Author Topic: [GB] LZ CLS s x h (Classic 60) : [Finish]  (Read 150763 times)
Offline ViệtNV
    • VNMK
Re: [GB] LZ CLS s x h (Classic 60) : [Order]
« Reply #50 on: Sun, 14 January 2018, 04:37:09 »
can i buy only bag?
Offline LifeZ
  • LifeZone
« Reply #51 on: Sun, 14 January 2018, 05:41:22 »
can i buy only bag?
sure, but It takes a long time because the order quantity is produced.
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #52 on: Sun, 14 January 2018, 05:58:10 »
[Note.]
Base Kit not including PCB
Because there are various PCBs, we want individual to choose according to preference.
So out of curiosity, would the Zeal60 pcb be compatible with the case?
sure. fit Zeal60 pcb
LZ Limited
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #53 on: Sun, 14 January 2018, 05:59:39 »
Also, I'm sure the answer is no, but will there be a option to get ANSI only plates?
Normal plate is universal
and ansi only plate is choice special plate option
Okay, thanks.
I was wondering if that's what that actually meant.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline donut_sauce
« Reply #54 on: Sun, 14 January 2018, 10:01:25 »
hey LZ,
Which plate would u recommend for a black HHKB? It’s awesome to have so many options but just curious , as the designer of the board, what ur preference would be?
Offline Helldrop
« Reply #55 on: Sun, 14 January 2018, 10:09:34 »
I’m in. Can’t help but get involved..
Offline Vadurr
  • Valar Morghulis
« Reply #56 on: Sun, 14 January 2018, 10:35:36 »
Will this case fit other plates as well?
« Reply #57 on: Sun, 14 January 2018, 11:23:40 »
no, since it's top mount
always buy extra
Offline shekki
« Reply #58 on: Sun, 14 January 2018, 16:40:21 »
Just curious, are there any plans for brass plate in the future?
Offline donut_sauce
« Reply #59 on: Sun, 14 January 2018, 16:47:22 »
How much are extra acrylic diffusers?
Edit: Nevermind just saw they're 4 dollars
« Last Edit: Sun, 14 January 2018, 16:49:06 by donut_sauce »
Offline poolside
« Reply #60 on: Sun, 14 January 2018, 17:57:41 »
That blue color is quite enticing  :thumb:
I have a few questions:
- Is there a close-up picture of 1u WKL blockers attached to a top piece available? I would like to see the seam between the blocker and the case.
- How would the carbon fiber plate feel compared to a PC one? Would that be about as flexible as PC, but springier on bottom-out?
- Are the add-on stabilizers the screw-in kind?
- 1u wkl blocker
- well, I will check again soon.
- No. only Cherry Genuine pcb mount stabilizers.
Thank you LZ. Would you happen to have detailed pics of these 1u blocker edges?
186575-0
186576-1
May we also see a few more pictures of the blue keyboard sample?
Offline LifeZ
  • LifeZone
« Reply #61 on: Sun, 14 January 2018, 18:13:11 »
hey LZ,
I too have a headache with too many options.
What switches do you use?
Sts n carbon for hardness.
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #62 on: Sun, 14 January 2018, 18:14:02 »
Welcom to helldrop
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #63 on: Sun, 14 January 2018, 18:15:21 »
sry, i have no plan for brass plate
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #64 on: Sun, 14 January 2018, 18:34:07 »
- 1u wkl blocker
Do you want it?
186577-0
186579-1
186581-2
now, Blue n Red sample is other keyboard.
Red is like LZ St same color.
LZ Limited
Offline nmur
  • ಠ_ಠ
« Reply #65 on: Sun, 14 January 2018, 18:35:16 »
damn this is tempting
Offline amnesia0287
  • Formerly Amnesia
« Reply #66 on: Sun, 14 January 2018, 18:36:49 »
I'd love to see more picks of the blue and red just to get a better idea. But I'm pretty sure blue is the right color for me. Gonna look so nice with a black plate and GMK Blue on Black.
I do kinda wish I could get both tops, but that would be expensive.
Offline LifeZ
  • LifeZone
« Reply #67 on: Sun, 14 January 2018, 18:44:14 »
Shall We Dance ;D
LZ Limited
Offline kekstee
« Reply #68 on: Sun, 14 January 2018, 19:32:57 »
The diffusor is optional, right?
It's so tempting, but I want a TX60 as well :D ...
Offline LifeZ
  • LifeZone
« Reply #69 on: Sun, 14 January 2018, 19:40:30 »
acrylic diffuser is include base kit, not option.
base kit ((Case, brass Weight plate, Switch plate, Acrylic Diffuser, BAG, Bolts, Bumpons)) :p
TX60 is good.
LZ Limited
Offline Quantastrophus
« Reply #70 on: Sun, 14 January 2018, 21:05:35 »
Hi,
I noticed that there are some imperfections on the bottom of the keyboard.  Noticeably here:
Is it possible to fix this issue as I think it could cause a problem with the rubber feet staying in place and the look is not the best.
Thanks.
« Reply #71 on: Sun, 14 January 2018, 21:07:18 »
Hi,
Thanks.
not an issue if you use 1) black bumpons or 2) good bumpons
buy a sheet of 100 3m bumpons from amazon and never think about it again
Offline amnesia0287
  • Formerly Amnesia
« Reply #72 on: Sun, 14 January 2018, 21:15:57 »
Hi,
Thanks.
If anything wouldn’t the spike help get air out from under the bumpon and prevent it from pulling off when sliding?
Offline LifeZ
  • LifeZone
« Reply #73 on: Sun, 14 January 2018, 22:26:40 »
Hi,
Thanks.
I dont have problem,
I think that the problem does not arise because the rubber feet staying in place.
All my keyboards have rubber feet staying in place.  :D
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #74 on: Sun, 14 January 2018, 22:29:02 »
Hi,
Thanks.
Yes, i use to keyboard 3M bumpons is #5302. for cls & tx series keyboard.
LZ Limited
« Reply #75 on: Sun, 14 January 2018, 22:31:01 »
Hi,
Thanks.
in case anyone is curious, here's the amazon link
the reason to use 3m bumpons over other is becuase the adhesive is a lot stronger than all the competitors
they're not coming off by accident
Offline kconfire
« Reply #76 on: Sun, 14 January 2018, 22:42:19 »
Hi,
Thanks.
Holy crap. I didn't know 3M made these.  Thanks for the info <3
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
« Reply #78 on: Mon, 15 January 2018, 00:13:42 »
Damn, I'm already in the BOK.CP GB... What's the deadline for this GB and the invoice payment?
bottom of the first post
1/31 for orders, 2/10 for invoice
Offline ihalatch
« Reply #79 on: Mon, 15 January 2018, 00:18:04 »
X%&#! The kits look fantastic. The normal layout with blockers configuration is very interesting.
Offline ricyuyc
« Reply #80 on: Mon, 15 January 2018, 00:44:36 »
TX60 is good.
Does the case could be assembled either with or without the acrylic diffuser, right? I hope the board to be clean and simple as it is. Thanks.
Offline ihalatch
« Reply #81 on: Mon, 15 January 2018, 00:47:02 »
TX60 is good.
Of course, you can assemble it without the diffuser like all recent LZ keyboards.
Offline HappyCatFish
« Reply #82 on: Mon, 15 January 2018, 02:12:33 »
As someone who does not care for RGB underglow or acrylic diffusers in general I am not a fan of the trend towards integrated diffusers that must be included in order to assemble the board. One reason I am a big fan of the CLS line and all of LZ's boards for that matter!
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #83 on: Mon, 15 January 2018, 03:13:32 »
I'm not a fan of RGB or diffusers also, but this board doesn't require it to be assembled.  If it did I wouldn't be planning on joining the GB.
WTB/WTS/WTT ---->
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #84 on: Mon, 15 January 2018, 04:54:07 »
Oh **** LZ,  LZ-GH (V2)!?  :eek:
I know this isn't the place to talk about it, but will it resemble the first version at all?
WTB/WTS/WTT ---->
Offline cgrums
« Reply #85 on: Mon, 15 January 2018, 13:12:38 »
I'm in and very excited for this. Silly question: are we supposed to see an immediate response via email upon submitting the order form?
« Reply #86 on: Mon, 15 January 2018, 13:19:27 »
give it a few hours
hopefully with a new (ish) bottom
the bar LZs aren't the best to type on
what is LZ GHOST?
Offline krispy
« Reply #87 on: Mon, 15 January 2018, 14:27:02 »
Anyone know if the optional PCB (L3 Finger60) supports holtites?
Offline kconfire
« Reply #88 on: Mon, 15 January 2018, 15:59:49 »
I really wish we could extend the deadline to February 15, 2018 that way I can add more stuff to my order..
LZ- would delaying the invoice due date to 15th not work for this GB?
Just checking.. :)  :thumb:
Offline poolside
« Reply #89 on: Mon, 15 January 2018, 16:39:35 »
- 1u wkl blocker
Do you want it?
Looks good, thanks for these additional pics LZ  :thumb:
I guess I will have to make a few changes to my order.
I am also curious if purchasing extra top pieces would be possible, like in Kin's TX-60/65 GB?
Offline Etherealsound
« Reply #90 on: Mon, 15 January 2018, 17:34:52 »
Do the plates allow for switch top removal?
Offline amnesia0287
  • Formerly Amnesia
« Reply #91 on: Mon, 15 January 2018, 17:41:02 »
I am kinda curious about this myself for the custom plates. I might do 1 each way just cause no openings looks better. But it’s way less useful.
Offline LifeZ
  • LifeZone
« Reply #92 on: Mon, 15 January 2018, 17:51:33 »
- 1u wkl blocker
Do you want it?
only kit. Each case should not be separate.
Now, many option.....im crazy!!! haha
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #93 on: Mon, 15 January 2018, 17:53:51 »
can't removal
LZ Limited
Offline nycxandy
« Reply #94 on: Mon, 15 January 2018, 18:43:23 »
I signed up two days ago, but didn't receive a confirmation e-mail.  Should I sign up again?
Offline LifeZ
  • LifeZone
« Reply #95 on: Mon, 15 January 2018, 18:46:27 »
Order Deadline & Order check 2018-01-31
We will arrange to have your order confirmation on Jan, 22
Please confirm your order then. Modifications are also possible.
LZ Limited
Offline kekstee
« Reply #96 on: Mon, 15 January 2018, 21:30:22 »
That was my question, didn't care so much about whether it was included o or not, but if it can be assembled for a clean look.
Another thing I would like to know: How high is the front edge of the keyboard above the table?
Offline donut_sauce
« Reply #97 on: Mon, 15 January 2018, 21:32:05 »
hey LZ,
Thanks, LZ. Not sure what switches i'm gonna use yet. My two MX boards have linear yellows and blacks with sts/aluminum plates. I still find myself using my HHKB though most of the time as it's favorite typing experience (lubed and silenced).  I went ahead and ordered in with a polycarbonate plate and backup black aluminum since I think what i might like about the HHKB is the softness maybe? Might try hako's with this one, didn't really care for zealios. Hoping to find an mx style setup that i like as much as HHKB:D
Offline Khers
  • Schrödinger's box
« Reply #98 on: Tue, 16 January 2018, 02:17:26 »
« Last Edit: Tue, 03 July 2018, 09:05:26 by Khers »
Offline LifeZ
  • LifeZone
« Reply #99 on: Tue, 16 January 2018, 02:22:58 »
About 20.5 mm
LZ Limited
