Author Topic: [IC]"60% G80" A GH60 compitable keyboard(case) base on G80-3000 serial  (Read 58977 times)
Offline _Entropy
Re: [IC]"60% G80" A GH60 compitable keyboard(case) base on G80-3000 serial
« Reply #50 on: Mon, 05 March 2018, 18:22:39 »
Oh man, this is awesome. I've been looking for more retro case designs for a long time, and it's awesome to see some of these happening!
Offline SixtyLife
« Reply #51 on: Mon, 05 March 2018, 18:52:12 »
I need this
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline ricyuyc
« Reply #52 on: Tue, 06 March 2018, 00:54:31 »
Have been busy for these days, launching a trial or small scale group buy in China. by now, 10 units sold at ¥1588 (around $250). Many friends can't accept with just the case, they hope PCB and plate included in the box. and there is a  problem might killing the PCB compatibility, this design is too thin that there is no enough space below the PCB, only 2.75mm height there. those PCB with a DIP switches or components higher then 2.75mm below it won't fit this case. ???  wow, there is a long way to go.
Anyway, here are some new photos, hopes you will love it.
THX for the info sharing, I like the streamline design so much.
Would you consider to offer retro style powder coating like Norbauer did?
Royal black wrinkle
Galaxy Console
« Reply #53 on: Tue, 06 March 2018, 01:15:30 »
Royal black wrinkle
Galaxy Console
FYI it seems that he renamed the powder colors, or these are just ones i can't find
Offline ricyuyc
« Reply #54 on: Tue, 06 March 2018, 02:11:18 »
Royal black wrinkle
Galaxy Console
They arewere available for realforce case.
https://shop.norbauer.com/products/the-norbaforce-cnc-aluminum-housing-for-realforce-keyboards?variant=627242500104
« Reply #55 on: Tue, 06 March 2018, 02:50:26 »
Royal black wrinkle
Galaxy Console
ah my mistake
i was talking about the names of the actual powdercoat colors on prismatic powders, not in norb's usecase
since i search for everything on there i sometimes get a bit lost with norb's color names
Offline unausgeschlafen
« Reply #56 on: Wed, 21 March 2018, 07:34:56 »
I would deffinetly take one (maybe two) if there is only aluminum.
I would take two if there was plastic (like 2 plastic, or one each).
I am loocking foward to seeing this happen!
Offline R4WBIT
« Reply #57 on: Wed, 21 March 2018, 07:45:16 »
Any chance of a HHKB-style blocker-top happening? :D
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #58 on: Wed, 21 March 2018, 08:12:26 »
Would buy. Was sad I never had a chance to purchase a J80, this will be nice  :thumb:
Offline dubious
  • 쏘쿨
« Reply #59 on: Wed, 21 March 2018, 18:56:47 »
this looks really nice :thumb:
Offline FrostyToast
  • Litshoard
« Reply #60 on: Wed, 21 March 2018, 19:01:29 »
Just a question:
If the case is already a 2 piece design, why is it still standoff mounted instead of mounting the plate to the top case? Usually standoff mounts are for 1 piece cases that can't be mounted any other way.
Quote from: elton5354
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #61 on: Wed, 21 March 2018, 19:55:00 »
G80 style case always looks good :cool:
Offline crusader_alex
Looks very very nice
Sent from my ONEPLUS A5000 using Tapatalk
Offline Pwner
  • soon™
« Reply #63 on: Thu, 22 March 2018, 05:59:21 »
Just a question:
I'm going to guess because of the usb daughterboard due to bezel size to keep it compatible with standard 60% pcb's.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #64 on: Thu, 22 March 2018, 07:38:53 »
Following for interest :thinking:
Offline turbosloth
« Reply #65 on: Fri, 23 March 2018, 03:12:04 »
Love it, looks real good. We need more vintage-y looking cases, now if we could get it in a nice beige that would be swell
Offline HotRoderX
« Reply #66 on: Fri, 23 March 2018, 03:17:57 »
How does one mount the center USB? This is a cool design and I like how unique it is. I Just can't for the life of me understand how the USB portion is meant to function. Also would this use standard size plates? Are would you just go plateless? Once again love the unique design this is really cool and not something you see every day if ever.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #67 on: Fri, 23 March 2018, 23:30:09 »
I need this
Your avatar is giving me PTSD.
Offline rioc
« Reply #68 on: Mon, 26 March 2018, 09:32:45 »
definitely interested in this
Offline jebbra
  • jebbra.net
« Reply #69 on: Wed, 28 March 2018, 04:35:50 »
Looking at the trial run and it looks really good!  :thumb:
If I may add some suggestion, looking at this photo:
192593-0
I think it is better to use the bezel width pointed by the green arrow instead of the one pointed by the violet arrow (see below image for reference)
192595-1
As I think the added width will give a more balanced looks compared to bezel on the left and right side.
« Last Edit: Wed, 28 March 2018, 04:39:35 by jebbra »
Offline xondat
  • i'm not a star
« Reply #70 on: Wed, 28 March 2018, 05:35:41 »
Agree with this, and I think reducing the top just a little more for balance too would look ever better.
It still looks amazing though.
Offline thokir
« Reply #71 on: Wed, 28 March 2018, 05:42:31 »
[..] reducing the top just a little more for balance [..]
IIRC reducing the top isn't possible because the case is quite flat and the design of the PCB and/or (?!) USB daughter board would need to be changed.
Offline BillyTheMute
« Reply #72 on: Wed, 28 March 2018, 06:46:32 »
+1 the top is to tall and there needs to be spacing at the bottom.
Offline jebbra
  • jebbra.net
« Reply #73 on: Wed, 28 March 2018, 07:24:16 »
I personally don't mind the thicc top though, I even prefer it thicc as it is literally the homage to G80-1800 IMO.
Offline thokir
« Reply #74 on: Wed, 28 March 2018, 07:27:38 »
It is in some way the main part of this design, the thing that really stays in mind. Without the big top bezel it'd be more like a dozen others..,.
Offline sujikinen
« Reply #75 on: Wed, 28 March 2018, 10:14:44 »
https://imgur.com/a/kHnEh
I got these pics from author,as you can see,it used as place to put battery
to power bluetooth pcb.
« Reply #76 on: Wed, 28 March 2018, 10:27:13 »
I never said it needed to be removed, just shortened a little.
Offline HotRoderX
« Reply #77 on: Thu, 29 March 2018, 02:51:13 »
I like the thick top it was the thing that made me even take a second look at the case. I don't think the bottom is to thick either! I kinda like the case overall as is from the photo! I am just wondering about price. That would be the major factor in if I want to buy in or not.
Offline hahihuhei
« Reply #78 on: Thu, 29 March 2018, 03:05:20 »
I do not think the top is too thick:
https://imgur.com/a/RV7dj
Offline TonyD
    • dtronixs
« Reply #79 on: Thu, 29 March 2018, 05:04:14 »
love the "classic" style
Offline ojrask
  • juuh elikkäs
« Reply #80 on: Thu, 29 March 2018, 06:32:14 »
The bulky top is good as is. Maybe add a millimeter or two of spacing between keys and the bottom wedge, but OK as is too.
Current:
Coming up:
IC/GB:
Offline schmoktopus
« Reply #81 on: Thu, 29 March 2018, 06:52:31 »
+1, would keep it a bit more original
Offline DasGnome
« Reply #82 on: Thu, 29 March 2018, 10:28:33 »
Definitely agree with this. I think making the bottom more consistent with how the G80 alphas are spaced away would also help balance out the top. It would take it from ok to perfect :)
Offline Poesjuh
Agree, not to much though, 2/3 mm is prolly enough.
Edit: any idea on timing by the way? Good chance I'm gonna join this stuff, want to know when to get excited :P
« Last Edit: Sat, 31 March 2018, 11:28:55 by Poesjuh »
Offline Arhipio
  • TheBananaMan
« Reply #84 on: Wed, 04 April 2018, 02:11:03 »
Just a little on the bottom would be great, otherwise this is one of the sexiest 60 cases I have seen in a while. Awesome stuff!
Offline SixtyLife
« Reply #85 on: Wed, 04 April 2018, 13:34:47 »
I'm ok w the bottom. looks more like g80-3000:
Offline iliketimex
« Reply #86 on: Thu, 05 April 2018, 13:05:06 »
Interested, always liked the original design.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #87 on: Sat, 14 April 2018, 15:58:40 »
I know a lot of people like the existing bulky top, but I would be much more into it if it was "functional" somehow. It's something I don't understand about the original design, either.
A lot of people start to panic when I talk about having an indent or lip for holding a pen, but I personally think it'd be a major usability improvement for *any* keyboard, and could justify the large top bezel even on a small desk.
Another alternative could be indicator lights, or a cutout for a nameplate that the user could replace with an OLED or something.
But nobody else probably wants those things... :))
Offline LightningXI
  • PPD
    • ArtisanMacro
Please keep the classic G80 look!
Sent from my mobile using Tapatalk
Offline babyfeets
« Reply #89 on: Sat, 14 April 2018, 16:18:21 »
I'm saving for this and I say your original, simple design is just right for me. I don't see a need to change the wedge to 1800 style either.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Replying here so I don't forget about this.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline DMacKB
I’d love to put a dz60 in this. Also plastic would be great so i can spray/dip it different colours!
Offline Windeh
  • a no name
Interested. Any updates?
Offline midnight2903
Lovely design. Though I feel that with that top piece, it would be much better to have a top/sandwich plate as compared to tray mount. But I guess that would be more cost and also harder to get plates for the board, so it's a tradeoff.  :thumb:
Offline rioc
Same!
After all it's supposed to be a 60% adaptation of the g80-3000, so that's exactly how I expect the case to be! :)
Offline hineybush
  • student of error
    • hineybush keyboards
This looks fantastic, it might be the only 60% I'd buy.
Do you have an estimate for how much it'd weigh?
« Last Edit: Mon, 07 May 2018, 13:19:15 by hineybush »
Offline peggisan
What usb types will this support? Would definitely get one if its not too expensive and has typeC.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
+1  Agreed
WTB/WTS/WTT ---->
Offline hineybush
  • student of error
The cool thing about having a separate USB board is being able to switch between USB types, ideally
Also, Cerakote options would be cool.
Offline beekey
« Reply #99 on: Sat, 23 June 2018, 08:40:07 »
Any update, is this going to happen?
