Author Topic: [IC]Hammer Dye-sub BSP Group buy Round4(Massdrop GB Starts)  (Read 115677 times)
Offline H3NT4I
  • 気持ちいい
Re: [IC]Hammer Dye-sub BSP Group buy Round4(Update 4/11# BIG UPDATE)
« Reply #350 on: Wed, 11 April 2018, 08:26:03 »
Gotta get in for APL and probably icon mods.  :D
Re: [IC]Hammer Dye-sub BSP Group buy Round4(Update 3/16# Add Icon mods)
« Reply #351 on: Wed, 11 April 2018, 11:32:14 »
I'm interested in a set as well, is there going to be a plain ANSI US one, without extra lettering om the keycaps? Something similar to the simple EnjoyPBT colored ones blue/purple/green ones?
Just buy EnjoyPBT if that's what you're looking for. There's more compatibility with them anyway.
BSP feels nicer tho
Right so I've not laid fingers on BSP but my understanding was that the legends are sharper and the caps feel nicer (and are maybe thicker?) than enjoyPBT. Is that about right?
Yes, the dyesubbing is the best and the caps aren't as gritty as other PBTs are. They are a little less gritty than new GMK. Thickness should be about the same
Don't forget R5 mods, I don't think enjoyPBT does them?
correct
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #352 on: Thu, 12 April 2018, 15:43:21 »
YESS
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline duynguyenle
  • Personal text? What personal text???
« Reply #353 on: Thu, 12 April 2018, 17:29:12 »
Shame this is going through assdrop
Eh... I like Massdrop, have mostly good experiences with them. Yes occasionally they **** up (sometimes badly) but if you get fed up with it, they do give you all your money back...
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Hammer
« Reply #354 on: Fri, 13 April 2018, 16:26:00 »
Link to Massdrop GROUPBUY:
https://www.massdrop.com/buy/hammer-bsp-classic-beige-pbt-dye-subbed-keycap-set
 :thumb:
This drop is set to launch on Monday, April 17th @ 6:00 am PT.
« Last Edit: Fri, 13 April 2018, 16:28:12 by Hammer »
Offline o3okevin
« Reply #355 on: Fri, 13 April 2018, 16:33:30 »
 :thumb:
Monday is April 16, is it the 17th or 16th?
Offline Hammer
« Reply #356 on: Fri, 13 April 2018, 16:35:21 »
 :thumb:
I guess it's 16th.
Offline o3okevin
« Reply #357 on: Fri, 13 April 2018, 16:35:57 »
 :thumb:
I guess it's 16th.
:thumb: can't wait
Offline The_judge_168
« Reply #358 on: Fri, 13 April 2018, 20:29:19 »
What is everyone getting?
Offline donut_sauce
« Reply #359 on: Fri, 13 April 2018, 20:59:36 »
Am I understanding right that OG ANSI is icon mod only?
Offline Cavemann6
« Reply #360 on: Sun, 15 April 2018, 02:49:46 »
 :thumb:
 :thumb:
Offline t8c
« Reply #361 on: Sun, 15 April 2018, 03:31:24 »
I hope that the icon mods are addon only. Would put OG tulip ansi buyers in a bad spot.
Offline RSC
Re: [IC]Hammer Dye-sub BSP Group buy Round4( 4/16 on Massdrop)
« Reply #362 on: Sun, 15 April 2018, 04:56:18 »
There's really no chance of split right shift compatibility, right?
Offline hansichen
« Reply #363 on: Sun, 15 April 2018, 05:57:05 »
You are right, as far as we know the 1,75u mold never existed.
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #364 on: Sun, 15 April 2018, 07:12:36 »
Quite hyped for this, gonna be joining pretty much as soon as the drop is live tomorrow morning. Need that Tulip + icon mods!
Offline avid
« Reply #365 on: Sun, 15 April 2018, 09:11:37 »
What is the best ways/sets to get extra compatability that is missing? epbt? gmk? else?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #366 on: Sun, 15 April 2018, 09:14:29 »
GMK 9009, GMK Hadapter/Hadditionals and Enjoypbt or Modern Beige in black, sir.
Sent from my mobile using Tapatalk
Offline donut_sauce
« Reply #367 on: Sun, 15 April 2018, 09:33:33 »
I agree, it’s seems odd that all the other sets would be text mods but this one is icon mod. But that’s what is shown on the renders/layouts.
« Reply #368 on: Sun, 15 April 2018, 09:55:38 »
CMYK/W and RGBK/W as well
ceresia and magenta mods also work
personally, i'm planning on using tulip OG with CMYK on a pink TGR alice
« Last Edit: Sun, 15 April 2018, 10:38:07 by Puddsy »
Offline Hammer
« Reply #369 on: Mon, 16 April 2018, 05:14:37 »
GMK I think, they have R5 cherry profile molds.
Offline rioc
« Reply #370 on: Mon, 16 April 2018, 06:02:56 »
Does BSP feel more like ABS or PBT? (I'm just interested in making it ISO Enter and split left shift compatible, in case I need it)
Offline nzhoward
« Reply #371 on: Mon, 16 April 2018, 07:13:25 »
Well BSP uses the same tooling as OG cherry dyesubs. So it is PBT. not sure how it could feel ABS..
Offline rioc
« Reply #372 on: Mon, 16 April 2018, 07:15:07 »
well yeah, I got that, but that doesn't determin the feeling and properties (maybe initial feeling, but idk if it smoothens out over time like abs or keeps the texture like pbt)
Offline nzhoward
« Reply #373 on: Mon, 16 April 2018, 07:18:22 »
They dont shine like ABS. These are as close to OG cherry as you can get.
Offline nastrovje
« Reply #374 on: Mon, 16 April 2018, 07:51:10 »
PBT is harder and more brittle. The caps keep the texture longer, feel a bit colder and your fingers don't stick to it as much as with abs.
They also sound differently of course, which is just a question of preference. I like deep thocks, so the thicker the better for me.
These Bsp sets are a tiny bit thicker than epbt for example.
Regarding texture, OG Cherry Sets and BSP are produced pretty smooth from the start.
Compared to epbt for example you definitely feel a difference.
epbt is still great though and I use a set in rotation all the time.
There are people who prefer the epbt texture, people who will only ever type on topre texture and people who prefer the smooth textures. There are even confused people who love shine on abs :))
So If I were you, I'd just order a set and try it out and find your type. Not much you can do wrong here. :thumb:
e/ For compatibility purposes, just go with whatever matches the color the best tbh. Having a different texture on a board interestingly doesn't annoy me
« Last Edit: Mon, 16 April 2018, 08:03:31 by nastrovje »
Offline rioc
« Reply #375 on: Mon, 16 April 2018, 08:23:38 »
oh man... I must still be hungover from the weekend... I kept thinking these were made out of a different plastic called BSP... not realizing they're our standard PBT material... oh well, I'm in
Offline nzhoward
« Reply #376 on: Mon, 16 April 2018, 10:22:27 »
lolol i was quite confused by how you phrased your questions. BSP is the name of the company who manufactures the caps. They purchased the Cherry original PBT tooling back when Cherry sold everything. :thumb: Can't go wrong with BSP
Offline rioc
« Reply #377 on: Mon, 16 April 2018, 10:42:01 »
yeah, I finally got it in the end... I was googling BSP Plastic compound without getting a usable result until I realised that's the company name  :))
Offline dubious
  • 쏘쿨
Re: [IC]Hammer Dye-sub BSP Group buy Round4(Massdrop GB Starts)
« Reply #378 on: Mon, 16 April 2018, 11:33:31 »
BGB buy period is only one week? Damn, I was hoping to get this set
also looks like the price got mass-upped  :eek:
« Last Edit: Mon, 16 April 2018, 12:10:18 by dubious »
« Reply #379 on: Mon, 16 April 2018, 18:04:53 »
he said in slack that it had to go up about $10 from previous GBs, and then massdrop fees got added on top of that
so it's many
Offline Hammer
« Reply #380 on: Mon, 16 April 2018, 18:33:40 »
so it's many
They didn't add puddsy.
Peacock sold $159 in the past and Arabic sells $169.
Just add 10 dollars in this drop.
Tulip has lots of extra key, that make it more expensive, but I think it's worth to pay more 25 usd for the extra 6 side printed keys.
« Reply #381 on: Mon, 16 April 2018, 19:17:50 »
so it's many
ah, that makes a lot more sense, thanks
i guess i misunderstood, sorry
Offline Hammer
« Reply #383 on: Wed, 18 April 2018, 02:00:08 »
I think it's even better than the renders.
« Reply #384 on: Wed, 18 April 2018, 12:30:27 »
i'm tempted to agree
Offline M
« Reply #385 on: Wed, 18 April 2018, 13:38:08 »
Might be the lighting , but I wasn't expecting the Cream one to be that bright. I think that's a good thing though imo
Offline Hammer
« Reply #386 on: Wed, 18 April 2018, 20:15:53 »
It's becoz of the light this picture can tell Billy. :)
« Last Edit: Wed, 18 April 2018, 20:19:47 by Hammer »
Offline M
« Reply #387 on: Wed, 18 April 2018, 20:27:50 »
lol alright thanks
Offline OmegaSupreme
  • For Cybertron!!!
« Reply #388 on: Thu, 19 April 2018, 14:54:47 »
Getting APL for sure but still deciding between OG and GK Tulip.
What is everyone else getting?
« Last Edit: Thu, 19 April 2018, 22:09:30 by OmegaSupreme »
| TX-CP | Dolphin V3x 2 | Dolphin Padx 2 | Unicorn X Legend | Jane V2 | Jane V2 CE |
« Reply #389 on: Thu, 19 April 2018, 18:24:15 »
Getting APL for sure but still deciding between OK and GK Tulip.
i considered GK, but went with OG since i'm gonna use it on a pink board with cmyk
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #390 on: Thu, 19 April 2018, 19:16:57 »
If I get the APL kit, will that help me learn APL?
Offline Hammer
« Reply #391 on: Thu, 19 April 2018, 19:49:43 »
Oh dear we just offer you the tools :D
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Last Edit: Fri, 20 April 2018, 08:25:30 by Signature »
