Author Topic: [IC] MIX profile "Big Bang" Ortholinear Keycap Set available on KBDfans  (Read 10602 times)
Offline muni_chang
  • Keyboarding Kills
Fit for:
1. Planck and clones
2. Preonic
3. XD75
4. Atreus and Atreus62
5. Diverge TM 2
6. Terminus Mini 2
7. Diverge 3
And any keyboards with 1u grid-spacing up to 15x5
PBT dye-sub
Available on KDBfans NOW
« Last Edit: Sun, 11 March 2018, 07:15:34 by muni_chang »
Keyboarding Kills
Offline jebbra
  • jebbra.net
Re: [IC] MIX profile "Big Bang" Ortholinear Keycap Set
« Reply #1 on: Fri, 09 March 2018, 05:17:08 »
Nice to see another Planck keyset will be run!
Offline AMongoose
  • happy workman user
« Reply #2 on: Fri, 09 March 2018, 06:58:35 »
Can you give as a side view of the profile?
That jump from R1 to R2 seems huge.
is this cylindrical or spherical?
Offline muni_chang
  • Keyboarding Kills
« Reply #3 on: Fri, 09 March 2018, 08:07:50 »
It's spherical and I will check again about the R1 and R2 is correct or not
Keyboarding Kills
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #4 on: Fri, 09 March 2018, 09:09:47 »
Finally a MIX profile set with proper legends! :eek: Been interested in the MIX profile since I first saw it, but the fact all the sets i could find had laser etched legends was a huge turn off to me. Also I really need a dedicated set for my Let's Split & this is looking to fit the bill perfectly! I almost pulled the trigger on the Acute set that was on MD last week, but decided against it since it was OEM profile.
Offline saucybulgogi
« Reply #5 on: Fri, 09 March 2018, 10:40:10 »
MIX profile looks cool. Hopefully I can afford this when it goes live!
Offline Visionaire
« Reply #6 on: Fri, 09 March 2018, 11:41:08 »
That looks really solid. I'm interested.
Offline InvidiousIgnoramus
« Reply #7 on: Fri, 09 March 2018, 12:31:47 »
Oh, hello, an IC for a MIX set? Color me interested.  :p
I long for the day when I find a beamspring. (At a not insane price)
Offline bluesclera
« Reply #8 on: Fri, 09 March 2018, 14:45:29 »
Pbt is nice but already have white and grey combo. Plus very similar to Xda.
« Last Edit: Fri, 09 March 2018, 14:47:37 by bluesclera »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #9 on: Fri, 09 March 2018, 18:52:11 »
Man, I love MIX and I want it to take off. But these colors really aren't good. RGB or CMY would have been a big hit. Please reconsider.
Offline muni_chang
  • Keyboarding Kills
« Reply #10 on: Fri, 09 March 2018, 22:11:53 »
below $50 include international shipping fee on KBDfans :p
Keyboarding Kills
Offline muni_chang
  • Keyboarding Kills
« Reply #11 on: Fri, 09 March 2018, 22:16:02 »
it's not white grey, it's light grey with darker one and row 112344
Keyboarding Kills
Offline muni_chang
  • Keyboarding Kills
« Reply #12 on: Fri, 09 March 2018, 22:20:41 »
Thank you for your advise, we will consider it, we plan to make 104+WKL with CMYK in near future just after the "Big Bang" :p
Keyboarding Kills
Offline CaedanLavender
« Reply #13 on: Fri, 09 March 2018, 22:22:48 »
If it's going to offer support for the XD75, then could you add a couple of 3u space bars?
Still, very interested in this set.
Offline muni_chang
  • Keyboarding Kills
« Reply #14 on: Fri, 09 March 2018, 23:33:27 »
Sorry we don't have plan to add 3U space bar, only fit the original XD75
Keyboarding Kills
Offline muni_chang
  • Keyboarding Kills
« Reply #15 on: Sat, 10 March 2018, 21:00:02 »
Keyboarding Kills
