Author Topic: [IC] Replacement PCB for Leopold FC980M  (Read 24271 times)
Offline hineybush
  • student of error
    • hineybush keyboards
« on: Thu, 03 May 2018, 14:37:52 »
yo
I've had prototypes made for a replacement PCB for the Leopold FC980M. The goals for this were to 1. allow more layouts and 2. allow full programming (QMK). My proto only has 1.5-1.5-7-1.5-1.5 bottom row, but others can be added. I did this because this started out as a personal project so I could use my OEM Dolch PAC caps with the board.
On the electronics side, it's a direct drop-in. The OEM FC980M has three PCBs: 1. main (switches, controller, etc) 2. middleman (DIP switches, pass through from USB port to main PCB) and 3. the USB port. This PCB bypasses the middleman and plugs directly into the OEM USB port PCB, allowing super easy installation. The difficult part of this is having to modify the plate to accommodate other layouts - I had to cut some switch spots into it with my Dremel tool. It was pretty straightforward but I know some people don't like the idea of that. I'd be interested in looking into getting some replacement plates made if there's interest.
Things I could probably add for a "production version":
-More layouts
-In switch LED (nice feature since Leopold doesn't offer this on their stuff)
-SIP sockets for the indicator LEDs
-ISO Support? idk
-A cooler color than green (it's cheap so I used it for protos idc)
-A smaller JST connector on the main PCB (probably SH or something, I'll look into them some more bc I forget what the codes/sizes are)
Google Form link: https://goo.gl/forms/JAl61c6gfoX1cuO73
pics:
In the above picture my jumper cable is soldered to the USB board - I didn't feel like waiting for those JST connectors in the mail  :D
Here's an idea of the modding I had to do the plate, I didn't feel like spraying it so don't tell me I should have, I know but idc enough (prototype). The stabs didn't need any work, except for the spacebar one (had to cut areas for them since the plate initially blocked em) so it's all just easy straight cuts to make room for the switches
I'm just trying to gauge interest, there's no concrete plans to run this as a fully-fledged GB as of yet.
« Last Edit: Thu, 03 May 2018, 18:29:46 by hineybush »
Offline merlin64
    • MechMerlin
Re: [IC] Replacement PCB for Leopold FC980M
« Reply #1 on: Thu, 03 May 2018, 14:46:02 »
I want!!! But I guess I need a FC980m first
Offline random0987
« Reply #2 on: Thu, 03 May 2018, 15:31:33 »
Great idea. I’ve always had trouble with the limited dip switch options for the bottom row keys and the (for me) useless insert key. Would be great to add some more functionality to this board.
Offline wholypantalones
  • text and icon mods plz.
« Reply #3 on: Thu, 03 May 2018, 16:17:41 »
Yes please.
Any plans to post on /r/mk? I'm sure there would be a big response.
« Last Edit: Thu, 03 May 2018, 16:21:23 by wholypantalones »
Offline hineybush
  • student of error
Offline hineybush
  • student of error
« Reply #5 on: Thu, 03 May 2018, 18:30:01 »
Updated to include a Google Form, please fill it out.
Offline goldworms
« Reply #6 on: Thu, 03 May 2018, 18:53:59 »
That is really cool! Once I buy 980m and wait for your PCB :thumb:
Offline get_weird
« Reply #7 on: Fri, 04 May 2018, 00:54:36 »
is it compatible with the FC980C?
Offline threedawg
« Reply #8 on: Fri, 04 May 2018, 01:22:02 »
+1 for this, been using FC980M for several month and while I'm absolutely love this board thanks to the layout, the lack of programmable function beside the dip switch is kinda turn me down
Offline shower_king
  • Pain is weakness leaving your body
« Reply #9 on: Fri, 04 May 2018, 02:16:34 »
interested.
BTW, any chance other size PCB?
Offline hineybush
  • student of error
« Reply #10 on: Fri, 04 May 2018, 08:19:16 »
No, Topre boards are completely different.
interested.
what size are you looking for? I have a few other projects in the pipeline atm.
Offline KeyBoulE
« Reply #11 on: Wed, 15 April 2020, 15:13:45 »
Still have any of these PCbs?
Offline hineybush
  • student of error
« Reply #12 on: Wed, 15 April 2020, 18:28:26 »
sadly not right now!
Offline manaorme
« Reply #13 on: Wed, 15 April 2020, 20:49:15 »
Wish I can have one
« Last Edit: Wed, 02 September 2020, 19:55:24 by manaorme »
Offline gecruz
« Reply #14 on: Sat, 25 April 2020, 23:02:53 »
This is cool. There aren't too many CP keyboards and top row was always a deal breaker for me to get a FC980M.
Offline ray160
« Reply #15 on: Wed, 24 June 2020, 00:49:21 »
Interested in this too
Offline neutralstate
« Reply #16 on: Wed, 24 June 2020, 02:32:44 »
Would u consider a pcb for FC750 too?
Offline RedRhyno
« Reply #17 on: Wed, 24 June 2020, 03:22:31 »
This gets my hopes up everytime it is bumped.  :'(
Offline Maniac
« Reply #18 on: Sat, 29 August 2020, 03:56:42 »
OP any chance we might get this GB up & running?
Offline hineybush
  • student of error
« Reply #19 on: Thu, 10 September 2020, 20:52:28 »
haven't been focused on this sort of project in a long while, but perhaps some day
Offline pixelpusher
« Reply #20 on: Thu, 10 September 2020, 21:55:27 »
I somehow missed this thread before, but it’s an interesting project.  Even more interesting with Norbauer’s Heavy-9 case confirmed to work with the FC980m
Offline Maniac
« Reply #21 on: Mon, 14 September 2020, 14:27:36 »
Yeah I really hope we get a custom PCB for FC980M, it deserves it :) I mean, both the G80-1800 & G80-11800 have them, and those keebs are almost 30 years old :D
Offline tnk
    • Github
« Reply #22 on: Sun, 11 October 2020, 17:07:10 »
Could I get a copy of the gerber files? My pcb has taken a turn for the worst and was hoping that I could find a project like this one.
Offline brainbowroll
« Reply #23 on: Mon, 30 November 2020, 18:17:00 »
Oooh any chance you'll continue with this to make it happen? I was recently looking for 1800 layout kit with plastic case. Leopold 980M looked pretty nice but I want to put in my modded switches and desoldering Leopold board is risky as the stock pcb is not that great from my experience with FC750R.
This replacement PCB would be awesome. Hotswap would be even better.
Offline hineybush
  • student of error
« Reply #24 on: Tue, 01 December 2020, 01:58:02 »
I've had a lot of requests for this lately! When I can I will work on a new revision with expanded layout options.
Offline retoid
« Reply #25 on: Tue, 01 December 2020, 12:02:44 »
Awesome! Count me in for one as well. I appreciate you willing to take this on.  :)
Offline Henrythewound
« Reply #26 on: Tue, 01 December 2020, 12:04:51 »
exciting! I would be interested in an updated PCB if you do another round. I think these are good value boards and I don't mind the plastic case.
Offline whykayallday
« Reply #27 on: Tue, 01 December 2020, 20:36:57 »
yes please!
Offline Crooks
« Reply #28 on: Wed, 02 December 2020, 00:44:33 »
I'd be down for one!
f l y  o r  d i e
Offline colonelpanic
« Reply #29 on: Wed, 02 December 2020, 02:48:44 »
Would definitely be interested in a few myself.
Offline PizzaForce
  • Eat me.
« Reply #30 on: Wed, 02 December 2020, 08:34:06 »
This is awesome! What an excellent offering for the community. Would be cool to see the a compatible plate file created in the future to go along with this if it doesn't already exist.
Additionally, giving the same treatment to the other Leopold popular prebuilt boards would be HOT.
Hiney you rock.
Offline Foxmonsieur
  • Deus Ex Machina
    • French Mech Community
« Reply #31 on: Wed, 02 December 2020, 09:27:37 »
I need one, mine had a liquid accident 2 weeks after receiving it, freshly modded and lubbed by one of our gods.
Lockdown took a toll on us...
Count me in mate!
Offline Neodeus
« Reply #32 on: Wed, 02 December 2020, 15:58:17 »
Would buy. Gotta get those Cherry switches OOOUUUTTAAHEERRREEEE!!
Offline RedRhyno
« Reply #33 on: Sat, 05 December 2020, 16:10:16 »
Oh heck yes! Will instabuy a few of these. Would love the option of keeping the standard 980m layout.
« Last Edit: Sun, 06 December 2020, 02:27:13 by RedRhyno »
« Reply #34 on: Sun, 06 December 2020, 12:47:56 »
yes i second this !
Offline AdrianMan
« Reply #35 on: Fri, 11 December 2020, 08:20:48 »
Also interested in one !
Offline mustardgreens
« Reply #36 on: Fri, 11 December 2020, 09:15:38 »
would buy
Offline Æther
« Reply #37 on: Fri, 25 December 2020, 09:02:26 »
Also interested in this!
Offline Jhambone9160
« Reply #38 on: Fri, 25 December 2020, 16:32:34 »
Also in for this. :)
Offline pepo2181
« Reply #39 on: Fri, 25 December 2020, 17:40:03 »
I'm down for this!!!! Minimum for 2 PCB!!!!
Offline v683
« Reply #40 on: Sat, 26 December 2020, 02:31:01 »
You have my full attention
Offline 3wisemonkeyfist
  • Blacvelvetpengun
« Reply #41 on: Fri, 08 January 2021, 00:13:04 »
I'm in the market for a Leopold so this would be so good to have. Count me in if it goes to gb.
Offline endless_steve
« Reply #42 on: Thu, 04 August 2022, 18:01:45 »
Late to the party, but I'm very interested in this for my Norbauer Heavy case
