Author Topic: [GB] Butterfly 60% case (Taking Order)  (Read 20968 times)
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« on: Fri, 16 February 2018, 22:20:40 »
Final Design:
Plate will be hidden inside case with 8 degree angle
MX Plate
Prototype before anodize:
  https://imgur.com/a/A3omk
Price: (Top, Bottom, Aluminum Plate, Aluminum weight, Fix bolts, Rubbers) +4% PP fees
  • Moq 1: 50 @ $259
  • Moq 2: 70 @ $239
  • Moq 3: 100 @ 219
Spec:
  • HHKB or Poker 60%
  • 6061 aluminum CNC
  • 8-degree angle
Universal Plate:
  • Default: SS (support switch top removal)
  • Brass +$19 (support switch top removal)
Weight:
  • Aluminum
  • Brass +$35
Default Colors:
  • Black, Grey, Silver, Dark Red
  • Green, Purple, Blue (+$19)
Shipping:
  • Estimated shipping date: Jun 27th
  • Estimated $39 ship anywhere
GB deadline: Mar 27th (14days to pay after GB closed)
Order Here
Check Your Order Here
« Last Edit: Sun, 18 February 2018, 03:25:33 by BlackInk »
Offline KaosJ
Re: [GB] Butterfly 60% case (Taking Order)
« Reply #1 on: Sat, 17 February 2018, 05:51:18 »
Nice prices, but i think your plate is a bit wrong (at least on the sample).   Seems like you toke the swillkb file and cutted it.
E.g. you have some holes for plate mounted stabs where you clearly can't use plate mounted stabs in that case (this only on the sample, not on the plate render)
Also the holes for the stab wire seems like 0.8-1mm on the render (?) which is the swillkb standard which is really the minimum.
Also 2, in both the render and the sample, since you are not offering a pcb,  you might want to add some more stab wire holes, e.g. look at the whole enter ansi/iso (e.g.dz60)
« Last Edit: Sat, 17 February 2018, 05:53:33 by KaosJ »
Offline BlackInk
    • TeamGSB
« Reply #2 on: Sat, 17 February 2018, 14:24:53 »
Changed the plate a little, and i will make the stab holes a little bigger
Offline p_blaze
« Reply #3 on: Sat, 17 February 2018, 15:06:17 »
Will this have alps compatibility?
Offline m4us
  • regretting ISO User
« Reply #4 on: Sat, 17 February 2018, 17:00:12 »
plate does not look like its alps compatible
Offline BlackInk
    • TeamGSB
« Reply #5 on: Sat, 17 February 2018, 18:17:51 »
I can change the plate again to make it alps compatible
Offline KaosJ
« Reply #6 on: Sat, 17 February 2018, 18:29:30 »
 :thumb:
2mm imho is a good hole to allow a easy lube
Offline p_blaze
« Reply #7 on: Sat, 17 February 2018, 18:30:37 »
That would be awesome!
Offline Unforgivable
« Reply #8 on: Sat, 17 February 2018, 18:38:33 »
Nooo! Please don’t. If you’re going to make it for Alps, please make a seperate plate.
I like solid plates. Your prototype’s switchtop removable option is good enough for me. If you make it for both Alps and Cherry, it’ll just be more Swiss cheese and less stability!
Offline BlackInk
    • TeamGSB
« Reply #9 on: Sat, 17 February 2018, 19:06:24 »
Yea i will add another option for alps plate
Offline xondat
  • i'm not a star
« Reply #10 on: Sat, 17 February 2018, 19:08:11 »
FYI the side "supports" don't support the switch with the H cutouts. Stability is not lost.
Offline BlackInk
    • TeamGSB
« Reply #11 on: Sun, 18 February 2018, 03:35:53 »
Just fixed the plate a little, and for the alps plate... i don't think its possible to make another one because it costs too much to only make 1-2 alps plate.
Offline KaosJ
« Reply #12 on: Sun, 18 February 2018, 05:44:30 »
Seems good now, didn't checked the ISO enter but seems all on point  :thumb:
What are the current numbers?
« Reply #13 on: Sun, 18 February 2018, 10:10:51 »
Nice job on the updated plate! ;)
Are aluminum plates still possible, or only Brass/Stainless Steel?
I said this before, but great job on such a beautiful design. This deserves a lot more attention, especially for the great price. If this hits 100 orders, it would make it an even sweeter deal for everyone.
Do you have any samples of the purple/blue anode?
« Last Edit: Sun, 18 February 2018, 10:17:21 by Unforgivable »
Offline BlackInk
    • TeamGSB
« Reply #14 on: Mon, 19 February 2018, 01:30:13 »
Not many :( you can check from the link above
I'll add some sample soon
