Author Topic: HS60 PCB - Hotswap 60% with SMD RGB LED's (V3 Shipping Soon)  (Read 128979 times)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« on: Fri, 06 April 2018, 04:52:04 »
Exclusive Hotswappable SMD RGB LED 60% Keyboard in ANSI, ISO, or HHKB. Supports QMK. Developed in partnership with Yiancar
Fits all standard and aftermarket 60% cases.
SEE MORE FOR FAQ’S
The PCB is compatible with QMK firmware. The PCB will ship fully complete, with all components in place.
V2 will include an ARM processor, and Matte Black finish.
This preorder will run for 2 weeks. Looking at delivery 8 weeks from now (18-25th Dec)
Ordering from Australia/NZ? – PREORDER FROM DAILYCLACK
Ordering from Canada? – PREORDER FROM MECHKEYS.CA
Ordering from the US? – PREORDER LINK SOON
Did you order the V1? Get £15 off when ordering by entering your OLD order number in the notes section. We’ll then manually apply the discount after purchase. Order must be placed through Mechboards.co.uk
Q1: What about other layouts?
A1: We now have ANSI, ISO, HHKB layouts. We’re sticking with standard layouts for now, as we can’t add multiple layouts to the same PCB as the hotswap sockets can’t overlap. Trying to cover all possible layouts would be impossible so it’s standard for now. if there are enough people wanting other layouts, we may look into them.
Q2: What happened to the upside down esc and 1 keys?
A2: It’s due to the placement of the USB connector following the universal GH60 standard. The hotswap sockets can’t fit otherwise!
Q3: Is it difficult to collect all the parts needed for a full keyboard and to put it together using this PCB?
A3: Any other 60% case you find that has standard mount holes, and any standard plate, will work with this PCB
Q4: Does it have underglow?
A4: No as the power draw for all the in-switch LED’s is quite high already. There are exposed pins to add underglow RGB strips, but this is experimental and up to the user.
Q4: Can I set the RGB?
A4: Yes! It comes with different styles as well as colour picker. QMK community is working toward a hosted software to do that as well but its still under development.
Q5: USB-C? or Mini
A5: Mini for now
Q6: Do i need diodes, resistors, etc?
A6: The board is fully complete and ready to go!
V1 -
Hotswap 60% in standard ANSI or ISO layouts. Fully soldered PCB with in-switch SMD RGB LED's, which fits all standard 60% cases and plates.
White PCB. Designed and assembled in the UK. QMK Support.
GB will run for 3 weeks (End 27th April) and looking to ship 2-3 weeks after for mid May release
206101-0
206103-1
2 versions:
ANSI in standard 60% layout
ISO in standard 60% layout
£50 for Group Buy, £65 after (plus shipping) - NEWS - We now have an NA proxy! thekey.company will be handling all orders to North America. Therefore I will be refunding shipping (besides £2.50 to cover my shipping to TKC) in due course and then TKC will send a separate invoice prior to final shipment. This will lower the shipping costs considerably.
https://mechboards.co.uk/shop/parts/hs60-pcb/
This will first be a GB and then stocked all the time at Mechboards.co.uk
We're also looking for non-EU stockists!
More images and details soon
FAQ
Q1: What about split shift/split backspace/other layouts?
A1: We’re sticking with standard layouts for now, as we can’t add multiple layouts to the same PCB as the hotswap sockets can’t overlap. Trying to cover all possible layouts would be impossible so it’s standard for now. if there are enough people wanting other layouts, we may look into them.
A2: It’s due to the placement of the USB connector. The hotswap sockets can’t fit otherwise!
Q5: USB-C? or Mini
A5: Mini for now
« Last Edit: Sun, 29 December 2019, 08:17:07 by Mechboards »
Offline Mechboards
  • Mechboards UK
    • Mechboards
Re: [GB] HS60 PCB - Hotswap 60% with SMD RGB LED's
« Reply #1 on: Fri, 06 April 2018, 05:03:14 »
Some development pictures
193231-0
193233-1
193235-2
193237-3
« Last Edit: Fri, 06 April 2018, 05:05:07 by Mechboards »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Fri, 06 April 2018, 08:37:50 »
Approved!
Offline Unforgivable
« Reply #3 on: Fri, 06 April 2018, 09:39:46 »
This is pretty nice!
Would love to see a HHKB + Winkeyless combo though.
Basically the HHKB layout, but with 1.5/1/1.5/7/1.5/1/1.5 bottom row layout, so there are no issues with the sockets and can be used in both manners. Would this be possible?
« Last Edit: Fri, 06 April 2018, 09:45:48 by Unforgivable »
Offline Perfex
« Reply #4 on: Fri, 06 April 2018, 09:54:07 »
Instant buy if it supported HHKB layout.
Offline kmba
  • Formerly tameone
« Reply #5 on: Fri, 06 April 2018, 10:09:01 »
Agreed on the hhkb/wkl support. Split shift, split backspace, wkl bottom.
keyboards.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #6 on: Fri, 06 April 2018, 10:25:47 »
Thanks for the comments guys. We've already got 2 PCB's for ANSI and ISO, and if we wanted one to include split shift and split bspace, that would be 4. To add HHKB/WKL to the mix, that would be 8 different PCB's to cover all variants. We will look into different layouts further down the line if they become really popular, but for now standard is the best approach :)
Because of the hotswap sockets, it's pretty impossible to add other layouts to the same PCB (and we'll be selling these fully soldered/built)
Cheers!
Offline enrique.aliaga
« Reply #7 on: Fri, 06 April 2018, 10:34:53 »
Hi! Couple questions:
1. What kind of hot-swap sockets does this PCB have? Does it use "holtites"? Or does it use the Kailh hot-swap sockets (used by the K-Type, among others)?
2. Would it be possible to swap the stock PCB that comes with a Pok3r for this one? My goal is to have hot-swappability.
The project looks great, BTW! I wish you all the best.
« Last Edit: Fri, 06 April 2018, 12:24:31 by enrique.aliaga »
Offline Perfex
« Reply #8 on: Fri, 06 April 2018, 12:42:41 »
Cheers!
I completely understand and agree that the layouts you chose is the best route to take for the time being, good luck with the sale :)
Offline odd
« Reply #9 on: Fri, 06 April 2018, 12:43:19 »
Go buy a Zeal 60 then
Offline yiancar
« Reply #10 on: Fri, 06 April 2018, 16:21:27 »
1. It has Kailh sockets :)
2. Highly likely it has the standard mounting holes as GH60 etc.
Offline befbef
« Reply #11 on: Fri, 06 April 2018, 17:21:46 »
USB-C and I take 3.
« Reply #12 on: Fri, 06 April 2018, 17:48:25 »
That's great! I just joined the GB. My plan is to replace the stock Pok3r PCB with this one. :)
Offline kmba
  • Formerly tameone
« Reply #13 on: Fri, 06 April 2018, 19:20:51 »
Not hot swap and $55 more, but great advice :rolleyes:
keyboards.
« Reply #14 on: Fri, 06 April 2018, 23:37:12 »
kailh hotswap sockets don't allow for layout choices, so this is the best you'll be able to get with that requirement
Offline ArchDill
« Reply #15 on: Fri, 06 April 2018, 23:50:34 »
SAME.
I could care less about the LED's. Just having the hot swap would be nice.
« Last Edit: Fri, 06 April 2018, 23:53:16 by ArchDill »
Offline kmba
  • Formerly tameone
« Reply #16 on: Sat, 07 April 2018, 08:47:10 »
In the FAQ he says if enough people are interested in alternate layout on a new PCB he will look into it. People are just voicing that interest.
keyboards.
« Reply #17 on: Sat, 07 April 2018, 09:54:36 »
i was just explaining why it's not there
i probably wouldn't buy an HHKB layout PCB, but i'm not the biggest fan of hotswap (just personal taste, the kailh hotswap sockets are a good implementation)
GLWGB, mechboards
Offline befbef
« Reply #18 on: Sat, 07 April 2018, 10:43:42 »
Why? Do you feel the difference?
« Reply #19 on: Sat, 07 April 2018, 11:45:43 »
just personal taste, i'm a bit of an elitist
i see the merit in it
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #20 on: Sat, 07 April 2018, 19:27:14 »
GLWGB, mechboards
Thanks man! This is more for the beginners in buildling a keyboard, and for people who can't make a decision about which switch they want ;)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #21 on: Mon, 09 April 2018, 10:21:08 »
GB update - 25 Sold, 25 to go.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #22 on: Thu, 12 April 2018, 10:07:09 »
« Last Edit: Thu, 12 April 2018, 10:09:29 by Mechboards »
« Reply #23 on: Thu, 12 April 2018, 10:10:45 »
Oh wow! Looks sweeeet.
BTW, does this PCB support GMK screw-in stabilizers?
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #24 on: Thu, 12 April 2018, 10:29:18 »
I’ve watched the development of the board through David and Yiancar and it should do - I’m getting a prototype to test tomorrow direct from David so will confirm for sure then.
Additionally I’ll be streaming a live build of the HS60 with /u/Meliewx from the MKUK community a week on Saturday!!
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #25 on: Thu, 12 April 2018, 10:38:57 »
The PCB will allow GMK screw-in stabilisers :)
« Reply #26 on: Thu, 12 April 2018, 11:00:38 »
Awesome! Thanks for the response.
Would it be possible to combine this PCB with GMK screw-in stabilizers and the plate from a Pok3r?
I think I would have to discard the Pok3r’s stock Cherry plate-mount stabilizers. Right?
Or would I be better off buying a separate plate just for this build?
Thanks for the guidance.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #27 on: Thu, 12 April 2018, 11:03:00 »
Yes! All plates and cases for a standard 60% work with this PCB. We're also running a GB for Screw-ins at the moment if you need them.
« Reply #28 on: Thu, 12 April 2018, 11:09:39 »
Yes! I have joined the GB of those stabilizers, too! :)
Offline pon10
  • looking at my keycaps..
« Reply #29 on: Thu, 12 April 2018, 11:12:33 »
Is the pcb only with "RAW" QMK support?  :confused: or does it comes with some predefined layouts & LED settings which is slightly easy accessible in some way :D
( sry.. My QMK learning patience/time is no more ) :p
« Last Edit: Thu, 12 April 2018, 11:20:19 by pon10 »
Offline Vadurr
  • Valar Morghulis
« Reply #30 on: Fri, 13 April 2018, 03:01:53 »
Def in for a few if HHKB becomes an option :)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #31 on: Fri, 13 April 2018, 03:55:58 »
It comes with a lot of preset settings and profiles :)
Offline Anaconda
« Reply #32 on: Sat, 14 April 2018, 00:28:43 »
I would like to see an ISO only plate on your website. Universal plate might be really loose with kailh hotswap sockets for a 60% board. There is really no one selling ISO only plates any where.
Offline pon10
« Reply #33 on: Sat, 14 April 2018, 05:49:11 »
Try 1upkeyboards.. They seem to have a ISO PRO PLATE.  :thumb:
    • Jae | Top Clack
« Reply #34 on: Sat, 14 April 2018, 07:12:33 »
It’s something I’ve mentioned to David as well. I’m doing a livestream build of a prototype HS60 a week today with Meliewx - we will be using a universal plate so will be able to confirm then :)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #35 on: Mon, 16 April 2018, 07:18:52 »
« Reply #36 on: Mon, 16 April 2018, 09:05:19 »
I’d love to watch that! Where can I find it? :)
« Reply #37 on: Mon, 16 April 2018, 09:10:22 »
What about the South American customers. Also going to get our orders shipped from the US?
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #38 on: Mon, 16 April 2018, 09:19:46 »
Sure, if it works out cheaper. We'll check it out.
Sent from my F5121 using Tapatalk
    • Jae | Top Clack
« Reply #39 on: Mon, 16 April 2018, 10:46:56 »
It will be on twitch. I’ll post some details up in this thread in a couple of days once we work out all the detail
    • Jae | Top Clack
« Reply #40 on: Fri, 20 April 2018, 08:21:53 »
here are the details of the livestream build:
https://www.reddit.com/r/MechanicalKeyboards/comments/8dnh05/mechboards_hs60_livestream_build/
« Reply #41 on: Fri, 20 April 2018, 10:33:32 »
Thanks! I'm eagerly awaiting! Are you going to use Cherry screw-in stabilizers, just like the ones in the other MechBoards' group buy? I ordered those, too. :)
    • Jae | Top Clack
« Reply #42 on: Fri, 20 April 2018, 10:34:51 »
Sadly not as I'm waiting on the GB to get some more. We will be clipping and lubing some genuine cherry stabs tho and showing Mel how to do it :)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #43 on: Tue, 24 April 2018, 02:28:34 »
Swires got in on the action
194488-0
    • Jae | Top Clack
« Reply #44 on: Tue, 24 April 2018, 02:54:59 »
Nice! I stole the image for the opening of my stream at the weekend!!
If anyone wants to re-watch the livestream build you can check it out at twitch/jaekeebs
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #45 on: Tue, 24 April 2018, 08:07:11 »
Offline oldcat
  • 65% is Life
« Reply #46 on: Wed, 25 April 2018, 20:27:25 »
Can we have a YAS layout or 65% layout hot swap PCB please?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #47 on: Wed, 25 April 2018, 20:47:34 »
HHKB layout when?
Offline oldcat
  • 65% is Life
« Reply #48 on: Wed, 25 April 2018, 21:07:25 »
This is an amazing PCB... hope OP will make a 65% hot swap PCB soon
Offline Vadurr
  • Valar Morghulis
« Reply #49 on: Thu, 26 April 2018, 12:32:12 »
HHKB pls
