Author Topic: [WTB] Cherry G81 or G80 3000 case/shell  (Read 3478 times)
Offline punkpc
  • Trade Count: (1)
« on: Fri, 16 February 2018, 12:19:30 »
Looking for a Cherry G81 or G80-3000 case for a project.
Let me know what you have an how much you want.
Thanks
Offline Nafs_asp
  • Trade Count: (0)
Re: [WTB] Cherry G81 or G80 3000 case/shell
« Reply #1 on: Mon, 19 February 2018, 21:00:42 »
Thanks
I have a G81-1000SBD case (iirc) in pretty nice condition if you're interested. I think I might have cut the mounting pins off inside the case, but if you're planning a leeku build you'd be doing that anyway.
Offline punkpc
  • Trade Count: (1)
« Reply #2 on: Mon, 19 February 2018, 21:56:20 »
Do you have pictures?
Offline Nafs_asp
  • Trade Count: (0)
« Reply #3 on: Mon, 19 February 2018, 22:36:45 »
https://i.imgur.com/dnhHgcF.jpg very old pic, but should be the same as this. I can take more pics this week if you'd like. I don't think I have the PCB/cable any more though. I also have this Olivetti KBD2812 (complete board) if you're interested: https://imgur.com/a/UGeaF. It had dye sub PBT caps but the stabilizers are not MX-compatible so not all the caps will be usable without modification.
Offline punkpc
  • Trade Count: (1)
« Reply #4 on: Mon, 19 February 2018, 22:53:05 »
I would only need the case for the G81-1000, so its ok that you don have any thing else. How much are you asking and where are you located?
Offline Nafs_asp
  • Trade Count: (0)
« Reply #5 on: Fri, 02 March 2018, 07:58:00 »
Hey, sorry, I forgot who was looking for the G80/G81 case. I took some pictures of it for my last post on r/mechmarket: https://imgur.com/a/0BZIr. Let me know if you're interested. The case is in really excellent shape. The only thing I did to it is cut the two plastic posts for mounting the G81 plate to. If you plan to build it up with a G80 or leeku PCB it should be fine that way.
Offline punkpc
  • Trade Count: (1)
« Reply #6 on: Mon, 05 March 2018, 08:44:17 »
Case looks great, but I ended up finding a case local. Good luck with your sale.
Offline punkpc
  • Trade Count: (1)
« Reply #7 on: Mon, 05 March 2018, 08:44:29 »
Case found! You can close this post.
