23 on: Sat, 03 February 2018, 20:59:55 »
Hi, I'm still waiting for the refund on my order so that I can buy 3 pcbs instead.
Offline wixxzblu
« Reply #24 on: Sun, 04 February 2018, 00:37:21 »
i would like to see a GB extensio since everybody is still waiting for refunds before buying more pcbs.
Offline sennin32
    • Doyu Studio
« Reply #25 on: Sun, 04 February 2018, 07:43:20 »
Hi, do you have order number?
We’ll cancel old order and you can buy again.
Offline Visionaire
« Reply #26 on: Sun, 04 February 2018, 12:12:33 »
Can you get this PCB as an add-on for the 60% case you're doing IC for now as well, or do you only get it from this GB?
Offline Visionaire
« Reply #27 on: Sun, 04 February 2018, 17:28:00 »
Ordered 2!
Offline nzhoward
« Reply #28 on: Tue, 06 February 2018, 08:20:17 »
I emailed with a question a few days ago. Can you take a look please?
Offline sennin32
    • Doyu Studio
« Reply #29 on: Tue, 06 February 2018, 09:15:37 »
I think I just read and replied all the mails during weekend couple hours ago.
Could you send pm with your mail address?
Let me check for you.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #30 on: Tue, 06 February 2018, 22:37:55 »
The GB page you link to gives a 404 error.
Offline sennin32
    • Doyu Studio
« Reply #31 on: Tue, 06 February 2018, 22:41:19 »
Hi, this groupbuy ended this week :)
Offline Bizpit
« Reply #32 on: Thu, 08 February 2018, 17:37:26 »
 :D
« Last Edit: Fri, 09 February 2018, 16:11:22 by Bizpit »
Offline sennin32
    • Doyu Studio
« Reply #33 on: Thu, 22 February 2018, 23:29:30 »
Hi,
Everybody, thank you for join this group buy.
Lunar new year vacation just end this week and we're back.
As we discussed in IC thread (https://geekhack.org/index.php?topic=91773), we spotted a issue with type c device connection.
Which is not able to be recognized directly by a device w/ native USB type C port.
Thanks jmdaly (https://geekhack.org/index.php?action=profile;u=57757) for helping us to find issues on our board.
We've solved it before vacation, but we have to make one more prototype and make sure the board work great.
It is going have 2 weeks delay.
We're really sorry for that, but we hope we can bring people the best items!
Offline mdaly001
« Reply #34 on: Fri, 23 February 2018, 01:06:02 »
Hi,
I screwed up by not ordering a plate. Any chance it's still possible to order a plate?
Sent from my ONEPLUS A5010 using Tapatalk
Offline jmdaly
« Reply #35 on: Fri, 23 February 2018, 09:26:57 »
I'm glad to help and really appreciate you guys making the effort to resolve the issue! Really looking forward to doing some builds with these PCBs :)
Offline iFreilicht
« Reply #36 on: Fri, 16 March 2018, 12:17:18 »
How's the new prototype looking?
Offline Ponkan
« Reply #37 on: Sun, 18 March 2018, 19:19:09 »
Any updates? Also, can I add a bunch of MX Clears to my order and ship it together w/ the pcbs?
Offline sennin32
    • Doyu Studio
Offline d.caminero
« Reply #39 on: Thu, 05 April 2018, 10:27:30 »
Any update on the GB status?  :)
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #40 on: Fri, 13 April 2018, 15:05:18 »
Still wondering the same...
Offline DubbleYew
« Reply #41 on: Sat, 14 April 2018, 11:26:10 »
I think we should get an update considering we were originally told it would ship out in the middle of March. We are well over the 2 week delay given in the last update.
Sent from my SM-G955F using Tapatalk
Offline Ponkan
« Reply #42 on: Tue, 17 April 2018, 03:00:24 »
Any updates?
Offline d.caminero
« Reply #43 on: Wed, 18 April 2018, 03:33:29 »
I PM'd the runner shortly after my comment and they told me this:
We received the PCB, but the led is wrong.
That makes lot of led fail.
We've send back and ask manufacturer to process it again.
I guess we will have to wait a bit more.
Offline Helldrop
« Reply #44 on: Fri, 20 April 2018, 13:39:40 »
April is coming to an end, I think the runner must appear on this stage.
Offline sennin32
    • Doyu Studio
« Reply #45 on: Sun, 22 April 2018, 09:14:33 »
Hi,
PCB manufacturer use wrong led brand.
And the temp is not correct, make lot of leds fail.
We've sent them back for replacement 2 weeks ago.
And it should already finished, manufacturer told us it will be sent around Apr 20th. we'll receive them in 1 week :)
Sorry for delay :(
Offline iPhantomMonkey
« Reply #46 on: Tue, 24 April 2018, 23:17:13 »
Thanks for the update. If you are able to answer, when do you think the PCBs might be shipped out to backers, as I might need to update my shipping address depending on the eta
Offline peggisan
« Reply #47 on: Tue, 24 April 2018, 23:19:40 »
Will there be any extras for sale after this concludes?
Offline sennin32
    • Doyu Studio
« Reply #48 on: Wed, 25 April 2018, 04:25:22 »
Hi,
I think we'll pack and ship most packs before May 5th.
But I don't know which shipping method you use.
Please send us message include your order#.
I'll tell you when it should arrive :)
Offline merlin64
    • MechMerlin
« Reply #49 on: Tue, 08 May 2018, 09:55:11 »
Are there any updates to this?
