Author Topic: [IC] The DO60 PCB - update 2018 Jan 23  (Read 67735 times)
Offline sennin32
    • Doyu Studio
« on: Wed, 27 September 2017, 20:56:15 »
Hi guys!
We're  we're Doyu Studio and I'm sennin32.
We're too busy to launch this project this year although we've already edited it.
Support layouts : http://www.keyboard-layout-editor.com/#/gists/a1bef8bf2784f5d009c96665a19bfc5e
Update 2018 Jan 23 :
GB Launched!
Geekhack link : https://geekhack.org/index.php?topic=93685.0
GB Link : https://shopkey.doyustudio.com/001pcb60s
Pic of prototyping :
More pics : https://imgur.com/a/Rb8hf
end of Update 2018 Jan 23 :
Update 2017 DEC 11 :
We found ws2812b is too sensitive to temperature.
First sampling is using normal setting while smt processing.
Makes the failure rate too high.
We're going to make second batch and change the setting.
end of Update 2017 DEC 11 :
Do your own GH60 now! if you never have one before.
IC Link : https://goo.gl/forms/yZyEVn9wiEkqli392
This will be the layout support by final design
We'll also make aluminum plate with anodized.
Makes your project colorful.
Features:
1. Available for standard arrows
2. Keep Shift on the right hand
3. Won't change alpha layout
4. USB Type C
5. RGB underglow LEDs presoldered
6. Both work with ANSI and ISO
7. Switches light support
8. Gold plated soldering pads
9. Split spacebar, support both Filco type 3u Spacebar and 2.75u Keycap
10. SMD parts pre-soldered
11. 3u sacebar*2, use them evenly.
12. QMK ready
13. alpha shifted support
Processing:
Plate Prototyping Processing
add one more extra keys on the right of sapce bar, let 6.25u with arrow
PCB Prototyping Finished, https://geekhack.org/index.php?topic=91773.msg2531169#msg2531169
Manufacturer Plate
Manufacturer PCB
Case design Check it out here : https://geekhack.org/index.php?topic=92790.0
About manufacturing:
Takes around 2 months to manufacture
Pricing:
PCB : $30 Looking for higher quantity, and make the price as low as $25
Plate : $17 each Hope we can do it with only $12 after higher quantity
Stabilizer : $6 each for 7*2u and 1*6.25u
« Last Edit: Thu, 25 January 2018, 21:25:54 by sennin32 »
Offline sennin32
    • Doyu Studio
Re: [IC] The DO60 PCB
« Reply #1 on: Wed, 27 September 2017, 20:56:53 »
Update :
2017 OCT 19th
We're modifying PCB for some layouts and RGB underglow.
And communication with parts suppliers/PCB manufacturer.
If we can reach 500 PCs at first batch.
Price might around $25.
Layout update : http://www.keyboard-layout-editor.com/#/gists/a1bef8bf2784f5d009c96665a19bfc5e
« Last Edit: Thu, 19 October 2017, 16:17:29 by sennin32 »
Offline sennin32
    • Doyu Studio
« Reply #2 on: Wed, 27 September 2017, 20:57:09 »
FAQ:
Is the stabilizer PCB or plate mounted?
PCB mounted.
It is limited due to support more layouts.
About Shipping
The PCB + plate +stabilizer is around 200g~300g
International shipping will be under $10 to world wide.
~$8 to USA, CA, Europe, South America
~$7 to Asia, AU
Steeped capslock
Yes, this board support steeped capslock
« Last Edit: Fri, 29 September 2017, 15:11:29 by sennin32 »
« Reply #3 on: Wed, 27 September 2017, 21:06:23 »
What makes this more special than any other 60% PCB?
« Reply #4 on: Wed, 27 September 2017, 21:07:10 »
The same thing that makes you special from any other person.
« Reply #5 on: Wed, 27 September 2017, 21:07:38 »
I'm ****ing dense, so I hope that's not what it is.
Offline FoC_Tow
  • Brokehlicious
« Reply #6 on: Wed, 27 September 2017, 21:12:09 »
Interested =)
Layout Support for once.
There aren't many 60 PCBs with arrow support ya know
Offline Zobeid Zuma
« Reply #7 on: Wed, 27 September 2017, 21:14:46 »
Split space bar is what caught my eye.  It's nice to see more PCBs turning up with support for that.
The layout options still seem awkward to me, though.  I'll be holding out for the next round of Banana Split 60.
Offline pixelpusher
« Reply #8 on: Wed, 27 September 2017, 21:16:47 »
Underglow and more split space support probably. Pretty good layout options for a low price
Offline sennin32
    • Doyu Studio
« Reply #9 on: Wed, 27 September 2017, 21:41:34 »
To keyboard geeks, it support more layout but with easy to find caps.
Makes it more easy to use for those who are not familiar with 60% keyboards.
To us, we are looking for better QA control.
Better packaging from manufacturer to us, better printing...etc.
We've tried to communicate with suppliers who offer us PCBs for passed few years.
The packaging is bad, QA pass rate is low, makes us spend too much time to fix those issues.
But nothing changes after communications.
Let's do it ourselves!
Offline pixelpusher
« Reply #10 on: Wed, 27 September 2017, 22:37:50 »
I filled out the form.  I'm down for 2 definitely.  Any idea on holtite support?
Offline sennin32
    • Doyu Studio
« Reply #11 on: Thu, 28 September 2017, 00:36:03 »
I'm not sure about holtite.
The hole size is from Cherry datasheet suggestion.
If the socket is design to fit Cherry standard, it will fit.
But I never try that before.
Offline Fausuto
« Reply #12 on: Thu, 28 September 2017, 01:19:00 »
Is the PCB going to be black and QMK support?
Offline Trousers
« Reply #13 on: Thu, 28 September 2017, 02:40:09 »
I'm pretty bad looking at these PCB's, but I assume you could do a layout with arrow keys and a regular 6.25 space bar? Just five 1u keys on the right.
Offline FoC_Tow
  • Brokehlicious
« Reply #14 on: Thu, 28 September 2017, 03:30:09 »
Looks to me like you can only go 7u space with 4 1u on the right, or split space if you want all se arrows =D
Offline excluisve
  • Making & Thinking.
« Reply #15 on: Thu, 28 September 2017, 05:22:35 »
It will have rgb led Underground ?
« Reply #16 on: Thu, 28 September 2017, 08:41:20 »
It does.
Offline kawasaki161
« Reply #17 on: Thu, 28 September 2017, 09:32:16 »
It does.
Are you sure? I don't see any 4-pad footprints for that in the picture.
Offline sennin32
    • Doyu Studio
« Reply #18 on: Thu, 28 September 2017, 10:11:26 »
For now.
We focus on TMK firmware, and I never study QMK.
If there's many people want QMK support.
We have to do some research.
Offline sennin32
    • Doyu Studio
« Reply #19 on: Thu, 28 September 2017, 10:14:55 »
Seems this will works.
Add one more key on the right of spacebar.
Offline sennin32
    • Doyu Studio
« Reply #20 on: Thu, 28 September 2017, 10:17:46 »
No,
For now, unless we make a brand new firmware.
Or it will be hard to do that.
Our next project will be a 60% Keyboard with full aluminum case and RGB LED.
Include custom firmware(Support windows only now)
Offline sennin32
    • Doyu Studio
« Reply #21 on: Thu, 28 September 2017, 10:18:46 »
It does.
It does.
No, doesn't support RGB :(
But you can chose color you prefer :)
Offline kawasaki161
« Reply #22 on: Thu, 28 September 2017, 10:34:04 »
For now.
QMK is an extension of TMK and uses the same core, if you know TMK it is really easy to add also support QMK (unless you have extensive custom code and non-standard hardware at least).
Offline sennin32
    • Doyu Studio
« Reply #23 on: Thu, 28 September 2017, 10:47:26 »
For now.
Yup,
I believe QMK add some more features.
And the setting file must have to support those features.
Offline FoC_Tow
  • Brokehlicious
« Reply #24 on: Thu, 28 September 2017, 19:32:21 »
If you examine the layout sheet, this will most definitely not work, sorry.
Only 7u and split space support with arrows.
Offline sennin32
    • Doyu Studio
« Reply #25 on: Thu, 28 September 2017, 22:17:56 »
Yes,
Have to add one more key position
Offline sennin32
    • Doyu Studio
« Reply #26 on: Thu, 28 September 2017, 23:00:22 »
Offline sennin32
    • Doyu Studio
« Reply #27 on: Sun, 01 October 2017, 11:55:13 »
There's another question added in to the checking form.
It is about do you use TKG as your main tool to flash your keyboard?
We're looking for some possibility to reduce the pricing.
The most possible way is to change MCU.
But TKG seems support only atmel AVR.
Means if we change it into ARM, the only way to flash it is compile it yourself.
Hope I can get some feedback!
Offline pixelpusher
« Reply #28 on: Sun, 01 October 2017, 14:21:43 »
For me that all depends on if you put a config for it here:
https://kbfirmware.com
I’m lazy :(
Offline mike873
« Reply #29 on: Tue, 10 October 2017, 19:33:08 »
Are there significant differences between this board and the DZ60 from KBDFans? I'm not criticizing, just curious.
Offline Zobeid Zuma
« Reply #30 on: Tue, 10 October 2017, 20:22:58 »
An obvious difference to me is that the bottom row layouts with split spacebar are different.  DZ60 supports the [2.25][1.25][2.75] or [2.75][1.25][2.25] split.
Offline DarKou
« Reply #31 on: Wed, 11 October 2017, 05:34:34 »
This PCB looks great but:
- No screw hole near the space bar (ATMega is on his way?)
- No right screw hole
I think this 2 "issues" will limit the cases choice.
Offline pixelpusher
« Reply #32 on: Wed, 11 October 2017, 08:36:42 »
I hadn’t noticed that.  You’re correct.  I would expect all 6 standard mounting holes.  I might be able to live without the bottom one, but we need thr one on the right for sure
Offline DarKou
« Reply #33 on: Wed, 11 October 2017, 09:00:57 »
I think the bottom will be a real problem if ATMega is crushed by the hole support of the case.
Offline sennin32
    • Doyu Studio
« Reply #34 on: Thu, 19 October 2017, 13:37:24 »
We remove one of screw hole from the PCB because of it is on the stab/switches' position.
I think that won't be a major issue for remove only one hole @@
Offline sennin32
    • Doyu Studio
Re: [IC] The DO60 PCB - update 2017 OCT 20
« Reply #35 on: Fri, 01 December 2017, 04:23:54 »
Update:
1st Prototyping finished, awaiting SMD processing
IC for Case design : https://geekhack.org/index.php?topic=92790.0
Offline Badwrench
  • ummmm.....I forgot
« Reply #36 on: Fri, 01 December 2017, 12:21:44 »
Update:
What is your target price range for the case/plate combo?
Offline madn3ss795
Re: [IC] The DO60 PCB - update 2017 DEC 1st
« Reply #37 on: Mon, 04 December 2017, 05:56:03 »
Very interested in the dual 3u spacebars layout, but I'm skeptical about the lack of 2 mounting holes ( bottom and right edge ).
Offline sennin32
    • Doyu Studio
« Reply #38 on: Mon, 04 December 2017, 23:46:54 »
Samples:
Offline pixelpusher
« Reply #39 on: Tue, 05 December 2017, 00:34:32 »
Samples:
Looks nice.  Is there any way you can get a full shot of the back.  The whole board
Offline sennin32
    • Doyu Studio
« Reply #40 on: Tue, 05 December 2017, 00:49:47 »
We’ll do it later.
Haven’t received it, I just ask Pcb manufacturer take some pic for me.
Offline pixelpusher
« Reply #41 on: Tue, 05 December 2017, 00:52:49 »
We’ll do it later.
Offline kiwi99
  • that's a gnarly dookie
« Reply #42 on: Wed, 06 December 2017, 20:14:02 »
Could you possibly support offset 6u spacebar?
Offline amnesia0287
  • Formerly Amnesia
« Reply #43 on: Thu, 07 December 2017, 00:53:39 »
Do you have any choice over soldermask color?
Offline sennin32
    • Doyu Studio
« Reply #44 on: Thu, 07 December 2017, 06:43:25 »
Only white now :(
It should support if you mean 6 units (114mm wide, 3 keymounts, 57mm and 38mm apart).
I'll test it again when 2nd sample arrive.
Offline sennin32
    • Doyu Studio
« Reply #45 on: Sat, 09 December 2017, 06:39:52 »
We haven't receive the sample yet.
But we've found some bugs/things want to change in first sample :
1. for shorter trackers, we put diode/LED in different direction, which is not a good idea for repairing and looks a little bad.
2. Move LED position to fit the MCU, more reasonable trackers.
3. put all screw holes back include the one near bottom.
4. One of tracker pass the logo on the mask layer, makes it explore
Offline sennin32
    • Doyu Studio
« Reply #46 on: Tue, 12 December 2017, 23:33:28 »
Samples:
updated in origin post.
Offline Applet
Re: [IC] The DO60 PCB - update 2017 DEC 11
« Reply #47 on: Wed, 13 December 2017, 03:09:40 »
Does it support 6u spacebar? :)
Offline sennin32
    • Doyu Studio
« Reply #48 on: Wed, 13 December 2017, 06:20:58 »
quick reply : yup it does.
complete : You might want to send layout, see if it support.
Offline pixelpusher
« Reply #49 on: Wed, 13 December 2017, 13:12:10 »
Is there a center screw hole?  I’m not seeing one.  Usually between the G and the H
Really like the options this pcb has.  Good work
« Last Edit: Wed, 13 December 2017, 13:14:22 by reececonrad »
