Author Topic: Are there popular 60% PCBs that deviate from the common USB connector placement?  (Read 3760 times)
Offline ojrask
  • juuh elikkäs
I'm playing around with a 60% case design. I was wondering how many 60% PCBs there are that do not adhere to the GH60-style PCB layout (mainly concerned about the USB connector placement)?
I would like to make a case that has a single UCB connector cutout but if there are many different ones that are popular then I would have to consider making a second USB hole.
Ones I've seen that use the same layout base (have not measured but most of them have the USB connector at the top-left around 1cm from the left edge):
- GH60
- GH60 Satan
- DZ60
- KC60
- Sentraq 60%
- GK64
- GON NerD 60%
- FaceW 60%
- B.face 60%
- Zeal60
The case I'm working on would come with a dedicated top-mounted plate so mounting holes are not a concern for the PCB.
Current:
Coming up:
IC/GB:
Offline xondat
  • i'm not a star
Zeal60 and NerD60 extend further than others, which is why there needs to be a cutout for it.
Offline ojrask
  • juuh elikkäs
I see, thanks! But horizontally they are aligned the same as a GH60 for instance, I presume?
Current:
Coming up:
IC/GB:
Offline xondat
  • i'm not a star
Yes, exactly half way between Esc and 1.
Viper and E6V2 center USB PCBs are interchangeable, but that's about it.
356mini also uses a non standard PCB.
Offline ojrask
  • juuh elikkäs
Seems like custom koreans and the like want to stand out from the rest, which is not a bad thing IMO. Thanks for mentioning!
Current:
Coming up:
IC/GB:
Offline TalkingTree
    • My projects
Any preview?
Just be aware that they don't have extras available in perpetuity, which is why I think the standard left USB design is so popular.
Offline hasu
  • @tmk
It is not exactly midway at least in GH60 and some pcbs which refer to de facto Poker X desgin faithfully. I don't know if this difference is important here, though.
Offline ojrask
  • juuh elikkäs
Any preview?
Not yet, sorry. Still poking around a few ideas in my head and on paper. :)
I have a GH60 and a Satan60 at hand so I can measure. But making a connector hole wide enough to work with a few different designs should not be a problem I think. :)
Current:
Coming up:
IC/GB:
Offline TalkingTree
    • My projects
Any preview?
I'm looking forward to it.
