Author Topic: [IC] Keyboard Bag (Eva Foam) Shockproof and Custom Design | Form Update  (Read 20811 times)
Offline yasintahir
  • Formerly silentreader
FORM!!!
Hello folks!
Maybe one of you know me run custom sleeve for keyboard before with you can custom design on your sleeve as you want with cheap price.
Here's the idea :
1. I will make inside of bag like whitefox did with this one
2. I will put handle like tx bag
3. Add extra foam like pelican case did so you can customize size of hole to fit your keyboards
4. I will use spill proof fabric like i use on my custom sleeve, and you can use image as you want for this bag.
Estimated Price : $30-$35
What to do :
- Size will we use for this bag (Is it 1 bag for every size of keyboard or 1 bag for more than 1 keyboards)
- Get Moq at least 30 pcs for this run
- Make sample (I will do it on may)
Update:
- 27 April
Ok so i got confirmation from my vendor, if we go with different size we need 30 moq of each size. So it think i will make 1 fit for (40%, 60%, 65%) and second will fit for (75%,TKL,Compact and 1800). I will make form ASAP.
- 1 May (1)
- The size will be fix 440x220x70mm and 370x170x70mm. I can't make other size until i get big order because 1 size need 1 mould and 1 MOQ.
- Fabric canvas need to change because they told me i must use stretch fabric. And this is will be hard to customize image.
- I will make 4 sample this time with big size all of them, Here's the detail sample i will make :
  1. Use seamless pattern image
  2. Use Non seamless image and different on both side
  3. Use text on corner of the bag
  4. Use 2 solid color on Back and Front bag
I will print new fabric and will be ready this weekend so i can make prototype next week.
If prototype look good we will run GB on 14 May
- 1 May(2)
I check shipping fee through website it's about $50-$55 /pcs for EMS
I'm already contact them to see if i can use different service to decrease the cost.
1. The option is use ocean service need more time but will be cheaper.
2. Use another service beside EMS with cheaper cost.
3. Send them in cargo and find some proxy for Conus and Europe.
Let me know how much you can pay for shhipping fee /pcs?
So let me know what do you think on this one.
« Last Edit: Tue, 01 May 2018, 06:56:50 by silentreader »
Offline yasintahir
Re: [IC] Keyboard Bag (Eva Foam) Shockproof and Custom Design
« Reply #1 on: Thu, 26 April 2018, 05:34:09 »
Reserved!
Offline KaosJ
« Reply #2 on: Thu, 26 April 2018, 05:37:15 »
What dimensions will you offer?
Interested
Offline yasintahir
« Reply #3 on: Thu, 26 April 2018, 05:38:49 »
Interested
This is what we need to talk on IC phase.
I will make form later to easy collect data
Offline Petch
« Reply #4 on: Thu, 26 April 2018, 05:43:39 »
Interested for one or two
Offline Vigrith
« Reply #5 on: Thu, 26 April 2018, 07:08:18 »
Great idea! If you provide the most common sizes (HHKB, 65-68% and TKL for me) then I'll definitely buy 2 or 3 at the estimated price.
Offline yasintahir
« Reply #6 on: Thu, 26 April 2018, 07:13:52 »
I was thinking to make it at 1 size 50x20x10cm and would be fit until 1800 layout keyboard. And you can customize inner padding use foam like pelican case did.
But if my vendor can do multiple size and combine them in the same order moq. I would go for diffrent size support.
Offline yasintahir
« Reply #7 on: Thu, 26 April 2018, 07:14:41 »
Thanks man! Let's see until make the sample.
Offline KaosJ
« Reply #8 on: Thu, 26 April 2018, 07:19:20 »
Interested
Well i'm interested in a 96% or 60%, not sure yet
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #9 on: Thu, 26 April 2018, 07:23:00 »
gonna need some for some boards coming in. with that price point. I'm definitely in.
Offline Vigrith
« Reply #10 on: Thu, 26 April 2018, 07:40:46 »
Oh yea that'd work too, of course the latter solution would be easier for the customer but either would be just fine, I'd say.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #11 on: Thu, 26 April 2018, 08:47:58 »
I'd be interested in 1 or 2 for TKLs.  Custom foam is a nice idea, that way could potentially do a case for a TKL and a numpad.
« Reply #12 on: Thu, 26 April 2018, 08:54:12 »
I would be in 3... Looking for 1800, tkl an 75%
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #13 on: Thu, 26 April 2018, 09:18:23 »
Looking for cases for an 1800, a 96key, a 75%, a TKL (as large as a Realforce), a Blackbird style layout keyboard (TKL could work), a 65%, and a few 60%s.
Sent from my mobile using Tapatalk
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #14 on: Thu, 26 April 2018, 09:19:44 »
Interested in a few, maybe 5-10 bags for TKL. But at that number I'd want to see the prototype first, so good luck with that!
Offline Keebmeupscotty
« Reply #15 on: Thu, 26 April 2018, 09:48:05 »
Interested. I'd be in for at least one at that price. I better start looking for a nice image to throw on there.  ;D Question: If your vendor won't do multiple sizes and you go with the one size fits all and cut your insert to size method, would we be able to buy multiple foam inserts? (And if so, do you have an estimated price per foam insert?) Looking forward to this.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #16 on: Thu, 26 April 2018, 09:53:49 »
Yes, very interested.
Somewhere in the 15-20 range depending on final price.
50 * 20 * 10 is big enough for even my largest keyboards.
Offline sodiumjoe
« Reply #17 on: Thu, 26 April 2018, 10:02:52 »
I'm in for at least one at 65% (specifically fc660c).
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #18 on: Thu, 26 April 2018, 10:12:28 »
Sounds good
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #19 on: Thu, 26 April 2018, 10:41:55 »
Definitely interested in this depending on how the pricing turns out. I'd be interested in sizing closer to 40x16x5cm interior for 96key.
Offline ___q
« Reply #20 on: Thu, 26 April 2018, 10:50:20 »
I would want to see a prototype but I could be in for a few of these.  I have a couple of the TX/LZ cases and they are extremely convenient for storage and shipping.
In terms of sizing, I'd prefer the smaller side of things (TKL, 65, 60).  You could probably make a 65%-sized case work for both 65 and 60 easily enough. But putting a TKL in a larger-than-TKL-sized case starts to get unwieldy.
Offline vtachkov
« Reply #21 on: Thu, 26 April 2018, 12:26:49 »
I'd be in for a 60/65 and a TKL.
Offline M
« Reply #22 on: Thu, 26 April 2018, 12:34:41 »
I'd definitely be in for one, although the board I have in mind isn't standard layout, so I would probably just end up getting an 1800-sized bag and changing how much foam is inside
Offline Kafka
  • i like clean things
« Reply #23 on: Thu, 26 April 2018, 12:52:21 »
60/65%
Offline mago
« Reply #24 on: Thu, 26 April 2018, 13:36:02 »
Would be in for a few 60%
Offline PotatoTM
« Reply #25 on: Thu, 26 April 2018, 15:22:41 »
I'd be very interested in at least one 65% sized bag :)
Offline FoC_Tow
  • Brokehlicious
« Reply #26 on: Thu, 26 April 2018, 16:55:47 »
Sounds awesome!
I use your sleeves on a daily basis and would love to get 2-3 of these for my ve.a and sx60 <3
« Last Edit: Thu, 26 April 2018, 17:02:27 by FoC_Tow »
Offline pr0ximity
« Reply #27 on: Thu, 26 April 2018, 17:49:44 »
Interested in two for 60/65% sizes. I'd prefer smaller size overall rather than a TKL-sized with foam.
Any idea what shipping would be like for these in the CONUS?
Offline roostrc0gburn
  • its just plastic
« Reply #28 on: Thu, 26 April 2018, 17:57:54 »
i'll buy a couple - i need one for ZZ96, one for KBD66, and one for TG3-BL82. maybe a couple more. at that price point, why not?
Offline euphxenos
« Reply #29 on: Thu, 26 April 2018, 18:22:32 »
I'd be interested in several sized for 65%, and several sized for larger keyboards.  I wouldn't be interested in using a larger case padded out with lots of foam for a 65%, but I still have use for some of the larger cases.  I'm very interested in seeing how the prototype turns out.  Given the low MOQ you're talking about, would you consider running multiple rounds so we can try them out and come back for more?
Offline yasintahir
« Reply #30 on: Thu, 26 April 2018, 23:02:19 »
Update
Offline speedyzy
« Reply #31 on: Thu, 26 April 2018, 23:09:14 »
definite in
Offline yasintahir
« Reply #32 on: Thu, 26 April 2018, 23:13:17 »
Ussually i send custom sleeve is $20 but i'm not sure this one will charge by volume or not.
Offline yasintahir
« Reply #33 on: Thu, 26 April 2018, 23:14:27 »
For multiple round probably i will did. But not every month like custom sleeve.
Offline yasintahir
« Reply #34 on: Thu, 26 April 2018, 23:16:18 »
I think height 5cm is not thick enough to cover top and bottom keyboards. And the size i use is the outside bag. Maybe i will use 8/9cm height
Offline crcstig
« Reply #35 on: Thu, 26 April 2018, 23:17:36 »
Defnitely in for a couple of both sizes. This price seems fine, and shipping sounds good for what it is. I like the size breakdown too, its a great compromise.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline sodiumjoe
« Reply #36 on: Thu, 26 April 2018, 23:34:58 »
Do you have a color way in mind? Personally I would prefer all black. And if there was an option for no handle, I would prefer that as well.
I think it would also be cool to have a Velcro patch on the outside to add a custom patch.
Offline yasintahir
« Reply #37 on: Thu, 26 April 2018, 23:39:17 »
I print it first on white canvas, so basically you can put color as you want. Yes you can remove the handle if you want. And for patch i need to think it first because it will lot to do.
Offline sodiumjoe
« Reply #38 on: Thu, 26 April 2018, 23:40:51 »
Thanks for the quick reply. I misread your original post and did not realize you were offering custom designs. I think that's actually way better so probably don't worry about the Velcro patch. Thanks!
Offline oh_chesteroni
« Reply #39 on: Fri, 27 April 2018, 00:02:49 »
I'll be getting one of each size, great price!
Offline wholypantalones
  • text and icon mods plz.
« Reply #40 on: Fri, 27 April 2018, 16:47:09 »
In for some bags.  :thumb:
Offline foxmancore
« Reply #41 on: Mon, 30 April 2018, 04:59:56 »
I'd buy one :)
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #42 on: Mon, 30 April 2018, 05:07:24 »
i think interest is there even if you have different bag for each size, main thing now is to produce the prototype where most of the IC like this fail to do and then just forget about it.
Once you have prototypes and at a reasonable price and shipping, youll get alot of orders including from me  :))
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Offline yasintahir
« Reply #43 on: Mon, 30 April 2018, 05:30:03 »
It's hard to get diferrent size on this vendor. Because they charge me with 100 moq of each size.
For price i'm pretty sure it will $30 for smaller size and $35 for bigger size.
The problem is shipping, it will got volume for sure. Maybe i need some proxy to reduce the shipping fee.
Offline kmba
  • Formerly tameone
« Reply #44 on: Mon, 30 April 2018, 06:35:14 »
In for multiple
keyboards.
Offline yasintahir
Re: [IC] Keyboard Bag (Eva Foam) Shockproof and Custom Design | Form Update
« Reply #45 on: Mon, 30 April 2018, 22:14:11 »
I already make the form.
Please fill that to see what will we get about the size.
Offline Photoelectric
« Reply #46 on: Mon, 30 April 2018, 22:26:49 »
I like the WhiteFox color scheme bag shown in the first post.  I'd be inclined to get some light toned combination myself, such as light gray shell with teal or rose-gold/dusty rose/pink lining, if anything like that is available.  Otherwise light gray case and dark gray inside foam.  The mesh pouch in the WhiteFox bag is also useful for various addons, matching cable, or paper notes.  Looking forward to the final configuration and color options.
  • its just plastic
« Reply #47 on: Mon, 30 April 2018, 22:28:25 »
can you put dimensions? not all tkl boards are the same thickness
Offline yasintahir
« Reply #48 on: Mon, 30 April 2018, 23:01:35 »
I put that on form. 440x220mm for big size and 370x170mm for small size
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #49 on: Mon, 30 April 2018, 23:59:19 »
Do you have sample(s) yet?
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
