Author Topic: [GB] TGR-Alice - 100% Completed  (Read 561376 times)
Offline gabbbe
Re: [GB] TGR-Alice - 100% Completed
« Reply #900 on: Mon, 28 January 2019, 21:42:01 »
Built!
« Reply #901 on: Tue, 29 January 2019, 02:01:25 »
Offline gabbbe
« Reply #902 on: Tue, 29 January 2019, 09:13:10 »
Built!
that's that ****
this board brings the sunshine to a rainy afternoon.
Offline murimurimuri
« Reply #903 on: Sun, 10 February 2019, 23:43:16 »
Looking to buy one if anyone is interested in selling theirs for whatever reason slide into my DMs
Offline clik_clak
« Reply #904 on: Sun, 10 February 2019, 23:54:53 »
You and everyone else.
Offline dilkROM
« Reply #905 on: Fri, 15 February 2019, 12:05:54 »
Exactly. Been seeing these a bit but didn't dig into them much yet and now starting to really like 'em. Wish I had been awares during the GB!
« Reply #906 on: Fri, 15 February 2019, 12:08:12 »
lol Newbs.
« Reply #907 on: Fri, 15 February 2019, 13:04:31 »
post on mechmarket and pray, like everyone else who missed the GB
Offline aeryxz
    • aeboards
« Reply #908 on: Tue, 19 February 2019, 02:47:54 »
Last calls for Alice Wooden rest R3. This is hopefully the last alice rest gb (well I said that last time so...)
I'll be sending invoices out soon. If you did not fill the form out, PM ME ASAP, as I will be sending the order out in the next couple of days.
Alice is my favourite board and my daily, and hope that the wrist rest brings it up that extra level. Here are some pics from r1: https://www.instagram.com/p/Bl4lDyVjJva/
Here's a quote from blacksimon: "I don't even use wrist rests, yet my Alice rest gets used on the regular now, it's such a treat to use. Also burritos"
Offline futurecrime
  • Get Zooted
« Reply #909 on: Thu, 21 February 2019, 15:32:14 »
Can anyone advise on how to set indicator leds in bootmapper? I've tried setting them to on and various other settings and I just can't get any to light up. I tested them all before soldering and I know they work. Pretty sure I soldered them in the correct way around... I'd like to set one to indicate when I'm toggled to my fn3 layer. And I'd like the capslock led to toggle as well. I've never bothered with indicator leds before so this is wild new territory for me.
« Reply #910 on: Thu, 21 February 2019, 16:58:25 »
i'm not sure you can set them to work with fn layers
mine just worked with the other locks straight out of the box, set to toggle
lemme take a look
« Reply #911 on: Thu, 21 February 2019, 17:00:43 »
found it super fast actually
it's under options ->lock LED settings, you should be able to do what you want there
you have to make sure the board is connected (as in click the connect button) to activate this menu
can't just download your hex and go
if it doesn't work i can take another look
Offline nulltorious
« Reply #912 on: Thu, 21 February 2019, 20:22:49 »
Edited.
Just to check the LED Long Leg go to the SQUARE of the Alice PCB. I soldered mine backwards the first time around.
« Last Edit: Fri, 22 February 2019, 06:14:40 by nulltorious »
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #913 on: Thu, 21 February 2019, 23:47:44 »
Just to check the LED Long Leg go to the outside of the Alice PCB. I soldered mine backwards the first time around.
The longer leg goes the "square" hole.
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
« Reply #914 on: Thu, 21 February 2019, 23:49:20 »
square hole is always +
long leg is also +
Offline nulltorious
« Reply #915 on: Fri, 22 February 2019, 04:40:30 »
My mistake, you guys are correct. LED Long leg with square hole.
Offline futurecrime
  • Get Zooted
« Reply #916 on: Wed, 27 February 2019, 17:16:18 »
Oh cheers, didn't see these replies til now for some reason. Yeah I tried a bunch of settings in that menu but to no avail. I guess it's possible I soldered the led the wrong way around. I'll check it when my PC plate arrives and I do a second build.
« Reply #917 on: Wed, 27 February 2019, 18:07:45 »
if you plug the PCB in and touch the LED to the pads, they'll light up if you have em the right way round (and they are enabled in the software)
long leg square hole
Offline dantambok
« Reply #918 on: Tue, 12 March 2019, 20:29:01 »
Just infilled the engravings. Pretty happy with how they look  ;D
215044-0
215046-1
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #919 on: Tue, 12 March 2019, 20:33:15 »
Nice. I like the black one with black infill
Offline ejewell89
  • 4ever Smol
« Reply #920 on: Tue, 12 March 2019, 20:36:59 »
howd you do dat
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #921 on: Tue, 12 March 2019, 20:52:02 »
howd you do dat
With Acrylic paint
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #922 on: Tue, 12 March 2019, 21:21:59 »
howd you do dat
Stole from Dan
Offline dantambok
« Reply #923 on: Tue, 12 March 2019, 22:11:20 »
I used water based acrylic paint and applied it with a rubber paint brush. Wiped the excess paint using some cardboard, let it dry then cleaned up the rest using Q tips and alcohol.
Do note that anodized aluminum is easy to clean. Sandblasted brass parts are harder to clean due to the rough texture and paint getting stuck there
Stuff  I have
100+ GMK sets
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #924 on: Tue, 12 March 2019, 22:49:30 »
When you say "harder to clean", they are still cleanable with enough rubbing alcohol/q-tip right?
Offline dantambok
« Reply #925 on: Tue, 12 March 2019, 23:01:05 »
Yes still cleanable with more rubbing needed. On anodized aluminum, it just slides off. The alice weights were smoother vs the 910 weights that i have. Had a hard time cleaning up the weight on the poly (check the 910 logo, a bit of discoloration on the edges from all the rubbing off q tips and alcohol)
215056-0
Rip q tips
215058-1
Stuff  I have
100+ GMK sets
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #926 on: Tue, 12 March 2019, 23:02:59 »
Rip q tips
Interesting. Thanks for the details. At least it worked, and frankly, the said discoloration isn't even that bad.
Offline dantambok
« Reply #927 on: Tue, 12 March 2019, 23:06:15 »
It’s more visible on a different angle though. Also, idk how all the rubbing with alchohol affected the coating on the sandblasted brass parts.
I do know for sure that alcohol and acetone will have no effects on anodizing at all
Stuff  I have
100+ GMK sets
« Reply #928 on: Wed, 13 March 2019, 01:41:37 »
i wanna do my alice weight but idk what color id do
might do it to match the cerakote i wanna do on my alice
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #929 on: Wed, 13 March 2019, 03:31:30 »
Thanks for the insight. I think a solution might just be to try using a finer brush in applying on brass so as to minimize the amount of cleanup required.
Looks great on your boards!
Offline ejewell89
  • 4ever Smol
« Reply #930 on: Wed, 13 March 2019, 08:22:04 »
Rip q tips
glad i'm not the only one with two alice's and two 910's. lol
Offline Dawn
Re: [GB] TGR-Alice - 75% Completed
« Reply #931 on: Sat, 16 March 2019, 23:14:24 »
Hey guys, here are the files.
PCB layout file https://www.dropbox.com/s/71r8ra5ft25uiqa/alice_PCB_layout.DWG?dl=0
Plate https://www.dropbox.com/s/35dhihpsjpnb2nx/alice_plate_rev_C.DWG?dl=0
Acrylic case https://www.dropbox.com/s/kq2i2yhk1mshpuv/alice_case_acrylic.DWG?dl=0
Thanks.
Any chance anyone has some STL files so I can try 3d printing the case? (Borrowing a friend's 3D printer... don't have any clue about file formats... I'm a SWE... not an engineer that 3d prints by any means).
Offline Darknight00z
« Reply #932 on: Sun, 07 April 2019, 07:54:33 »
Any weight on the rumors of Alice v2 in late 2019?
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #933 on: Sun, 07 April 2019, 08:46:36 »
the only person who can provide any sort of information of value regarding this would be yuktsi
(and not someone else who seems to always pop up in every group buy thread asserting knowledge regardless of them being in the group buy or not)
Offline dantambok
« Reply #934 on: Sun, 07 April 2019, 08:51:27 »
216772-0
thonk
Stuff  I have
100+ GMK sets
« Reply #935 on: Sun, 07 April 2019, 12:23:37 »
Highly doubtful
Offline vegs
« Reply #936 on: Sun, 07 April 2019, 13:01:08 »
Highly doubtful
hhkb 4 life
buy less
« Reply #937 on: Sun, 07 April 2019, 13:45:55 »
Highly doubtful
i'm basing that off the fact that sam has said nearly everywhere he doesn't want to do one
then again i got screwed on the same basis for orion v3 soooo
Offline ejewell89
  • 4ever Smol
« Reply #938 on: Mon, 08 April 2019, 09:13:37 »
Highly doubtful
grasps his alice tighter
Offline fishinaspacesuit
« Reply #939 on: Mon, 15 April 2019, 04:43:51 »
Finished putting this together last week  :-*
Offline strigif0rm3s
« Reply #940 on: Thu, 06 June 2019, 12:43:17 »
Seriously, please announce round 2!!! I want so bad
Sent from my Nexus 6P using Tapatalk
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #941 on: Fri, 07 June 2019, 18:49:29 »
He's said a few times the Alice GB wasn't great for him, so the chances of him running another any time soon are slim. His schedule also looks pretty full for the next year already(Jane 2 ce, Zooey & potentially another board).
Offline SBN
« Reply #942 on: Sat, 08 June 2019, 02:04:17 »
Did he say that Zooey is next?
« Reply #943 on: Sat, 15 June 2019, 20:19:21 »
if he did i didn't see it
Offline Solotov
« Reply #944 on: Fri, 04 October 2019, 02:02:28 »
I had a great dream last night. There was TGR Alice round 2.  :-[
Flex is love, flex is life.
Offline funderburker
« Reply #945 on: Fri, 04 October 2019, 02:43:54 »
Resurrecting old GB threads is the best. :D
But I gotta say - given how many Alice like projects are there right now with Yuktsi approval, I don't think there's a need for a legit TGR Alice re-run. There's Lubrigante, Rukia, Nunu, Austere and a couple of more for sure, not even counting Majapahit and other TKL layouts. A lot of them even share the same PCB and plate compatability.
Keyboard design by Skepur
Offline yuppie
« Reply #946 on: Sun, 29 December 2019, 20:39:39 »
If anyone has an extra PCB, Plate or LED kit they'd like to sell, please contact me  :cool:
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline Aznguyen316
« Reply #947 on: Sat, 11 April 2020, 22:05:00 »
nevermind.
« Last Edit: Sun, 12 April 2020, 19:08:39 by Aznguyen316 »
Offline Crazy Designers
    • Angry Miao Official Website
« Reply #948 on: Tue, 14 April 2020, 01:48:21 »
it looks so nice :D :D
Angry Miao Team. Future Art Community.
Offline delet_d
« Reply #949 on: Tue, 14 April 2020, 13:45:52 »
Nothing can beat the original weight and engraving though...  Still waiting.
