Author Topic: Where to get custom TKL kit  (Read 10423 times)
Offline TheInverseKey
  • You can run but you cannot hide!
« on: Tue, 13 February 2018, 12:53:18 »
Hi,
I am new to building my own keyboard and looking to build a TKL.  I was looking for a kit that includes everything except the swtiches because I wanted to get the new Navy box switches.  If you know where I should be looking to get either parts or the kit that would be much appreciated.
Thanks
Offline ppp
  • KappaKeepoKoopa
Re: Where to get custom TKL kit
« Reply #1 on: Tue, 13 February 2018, 13:16:03 »
Pretty sure you can find everything on mechanicalkeyboards.com
Phantom PCB: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=536
Case: https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=44
Actually not sure where you'd find a plate though ¯\_(ツ)_/¯
« Reply #2 on: Tue, 13 February 2018, 13:20:32 »
MechanicalKeyboards.com also has Phantom plates in anodized aluminum: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2551
and in stainless steel: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2552
...and my universal ANSI plate in SS (says for 108, but can be cut to use with 104 and 87 also): https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2554
« Reply #3 on: Tue, 13 February 2018, 16:37:33 »
you can also get one on /r/mechmarket or the group buy subforum
Offline Leslieann
« Reply #4 on: Wed, 14 February 2018, 06:04:13 »
Honestly, while you can get them without switches, you can often get such a good deal on the switches you would be smart to get them anyhow.
Last one I ordered, a complete set of switches was something like $14, I can sell them for more than that or just keep them as spare.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
