Author Topic: [GB] ELEMENTO X zFrontier. Fr87 GB ended.  (Read 148853 times)
Offline zFrontier
« on: Sat, 17 February 2018, 23:52:56 »
189080-0
189082-1
GB for Fr87 will start on Feb. 18th 0:00 a.m. PST  ;D and will last til March 18th
Join here: https://en.zfrontier.com/products/fr87-by-elemento
EVERY BOARD WILL HAVE A SERIAL NUM ON THE BOTTOM!
And here are the detailed pricing:
KIT OPTIONS:
  • Full Kit with Half Plate (WK or WKL Aluminum case, PCB, Aluminum Half Plate, Aluminum Weight, plastic feet and screws)  -  $368 Shipping included, DHL
  • Full Kit with Full Plate (WK or WKL Aluminum case, PCB, Aluminum Full Plate, Aluminum Weight, plastic feet and screws)  -  $368 Shipping included, DHL
  • Upgrade to Gold PVD Brass Plate  -  + $30
  • Upgrade to Gold PVD Brass Weight  -  + $25
  • Upgrade to American Black Walnut Weight  -  + $35
  • Colors for case: Speed Silver, Cool Gray, Dark Black, Tactical Blue
  • Colors for Aluminum Plate: Silver, Gray, Black
  • Colors for Aluminum Weight: Gray, Black
EXTRAS:
  • Extra Aluminum Half or Full Plate  -  $20
  • Extra Gold PVD Brass Half or Full Plate  -  $65
  • Extra Aluminum Weight  -  $20
  • Extra Gold PVD Brass Weight  -  $55
  • Extra American Black Walnut Weight  -  $65
  • Extra PCB  -  $70
189084-2
189086-3
189088-4
189090-5
IC link
« Last Edit: Wed, 21 March 2018, 02:59:47 by zFrontier »
Chinese Website: https://www.zFrontier.com/
English Website: https://en.zFrontier.com/
Facebook: https://www.facebook.com/zFrontier/
Email: support@zFrontier.com
Offline zFrontier
Re: [GB] ELEMENTO X zFrontier. Fr87 STARTING from Feb.18
« Reply #1 on: Sun, 18 February 2018, 01:50:54 »
Sorry for the late update guys.
At around half of the GB period, Elemento submitted the design to the factory for a prototype.
Due to the intricacy of the structural design, a rather small MOQ and the backlog of CNY orders the factory fails to deliver the proto in time.
While Elemento and we are waiting for the factory to get us a proto:
- Revised PCB design has also been submitted to a different factory.
- Plate samples have been CNCed in house and checked for the mountings / alignment.
- Battery housing sample has been 3d printed and checked.
- Wooden material samples has arrived and will be CNCed in house.
To all those who have joined this GB, we promise we will deliver one of the best customs to you and will not fail your trust.
To everyone who is interested in this project, we apologize for the lack of updates and we will open up a pre-order after we receive the final proto.
Early Prototype ↓
This is a prototype of the very initial design.
192043-0
192045-1
With this proto, we discovered the following issues:
- the surface finish was underwhelming
- the structure was kept as simple as possible to hide all the screw holes on the surface, so it was basically a 2 piece case with an integrated plate on top and bottom mounted
- lack layout support
- lack switch top removal support
- not sleek enough
RGB ↓
192047-2
192049-3
192051-4
192053-5
As you can see the screw holes are on the integrated plate and are all hidden when keycaps are installed. But an integrated plate is neither ideal for customizability (layout support / color combinations / different materials) nor typing experience.
Therefore, drastic structural changes have been made to the design:
192055-6
Screws are hidden in the rubber bump on, top mounted plate, switch-top removal, weight moved towards the back.
3D printed battery housing ↓
192057-7
192059-8
192061-9
192063-10
« Last Edit: Wed, 21 March 2018, 02:59:12 by zFrontier »
Offline Hako
« Reply #2 on: Sun, 18 February 2018, 03:15:24 »
Any chance we can get some real color samples for the cases (especially for the blue)?
Offline zFrontier
« Reply #3 on: Sun, 18 February 2018, 03:36:49 »
That's possible since the factory Elemento picked will come back online after CNY
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #4 on: Sun, 18 February 2018, 06:07:23 »
need better pictures for the colors. really hard to tell from the renders of them in a group.
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #5 on: Sun, 18 February 2018, 07:35:59 »
Do you have any info on the weight of this kit?
Offline vtachkov
« Reply #6 on: Sun, 18 February 2018, 13:10:17 »
Will it work with rechargeable batteries? I don't remember if it was confirmed in the interest check but I believe it was asked.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #7 on: Sun, 18 February 2018, 19:37:25 »
I AM SUPER INTERESTED IN THIS. However, my main concern is the programmable option.
What firmware will the PCB support? Can we please have more details?
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Mainian
« Reply #8 on: Sun, 18 February 2018, 20:08:47 »
I think this was on the reddit post. But it will be programmable through a web app.
Offline zFrontier
« Reply #9 on: Sun, 18 February 2018, 20:57:27 »
Elemento will work out a rechargeable solution once the factory comes back online ;)
Offline zFrontier
« Reply #10 on: Sun, 18 February 2018, 20:58:16 »
Many requested QMK, we will have QMK in our discussion with Elemento
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #11 on: Mon, 19 February 2018, 10:03:47 »
Yeah if you can have open source QMK, that would make this an instant buy. Relying on a web app is no bueno, especially when spending this much on a keyboard :).
Offline Vadurr
  • Valar Morghulis
« Reply #12 on: Fri, 23 February 2018, 01:26:14 »
A few questions... How much will the board weigh with the stock aluminum options? How long will the battery last for bluetooth mode? How long will it take to charge the battery to full?
Offline zFrontier
« Reply #13 on: Fri, 23 February 2018, 01:50:52 »
this should weight at around 3-4 pounds (1.5kg+) with stock alu options.
The factory Elemento contacted will be back from holiday next we and we would be able to get the latest sample and test everything out by then  ;)
Offline SadisticReap
« Reply #14 on: Fri, 23 February 2018, 14:23:09 »
What if we were wanting to pick the brass plate, and brass weight, how much would it weigh?
Offline adam.baranyai
« Reply #15 on: Fri, 23 February 2018, 23:46:09 »
I'm considering joining this group buy but have a lot of unanswered questions in my head that I couldn't find answers to in any topics (IC, GB, Reddit, zfrontier). The questions are the following:
* Does the PCB allow split backspace and/or split right shift or just the traditional TKL layout?
* Do I necessarily need to add weight to the keyboard or there's an alternative method to cover the battery compartment?
* What's the lightest possible weight of the keyboard and what parts do I need to purchase if that's my goal?
* How does the battery life look like if I don't use the keyboard as a Christmas decoration (eg: no backlight or fancy led strips)?
I'm wondering if there's any forum where these are all discussed that I obviously missed? The GB already went live but I don't feel confident purchasing quite an expensive keyboard without knowing anything about the technical parameters.
Offline mkarlsson
« Reply #16 on: Sun, 25 February 2018, 18:06:08 »
Joined in! Tactical blue + half plate
Offline Randalljai
« Reply #17 on: Mon, 26 February 2018, 01:13:04 »
What made you choose half plate? I never tried it out and I'm still not sure which to choose
Offline mkarlsson
« Reply #18 on: Mon, 26 February 2018, 13:22:50 »
I have never tried it before either. I expect it to be softer or mushier which I like. Also the sound will probably be different.
Offline RavenPanther
« Reply #19 on: Wed, 28 February 2018, 01:45:03 »
Just curious, if I want to change/add something to my GB order, how can I go about that?
Offline zFrontier
« Reply #20 on: Wed, 28 February 2018, 03:56:27 »
* split right shift is available
* yes
* the lightest combination will be: an aluminum half plate + American black walnut weight
* Elemento will have it tested and we will update the numbers once available (hopefully before the GB ends)
Offline zFrontier
« Reply #21 on: Wed, 28 February 2018, 04:00:20 »
just send us your changes to your order along with your order no. to support@zFrontier.com :)
Offline JDragon
« Reply #22 on: Wed, 28 February 2018, 17:27:24 »
Any word on those color samples? I can't figure out which one I want. :(
« Reply #23 on: Wed, 28 February 2018, 22:08:47 »
* yes
Cheers. Few more questions:
* Does the PCB allow split backspace as well?
* Yes to what? :) The question was: "Do I necessarily need to add weight to the keyboard or there's an alternative method to cover the battery compartment?"
* Do you know the weight of any of the light weighted combinations? I mean the weight in grams or in kilograms? Is it closer to 3 kg or to 1 kg?
* If Elemento doesn't manage to give tech details about the keyboard before the GB finishes, will the GB be extended?
I really would like to know more details about this keyboard but seemingly most of the certain parameters known so far are related to look and feel. What I see is amazing and all my appreciation goes to the designer. I'm desperately hunting for a Bluetooth mechanical keyboard since a long while though and to me, weight and battery life is as important as programmability (which I also don't know much about) and layout. I feel a bit silly asking these questions though. Looks like the answers are either obvious to everyone else or simply most people don't care about these details.  :rolleyes: Anyhow, I'll keep an eye on the GB to see if you guys manage to find out what exactly is for sale here other than an amazing looking and finely crafted piece of aluminum with some additional weight.
Offline wowremy
« Reply #24 on: Thu, 01 March 2018, 00:19:31 »
I want this to be my first custom build. Is this a good idea?
Offline Kevadu
« Reply #25 on: Thu, 01 March 2018, 01:14:24 »
You have to start somewhere.  Probably the best place to start is a board you want.
« Reply #26 on: Thu, 01 March 2018, 01:16:26 »
Well put - if this is your board, then go for it! (Funny, you posted this right as I was replying to them, too, lol)
It's gonna be my first and I'm stoked!  :D
Thanks, will do!
« Last Edit: Thu, 01 March 2018, 01:18:02 by RavenPanther »
Offline wowremy
« Reply #27 on: Thu, 01 March 2018, 12:39:12 »
Am I going to want an extra pcb in case if soldering errors? Was thinking of getting both plates, should I get at least 1 pcb per?
« Reply #28 on: Thu, 01 March 2018, 15:21:39 »
always good to get extras just in case if you can afford it
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #29 on: Thu, 01 March 2018, 15:34:48 »
I was considering doing this --- for the simple fact that you could have TWO sets of switches & programmed PCB's. For me, I'd probably have a lubed tactile switch and then a lubed linear ;P.
« Reply #30 on: Thu, 01 March 2018, 15:37:18 »
this is exactly why i double up
Offline wowremy
« Reply #31 on: Thu, 01 March 2018, 18:31:37 »
This being my first build, what will I need other than switches and stabilizers?
« Reply #32 on: Thu, 01 March 2018, 19:22:45 »
USB cable and keycaps, maybe batteries for the bluetooth
Offline vtachkov
« Reply #33 on: Thu, 01 March 2018, 19:33:23 »
Don't forget some decent lube!
Offline wowremy
« Reply #34 on: Thu, 01 March 2018, 20:29:16 »
Thank you gentlemen. I wont need to solder in the usb thing, or buy a micro controller? No idea what im doing.
« Reply #35 on: Thu, 01 March 2018, 20:30:03 »
nope, just need a cable
PCB should come SMD presoldered
Offline Kevadu
« Reply #36 on: Thu, 01 March 2018, 21:16:15 »
Because I have to ask: Costar stab support?
« Reply #37 on: Thu, 01 March 2018, 21:18:23 »
can tell from the shape of the cutout: no
Offline zFrontier
« Reply #38 on: Thu, 01 March 2018, 21:34:50 »
* yes
Thank you for showing much love to this project :) and sorry for missing some points on the previous answer :(
No, it will not support split backspace
You can only cover up the battery compartment with a weight
Elemento dont currently have every component, but the early structural prototype was around 1.5kg. We dont have the exact numbers but with the lightest combination you should be looking at something between 1.5-2 kg
Yes, we will definitely extend the GB if necessary
Offline zFrontier
« Reply #39 on: Thu, 01 March 2018, 21:35:48 »
No  :(
« Reply #40 on: Fri, 02 March 2018, 00:04:42 »
Since I've never built one before, what makes them different? I adore the costars on my WASD, and was looking forward to putting some on this... Is there really no way to make it work?
« Reply #41 on: Fri, 02 March 2018, 00:32:21 »
No worries. Thanks for unfolding the specs zFrontier.  ;)
I can't wait to hear more details from Elemento about programmability and battery life on Bluetooth.
QMK and a few months of battery life would be much appreciated but I guess we don't know much about these details at this point in time.
Will keep an eye on all the related pages to find more details about these parameters.
Offline Kevadu
« Reply #42 on: Fri, 02 March 2018, 01:20:29 »
Costar mounts are a slightly different shape than plate-mounted Cherry stabilizers for...no real reason, actually.  Slightly narrower and longer.  It is possible for a plate to support both by essentially having extra small notches in the stabilizer mounting holes.
The differences are entirely historic.  There is absolutely no technical reason why somebody couldn't make a mount for costars with the same dimensions as plate-mounted Cherry stabs.  But nobody does.  I guess it's just too niche?  I've seriously thought about 3D printing my own or something.
Offline wowremy
« Reply #43 on: Fri, 02 March 2018, 18:30:21 »
Do I use plate mounted stabs for this?
« Reply #44 on: Sat, 03 March 2018, 00:57:17 »
no, PCB mount
Offline wowremy
« Reply #45 on: Sat, 03 March 2018, 03:45:43 »
no, PCB mount
Regular or screw in?
Offline Vadurr
  • Valar Morghulis
« Reply #46 on: Sat, 03 March 2018, 03:58:21 »
« Reply #47 on: Sun, 04 March 2018, 20:00:08 »
Well if you do, I'm absolutely interested.
I wonder what it would take to get a limited run of them made professionally...
Offline Randalljai
« Reply #48 on: Mon, 05 March 2018, 13:26:40 »
Will any soldering need to be done for the side led light strips or the rgb leds per switch?
Offline JDragon
« Reply #49 on: Tue, 06 March 2018, 13:14:47 »
