Author Topic: UNIFORM - R4 Cherry Profile Keyset  (Read 6029 times)
Offline koduh
« on: Mon, 02 April 2018, 20:12:00 »
Uniform Cherry Profile : Dolch? Beige?
With all the hype from people about new keycap profiles I am here to propose something a tad different with an existing profile we all know and love: Uniform Cherry.
I am proposing to do a set using all Row 4 keycaps (bottom row) making it completely uniform. This allows less keys in the full kit to cover more boards similar to DSA sets, whilst keeping some angle to the typing experience.
Why Row 4?
That is simple: Because the keycaps/molds already exist in all sizes in R4: 1u | 1.25u | 1.5u | 1.75u | 2u | 2.25u | 2.75u | 6u | 6.25u | 7u
Cost?
Still TBD - Still kicking tires with the idea to see if its worth pursuing further.
Some may be worried about spending too much on something they will dislike; thus I propose that the initial run we do a small kit that can cover 65% and smaller boards, so the debut of a uniform cherry set isn't as harsh on the wallet.
Material?
With the goal of keep cost down I'd like to do a PBT Dyesub kit. I have spoken to a company that believes they can do some good reverse dye sub, so I'd like to challenge them with doing a Dolch style reverse dye sub. If that is unrealistic then a plain beige ala Enjoy PBT set will have to do.
Kit?
65% and smaller; feedback welcome but know I want to keep the kit as small as reasonably possible with covering as many common compact boards as we can.
Option 1 - Plain Beige
Option 2 - Dolch
But my ORTHO! But my 38.35%!
Like I said kit is open for discussion, but we can't add too many keys so this can be cheap cheap cheap!
(PS - Love note from a non 40% user here; can you 40% keyboard designers get on the same page when it comes to keysizes??? k thx bye)
Are you nuts?
Probably but I have tested the theory out mix and matching a bunch of other sets and I am quite satisfied. Granted its not 100% like Cherry but the uniform sculpt is better than flat DSA anyday.  :thumb:
Offline Sshimosawa
Re: UNIFORM - R4 Cherry Profile Keyset
« Reply #1 on: Mon, 02 April 2018, 20:15:41 »
Incredibke idea.
« Reply #2 on: Mon, 02 April 2018, 20:17:17 »
i can't read ignore me
Offline Vadurr
  • Valar Morghulis
« Reply #3 on: Mon, 02 April 2018, 20:17:28 »
In  :thumb:
Offline stryker09
« Reply #4 on: Mon, 02 April 2018, 20:47:37 »
I'd be interested on the 60% Dolch version, but could you do matching green alphas instead ala green on dolch? :D
Offline koduh
« Reply #5 on: Mon, 02 April 2018, 21:01:40 »
Sorry Charlie. Trying to keep it plain jane.
Offline kmba
  • Formerly tameone
« Reply #6 on: Mon, 02 April 2018, 21:18:58 »
homing keys.
keyboards.
Offline hahihuhei
« Reply #7 on: Mon, 02 April 2018, 21:33:59 »
How about the bar/scoop F/J? is that possible?
but I think this should be minimum investment :)
Edit: didn't notice it was asked too.
« Last Edit: Mon, 02 April 2018, 21:40:22 by hahihuhei »
Offline koduh
« Reply #8 on: Mon, 02 April 2018, 22:47:40 »
homing keys.
Yeah, I forgot to mention homing keys. We will have to inquire with the manufacturer as to feasibility of R4 homing keys.
Offline Myoth
« Reply #9 on: Tue, 03 April 2018, 03:41:14 »
as far as I know the asdf row feels like more like a uniform profile than this, and I've tried it
Offline a_ak57
« Reply #10 on: Tue, 03 April 2018, 04:02:53 »
I get that the R4 molds are convenient, but I can't honestly imagine that slope being a comfortable typing experience on the upper rows (edge-hitting seems like it'd be pretty common).  R2 would probably be the best choice since it's more neutral than R3/4 but not as tall as R1.
« Last Edit: Tue, 03 April 2018, 04:04:25 by a_ak57 »
Offline thokir
« Reply #11 on: Tue, 03 April 2018, 05:05:14 »
Hm, I can't really imagine this to feel good to type on... I need to set up that profile at home later and give it a try.
Offline pr0ximity
« Reply #12 on: Tue, 03 April 2018, 05:50:36 »
That keyboard picture makes it look like typewriter profile, was that actually comfortable to type on?
Offline AMongoose
  • happy workman user
« Reply #13 on: Tue, 03 April 2018, 06:01:07 »
If there are "T" and "N" homing keys (with bars preferably) i'm in.
Probably wouldn't hurt to put dvorak homing keys as well or even some blank homing keys. This set could be a great thing for alternate layout users that prefer cylindrical caps.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #14 on: Thu, 26 April 2018, 20:13:37 »
I ordered a bunch of R3 and R4 blanks from KBDFans to test out. So far so good -- definitely in for this.
