Author Topic: [GB] CU75 & CU24  (Read 14301 times)
Offline CAPS UNLOCKED
    • capsunlocked
[GB] CU75 & CU24
« on: Sat, 14 April 2018, 02:46:18 »
CU75
Images
193823-0
193817-1
193826-2
Supported Configurations
193895-3
CU24
Images
193821-4
193819-5
193828-6
Product Information
The CU75 and CU24 are the first custom mechanical keyboards developed by capsunlocked, and are the first to join the capsunlocked Originals range of keyboards.
Supporting a large amount of configurations respectively, the physical layouts of both the CU75 and CU24 can be customised and tailored to your specific requirements. However the customisation does not stop there, because once you have settled on your perfect physical layout you have the opportunity to customise the digital layout, with the QMK software. Want to swap Caps Lock and the Left Control key? No problem! Want to have a dedicated layer for your media keys? That is also no problem! QMK coupled with the large amount of physical configurations means that there is a level of customisation that has previously been unseen on a 75% and numpad.
Included in each kit is a Cherry MX Positioning Plate, however an Alps Plate is available as an optional extra. The Alps Plate will support the standard ANSI 75% layout only.
Both the CU75 and CU24 have solid, durable cases that have been CNC machined and anodised black.  Both cases are built up from two pieces of Aluminium that are held together with M2.5 screws, for added durability. Sandwiched between the case parts are the positioning plate and PCB. The positioning plate is mounted to the top case, meaning that no screws are visible when using the keyboard. M2 screws are used to hold the plate to the top case. When fully assembled, both cases sit at a comfortable 5 degrees.
Each keyboard comes with a selection of added extras, with a Mini-USB cable and microfibre cleaning cloth in each of the CU75 and CU24 boxes. The CU75 also comes with two-part screw-in, black 1.5u Aluminium blockers and a microfibre sleeve.
Both keyboards support screw in stabilisers, but do not support holtites or per switch RGB LEDs.
Whats in the box?
CU75:
CU75 Aluminium Top Case (Black)
CU75 Aluminium Bottom Case (Black)
Brass Cherry MX Positioning Plate
CU75 PCB
12 x M2.5 Screws
8 x M2 Screws
M2.5 Allan Key
M2 Allan Key
2 x 1.5u Aluminium Blockers (Black)
CU75 Sleeve
CU75 Microfibre Cloth
Mini-USB Cable
CU24:
CU24 Aluminium Top Case (Black)
CU24 Aluminium Bottom Case (Black)
CU24 PCB
4 x M2.5 Screws
6 x M2 Screws
M2.5 Allan Key
M2 Allan Key
CU24 Microfibre Cloth
Mini-USB Cable
Where can I buy these products?!
Europe: capsunlocked (https://caps-unlocked.com/cu-originals/)
Australia: Amtra5 Keyboards (https://amtra5keyboards.com.au/product-tag/capsunlocked/)
North America (and all other NonEU Countries): Cartel (https://cartel.ltd/)
China: zFrontier
All prices are the same worldwide!
Group Buy Information
CU75 Base Kit MOQ: 50
Current Orders: 12
CU75 Alps Plate MOQ: 10
Current Orders:
CU24 Base Kit MOQ: 50
Current Orders: 7
CU24 Alps Plate MOQ: 10
Current Orders:
Lead Time: 10 - 12 Weeks
End Date: 15/05/2018
Credits:
Designer of the CU75 Case and Plates: Hineybush
Designer of the CU75 PCB: ca178858
Designer of the CU24 Case and Plates: Sayu
Designer of the CU75 PCB: yiancar
Graphic Designer of capsunlocked logo and all capsunlocked Orginal logos: Blerc
Photographer: Mathew Teague
« Last Edit: Mon, 16 April 2018, 14:19:17 by CAPS UNLOCKED »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] CU75 & CU24
« Reply #1 on: Sat, 14 April 2018, 04:29:02 »
Approved
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #2 on: Sat, 14 April 2018, 18:39:12 »
Awesome! lets see how it does :D
    • capsunlocked
« Reply #3 on: Mon, 16 April 2018, 14:20:56 »
Update:
Current Orders: 12
Current Orders: 7
The assembly option will be going live over the next few days, sorry for the delay.
Offline rymnd6c28
« Reply #4 on: Mon, 16 April 2018, 19:13:28 »
Which proxy should I use if I'm in Indonesia?
    • capsunlocked
« Reply #5 on: Mon, 16 April 2018, 19:18:51 »
Please to use either the North American or Australian Proxy.
If you have any other questions, please feel free to ask! :)
Offline eagleheardt
« Reply #6 on: Sat, 05 May 2018, 12:36:29 »
I just bought the CU24, from the Cartel, for NA.
I really need ya'll to make a fullsized CU60% because these are SOOO nice looking!
Offline bluesclera
« Reply #7 on: Sun, 06 May 2018, 07:15:38 »
So far away from moq.
Offline eyedrop
« Reply #8 on: Sun, 06 May 2018, 07:50:45 »
The CU combo is great, but too many great board GB lately.  It must be tough picking one over another.
Sent from my PH-1 using Tapatalk
Offline Hokabuki
« Reply #9 on: Sun, 06 May 2018, 10:08:59 »
I think it’s a great design except for the logo on the back. With so many other options, it’s the tipping point for me not joining.
Offline sleepybrett
« Reply #10 on: Sun, 06 May 2018, 14:45:09 »
I know what you mean, I often leave my keyboards upside down on my desk.
On a more serious note, any update on wether or not these guys are going to hit MOQ?
Offline Mag_Flux
« Reply #11 on: Sun, 06 May 2018, 20:16:17 »
But yeah, I actually like the logo quite a bit and find it to be a nice modern design.
That being said I wished they offered something other than black which is what's keeping me from joining the GB.
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #12 on: Sun, 06 May 2018, 20:28:06 »
I think one of the original defining characteristics of this design was lost when they couldn't address the weak underglow and they removed the nylon/polycarb base option. I personally don't find enough that is unique or special about this design to compete with the other more unique 75% customs or available market options (basic wedge with rounded chamfer corners is pretty subtle), especially at the price.
I also think that the 1.5u blockers haven't been shown off or promoted enough, since that is also a design trend that could be used to set this apart from the rest.
That being said, I am sure there are those who like the understated design, and best of luck with the GB and reaching MOQ.
« Last Edit: Sun, 06 May 2018, 20:30:21 by Zuology »
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
    • capsunlocked
« Reply #13 on: Wed, 09 May 2018, 11:01:57 »
There have been approximately only 20 units of the CU75 ordered.
Offline runsamok
« Reply #14 on: Wed, 09 May 2018, 11:21:51 »
I think since it's likely not going to make MOQ that it might be wise to take it back to the drawing table for a bit.
Between the visible machine marks on the logo & the screw holes overlapping into the bevels on the bottom there's a lot that takes away from the premium feel & the removal of the nylon bottom combined with the lack of colour selections for the case doesn't provide broad aesthetic appeal.
It's a really nice project, it just needs that last little bit of polish & tweaking to justify the price.
    • capsunlocked
« Reply #15 on: Wed, 09 May 2018, 11:37:47 »
Thank you for the constructive criticism.
I think the points you have made are all valid, and I agree that this group buy will be reviewed. I guarantee that the lessons learnt from this initial group buy will be taken forward, to improve future projects and products.
Offline dc_in_sf
  • Old Bastard
« Reply #16 on: Wed, 09 May 2018, 13:31:05 »
What is the firmware for the CU75?
Offline Kevadu
« Reply #17 on: Wed, 09 May 2018, 20:21:04 »
I would suggest also exploring having more color options.  The black looks nice enough but being the only option seems kind of limited.
    • capsunlocked
« Reply #18 on: Tue, 15 May 2018, 07:34:48 »
The group buys for the CU75 and CU24 are now over.
Unfortunately these group buys were not successful, and all orders will be refunded.
Offline r5d
  • Reddit: /u/thisman
« Reply #19 on: Tue, 15 May 2018, 07:46:08 »
I recieved the refund.. very sad! I really like the Cu75! Any chance to buy one of the prototypes?
I like keyboards
Offline lendflat
« Reply #20 on: Tue, 15 May 2018, 21:02:11 »
This thing took way too long. Not surprised it flopped.
Offline Darknight00z
« Reply #21 on: Wed, 16 May 2018, 14:10:18 »
Very sad to see this GB not going through as well. What does this mean for the other originals like the CU30? I personally been waiting for the CU30 for a long time. I held off my purchase for a nyquist and have been waiting it through with my preonic.
Offline Daellin
« Reply #22 on: Wed, 16 May 2018, 18:24:01 »
Are all orders refunded yet? Still waiting on mine.
Offline eagleheardt
« Reply #23 on: Thu, 17 May 2018, 18:35:01 »
Really bummed out this didn't go through, these were SOOO sexy.
I hope that ya'll get the CU60 and such up and running and that this can go again, I want this design as my centerpiece of my keyboarding life!
