Author Topic: Kinda new, need help with signature formatting/displaying  (Read 3074 times)
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« on: Tue, 01 May 2018, 09:27:05 »
(Obligatory introduction that will likely go unseen) Got into MKs at end of 2016 via r/mk and recently have gained the confidence to start lurking over here more and officially created account.
Trying to get my signature to show properly, but not sure if glitch with GH right now, or if I am messing up the formatting. Currently it's only showing the image, but none of the text. Pasted below is the same markup I am trying to get to work.
75%: YMD75 (Gateron Green) | XD84 (Outemu Ice Purple/Grey) | Drevo Excalibur (Browns with Raincoat Mod) | E-Element Z-88 81-key (Outemu Purple/Teal) | Plum84 (BKE Heavy)
TKL: Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Redragon Kumara (Outemu Blue) | Archon RE:AL Superior EX (Nopre 65g)
« Last Edit: Tue, 01 May 2018, 09:57:53 by Zuology »
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Kinda new, need help with signature formatting/displaying
« Reply #1 on: Tue, 01 May 2018, 09:50:39 »
The signature only displays the first 10 lines and then it cuts out the rest. I'm assuming your image is probably equal to 10 lines of text.
Offline Zuology
« Reply #2 on: Tue, 01 May 2018, 09:53:02 »
Thank you for the clarification!
Offline xondat
  • i'm not a star
« Reply #3 on: Tue, 01 May 2018, 09:53:44 »
You can technically get around it by using the "more" tags, and it'll expand.
Offline Zuology
« Reply #4 on: Tue, 01 May 2018, 09:57:00 »
Thanks for the pro-tip! Gotta make sure I can show off my MK e-peen and promote projects I support at the same time   :))
