Author Topic: Great CHEAP carry case for 60% keyboards  (Read 6300 times)
Offline SixtyLife
« on: Mon, 07 May 2018, 17:47:34 »
xposting from reddit.
got this 4 pistol case, dirt cheap from amazon:
https://www.amazon.com/MTM-Pistol-Handgun-8-5-Inch-Revolver/dp/B000KOVN4S
laid out and cut out a rectangle size of kmac happy, then sliced the resulting rectangle down the spine:
put the big foam back in, then place X60 face down:
cover X60 with smaller foam:
place kmac happy:
closes easily, excellent keyboard protection for less than $14:
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline Cicada60
Re: Great CHEAP carry case for 60% keyboards
« Reply #1 on: Mon, 07 May 2018, 21:56:22 »
Honestly, though, I really don't want to carry this thing around in public just because it screams GUNS. Just a street-smart thing, you really don't want people to think you have guns.
Offline kiwi99
  • that's a gnarly dookie
« Reply #2 on: Mon, 07 May 2018, 22:09:40 »
easily remedied by a big sticker that says "not guns"  :))
Funny that if I saw this in Canada I would first think "camera gear"  :p
Offline SixtyLife
« Reply #3 on: Mon, 07 May 2018, 22:25:07 »
weird... maybe it's where I live (NJ) but I've never seen people carrying cases like this and guns would not be the first thing I'd suspect if I saw this. I'll def keep your advice in mind if I'm ever in other parts of the US though
Offline Sup
« Reply #4 on: Tue, 08 May 2018, 03:34:40 »
This case is overkill unless you go into a war zone with it  :). I think a 60% sleeve is much better and also fits into your backpack.
current
Coming soon
Offline SixtyLife
« Reply #5 on: Tue, 08 May 2018, 08:28:47 »
I have a couple sleeves which I use for hhkb, but found they're not adequate for protecting heavy metal boards. too easy to dent a corner  :(
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #6 on: Tue, 08 May 2018, 09:56:03 »
You gonna carry an 800$ kustom in a sleeve or this thing?
« Reply #7 on: Tue, 08 May 2018, 13:17:19 »
i'm prolly gonna buy 2 of those cases when i get home so i can put my 60%s in em
good storage solution as well
buy some stickers to make them look less aggressive
Offline Sup
« Reply #8 on: Tue, 08 May 2018, 16:17:46 »
Yeah why not. Also doesn't that defeat the purpose of the 60% making it not portable.
current
Coming soon
Offline elcubismo
    • Reddit page
« Reply #9 on: Tue, 08 May 2018, 16:22:14 »
Paint it white and add a large red cross. People will think you have a human heart in there.
Leopold FC660C lubed, silenced with landing pads | Norbatouch lubed, silenced with hyperspheres | Poker II MX Blue with vortex aluminum case, vortex red/white doubeshot pbt caps and o-rings | CODE TKL MX Clear with Miami | Unicomp Buckling Spring | GMMK with rainbow vomit switches, mostly jailhouse blues and pandealios
Offline SixtyLife
« Reply #10 on: Tue, 08 May 2018, 17:41:51 »
:)) that might make me a bigger target for mugging
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #11 on: Wed, 09 May 2018, 10:20:07 »
Portability is not the only reason to use 60% though tbh.
Offline jcoffin1981
« Reply #12 on: Sat, 12 May 2018, 01:21:15 »
Brilliant. And would survive a train crash.
Offline ander
  • I type, therefore I am
« Reply #13 on: Sat, 12 May 2018, 04:28:19 »
Well, that's great and all, I suppose, from a creative viewpoint... But do you really need, like, a Kevlar secret-agent-style case for a 60% keeb? I thought the whole point was how ultra-portable they were. (Why else put up with all those 3- and 4-key shortcuts to do basic stuff the rest of us take for granted?)
Seems like it defeats the purpose to reduce the concept of a keeb to its bare essence, then go and engulf it in a big ol' honkin' case like that. Why not just slip it into your pocket?
As you can see, I have many questions. Being married, though, I'm not usually allowed to question anything.
Offline funderburker
« Reply #14 on: Sat, 12 May 2018, 04:46:07 »
Well, it's not about how portable or small the board is, it's more about the safety of the object inside. A few comments back someone mentioned that alu cases dent easily so if you spend a bit more on a custom and it's an aluminium case, you wouldn't want to dent a valuable item. Also this case, in my opinion, isn't really meant to be used a everyday case but more of a storage unit or a carry case for when you go to meetups so that's why it fits two boards not just one.
Keyboard design by Skepur
Offline ptykozoon
« Reply #15 on: Fri, 18 May 2018, 17:26:59 »
necessary?
Offline jcoffin1981
« Reply #16 on: Sun, 20 May 2018, 01:36:31 »
To the OP, what is the white keyboard?
Offline SixtyLife
« Reply #17 on: Sun, 20 May 2018, 19:29:00 »
it's an old korean custom board called KMAC Happy
