Author Topic: HS60 PCB - Hotswap 60% with SMD RGB LED's (V3 Shipping Soon)  (Read 125951 times)
Offline Mechboards
  • Mechboards UK
    • Mechboards
Re: [GB] HS60 PCB - Hotswap 60% with SMD RGB LED's
« Reply #50 on: Mon, 30 April 2018, 05:38:12 »
Group Buy Complete. 75 orders. Will update this thread. Thanks all!
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #51 on: Thu, 03 May 2018, 06:37:18 »
GB Update No 1:
PCB's are in production.
All parts/components have been ordered
Offline TheDankMatter
  • Ladies & Gentlemen, We Are Floating In Space.
« Reply #52 on: Tue, 08 May 2018, 06:47:10 »
Any updates if HHKB will be available for purchase? Waiting with unbuild TX60 HHKB for this pcb.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #53 on: Tue, 08 May 2018, 10:32:00 »
Olivia and I have commissioned a limited run to test a HHKB layout - david from Mechboards might run after :)
Offline Vadurr
  • Valar Morghulis
« Reply #54 on: Tue, 08 May 2018, 11:11:23 »
I'd be in for a few if this is true! :thumb:
Offline profanum429
« Reply #55 on: Tue, 08 May 2018, 11:31:34 »
I'd definitely be in for some of these!
Offline JDragon
« Reply #56 on: Tue, 08 May 2018, 12:36:47 »
Will TKC have extras for purchase for those of us in the US that missed the GB?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #57 on: Tue, 08 May 2018, 23:37:37 »
definitely be interested as well.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #58 on: Wed, 09 May 2018, 02:07:47 »
Count me in
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #59 on: Thu, 10 May 2018, 05:06:19 »
Bare PCB's have arrived, time to pick n place!
195421-0
Offline pixelpusher
« Reply #60 on: Thu, 10 May 2018, 11:27:24 »
Nice!  Glad to see those left shift stabilizer holes cut out.  Not that I didn't trust you... but y'know.
You say bare, so does that mean you are doing all of the surface mount soldering?
Last question... when could one expect these boards to leave you and be en route to us?
Offline enrique.aliaga
« Reply #61 on: Thu, 10 May 2018, 15:55:04 »
Hey guys! I'm excited to get this PCB and do my very first build!
Any recommendation for a nice aluminum plate to go along this PCB?
I've seen Sentraq selling one in their website (with a nice Champagne Gold color); and am also aware of KBDfans selling them in their stores. Are these good options? Any other vendor I should be aware of?
Thanks!!
« Last Edit: Thu, 10 May 2018, 16:35:37 by enrique.aliaga »
Offline pixelpusher
« Reply #62 on: Thu, 10 May 2018, 16:24:55 »
Hey guys! I'm excited to get this plate and do my very first build!
Thanks!!
Both of those plates are fine and basically the same quality.  I've ordered two from each vendor.  I had a problem with one from KBDFans where the side had been crushed a bit and I couldn't get it back in the right shape (which is usually pretty easy for aluminum), and they sent a replacement quickly.  The only ones I've had issue with is the ones made for costar stabilizers (i think they sell them on aliexpress and ebay both).  The plate was too large to fit most of my 60% cases.  But the ones you mention shouldn't have that issue.
Offline Anaconda
« Reply #63 on: Mon, 14 May 2018, 13:13:23 »
How long until these ship? really excited to get mine  ;D
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #64 on: Tue, 15 May 2018, 05:36:36 »
All ordered ISO's have been completed. I just need to pick them up and get them posted which will happen over the next week or so :)
195683-0
Offline meliewx
« Reply #65 on: Fri, 18 May 2018, 09:47:52 »
Just a little snap of mine from the livestream build. Enjoy your pcbs everybody once they're shipped!
« Reply #66 on: Fri, 18 May 2018, 10:07:24 »
I would like to see an ISO only plate on your website. Universal plate might be really loose with kailh hotswap sockets for a 60% board. There is really no one selling ISO only plates any where.
It’s something I’ve mentioned to David as well. I’m doing a livestream build of a prototype HS60 a week today with Meliewx - we will be using a universal plate so will be able to confirm then
Hey guys, I finally ordered a Sentraq aluminum plate in Universal Layout. I am worried now that maybe I should have got the ANSI one instead.
Are the Kailh hot swap sockets loose on Universal Plates?
P.S.: I may still have time to change my Sentraq order.
« Last Edit: Fri, 18 May 2018, 10:14:26 by enrique.aliaga »
Offline Lisinge
« Reply #67 on: Fri, 18 May 2018, 10:46:27 »
It's really not that bad but yes some switches will be a bit looser than others where there is no alu on top or bottom of the switch where the switch clips are at, for example the pipe key.
I i were you and i got a ansi pcb them i would get the andi plate. Your switches will have a better fit and if you want to you could always so the plate later
« Reply #68 on: Fri, 18 May 2018, 13:25:59 »
Thanks a lot, man!
I’m gonna try to get my order changed and get an ANSI one instead of the Universal.
Sent from my iPad using Tapatalk
Offline rjsf
« Reply #69 on: Tue, 22 May 2018, 15:26:49 »
How about the ANSI PCBs? Have they started shipping out already? Will you update our Paypal with the tracking number?
Offline Eon2001
« Reply #70 on: Fri, 25 May 2018, 12:42:07 »
An update on ANSI PCBs would be appreciated.
« Last Edit: Sun, 27 May 2018, 10:37:18 by Eon2001 »
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #71 on: Sun, 27 May 2018, 19:01:43 »
ANSI PCB's are on the way to us now. They will be split into proxy and non-proxy and then shipped over the next week or so :)
Offline Skaazi
« Reply #72 on: Mon, 28 May 2018, 14:26:52 »
 Thanks for the update! I'm looking forward to it.
Offline Anaconda
« Reply #73 on: Tue, 29 May 2018, 18:53:27 »
When are the ISO ones shipping? it's end of the month already.
Offline Vadurr
  • Valar Morghulis
« Reply #74 on: Tue, 29 May 2018, 19:11:24 »
Anyone have any information regarding HHKB pcbs?
Offline GreyAmbience
  • I can stop when ever I want
« Reply #75 on: Thu, 31 May 2018, 01:53:07 »
Does anyone have the standard ISO layout as a hex file?
Offline Skaazi
« Reply #76 on: Fri, 01 June 2018, 18:03:35 »
Got the email to pay TKC for proxying. :thumb:
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #77 on: Sat, 02 June 2018, 07:53:11 »
So all individual orders have been either shipped for EU customers, or shipped to US proxy. All other orders that are combined with GMK stabs (for example) will need to wait till mid June sadly as that is when GMK will ship.
Here are the ANSI ones
196915-0
Offline yonghf
« Reply #78 on: Sat, 02 June 2018, 10:06:18 »
I sent an email regarding Order #1143.
Offline Lisinge
« Reply #79 on: Sat, 02 June 2018, 11:41:38 »
Haven't gotten any tracking info but maybe there are no tracking? I ordered only PCBs
Offline Yeoh
« Reply #80 on: Tue, 05 June 2018, 09:13:13 »
No tracking here, either.
I guess time will tell.
Offline nimblejacks
« Reply #81 on: Sat, 09 June 2018, 08:01:48 »
So if I ordered the GMK Stabs and an ANSI PCB and am located in the NA, when can I expect to receive my stuff?
Offline Darknight00z
« Reply #82 on: Wed, 13 June 2018, 15:33:28 »
Has it been shipped yet? I've just ordered a PCB
Offline manitoid
« Reply #83 on: Wed, 13 June 2018, 23:07:26 »
Any way to still get in on the ANSI PCB in the US? Would love one of these.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #84 on: Thu, 14 June 2018, 03:41:35 »
We're still waiting on GMK to send their stabs so all orders with those included are delayed. We'll have extras available soon, in the next couple of days or so.
Sent from my F5121 using Tapatalk
Offline Fatboychard
« Reply #85 on: Thu, 14 June 2018, 03:54:12 »
Are all the other orders without GMK stabs shipped? Im waiting on a Ansi pcb.
Offline Lisinge
« Reply #86 on: Thu, 14 June 2018, 04:23:49 »
Can you please ship my order for just the PCBs? I messaged you on FB and are eager to getting them built...
Offline Yeoh
« Reply #87 on: Fri, 15 June 2018, 22:38:22 »
Wondering if anyone has received an hs60 yet?
I thought these were shipped at the beginning of the month?
Offline Skaazi
« Reply #88 on: Mon, 18 June 2018, 00:30:20 »
Nothing here in the US yet.
Offline pixelpusher
« Reply #89 on: Wed, 20 June 2018, 10:48:45 »
I'm in the US.  Just got email that shipping label has be created  :thumb:
Offline yonghf
« Reply #90 on: Thu, 21 June 2018, 06:39:49 »
Is there supposed to be a tracking number? I just got an email that it shipped but no tracking information.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #91 on: Thu, 21 June 2018, 06:43:36 »
I'll be adding tracking to the orders a little later :)
Offline nimblejacks
« Reply #92 on: Fri, 22 June 2018, 08:09:08 »
What's the status of the US GMK stab + PCB orders?
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #93 on: Fri, 22 June 2018, 08:14:42 »
I recieved stabs TODAY so we'll be sending orders next week
Offline pixelpusher
« Reply #94 on: Sat, 23 June 2018, 16:32:50 »
FYI, I live in Tennessee, USA, and I just got my HS60 in the mail today.
I'm in the middle of packing for a week long vacation, so I don't know that I'll be able to test out much.  I'll report back what I can.
I do know that it won't fit in a Tex low profile case b/c of a diode by the USB cable.  Those cases have supports going across that restrict quite a few PCBs.  I wasn't really expecting it to work.  I'll try some more cases tonight if I have time.
Offline olivia
« Reply #95 on: Sat, 23 June 2018, 16:35:57 »
 :blank:
Offline Skaazi
« Reply #96 on: Sat, 23 June 2018, 19:09:44 »
Got mine today and looks like it's all working! Thanks :)
Offline pixelpusher
« Reply #97 on: Sat, 23 June 2018, 21:06:10 »
Okay, here's what I've tested:
Doesn't fit properly in Klippie (D2 diode is like RIGHT NEXT to the mounting hole)  It will go in if you put the PCB off-center which, I will not.
Doesn't fit in the 5degree case from KBDFans.  The extra two top screw mounts on that case come into contact with a diode and the hot-swap pieces on the back of the PCB.
Doesn't fit in Aliexpress wooden case (something making contact on the left and also the middle screw support)
Soooo.... I don't have any cases this will work in.
I guess I can put it in my TX60, although I'm not sure how a hotswap board works in a top mount board... maybe it will NOT just fall out?  Maybe the PCB mounted stablizers will hold it in?  AND I just remembered my TX60 is HHKB layout and this has no split right shift.  Hmm... I've got 5 empty cases that this PCB will not go in.  This blows.
Anyone have a case this fits in?
« Last Edit: Sat, 23 June 2018, 21:23:57 by pixelpusher »
Offline pixelpusher
« Reply #98 on: Sat, 23 June 2018, 23:02:27 »
sent you a PM
    • Jae | Top Clack
« Reply #99 on: Sun, 24 June 2018, 02:27:03 »
So I’ve got an ISO one here, and it works in a 5degree case - a bit of tape over the additional mount stops it shorting.
I have a wooden royal glam case, no issues whatsoever. I’ve got another cheap Ali wooden case that’s low pro - again no issues.
It also works just fine in my tina C, tx60 as top mount (seems held in pretty darn tight).
My klippe and revo also have 0 problems.
Do you have a pic of the pcb? I’m wondering if there is some part that is catching just on your one.
