Author Topic: Need help with TKL PCB  (Read 3727 times)
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« on: Fri, 29 December 2017, 01:36:45 »
Sup everyone,
I'm thinking to buy Gon Nerd TKL PCB V2.0 but wondering if it comes with RGB LED for underglow?
Is there any other TKL PCB that you guys would recommend? Anything that's the best with RGB LED
Thanks all
Offline loud_asian
Re: Need help with TKL PCB
« Reply #1 on: Fri, 29 December 2017, 02:43:22 »
TX87 PCB from Leeku
« Reply #2 on: Fri, 29 December 2017, 03:05:13 »
Do check up GON's status, unless you are ordering from another party.
There were some issues with him a while back. I don't know if they have been resolved.
Offline Blazestorm
« Reply #3 on: Fri, 29 December 2017, 03:30:42 »
Offline alienman82
« Reply #4 on: Fri, 29 December 2017, 12:16:15 »
removed.
« Last Edit: Thu, 01 March 2018, 00:21:01 by alienman82 »
Offline BlackInk
    • TeamGSB
« Reply #5 on: Fri, 29 December 2017, 15:42:50 »
Thanks guys, the Big question is which TKL PCB comes with presolder RGB LED? Does the Gonerd TKL PCB has it? If not, where can i buy the TX87 PCB?
Thank you
« Reply #6 on: Sat, 30 December 2017, 20:48:58 »
Thank you
message kin25 on telegram, he'll sell you a tx87 for i think $50+shipping from s korea
it has RGB underglow presoldered
it sounds sketchy, but he's super legit
unless you have a GON case, then you have to order from GON (because his USB ports are on the wrong side of the PCB) and that's sketchy. it'll say on his site what is presoldered
Offline BlackInk
    • TeamGSB
« Reply #7 on: Sat, 30 December 2017, 21:31:22 »
Thank you
Thanks Puddsy
Does tx87 comes with everything presolder? I dont know anything anout pcb and not really good at soldering so its best to buy one that come with everything presolder. Also where the usb port locate in the pcb? Left or right?
« Reply #8 on: Sat, 30 December 2017, 21:43:06 »
Thank you
Thanks Puddsy
yes, all presoldered
TX is A.87, so USB is between F12 and printscreen
with side, i was talking about top vs bottom of PCB, not left vs right
