Author Topic: [GB] TGR-Alice - 100% Completed  (Read 552410 times)
Offline i_tekneek
Re: [GB] TGR-Alice - 100% Completed
« Reply #950 on: Fri, 05 June 2020, 18:12:24 »
Anyone with experience flashing this board or an RGB kits they would be willing to let go of, or the files for the acrylic plate to make it please let me know~
Im dying to get rid of this windows key next to me left spacebar lol
Offline 4Holo
« Reply #951 on: Wed, 10 June 2020, 12:40:23 »
Hope TGR Alice can come back for a second round! I would love to make this keyboard
Offline eyedrop
« Reply #952 on: Wed, 10 June 2020, 13:00:36 »
Highly unlikely.  There are plenty of other options out there for Alice alternatives.
Sent from my Pixel 3 using Tapatalk
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #953 on: Wed, 10 June 2020, 18:05:07 »
Its Bootmapper
takes like 2secs to change the keymap
Offline ejewell89
  • 4ever Smol
« Reply #954 on: Mon, 17 August 2020, 08:45:07 »
Its Bootmapper
i, too, take 2 secs.
Offline h40
    • h40.io
Re: [GB] TGR-Alice - 75% Completed
« Reply #955 on: Tue, 18 August 2020, 12:25:50 »
Hey guys, here are the files.
PCB layout file https://www.dropbox.com/s/71r8ra5ft25uiqa/alice_PCB_layout.DWG?dl=0
Plate https://www.dropbox.com/s/35dhihpsjpnb2nx/alice_plate_rev_C.DWG?dl=0
Acrylic case https://www.dropbox.com/s/kq2i2yhk1mshpuv/alice_case_acrylic.DWG?dl=0
Thanks.
Is the acrylic case linked here designed for the top or bottom USB port? Anyone ever built it with the sneakbox hotswap alice PCB?
Offline DaiLoDong
    • Steam + Reddit same username
« Reply #956 on: Sun, 08 November 2020, 14:50:12 »
I recently got the OG TGR Alice with the original pcb and i cant get this damn thing to go into bootloader mode and nothing detects it
not qmk
not HIDbootloader
not VIA
And i tried shift+b unplug and replug, backspace, left ctrl, esc.
i feel like ive literally tried everything to get this finnicky boi to reset and nothing :C
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #957 on: Sun, 08 November 2020, 14:53:03 »
not qmk
not HIDbootloader
not VIA
The original PCB uses Bootmapper Client.
https://drop.com/talk/1392/programming-kbd-keyboards-via-bootmapper-client-tmk-guide-getting-added-soon-here
"Reset" is the FW_JP pins iirc
« Reply #958 on: Sun, 08 November 2020, 15:12:50 »
not qmk
not HIDbootloader
not VIA
+1
my OG alice PCB is bootmapper and the pins mentioned are correct (just tested)
Offline DaiLoDong
« Reply #959 on: Sun, 08 November 2020, 15:24:16 »
not qmk
not HIDbootloader
not VIA
not qmk
not HIDbootloader
not VIA
+1
Thank you so much for the information gentlemen. I really appreciate the fast responses and the help!
Edit: i fkn bricked the original pcb lmfao. i resoldered on a pkb pcb and shes good ahahha. oopsie daisie...
« Last Edit: Wed, 11 November 2020, 16:31:44 by DaiLoDong »
Offline DaiLoDong
« Reply #960 on: Fri, 13 November 2020, 11:46:33 »
Flex pic #69
Very excited to finally get my hands on this grail board.
Offline treeleaf64
    • treeleaf64
« Reply #961 on: Fri, 13 November 2020, 14:44:51 »
Good job DailoDong
Everyone must pay the cat tax
Offline Leon_TheKing
« Reply #962 on: Sat, 21 August 2021, 02:10:08 »
Quick question - can I assume this board has only 40 in quantity that are ever made per GB description in the #1 post? Thanks for any insight on this.
Offline itsundone
« Reply #963 on: Sat, 21 August 2021, 02:11:50 »
Probably more than 40, idk how much exactly
There are b stocks and fnf (family and friends) units
Offline toniwonkanobi
« Reply #964 on: Sun, 18 September 2022, 08:18:59 »
Has anyone taken the plate file and revised it with 0.5mm fillets in the switch cutouts (instead of the current 1.0mm fillets)? 🙏🏿
Offline packman86
  • Morning Coffee
« Reply #965 on: Sun, 18 September 2022, 11:10:51 »
There are probably thousands of Alice-like plates made and I'm sure someone has done .5mm instead of the 1mm.
Why you ask?
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
« Reply #966 on: Sun, 18 September 2022, 11:12:44 »
Why you ask?
There are a lot of vendors selling plates, for sure, but most (if not all besides CBB) are using yuktsi's original plate file, and maybe just adding support for non-stepped Caps Lock. They all use the same "rounder" internal switch cutouts. Asking because I'd like to make a copper plate with the same look as yuktsi's (e.g., no "CBB" branding), but with no restriction on switch type ;)
Offline packman86
  • Morning Coffee
« Reply #967 on: Sun, 18 September 2022, 11:28:33 »
Why you ask?
Download the file and make the 0.5mm - 1mm adjustment yourself. Its quite simple.
« Reply #968 on: Sun, 18 September 2022, 11:29:59 »
Why you ask?
Never used any 3D software. If it's as easy as you say, maybe I should just do it myself.
« Last Edit: Sun, 18 September 2022, 20:59:19 by toniwonkanobi »
Offline h40
    • h40.io
« Reply #969 on: Wed, 11 January 2023, 16:20:20 »
Why you ask?
It might be simple but it'd be extremely tedious. Probably too late for you now but for you or anyone here that is interested here is an Autodesk Fusion file you can download and modify things like switch cutout and corner radius to your liking: https://a360.co/3Xh0YsC. You can of course modify anything else as you wish. It defaults to .5mm.
  • If necessary sign up for and download Fusion 360
  • Open this file in Fusion 360
  • To change dimensions click Modify > Change Parameters
  • To change anything else modify the "Source" sketch
  • Export the sketch "EXPORT THIS - Plate Profile" to DXF
295309-0
« Reply #970 on: Wed, 11 January 2023, 17:14:38 »
Why you ask?
Yes, I actually just resigned myself to using Cherry switches lol. But thanks for this!
« Reply #971 on: Sat, 20 May 2023, 07:48:12 »
not qmk
not HIDbootloader
not VIA
not qmk
not HIDbootloader
not VIA
+1
Apologies for resurrecting a super old thread, but I just recently acquired an OG TGR Alice PCB, and when I try to enter Bootmapper, it doesn't recognize the keyboard :/
Where on this PCB are the pins that I should short in order to reset the PCB and/or enter into Bootmapper mode? I want to flash with a via-compatible `.hex` :)
Offline lecorsair
« Reply #972 on: Sat, 20 May 2023, 11:36:00 »
Is it the ps2avrGB pcb? Try holding Q as you are plugging it in.
« Reply #973 on: Sat, 20 May 2023, 22:21:40 »
Same—no response in QMK. Holding Escape does get me some kind of interaction with QMK Toolbox, but it just keeps connecting and disconnecting. I'll just use the Mechlovin one or something. Sigh @ ancient TGR PCB lol
