Author Topic: Filco Detachable cable question  (Read 5891 times)
Offline _Mochi
« on: Mon, 05 February 2018, 16:37:54 »
I just got my Filco Tkl keeb today and want to make its cable detachable would this work
https://www.amazon.com/dp/B072M4X8DG/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B072M4X8DG&pd_rd_wg=5XArO&pd_rd_r=FDWADHNN61SRM08R7WD2&pd_rd_w=kbXAk&keywords=5pin%20header
  i cant really make my own cable cause i have no experience in soldering and don't have the tool
Offline atarione
Re: Filco Detachable cable question
« Reply #1 on: Mon, 05 February 2018, 16:51:45 »
I'm going to say "I think so... BUT".. if anyone more qualified shows up with a different opinion that is cool..
I  think you could use this but you are going to have to take the wires out of the header of the replacement cable and the orig cable and use the original header to connect the extension cable.. you can see in these pics that the header on that mother board extension cable differs from the header used on the filco..
188030-0
« Last Edit: Mon, 05 February 2018, 16:55:13 by atarione »
Offline _Mochi
« Reply #2 on: Mon, 05 February 2018, 17:24:31 »
ahhh i thought it was the same header
Offline Leslieann
« Reply #3 on: Mon, 05 February 2018, 19:45:15 »
Not the same header and the pins are not interchangeable (you need 2.54mm DIP, the ones shown are commonly known as a Dupont connectors).
Amazon doesn't carry anything like you are looking for, neither does Ebay.
There are people on here who make sleeved cables, and it wouldn't surprise me if some do detachable, though, buying a cheap soldering iron and some solder is cheaper than buying one of their cables (they look good though) and is a skill and tool you can use more than just once.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline TalkingTree
    • My projects
« Reply #4 on: Tue, 06 February 2018, 03:28:39 »
The only ready made  mod that I know is made by pexon.
Offline _Mochi
« Reply #5 on: Tue, 06 February 2018, 14:18:08 »
where would be a good place to get the connectors and is there any guide on how to solder the micro usb to the connecter cause i dont know what cable goes where
Offline Leslieann
« Reply #6 on: Tue, 06 February 2018, 18:16:50 »
You can just trim the wires from your current lead or buy a replacement.
Ok, so I went back and double checked, glad I did, it is not the XH2.54 I thought it was, but is in fact a JST PHR-5 (search for that and look for a 5pin). You can get bare ones all over, but getting a pre-made lead will probably mean ordering from China off Ebay and you are not likely to find one with a USB connector already attached so your only option is to buy one from Pexon or build it yourself, which again, is not a bad thing.
As for how to wire it, USB is pretty simple with only 4 wires inside, plus an optional shielding wire (which Filco uses).
In a 4 wire setup, the two outermost are red and black, these are your power, the two inside are often white, yellow or green and these are the signal wires. The 5th wire is connected to shielding and the USB plug itself, if it has any (cheap ones do not), this can also be connected to black/ground when adapting a  4wire to a 5 wire or simply ignored (note, some devices require it to work). If you swap the power wires, most devices will simply shut down and the USB port will stop working until yo reset the hub or the computer. If you swap signal wires, you may or may not get a connection to the device, most often you get a failure to find the device driver (some can work in reverse). It's pretty simple and you are more likely to burn yourself with the soldering iron than you are to damage your keyboard. You can find soldering irons at dollar stores for under $5, they are terrible, but for a small job like this it will work just fine. Don't forget heat shrink, some electrical tape and solder. I HIGHLY recommend leaded to start with, but wash your hands after. You can use heat from the soldering iron or a cigarette lighter (use the blue part of the flame not yellow) to shrink the heat shrink tubing. Lastly, make sure no exposed metal is showing which can contact a pin on your keyboard.
If you look at the Pexon cable below, you can see the red and black power and ground (red and black) and in this case white and green signal wires. The orange wire is the shielding and is covered by some tubing. Most people just twist the strands together and solder them to the wire and cover in heat shrink or electrical tape.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline _Mochi
« Reply #7 on: Wed, 07 February 2018, 00:48:10 »
thank you so much im decided to try to do it my self since i really want to build a micro pad in the future
Offline Leslieann
« Reply #8 on: Wed, 07 February 2018, 02:27:51 »
You're welcome, and good luck.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline _Mochi
« Reply #9 on: Mon, 12 February 2018, 17:57:46 »
Hi i just got all my equipment and wanted to ask a question that I couldn't figure out I bought a micro USB board on it there is 5 holes  VCC D- D+ ID GND
VCC connects to Power Red cable
D- connects with D- white cable
D+ connects with D+ green cable
Gnd connects with Ground black cable
Does ID connect with shield? orange cable
again thank you so much for helping me
