Author Topic: [IC]Hammer Dye-sub BSP Group buy Round4(Massdrop GB Starts)  (Read 115675 times)
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: [IC]Hammer Dye-sub BSP Group buy-Round4(Update 2/25# More choice in Tulip)
« Reply #150 on: Sun, 25 February 2018, 02:28:24 »
Does BSP still have crooked stems/ banana shifts?
I think the banana shifts are because of the material reacting through shipping them and diff temp?. I think thats also why they dont do spacebar cause of how bad it would bend for longer keys so i dont think this is a problem with the tooling. Mostly an issue with pbt i guess?
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Offline hansichen
« Reply #151 on: Sun, 25 February 2018, 03:58:08 »
It's not an issue with pbt, these molds made perfect keycaps when they belonged to Cherry. So either way the molds are ****ed up or bsp doesn't know what they are doing.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #152 on: Sun, 25 February 2018, 04:44:31 »
maybe, its just weird it happens to SP pbt too like DSA granite while its thinner, also the reason the banana defect is worst. Also have epbt sets where it happens on their spacebar thats why i only use ABS on all my boards except for my mt3 set.
Offline Hammer
« Reply #153 on: Sun, 25 February 2018, 07:33:28 »
It's really difficult to change ISO into ANSI.
What about this :blank:
Offline Nafs_asp
« Reply #154 on: Sun, 25 February 2018, 07:36:19 »
I think it would be better to switch the ] and [ so they look like [ ] next to each other.
Standing by
« Last Edit: Sun, 25 February 2018, 08:05:21 by Nafs_asp »
Offline Hammer
« Reply #155 on: Sun, 25 February 2018, 07:37:00 »
Wait I just uploaded a wrong one.
Offline avid
« Reply #156 on: Sun, 25 February 2018, 08:09:21 »
Is there more info / pics on these sets:
ANSI APL
ANSI Tulip
RGB Set
Offline Cavemann6
« Reply #157 on: Sun, 25 February 2018, 16:49:00 »
Hey Hammer, any chance for a pinkish set?
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #158 on: Sun, 25 February 2018, 18:34:01 »
ANSI APL
ANSI Tulip
RGB Set
Hey dude, here are some references for you  :thumb:
tulip - https://deskthority.net/keyboards-f2/tulip-branded-g81-3246haf-strange-azerty-t10168.html
see the previous pages of this thread for the different variations of the pretty pad printed keys
APL - https://deskthority.net/wiki/Cherry_G80-3471
and the RGB set will be colored legends on beige modifers which should look good with pretty much every BSP/Cherry style PBT set ever. Like this
Offline Hammer
« Reply #159 on: Mon, 26 February 2018, 04:30:09 »
Done ;)
Offline crtexcnndrm99
  • *profile image used without permission* ;)
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #162 on: Mon, 26 February 2018, 06:30:52 »
Done ;)
 Oh man.
 This GB can't start soon enough!
Offline avid
« Reply #163 on: Mon, 26 February 2018, 07:07:17 »
info
Thanks a lot, appreciate it!
Is the Tulip pack only the incredible ISO keys or will it be bundled as a whole 104 key set?
Offline Petch
« Reply #164 on: Mon, 26 February 2018, 09:39:16 »
Any chance of getting more than just standard ANSI 104? 75%, HHKB, 1800, etc.?
Offline sncbraxsc2
« Reply #165 on: Mon, 26 February 2018, 10:01:17 »
info
BSP is 101 (Winkeyless layout) keys. The tulip set will have 2 extra variants of the colored 3 key pack, so probably a total of 107 keys for the Tulip set unless they are sold separate to the base kit.
Offline hansichen
« Reply #166 on: Mon, 26 February 2018, 11:04:45 »
I hope the tulip keys will be seperate. Many people don't need an ansi 101 set so having these keys as a standalone would be neat
« Reply #167 on: Mon, 26 February 2018, 12:13:39 »
but i want my set to feel uniform, especially if i'm gonna drop a lot of money on caps
Offline zekkin
« Reply #168 on: Mon, 26 February 2018, 12:38:40 »
Same, I don't want to have to buy a separate BSP set just to use my BSP Tulip keys on. I'd really prefer to get the full set with the Tulip "accents."
Offline hansichen
« Reply #169 on: Mon, 26 February 2018, 13:42:40 »
Using OG caps will feel uniform and you can get proper homing keys. There is definetly a market for pure accent keys and I would like to see it as a seperate kit. Many GBs have the novelties as special kits so it wouldn't be that uncommon.
« Reply #170 on: Mon, 26 February 2018, 15:43:37 »
OG dyesubs are like twice the price of a BSP set (for a decent set) and doesn't feel the same
Offline geniekid
« Reply #171 on: Mon, 26 February 2018, 16:23:44 »
Interested in the answer to this as well.
« Reply #172 on: Mon, 26 February 2018, 16:28:09 »
No, It's BSP.
Offline geniekid
« Reply #173 on: Mon, 26 February 2018, 16:39:32 »
No, It's BSP.
What exactly about BSP prevents support for additional layouts?  I'm under the impression that BSP will provide the blanks and Hammer will be doing the dye-subbing.
« Reply #174 on: Mon, 26 February 2018, 16:43:54 »
No, It's BSP.
No R4 1.75u, so that kinda kills a lot of non-87/104 layouts.
Offline geniekid
« Reply #175 on: Mon, 26 February 2018, 16:55:17 »
No, It's BSP.
Understood.  Yes, that R4 1.75u is pretty pivotal for many of the more popular non-standard layouts.  Thanks for the clarification.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #176 on: Mon, 26 February 2018, 19:00:27 »
I never had any experience BSP being flexible about layouts in the past buys. They just made keys on what moulds they have as from what ive seen in gbs. Also, unless you already have an r5 bottom row in your layout, i dont think you can mix these with other sets.
« Reply #177 on: Mon, 26 February 2018, 19:15:31 »
Correct. BSP also doesn't have 1.25x r5 or r4. Only 1.5x.
Offline Minha
  • I Don't Want To Die Like Cobain
Re: [IC]Hammer Dye-sub BSP Group buy-Round4(Update 2/24# Add RGB Set)
« Reply #179 on: Mon, 26 February 2018, 19:54:17 »
Does BSP only make homing dots? I mean, no bars or scoops?
bro shut up, seriously
Offline Waateva
« Reply #180 on: Mon, 26 February 2018, 20:16:38 »
So in on this
Offline Techno Trousers
  • ʘ_ಠ
« Reply #181 on: Mon, 26 February 2018, 23:45:37 »
I think I'm going to be out on this, then. I don't have any old school Cherry boards with 1.5x bottom row mods.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #182 on: Tue, 27 February 2018, 09:12:42 »
I think I'm going to be out on this, then. I don't have any old school Cherry boards with 1.5x bottom row mods. YET
I corrected it for you  :p
Offline Sshimosawa
« Reply #183 on: Tue, 27 February 2018, 11:18:58 »
Sign me up.
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #184 on: Tue, 27 February 2018, 13:01:38 »
Got my BSP Desko today and i must say i am impressed.
This is actually first pbt keycaps in cherry profile which i do like.
Offline sncbraxsc2
« Reply #185 on: Tue, 27 February 2018, 13:26:19 »
weeeww, lookin' good!! That RGB set will go so well with these!
Offline donut_sauce
« Reply #186 on: Tue, 27 February 2018, 14:24:37 »
That looks awesome :thumb:
« Reply #187 on: Tue, 27 February 2018, 14:59:44 »
Ugh so nice man. Send them this way when you’re done with them :p
« Last Edit: Tue, 27 February 2018, 19:56:03 by crtexcnndrm99 »
Offline nastrovje
« Reply #188 on: Thu, 01 March 2018, 22:45:05 »
I am very hyped!
In for APL, Tulip and RGB
Offline T0mb3ry
    • Flickr
« Reply #189 on: Sat, 03 March 2018, 06:35:54 »
Did some better photos of BSP Desko.
BSP Desko by T0mb3ry, auf Flickr
BSP Desko left modifiers by T0mb3ry, auf Flickr
BSP Desko right modifiers by T0mb3ry, auf Flickr
BSP Desko navigation cluster by T0mb3ry, auf Flickr
Offline Waateva
« Reply #190 on: Sat, 03 March 2018, 08:36:42 »
damn nice
« Reply #191 on: Sat, 03 March 2018, 09:05:25 »
Hell yeah. Always loved desko
Offline Giorgio
« Reply #192 on: Sat, 03 March 2018, 09:18:30 »
BSP user
190282-0
Offline Nafs_asp
« Reply #193 on: Sat, 03 March 2018, 11:25:41 »
Hi Hammer, for Arabic SAA can we get F and J with no homing too? Just normal key for them and the usual BSP nipple
Offline Hammer
« Reply #194 on: Sat, 03 March 2018, 12:15:38 »
Let me see how many people agree with you.
(1/10)
Offline Vigrith
« Reply #195 on: Sat, 03 March 2018, 12:18:35 »
I don't like homing of any kind, I'll gladly partake in that request too.
Offline oatmicro
« Reply #196 on: Sat, 03 March 2018, 12:24:55 »
(1/10)
+1 for no homing F and J
edit: also please keep the nipples alive to avoid drama
« Last Edit: Sat, 03 March 2018, 13:24:47 by oatmicro »
Offline mech0nly
« Reply #197 on: Sat, 03 March 2018, 12:43:00 »
(1/10)
Agree
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
« Reply #198 on: Sat, 03 March 2018, 12:50:18 »
i like the nipple
i don't know why everyone hates them
Offline Nafs_asp
« Reply #199 on: Sat, 03 March 2018, 12:56:44 »
i like the nipple
I’m just suggesting having both options, might be nice since the nipple is a love/hate thing
