Author Topic: Soldering feedback  (Read 1842 times)
Offline ju6ju8Oo
Soldering feedback
« on: Thu, 05 April 2018, 23:52:00 »
I'm a beginner on soldering.
https://imgur.com/a/yMBkz
are the solder joints okay?
And, I couldn't notice the difference between 63/37 and lead free 3% silver, except 63/37 smells bad
Offline thokir
Re: Soldering feedback
« Reply #1 on: Thu, 05 April 2018, 23:58:52 »
Yeah, those are totally fine.
Leadfree solder needs a bit more heat to get soldered, but with most soldering irons that's not a problem. The bad smell on the 63/67 is due to the lead.
I prefer solder with lead over lead-free solder, when you solder quite a bit and try to be fast you actually are faster unless you have a high-power soldering iron.
Offline Leslieann
« Reply #2 on: Fri, 06 April 2018, 06:40:38 »
You will only smell lead if you burn it and that would be bad, the smell is the flux, which is still bad for you, just in a different way.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
