Author Topic: [IC] Orange75 & Orange Pad (GB open)  (Read 65233 times)
Offline oldcat
  • 65% is Life
Re: [IC] Orange75 & Orange Pad
« Reply #150 on: Fri, 06 April 2018, 12:58:52 »
Looks like it is already launched in the Chinese store at zfrontier, any idea when this will launch on the English version of zfrontier or other places are you launching with?
Offline hndle
« Reply #151 on: Fri, 06 April 2018, 13:50:17 »
I just saw it.
but purchase time just a one day? :eek:
I think something is wrong.
« Last Edit: Fri, 06 April 2018, 13:52:23 by hndle »
Offline mint
« Reply #152 on: Fri, 06 April 2018, 13:59:52 »
Oh damn...it says limited to 59 pieces on their preview post as well.. https://www.zfrontier.com/post/detail/5954
Did they change their minds about making it international?
Offline HotRoderX
« Reply #153 on: Fri, 06 April 2018, 17:01:31 »
guys calm down!! nothing to worry about I don't think. if not mistaken Orange TKL and Timeless both launched with limited runs in the Chinese market before going live world wide. If I am not mistaken they where limited to like 50/25 last time. This makes since if I am right that they have a limited run then do the full group buy.
Offline senter
« Reply #154 on: Fri, 06 April 2018, 17:44:34 »
You are right. GB will be launched on zFrontier's international site in two days or so. I hope so :)
Offline oldcat
  • 65% is Life
« Reply #155 on: Fri, 06 April 2018, 20:12:53 »
hmm, by reading the descriptions I assume those early buyers on the chinese site get a free numpad?
Offline oldcat
  • 65% is Life
« Reply #156 on: Fri, 06 April 2018, 20:14:35 »
yeah, hope so!
Does anyone know if any of the PCBs used will be hot swappable?
Offline oldcat
  • 65% is Life
« Reply #157 on: Fri, 06 April 2018, 20:22:41 »
Will definitely get a pad to match my pizza80, it's good to see you back Senter!
A numpad without the logo would be appreciated
Thanks Simon. It was CNY and I was in a car accident. now I'm back  :D
I'm not satisfied with the current numpad design. Without a logo, do you think 4 top macro keys look good?
Sir, will the pcb support hot-swapping switches? Thank you very much.
Offline HotRoderX
« Reply #158 on: Fri, 06 April 2018, 21:42:37 »
no the keyboard won't be hot swap but requiring soldering skills.
Offline oldcat
  • 65% is Life
« Reply #159 on: Fri, 06 April 2018, 22:10:53 »
Would it be possible to install those hot swapping sockets on the pcb?
Offline HotRoderX
« Reply #160 on: Sat, 07 April 2018, 02:40:17 »
it would depend. The type of hot swap socket used on a K-Type etc.. wouldn't work. There are some cheaper less secure versions that might work just depends on the pin holes on the PCB. it really be hard to say. I would just assume they wouldn't because most people I heard that use those types of sockets solder then in once installed for added security. Which kinda defeats the entire purpose of a shotswap socket in my opinion.
Offline nevaenuf
« Reply #161 on: Sat, 07 April 2018, 14:40:52 »
any photos of the PCB?
Offline mint
« Reply #162 on: Sat, 07 April 2018, 16:51:23 »
There are some photos of the Orange TKL PCB in this review: https://www.ptt.cc/bbs/Key_Mou_Pad/M.1513424671.A.913.html
Don't know how relevant it is for the 75's PCB though
Offline Theswetiyeti
« Reply #163 on: Sat, 07 April 2018, 17:11:30 »
I'm vary interested
Offline oldcat
  • 65% is Life
« Reply #164 on: Sat, 07 April 2018, 21:34:25 »
Thanks! just feel that disordering is a lot of work. Would love to have a hot-swappable option....
Offline senter
« Reply #165 on: Sun, 08 April 2018, 08:53:32 »
Lookin' really good!   How heavy will the Orange75 be?
IDK. We didn't make brass Orange 75 prototype. The estimated weight is 4kg but don't count me on this. The density of brass alloy is about 3 times as 6063 aluminum.
Offline senter
« Reply #166 on: Sun, 08 April 2018, 08:54:39 »
GB post has been submitted. GB ends 10 days after GB starts.
Offline senter
« Reply #167 on: Sun, 08 April 2018, 09:41:41 »
