Author Topic: [GB] SKB75, SKB65 & SKB60 / GB CONCLUDED  (Read 720801 times)
Offline PlastikSchnittstelle
Re: [GB] SKB75, SKB65 & SKB60 (Invoices out, payment phase extended)
« Reply #700 on: Sat, 15 December 2018, 10:27:17 »
Just checking in, February still the goal? Also an updated orders list was mentioned a few weeks back, would be great to let everyone verify their orders. :)
Yes, February is still the goal.
Here I attached the updated order list as pdf again.
If for some reason there are still some mistakes - no problem, there are still quite a few extras left from each version, so I can manage if I got something wrong.
Since there is not much for me to do now other then waiting, I'll keep it quiet for a while.
Also:
Some of you had asked me for a custom plate. I made quite a few already, some interesting ones, already three alps plates, for example. So if I haven't made this clear by now: If you want a custom plate, just pm me, let me know what you want and you'll get a DXF with your custom plate from me.
Offline anfledd
« Reply #701 on: Sat, 15 December 2018, 12:14:32 »
Looks good, looking forward to February!
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #702 on: Sat, 15 December 2018, 13:04:55 »
Plastik forever! :)
Offline rondg
« Reply #703 on: Sat, 15 December 2018, 14:56:52 »
Also:
I'm not on the list...  :(
« Reply #704 on: Sat, 15 December 2018, 15:10:19 »
yep, I got you, you joined just very recently, so that's why I haven't moved your name to the spreadsheet that I made for public export. so don't worry, I got you, you paid your SKB75, all fine.
Offline rondg
« Reply #705 on: Sat, 15 December 2018, 15:14:46 »
Ok. Thanks! ;D
Offline Zytyx
« Reply #706 on: Mon, 07 January 2019, 15:51:23 »
I've had this concept sitting around my head for a bit now, so I'm throwing it out there in case anyone else has thought of something similar. Given the way the plate is mounted in the case, how hard would be to use longer bolts, shorter spacers, washers, and o rings to sandwich the plate between them?
« Last Edit: Mon, 07 January 2019, 16:49:46 by Zytyx »
« Reply #707 on: Tue, 08 January 2019, 04:15:55 »
That's not hard at all. Being able to use some kind of dampeners like orings is part of the whole idea. Was already mentioned a while ago. here as well.
something like this:
210167-0 210169-1
« Last Edit: Tue, 08 January 2019, 04:25:52 by PlastikSchnittstelle »
Offline Coloneljesus
« Reply #708 on: Tue, 08 January 2019, 15:15:05 »
Good idea, haven't thought of that!
You can also find them on AliExpress when you search for "damper stand off". We would need size M3, correct? How long would they need to be?
« Reply #709 on: Fri, 11 January 2019, 05:38:28 »
exactly the ones from the secon picture would fit. yes all M3. length 7mm woul be optimal, but 6mm length is ok as well (caps would't sink in that deep but still deeper than usual).
here are two sources for europe/germany: source one, source two. those would require you to use shorter screws than the ones that I'll include (M3x12). you'd need M3x4 or M3x5 (source option).
generally you can find these and similar kind of dampeners when you google for RC and drone accessories. there dampeners (usually M3 as well) are used to secure the controller boards. o-rings are probably the cheapest option.
« Last Edit: Fri, 11 January 2019, 06:11:43 by PlastikSchnittstelle »
Offline menuhin
« Reply #710 on: Fri, 11 January 2019, 05:57:42 »
It is nice to have such a "gasket" keyboard DIY guide for the SKB keyboards  :thumb:
Looking forward to compare it "gasketed" versus "stock".
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #711 on: Wed, 16 January 2019, 08:55:47 »
What switches does everyone plan to put in this? I'm thinking holy pandas or lubed vintage blacks...
Offline menuhin
« Reply #712 on: Wed, 16 January 2019, 09:39:48 »
I'm a linear guy, so probably some lubed filmed vintage blacks, or retooled blacks, or even some Gateron blacks or yellows or clears if I managed to get a hotswap PCB.
Holy Pandas, call me saying out of jealousy cuz I missed the MD, are mostly and mainly a curiosity thing anyway.
My tactile holy grail, that the Holy Pandas and the Halo True want to mimic is Topre, something I'm typing on right now. The next thing close to Topre is SKCM browns before everyone is talking and making their own Holy Pandas, Outemu/Zeal/Gsus/KBDfans - I hope the mechanical switch market in 2019 won't be this boring in Q234.
IBM M13 black
HHKB Pro 2 HasuBT
Offline macken
« Reply #713 on: Wed, 16 January 2019, 09:40:35 »
I am gonna do the new version of box navy combined with SA caps.
Offline ballinboyz
« Reply #714 on: Wed, 16 January 2019, 09:42:25 »
Healios for my SKB65. Figure it could go well with the stiff steel plate.
Offline SteffeMK
« Reply #715 on: Wed, 16 January 2019, 13:17:33 »
I don't know if this has been asked before. But can I use a usb-c pcb with this?
Offline catamscott
« Reply #716 on: Wed, 16 January 2019, 17:22:37 »
been thinking about what to put in this for a while now lol. was planning on putting in some lubed linear mod-h switches, but am now leaning towards mx zilents. but who knows, i've also got cream switches and red pandas/halo trues on the way  :eek:
Offline ojrask
  • juuh elikkäs
« Reply #717 on: Wed, 16 January 2019, 22:23:26 »
The first plate and PCB will get some 100g silent MX Blacks, second plate and PCB will probably be 78g Zealios.
Current:
Coming up:
IC/GB:
Offline laserbeamspewpew
« Reply #718 on: Thu, 17 January 2019, 08:31:31 »
V2 zilents. I think the softer bottom out would work particularly well with the hard steel plate.
« Reply #719 on: Thu, 17 January 2019, 10:25:16 »
no problem, if you dig into this thread you'll find a post where I bought three common usb-c cables from amazon and tested them with the case in order to make sure there are no issues.
Offline menuhin
« Reply #720 on: Thu, 17 January 2019, 11:10:00 »
I may actually try some silented linear switches too!
IBM M13 black
HHKB Pro 2 HasuBT
Offline SteffeMK
« Reply #721 on: Thu, 17 January 2019, 11:23:43 »
Okay, thanks!
Skickat från min ONEPLUS A6013 via Tapatalk
« Reply #722 on: Thu, 17 January 2019, 13:24:42 »
Unsure. I have a bag of V1 Zilents but I may change my mind and try out some BOX switches or something.
Offline Soft_Sama
« Reply #723 on: Thu, 17 January 2019, 13:50:06 »
Bringing this board to school so I'm probably going to use the Aliaz I have on hand or swap the stems with Silent Sky
« Reply #724 on: Fri, 18 January 2019, 14:16:13 »
I forget. Does the plate support switch opening?
Offline Starston3
« Reply #725 on: Fri, 18 January 2019, 14:27:11 »
It does not.
« Reply #726 on: Fri, 18 January 2019, 16:41:46 »
you mean switch top removal?
no it doesn't, just standard cutouts.
I explained in the beginning why I prefer that.
make your switches perfect before you start building, or get a PCB witch hot-swap sockets.
« Last Edit: Fri, 18 January 2019, 16:43:38 by PlastikSchnittstelle »
Offline macken
« Reply #727 on: Sun, 20 January 2019, 09:11:05 »
Any update on the progress?
Sill on time for finished production and delivery in february?
« Reply #728 on: Mon, 21 January 2019, 07:48:37 »
that's what I assume. But I won't bother until mid february. If I don't have the parts by then or a more specific time, I'll call them and ask.
Offline booleanjulien
« Reply #729 on: Mon, 21 January 2019, 11:22:29 »
Do you just mean fixed stems, or are they reworked in other ways? If the latter, where can I find more info?
Offline macken
« Reply #730 on: Mon, 21 January 2019, 11:28:18 »
Just fixed stems.
Offline Gamatatsu
« Reply #731 on: Mon, 21 January 2019, 21:07:11 »
I payed for the 75% and I'm not on the list :(
Offline tectonicplate
« Reply #732 on: Tue, 22 January 2019, 00:31:05 »
Hako Violets. I have some lubed with Tribosys 3204 in another board that feel pretty good, but I'm thinking a few layers of RO-59 might be worth the effort.
Offline kim-kim
« Reply #733 on: Thu, 31 January 2019, 20:17:43 »
today is February (at least on my place), so any updates on production?
Offline johngodsmith
« Reply #734 on: Thu, 31 January 2019, 20:35:10 »
A few posts up, he said he’ll update mid Feb
Offline kim-kim
« Reply #735 on: Fri, 01 February 2019, 01:45:35 »
Ah, I see. Thank you, the case will come soon™
Offline synchromatik
« Reply #736 on: Sat, 02 February 2019, 07:43:49 »
What do you guys think about GMK Bento combo on this case (75 one) ?
My favorite is SA Pulse but i cant find it anywhere.
Offline r5d
  • Reddit: /u/thisman
« Reply #737 on: Tue, 05 February 2019, 15:31:35 »
Dolch or banana dolch for sure!
I like keyboards
Offline RETURNISO
« Reply #738 on: Tue, 05 February 2019, 15:47:26 »
SA Oblivion  :cool:
« Reply #739 on: Wed, 06 February 2019, 14:29:45 »
SA Oblivion  :cool:
o lala, decisions, decisions...  :D
Offline RETURNISO
« Reply #740 on: Tue, 12 February 2019, 03:23:25 »
ISO LIFE :cool:
212758-0
Offline FSund
« Reply #741 on: Wed, 13 February 2019, 03:24:54 »
Could anyone do a quick sanity check for me? I'm considering the KBD65 PCB from KBDfans, and as far as I see it should fit the SKB65. Can anyone confirm/deny this?
Join the Mechanical Keyboards Norway Discord server
Offline RETURNISO
« Reply #742 on: Wed, 13 February 2019, 04:09:20 »
Your are sane!!  :thumb:
Offline Draic
« Reply #743 on: Wed, 13 February 2019, 04:10:59 »
But your SKB will not have a blocker between ctrl and the arrow keys.
Offline RETURNISO
« Reply #744 on: Wed, 13 February 2019, 04:29:58 »
Then maybe i have lost my sanity.. But it looks like it support a BR: 1.25, 1.25, 1.25, 6.25, 1.50, 1.50, 1, 1, 1.
Offline FSund
« Reply #745 on: Wed, 13 February 2019, 07:03:01 »
I naturally forgot about the whole blocker issue.
The 1.50, 1.50, 1, 1, 1 lower right might be possible as you said, but It's a bit hard to say with all the holes in that area. I'm going to gamble that it does support that, and in any case I can fall back to non-blocked 1.25, 1.25, 1, 1, 1.
Offline RETURNISO
« Reply #746 on: Wed, 13 February 2019, 07:18:26 »
I gambled and have made a custom plate for it! :p
Offline okidna
« Reply #747 on: Wed, 13 February 2019, 09:46:46 »
This is the underside picture of my KBD65 PCB (USB-C), sorry it's already soldered (with 1.25u - 1.25u - blocker - 1u - 1u - 1u layout) but you can still see the option for the lower right area, I've marked the switch holes for 1u - 1u -1u and 1.5u - 1.5u layout :
« Last Edit: Wed, 13 February 2019, 10:03:51 by okidna »
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #748 on: Wed, 13 February 2019, 13:31:10 »
What are Bob's choices for a 75% PCB? Just the kbd75 or are there other options?
Offline okidna
« Reply #749 on: Wed, 13 February 2019, 18:20:52 »
You can also use EEPW84 (XD84 PCB) or YMD75 PCB, both can be found at Aliexpress or KPrepublic's site.
