Author Topic: [IC] S7-Elephant 70% custom keyboard!(GB OPEN)  (Read 87631 times)
Offline bball2
Re: [IC] S7-Elephant 70% custom keyboard!(Prototype will come!)
« Reply #100 on: Wed, 02 May 2018, 00:48:20 »
Okay let is start talk the namtag
cancel ?change ? reserved ? :))
I like it, as long as it's customize-able. Maybe move it slightly down and to the left (ie. give a bit more room between the nametag and the top, and line up the right side with the far right keys)
Offline mudcakehoney
« Reply #101 on: Wed, 02 May 2018, 02:49:30 »
I love the colours in general but feel like you need one more light colour like light orange or yellow. It just seems to fit the design so much better. But it’s your board mate do what you think is best
Offline RSC
« Reply #102 on: Wed, 02 May 2018, 07:52:42 »
This kind of blue would be a killer on this board.
What it is ?which color
It's like a 60's baby blue. It's from the Norbauer Realforce case drop. I think it just fits so well into the design of your board, it's just perfect for it.
I would cut it off. The overall board look is so perfectly clean, don't ruin the aesthetics by putting a tag on the top.
Offline Harms
« Reply #103 on: Wed, 02 May 2018, 12:47:19 »
Keep the elephant weight, but remove the name tag at the top of the board :).
Sent from my STV100-3 using Tapatalk
Offline jacky
« Reply #104 on: Wed, 02 May 2018, 23:33:39 »
I have update the pic !
Offline M
« Reply #105 on: Wed, 02 May 2018, 23:37:27 »
That white looks so clean :thumb:
Personally I would like the nametag to stay on but it's not a dealbreaker for me. Any idea on when you'll have a prototype to show us?
Offline oh_chesteroni
« Reply #106 on: Wed, 02 May 2018, 23:39:54 »
To be honest, I like the nametag, but only if it's customizable with our own personal text.
Also, can we please get a render with the right side of the nametag aligned with the right side of the plate? Just move it to the left slightly.
Offline jacky
« Reply #107 on: Wed, 02 May 2018, 23:48:45 »
It comes sonn :thumb:
Offline _ODIN_
« Reply #108 on: Wed, 02 May 2018, 23:59:04 »
I like it  :thumb:
Offline jacky
« Reply #109 on: Thu, 03 May 2018, 02:08:21 »
Six color have update on homepage!
Offline briano1905
« Reply #110 on: Thu, 03 May 2018, 05:27:01 »
wow purpul :eek:
Offline vewy_nice
« Reply #111 on: Thu, 03 May 2018, 11:29:34 »
Is the white MAO, or powdercoating?
Offline KaosJ
« Reply #112 on: Thu, 03 May 2018, 13:31:30 »
I would say, delete it :D
Offline KaosJ
« Reply #113 on: Thu, 03 May 2018, 13:33:06 »
But wait, if you want to replace it with an elephant engraved on the top alu, DON'T! I would prefer the nametag at this point.
Please no elephant on top.  It ruins the awesome look of the keeb
« Last Edit: Thu, 03 May 2018, 13:36:05 by KaosJ »
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #114 on: Thu, 03 May 2018, 14:01:38 »
Oof, my brother loves elephants, I have to get him this one.
Offline jacky
« Reply #115 on: Thu, 03 May 2018, 23:08:04 »
Yea name tag may delete
Also weight design will delete the letter but will keep elephant 🐘
Offline jacky
« Reply #116 on: Thu, 03 May 2018, 23:11:18 »
Mao
Offline _ODIN_
« Reply #117 on: Fri, 04 May 2018, 00:05:51 »
i like the elephant on the bottom of the board
Offline KaosJ
« Reply #118 on: Fri, 04 May 2018, 13:28:34 »
Can you offer a blank weight option :D? (should cost less to you).  I guess custom engraves are not possible as well?
Offline beekey
« Reply #119 on: Fri, 04 May 2018, 14:08:46 »
Colors are nice. Would go for Mao and without name plate.
For me the plate does not match with the clean symmetric look of the case.
Offline Mag_Flux
« Reply #120 on: Sat, 05 May 2018, 12:01:14 »
The new renders look fantastic. So clean without the nametag and the colors look great too.  :thumb:
Offline jacky
« Reply #121 on: Sat, 05 May 2018, 22:26:31 »
hey guys
i just get sample from factory .
Offline M
« Reply #122 on: Sun, 06 May 2018, 00:46:24 »
hey guys
looks great, just the right amount of brightness imo
Offline KaosJ
« Reply #123 on: Sun, 06 May 2018, 03:45:00 »
Looks soooo good for color option!!!
Offline HotRoderX
« Reply #124 on: Sun, 06 May 2018, 04:37:44 »
Mao white with green plate! holy crap! might just be back in for this is it possible to see a MAO option? I have heard MAO white can look silver.
Offline excluisve
  • Making & Thinking.
« Reply #125 on: Sun, 06 May 2018, 04:53:43 »
I think Mao is little grey not like silver
Offline KaosJ
« Reply #126 on: Sun, 06 May 2018, 05:57:30 »
Mao for OP is the WHITE Mao, Silver should be normal Anod.
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #127 on: Sun, 06 May 2018, 07:07:40 »
In for a mao! It looks so good!
Offline HotRoderX
« Reply #128 on: Sun, 06 May 2018, 12:32:09 »
is the white the one above the purple render are is that just straight silver that looks white? I am a bit confused but yea this thing looks amazing.
Offline KaosJ
« Reply #129 on: Sun, 06 May 2018, 14:55:47 »
above the purple there is the white MAO which OP calls just "MAO"
That's not silver, not sure what you mean tbh
Offline jacky
« Reply #130 on: Sun, 06 May 2018, 21:45:53 »
yep above purple is mao and then is silver .
« Reply #131 on: Sun, 06 May 2018, 23:15:59 »
i think you missed the point
MAO is not the stark white that you're thinking, it's a more greyish color in person
Offline jacky
« Reply #132 on: Tue, 08 May 2018, 03:50:36 »
Mao is not anode
Offline KaosJ
« Reply #133 on: Tue, 08 May 2018, 17:43:49 »
MAO is not a color in the first place and MAO White is the "most white" we can have on alu tho so not sure what's the point
« Reply #134 on: Tue, 08 May 2018, 18:43:08 »
I think the point is that MAO (the technique) will not produce a pure white color as seen in OPs MAO (what he incorrectly refers to as a color) render. It is the closest you can get to white, but it still does have a grey tint to it, and depending on the quality of the factory/their MAO process, this can range to barely noticeable grey to a more pronounced gray. Unless the OP and his factory have found or improved on the MAO process, I think it's very misleading to show a pure white case in his render.
For those of us that know MAO does not produce a pure white, this is not a big deal. However, I can imagine new enthusiasts in our hobby to be led to believe that they will receive a pure white case as per the render.
Offline jacky
« Reply #135 on: Tue, 08 May 2018, 20:30:21 »
In my opinion ,anode seems can’t be pure white
Mao is close to white I am not say it pure white
Thank
Offline KaosJ
« Reply #136 on: Wed, 09 May 2018, 00:29:13 »
Thank
What about make the MAO white as sample instead of green, you kinda showed the green anod. already.
Or maybe try to get a white MAO sample on a small piece of alu.
Offline jacky
« Reply #137 on: Wed, 09 May 2018, 06:54:09 »
Thank
navy blue i will show this .
mao is common  i think .
Offline InvidiousIgnoramus
« Reply #138 on: Wed, 09 May 2018, 06:57:32 »
Thank
It still wouldn't hurt to see an example of your factory's MAO quality.
I long for the day when I find a beamspring. (At a not insane price)
Offline jacky
« Reply #139 on: Wed, 09 May 2018, 07:18:41 »
Thank
yea for sure .
Offline KaosJ
« Reply #140 on: Wed, 09 May 2018, 13:45:16 »
Thank
yea for sure .
Purple is pretty hard to imagine too, could be nice to see it on a small piece of alu.
Offline jacky
« Reply #141 on: Mon, 14 May 2018, 08:46:49 »
I sent the files to factory last week
It will start to make a prototype those days
Wait my news !
Offline _ODIN_
« Reply #142 on: Thu, 24 May 2018, 10:26:55 »
Wait my news !
still no updates? :-[
Offline jacky
« Reply #143 on: Tue, 05 June 2018, 07:00:59 »
Sry for the delay
I just pick this “brick” from factory
It too heavy and lager
Here is the pic
There is anyone still interested? If not I will keep for myself  :'(
Offline JSaintS
    • JSaintS
« Reply #144 on: Tue, 05 June 2018, 07:03:59 »
Sry for the delay
Here is the pic
I'm in for sure! As long as iso is supported you have my money <3 Mao white for me :3
Offline _ODIN_
« Reply #145 on: Tue, 05 June 2018, 07:04:14 »
Sry for the delay
Here is the pic
Looking sweet
Offline _ODIN_
« Reply #146 on: Tue, 05 June 2018, 07:04:59 »
Sry for the delay
Here is the pic
Mao and iso for me as well :thumb:
Offline Mag_Flux
« Reply #147 on: Tue, 05 June 2018, 07:10:02 »
Sry for the delay
Here is the pic
Man that looks good. Definitely in for one in gray.  :thumb:
Re: [IC] S7-Elephant 70% custom keyboard!(Prototype come)
« Reply #148 on: Tue, 05 June 2018, 10:16:42 »
Sry for the delay
Here is the pic
Haha, still very interested. Any chance we could get some pictures of the inside? I'm curious as to how much space there will be inside.
Offline _ODIN_
« Reply #149 on: Tue, 05 June 2018, 10:18:17 »
please make this happen
