Author Topic: What's the best mouse pad ever?  (Read 68098 times)
« on: Fri, 15 December 2017, 14:40:53 »
BEST MOUSE PAD?
Qualifiers are:
Mouse performance
Surface glide
Durability (will it fray or fall apart after a while?)
Ease of cleaning
Material
Style
« Last Edit: Wed, 20 June 2018, 02:52:33 by noisyturtle »
Offline anode
Re: WHAT IS BESTEST MOUSE PAD EVER?
« Reply #1 on: Fri, 15 December 2017, 15:12:36 »
I use a Glorious Extended from https://www.pcgamingrace.com
My G400S performs great on it. No tracking issues. It's an exceptionally smooth cloth pad, so it's more "speed" than "control" IMO. I bought it specifically because I can sit my keyboard on top of it, and because I wanted stitched edges since my last pad came unglued.
You can clean it with soap, water, and a brush. One thing to note is when I was cleaning it recently, I used way too stiff of a brush, and afterwards the surface was a bit rougher than before. Still plenty usable, just slightly different feeling now. My own fault probably. Also, the white version looks stunning but stains extremely quick. It's in my LAN bag but I would avoid it for daily use.
Alps good
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #2 on: Fri, 15 December 2017, 15:20:54 »
Depends if you want a hard plastic mat or if you want a soft mesh material. Hard plastic I think that steelseries 4HD is tied with Logitech G440 as the best ones. Pros with these are that they are very easy to clean and is a very good mouse pad if you like hard surface.
Otherwise if you want soft meshthere are many good alternatives. I use an xtrfy which I feel is really solid and looks to last for an eternity.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Fri, 15 December 2017, 20:06:44 »
I have been using this same RocketFish mouse "pad" for probably over 10 years:
Its aluminum, its so far been indestructible, and its smooth and accurate.
https://www.amazon.com/RocketfishTM-Gaming-Mouse-Pad-Black/dp/B001719CMI/ref=cm_cr_arp_d_product_top?ie=UTF8
« Last Edit: Sun, 17 December 2017, 00:43:33 by OfTheWild »
-Dana
Offline Leslieann
« Reply #4 on: Fri, 15 December 2017, 21:56:01 »
Despite being a Razer product
The Razer Sphex pads are excellent, no fray, super slim(paper thin), never moves (it's glued down)and super slippery. Cleaning? Wipe it off with a damp towel.
I have one of the Corsair pads people rave about, hate it. I need more dpi to compensate, has higher drag and over time will fray. It also skates around my desk and messes with keyboard placement.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Sat, 16 December 2017, 04:39:26 »
Artisan pads, anyone?
« Reply #6 on: Sat, 16 December 2017, 16:28:38 »
I love cloth mouse pads and love Artisan, I've bought 4 over the years, but they ALWAYS fall apart on me after just 4-6 months. The Hein Hard is my fav probably, but sadly that too started coming apart at the edges after a few months.
Offline devoi
« Reply #7 on: Sat, 16 December 2017, 17:16:45 »
Zowie G-SR or P-SR pads are great from what I've seen.
Offline Giorgio
« Reply #8 on: Sat, 16 December 2017, 17:25:52 »
I hate the mousepads that can't be cleaned, so I got a Logitech g440 hard mousepad, which is the best one that I've owned. It's big and smooth.
« Last Edit: Sat, 16 December 2017, 17:31:16 by Giorgio »
Offline Niahi
« Reply #9 on: Sat, 16 December 2017, 19:05:25 »
Love my Artisan, I have had plenty of mouse mats before but it beats them all
Offline nugglets
« Reply #10 on: Sat, 16 December 2017, 19:28:17 »
I've had my qck+ for... 4 years? It hasn't frayed in any meaningful way, still tracks extremely well and when washing I just use a soft brush and hot water.
I can't get used to hard pads. There's no doubt they're easier to clean but that's the least of my worries, realistically.
And stitched mats are no good for me when it comes to gaming. The raised stitching reduces the usable area. When your mouse inevitably smacks into the edge you're as good as dead when your crosshair jumps.
« Last Edit: Sat, 16 December 2017, 19:30:50 by nugglets »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #11 on: Sun, 17 December 2017, 17:27:17 »
THIS IS THE BEST MOUSEPAD. ORDER YOURS TODAY FOR AN EXCLUSIVE LOW PRICE OF $39.99!
https://geekhack.org/index.php?topic=49858.0
Offline JP
« Reply #12 on: Mon, 18 December 2017, 10:06:30 »
About Me | The Collection
« Reply #13 on: Tue, 19 December 2017, 14:18:08 »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #14 on: Wed, 20 December 2017, 23:29:40 »
Have NEVER cleaned a single mouse pad in my entire Life (trust me I'm very old) - far cheaper and quicker to BUY another mouse pad or even better yet, buy several so that when one gets dirty dump it in the bin and bring out the new one.
Nothing complicated here, simple way to live without any worries about any stupid "dirty" mousepad  ;D .
Offline davkol
« Reply #15 on: Thu, 21 December 2017, 02:37:44 »
…and some extra waste that contributes to Australia (and the rest of the world) becoming a wasteland.
Unless you're like my dad, who cuts old thick mousepads into smaller pieces and uses it for damping, instead of buying, you know, damping foam specifically.
Offline HotRoderX
« Reply #16 on: Thu, 21 December 2017, 02:57:59 »
This is what I use might be something you want to take a look at https://www.amazon.com/Glorious-Extended-Gaming-Mouse-Mat/dp/B00J2EF4K6/ref=sr_1_sc_1?ie=UTF8&qid=1513846600&sr=8-1-spell&keywords=glorius+pc+master+race+gaming+mat
I have the Glorious Extended White Gaming Mouse Mat / Pad - XXL Large, Wide (Long)
Personally like it cause it gives me a spot for my keyboard and ample room for my mouse to work also!
Offline OfTheWild
« Reply #17 on: Thu, 21 December 2017, 09:01:20 »
I use the one from massdrop at work - definitely a nice setup if you don't move your desk items out of the way to work on stuff. The stitching around the edge works quite well to keep it from fraying. Also adds some sound reduction i suppose.
-Dana
Offline Elrick
  • Hype Master
« Reply #18 on: Thu, 21 December 2017, 17:11:52 »
Some facts about "Australia" - it's already the largest Waste Depot on this planet which already stores the World's Most Toxic Chemical and Nuclear Waste here.
My used mouse pads are quite benign compared to the poisonous crap that's oozing out of the ground, why do you think we export about 95% of food grown here instead of eating it ourselves  ;D .
Offline HouseofSuffering
« Reply #19 on: Thu, 21 December 2017, 17:32:05 »
I agree. I have had a 4HD for like 3 years now and it still looks brand new. East to clean, durable and super slick.
only down side is the Steel series logo pattern on it....
...dis guy....
https://smile.amazon.com/SteelSeries-4HD-Professional-Gaming-Mouse/dp/B002J9G5AE/ref=sr_1_2?s=electronics&ie=UTF8&qid=1513899249&sr=1-2&keywords=steelseries+mouse+pad
« Last Edit: Thu, 21 December 2017, 17:34:41 by HouseofSuffering »
Offline daerid
    • Rossipedia
« Reply #20 on: Fri, 22 December 2017, 19:19:26 »
I use the rough side of the Corsair MM600. Have one for each computer. Feels great, easy to clean, works with all my mice.
Offline typo
« Reply #21 on: Thu, 28 December 2017, 22:15:28 »
Mouserug. Looks great, feels great, very robust, easily cleanable, instead of super slick some resistance like a solid confident feel. Comfortable without a wrist rest getting in the way due to 4mm blown rubber. Downside is $20 for tiny mat. Good for coding perhaps not gaming. If you want good larger cloth for gaming their are the Razer offerings. Only good things they make IMO.
Offline _rubik
« Reply #22 on: Thu, 28 December 2017, 22:37:26 »
My mouse pad experience is limited, but I might as well share the pad that I've been using for the last ~5 years: the SteelSeries Rubber Base gaming pad.
I find it to qualify all my mouse pad requirements, quality cloth top that slides well but also feel pleasant, grips the desk, durable, long lasting, and, above all, dead simple.
It's inexpensive and is one of the few parts that I've never once considered swapping out. In my opinion, the best mouse pad is one you don't notice.
https://www.amazon.com/SteelSeries-Rubber-Gaming-Mouse-450mm/dp/B000UVRU6G/ref=sr_1_3?s=electronics&ie=UTF8&qid=1514521965&sr=1-3&keywords=steelseries+mouse+pad
« Last Edit: Thu, 28 December 2017, 22:40:49 by _rubik »
Offline davkol
« Reply #23 on: Fri, 29 December 2017, 01:12:12 »
So, QcK.
I bought mine almost 7 years ago, when there were basically no alternatives at that price point. Since then, however, almost everyone who had anything remotely associated with PC gaming (like, making CPU coolers) has released a bunch under their brand. All these new mousepads are nearly identical, but only _nearly_ as there are slight differences in texture, thickness and price.
SteelSeries QcK has turned out to be my least favorite in the end, because the texture isn't suited towards fast, effortless sliding. There are also pads with better size/thickness for the price. I mainly use a plastic pad these days (SteelSeries 4HD), but if I had to pick a cloth one, it'd be CM Storm Speed RX from what I've tried.
Offline _rubik
« Reply #24 on: Fri, 29 December 2017, 01:17:34 »
So, QcK.
Yeah, QcK... I knew there was a better name for it.
You clearly know mouse pads better than I do, but I've never felt that I was putting in 'effort' when using it. Maybe the cloth is just worn down, or maybe I'm just a filthy casual. Either way, I'll have to take a look at the Speed RX. Thanks for the rec!
Offline davkol
« Reply #25 on: Fri, 29 December 2017, 02:50:21 »
I don't even know, if they still sell them. Probably not, because the CM *Storm* brand has been deprecated.
Anyway, there's a ton of these pads these days. Besides SteelSeries QcK/SteelPad and CM Storm Speed RX (there was another model with a slower texture too), I've had some from Kingston, Corsair, Roccat (those were at least a bit different) etc. Choosing an exact model is a matter of what exact size, rubber thickness, cloth texture and price you're looking for. Like, let's say I want something very wide, but not too deep (i.e., closer to 30 cm than >45 cm), thicker than the basic 2mm rubber, faster than QcK and as cheap as possible… that leaves me with only one pad, then another a bit thicker for extra €5 and one or two more that are a worse match in terms of size.
All that said, I use only a cheap pseudo-branded mousepad/deskmat these days, besides the aforementioned plastic 4HD:
What I do use is C-Tech Anthea XL, which is ridiculously cheap (€7 in a local store), has all the bell and whistles (stitched edges, 4mm thickness, decent texture), and fits my tray perfectly (90×27 cm). The only downsides are the fugly red logo (but I usually have something covering it), and who knows how they've made it so cheap... but then again, there's no guarantee, that SteelSeries' or anyone else's suppliers don't use child labor and what not either.
Offline MKULTRA
  • telling it how it is
« Reply #26 on: Wed, 03 January 2018, 14:52:14 »
https://i.imgur.com/95TlNyP.jpg
I got these on Taobao about a week ago. One I use at work, one is on my desk at home. And I got one extra one since they were so cheap. I like them so far.
« Reply #27 on: Thu, 04 January 2018, 14:27:31 »
...dis guy....
Just ordered one of these 4HDs on your suggestion. It was this or an aluminum one which idk if that's a good surface for gaming.
Offline Parak
« Reply #28 on: Thu, 04 January 2018, 15:44:47 »
I just use a sheet of UHMW... not all mice can track on it though.
« Reply #29 on: Thu, 04 January 2018, 16:05:30 »
...dis guy....
Hopefully you like it.
I had the Largest Fabric Steelseries Qck+ before and hated that the edges separated and peeled back ever so slightly and although I could and did wash it a few times, it never looked as good as it did when new.
The 4HD still looks brand new. I have no regrets about the purchase. I will never go back to a fabric mat.
Offline scotcheyn
« Reply #30 on: Mon, 08 January 2018, 20:43:57 »
Are there any mousepads that can be written on (like I can rest a paper on it and not tear the paper)?
Offline iLLucionist
  • Topre is Love.
« Reply #31 on: Tue, 09 January 2018, 09:54:36 »
BEST MOUSE PAD?
Qualifiers are:
Mouse performance
Surface glide
Ease of cleaning
Material
Style
QCK XXL.
All of the above, minus the cleaning. It is a dust magnet.
« Reply #32 on: Tue, 09 January 2018, 12:57:01 »
Finding the hard reflective surface of the 4HD to be a bit too glidy. I find myself misclicking with slight movement, need to keep my wrist more stabilized when clicking. For gaming it's great, but for regular use the missed mouse clicks are annoying.
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
« Reply #33 on: Sat, 10 February 2018, 20:15:11 »
They've recently started selling versions of their mouse pads with stitched edges.
I replaced my Hayate with a Ninja FX Hayate Kou earlier this week and I'm happy with it so far.
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline Bucake
« Reply #34 on: Sat, 17 February 2018, 03:54:59 »
glass!
Offline typo
« Reply #35 on: Fri, 09 March 2018, 05:09:03 »
MouseRug.
Offline vegs
« Reply #36 on: Sat, 10 March 2018, 05:56:22 »
I used a Artisan Hayate for a good year but recently switched to a QcK Heavy. I like this one much better.
I haven't tried other Artisan pads but QcK seems to be best bang for the buck.
hhkb 4 life
buy less
Offline proto
« Reply #37 on: Sun, 13 May 2018, 21:41:12 »
I love my godspeed desk pad from NovelKeys. I always liked large mousepads that way I can position the mouse anywhere, and the clean design based on a keycap set is pretty cool. I am hoping he makes one for the nautilus keycaps as well
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #38 on: Mon, 14 May 2018, 15:19:39 »
Still using a TekMat because I want a gun but I can't have one so I have a mat with a picture of one on instead.
« Reply #39 on: Mon, 14 May 2018, 15:24:59 »
Been using a Wow!Pad at work for over 8 years on and off again, I keep going back to it.
Offline aya3154
« Reply #40 on: Wed, 30 May 2018, 12:19:03 »
QcK Mass does the trick for me
Offline dwarf.factory
  • Hi Im Dwarf!
    • Dwarf Factory
« Reply #41 on: Thu, 31 May 2018, 05:15:32 »
Qck Limited edition is my favorite
My pure desire is GOLD
Offline Lansky
  • Realest motherthocker
« Reply #42 on: Thu, 31 May 2018, 06:17:39 »
I've been perfectly happy with the performance of my QcK and QcK+.
But I prefer the Zowie G-SR. The combination of the material, the stitching and the much less intrusive logo gives it a more premium look and feel. But in terms of performance, I don't really notice any difference between this and the QcK's. Either works just fine.
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #43 on: Thu, 31 May 2018, 22:16:34 »
I've been using https://www.amazon.com/gp/product/B00WY1BMDM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 Reflex Lab large mouse pad for years and it's still going great. Good price and quality!!
« Reply #44 on: Sat, 02 June 2018, 02:11:15 »
I believe the optimal setup would be to have your actual desk as the mousepad, so that begs the question: What desktop surface is best for laser tracking? I would guess aluminum or glass, although I reckon a quartz desktop would probably be the best material in terms of comfort.
Offline Colourr
  • no worries
« Reply #45 on: Sat, 02 June 2018, 16:05:47 »
I use my Cherry deskpads as my mousemat!  :thumb:
Offline Aerizu
  • Professional Lurker
« Reply #46 on: Sat, 02 June 2018, 20:24:57 »
After trying a bunch of different mousepads, I can say that Artisan mousepads are probably the best out there.
Aside from the different choices in materials, they also offer varying sizes, hardness and thickness for each.
I currently own a Zero MID Large (4mm thick) and Hayate Otsu MID Large (3mm).
Offline NewbieOneKenobi
« Reply #47 on: Wed, 06 June 2018, 15:12:06 »
One-of-a-kind custom pairings turn out the best. For example I had a tiny but heavy Logitech E110 wireless mouse back in the 1024*768 era, which I used on high sens and high accel, double teflon sliders and small, extremely grainy round pad I purchased in 2007 from a ticket office in a Greek museum (obviously, by 2018 it shines like a well-polished space bar), and it was the best thing I could think about bar the occasional stiffening of my fingers due to prolonged use of claw grip.
Otherwise I loved Razer Goliathus Speed (for optical mice and RTS games) but after purchasing Steelseries's whatchacallit hard pad I've kept it and eventually bought a laser mouse to match (the Sensei). The pairing isn't bad but not spectacular either. I'll probably want to go wireless again for gaming now that signal deterioration can probably be avoided by state-of-the-art tech. And that may well be an optical mouse, meaning back to cloth pad.
A while ago I purchased a Steelseries QCK for my Internet dweller of an aunt, who plays no games whatsoever, along with a gaudy gaming mouse with huge green lights pretty much because no other purchase made practical sense in comparison. She has loved the setup ever since and she swears she would never go back to a non-gaming mouse or pad.
« Last Edit: Wed, 06 June 2018, 15:14:49 by NewbieOneKenobi »
Offline johngodsmith
« Reply #48 on: Thu, 07 June 2018, 04:10:47 »
Zowie gsr special blue edition. super smooth
If they made an XXL size, I would use it til the end of my days
« Reply #49 on: Thu, 07 June 2018, 08:11:37 »
What's the surface like?
