Author Topic: [IC finished] TX60/TX65/TX84se  (Read 118373 times)
Offline Marutks
Re: [IC] TX60/TX65/TX84se
« Reply #50 on: Fri, 08 December 2017, 06:33:22 »
Jigon runs on windows only !   :eek: I am not allowed to use windows at work!     I am not going to buy a windows computer just to change keymap  :p
does this keyboard work in macos and linux?
« Last Edit: Fri, 08 December 2017, 07:09:48 by Marutks »
Offline kmba
  • Formerly tameone
« Reply #52 on: Fri, 08 December 2017, 08:28:33 »
any more pics?  side profile?  bottom?
any dimensions?  front lip height, angle, etc.  thanks
https://geekhack.org/index.php?topic=92437.0
Here is DanielT's review on the TX60
Thanks.  Height of the board is pretty tall IMO, but still definitely on my radar.
keyboards.
Offline Petch
« Reply #53 on: Fri, 08 December 2017, 08:37:07 »
Can probably get QMK running on it, it's been done for other jigon boards before
Offline heckenjoni
« Reply #54 on: Fri, 08 December 2017, 09:44:11 »
if i want to check for 1 tx84se in black do i check "0ea" or "1ea" ?
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #55 on: Fri, 08 December 2017, 09:47:52 »
Definitely in for the 84se. That weight is fantastic and I'm loving the no-lip this time :D
The TX84SE plate looks really similar to LZ CLS. Is it the same?
« Last Edit: Fri, 08 December 2017, 10:26:36 by zekkin »
Offline aznreaper
« Reply #56 on: Fri, 08 December 2017, 10:52:59 »
What colour is the green like? Would it be similar to the olive that you had for the TX1800 or a brighter one like the old tx84/87's?
Offline Jedi
« Reply #57 on: Fri, 08 December 2017, 11:08:16 »
IN!
Offline funderburker
« Reply #58 on: Fri, 08 December 2017, 12:07:45 »
Oh, that olive color would be crazy :)
Keyboard design by Skepur
Offline wholypantalones
  • text and icon mods plz.
« Reply #59 on: Fri, 08 December 2017, 12:27:50 »
Any chance on not having the logo on the front of the TX84se?
Offline derzemel
« Reply #60 on: Fri, 08 December 2017, 12:28:44 »
any chance for an ALPS/Cherry PCB with led support? I remember that Leeku used to make cherry/Alps PCBs
Offline Vadurr
  • Valar Morghulis
« Reply #61 on: Fri, 08 December 2017, 13:03:02 »
It is def on the taller side. I was thinking something closer to 21mm
Offline kmba
  • Formerly tameone
« Reply #62 on: Fri, 08 December 2017, 13:17:52 »
Looking at the pics again, the keycaps are inset pretty far and the bezel height is taller than most other boards.  So you can subtract a few mm to get a better idea of the switch height compared to other boards which just barely cover the bottom of gmk caps.
keyboards.
Offline nothingzzz
« Reply #63 on: Fri, 08 December 2017, 22:24:24 »
Definitely want the tx60 hhkb layout
Sent from my HTC One using Tapatalk
Offline DanielT
« Reply #64 on: Sat, 09 December 2017, 02:08:23 »
At least TX60 is compatible with any standard 60% PCB, there are plenty to chose from and some really cheap.
Aside from the programming software the keyboard works on any OS.
P.S: you don’t have to buy a computer just to have windows, I for example have a Virtualbox VM.
Offline DanielT
« Reply #65 on: Sat, 09 December 2017, 02:13:05 »
You are right, the bezel covers almost 2mm from the base of the caps. Anyway even if it seems high in reality due to the design and angle it feels very comfortable to type on. I have been using it constantly for the last 2 months and it’s just amazing.
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #66 on: Sat, 09 December 2017, 02:17:18 »
A little jealous dude.
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline DanielT
« Reply #67 on: Sat, 09 December 2017, 06:42:01 »
The ano shop was changed and now these are the available colors :
Offline duynguyenle
  • Personal text? What personal text???
« Reply #68 on: Sat, 09 December 2017, 11:37:51 »
Hello Kin, I filled out the IC form.
Can you elaborate more on the new design TX84? I want to know if plate/PCB from TX84v1 will be compatible with the new TX84se (i.e. if I already have a TX84 can I drop the old plate into the new case and have it be compatible?
Also, have you got any more pictures of the bottom? I would like to see different views from a few different angles looking at the new design TX84 weight plate.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline kin25
    • TXKeyboards
« Reply #69 on: Sat, 09 December 2017, 11:43:06 »
tx84se plate is different. it is top mounted plate.
Offline duynguyenle
« Reply #70 on: Sat, 09 December 2017, 12:22:13 »
I see! Would still be interested depending on how the bottom weight plate turns out. In my opinion simpler is better, so even just a flat polished brass weight without any fancy details is still fine by me!
Are there any plans for a non-blocked top plate (a la TX87se)?
Offline Blackhawk
« Reply #71 on: Sat, 09 December 2017, 12:31:43 »
For the 84se, will there be options for
a) switching to an aluminum plate?
b) buying without accessories at a lower price point (wrist rest, pen, bag etc.)?
Offline kin25
    • TXKeyboards
« Reply #72 on: Sat, 09 December 2017, 12:43:30 »
sorry. impossible
Offline derzemel
« Reply #73 on: Sat, 09 December 2017, 12:53:36 »
Any chance for ALPS support?
Sent from my LG-H815 using Tapatalk
Offline kin25
    • TXKeyboards
« Reply #74 on: Sat, 09 December 2017, 13:44:53 »
sorry.. No ALPS
Offline Ball-o-tron
Re: [IC, Finish] TX60/TX65/TX84se
« Reply #75 on: Sun, 10 December 2017, 18:13:51 »
Do you have any side profile photos of the 60%? It doesn't look the same as the rest of the boards from the top
Offline kin25
    • TXKeyboards
« Reply #76 on: Sun, 10 December 2017, 18:44:58 »
184084-0
184086-1
Offline Ball-o-tron
« Reply #77 on: Sun, 10 December 2017, 18:54:54 »
Nice, looks great!
Offline lanyusea
« Reply #78 on: Sun, 10 December 2017, 19:59:49 »
any plan to show the total order namelists for people to check their names?  :p :p :p
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline kin25
    • TXKeyboards
« Reply #79 on: Sun, 10 December 2017, 20:24:37 »
sorry, I have no plan.
Offline Vadurr
  • Valar Morghulis
« Reply #80 on: Sun, 10 December 2017, 22:32:58 »
So what are the official color choices we'll get to choose from?
Offline DanielT
« Reply #81 on: Sun, 10 December 2017, 22:52:43 »
You can find here https://geekhack.org/index.php?topic=92437.0 more photos and details.
If anyone wants some detailed photos or anything like that for TX60 please let me know  :thumb:
Offline Petch
« Reply #82 on: Mon, 11 December 2017, 03:30:26 »
I'd love to see a TX-CPv2 with this new style of TX housing  ;)
Offline kin25
    • TXKeyboards
« Reply #83 on: Mon, 11 December 2017, 03:41:56 »
Black
Silver
Dark grey
Bloody red
Deep blue
Olive
Champagne gold
Offline kin25
    • TXKeyboards
« Reply #84 on: Mon, 11 December 2017, 03:45:58 »
My friend BOK will start GB of new CP layout keyboard.
But it is different from txcp.
The plate is mounted on top case like LZ.cp
Bok.cp proto was made.
It is in the anodizing factory.
Offline amnesia0287
  • Formerly Amnesia
« Reply #85 on: Mon, 11 December 2017, 04:26:32 »
Black
Silver
Dark grey
Bloody red
Deep blue
Olive
Champagne gold
Deep Blue? Is it a dark blue? It looked on the light side in the photo.
Offline Marutks
« Reply #86 on: Mon, 11 December 2017, 05:41:14 »
I submitted the form !  :thumb:   I hope switches on TX65 PCB are south facing?  and split backspace is supported
Offline zekkin
« Reply #87 on: Mon, 11 December 2017, 08:51:26 »
i dont think kin has ever had a board with south facing LEDs so i think you're safe there  :thumb:
Offline Unforgivable
« Reply #88 on: Mon, 11 December 2017, 10:34:34 »
Black
Silver
Dark grey
Bloody red
Deep blue
Olive
Champagne gold
Yes! Another red! Awesome!
Offline kin25
    • TXKeyboards
Re: [IC, Opened again] TX60/TX65/TX84se
« Reply #89 on: Mon, 11 December 2017, 10:55:11 »
this pics are tx1800v2 red and blue.
tx60/tx65/tx84se will be same colors.
Offline aaron6301
  • Pixel Pusher
« Reply #90 on: Mon, 11 December 2017, 21:01:50 »
Interested in TX65  :thumb:
Offline energyd
« Reply #91 on: Mon, 11 December 2017, 22:30:26 »
any chance making a blue like this? It will look good with Yuri and Nautilus
https://imgur.com/a/2dTps
Offline stevenpa
« Reply #92 on: Tue, 12 December 2017, 00:06:52 »
Just to confirm HHKB top plate and regular top plate are interchangeable correct?
« Reply #93 on: Tue, 12 December 2017, 00:29:07 »
they're the same, yeah
Offline kuished
« Reply #94 on: Tue, 12 December 2017, 00:34:37 »
I would be interested in such a colour as well.
Offline amnesia0287
  • Formerly Amnesia
« Reply #95 on: Tue, 12 December 2017, 02:54:44 »
I would literally have no choice but to buy one. I don’t even know if I’d get it in 60 or 65. I’m scared I’d want both.
Would be nice for Yuri and Nautilus and maybe Dark Solarized.
Offline Marutks
« Reply #96 on: Tue, 12 December 2017, 05:01:58 »
TX65 seems to be great match for Nautilus keycaps.  On TX65 you can show off those 1.5u novelty keycaps.   :thumb:  I hope this GB starts soon !
« Last Edit: Tue, 12 December 2017, 06:14:38 by Marutks »
Offline Petch
« Reply #97 on: Tue, 12 December 2017, 09:41:28 »
Any chance of an 87 top for the TKL?
+1 for this blue https://imgur.com/a/2dTps
« Last Edit: Tue, 12 December 2017, 09:46:33 by Petch »
Offline kin25
    • TXKeyboards
« Reply #98 on: Tue, 12 December 2017, 10:00:12 »
Sorry. Tx84se is only 84 top.
Offline Ball-o-tron
« Reply #99 on: Tue, 12 December 2017, 10:10:11 »
Any photos of champaigne and silver side by side? I'm curious if they work well together =)
