Author Topic: Quickfire Rapid plate  (Read 4990 times)
Offline MercenarySnake
« on: Tue, 07 November 2017, 00:49:47 »
I am looking for a plate compatible with a TKL Quickfire Rapid but it seems there isn't any options for that besides cutting out a plate but I'm not sure how to go about that. I did see that universal plate in another thread but I imagine that has long since passed.
Offline TalkingTree
    • My projects
Re: Quickfire Rapid plate
« Reply #3 on: Tue, 07 November 2017, 04:27:46 »
China is always your friend in that regard.
Is it a custom layout that you're after?
« Reply #4 on: Tue, 07 November 2017, 04:42:34 »
No just the standard layout it uses(of course my dream layout would be winkeyless). Would prefer an anodized aluminum plate.
« Last Edit: Tue, 07 November 2017, 04:44:25 by MercenarySnake »
Offline TalkingTree
    • My projects
« Reply #5 on: Tue, 07 November 2017, 05:05:52 »
Like so? Check if the PCB supports winkeyless layouts though.
* plates.zip
« Reply #6 on: Tue, 07 November 2017, 05:34:00 »
Here's what the back of the PCB looks like, I've never tried to create a winkeyless layout on a keyboard before so I'm not sure how I would go about doing it.
Offline TalkingTree
    • My projects
« Reply #7 on: Tue, 07 November 2017, 05:52:53 »
That's pretty much like the Filco Majestouch 2 PCB which, as far as I know, is universal for ANSI, ISO and JIS but won't support winkeyless layouts.
« Reply #8 on: Tue, 07 November 2017, 06:03:08 »
That sucks, looks like I would have to go with standard layout then. I don't know how to use one of those layout editors to make a spot for the controller above the arrow keys though.
Offline TalkingTree
    • My projects
« Reply #9 on: Tue, 07 November 2017, 07:51:09 »
Define your layout in the KLE, then paste the output from the raw tab in swill's builder and define the following polygons.
181750-0
Your plate will look like this.
* plate.svg (32.68 kB - downloaded 125 times.)
« Reply #10 on: Tue, 07 November 2017, 14:47:06 »
Thank you very much for helping me out with this(reddit wasn't much help when I was asking for help with this), so this should fit properly for my Quickfire Rapid? Also where would you recommend I get this cut?
Offline TalkingTree
    • My projects
« Reply #11 on: Tue, 07 November 2017, 15:00:04 »
I don't own a QFR so I can't be entirely sure, I just tried to make a clone of the universal phantom plate found on the deskthority wiki and added the controller cutout that your board needs. If you still own the original plate, I would recommend you visually inspect it to see if there is any notable difference.
I had mine laser cut in China at Hek's store out of steel and then painted them myself with a spray can. They do cut aluminum and I believe they can also anodize.
You can also see if there's any laser cutting workshop in your town.
« Reply #12 on: Tue, 07 November 2017, 17:01:45 »
I live in a small town so I doubt there's anybody here that could do that. As for the plate design, thanks to your help I was able to understand how to place polygons/shapes and was able to get it to look as similar to what my current plate looks like as possible. Here is what I came up with.
« Last Edit: Tue, 07 November 2017, 17:03:22 by MercenarySnake »
Offline TalkingTree
    • My projects
« Reply #13 on: Tue, 07 November 2017, 17:14:32 »
Widen then controller cutout a bit more on the right side, ideally its edge should be at the same distance of the switches'.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #14 on: Tue, 07 November 2017, 19:12:55 »
If you don't mind me asking, why are you getting a custom plate for a non custom board that doesn't support different layouts?
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
« Reply #15 on: Tue, 07 November 2017, 19:45:08 »
The plate didn't come in the best condition when I purchased it from someone.
Is this good?
« Last Edit: Tue, 07 November 2017, 19:49:15 by MercenarySnake »
Offline _haru
« Reply #16 on: Tue, 07 November 2017, 20:06:16 »
Oh I see. What switches are going in this board?
« Reply #17 on: Tue, 07 November 2017, 20:25:42 »
I plan on putting in the Kailh Box Navy switches once they are finally shipped out.
Offline _haru
« Reply #18 on: Tue, 07 November 2017, 21:56:57 »
Very nice :thumb:
Offline TalkingTree
    • My projects
« Reply #19 on: Wed, 08 November 2017, 03:05:22 »
Is this good?
It looks ok to me.
