Author Topic:  C³-LDN RGB80% PCB(Complete)  (Read 107000 times)
Offline C³—Ears
« on: Sat, 19 May 2018, 11:54:38 »
Ic thread:https://geekhack.org/index.php?topic=95157.0
Hello,Geekhackers
Finally, we bring this alive.
Here’s final information about this PCB:
1.LDN have faster CPU. We use STM32F103. 72M frequency. More faster and Expandable. Key scan frequency:500hz
2.A87/B87size
3.Ansi Winkey/Winkeyless,Iso
4.Full in-switch SMD RGB pre-soldered on the PCB include 20 led under. 64 level brightness and 16 default effect.Custom Led effect support.You can change each and every key’s Led.
5.Fully programmable and have 16 layer now
6.Support up to 200+ media keys
7.NkRO under USB mode
8.English software.You can translate the language file into your own language.
9.Usb-mini port for now. Support USB port up and under PCB.Type-C port will be release when we have suitable case.
10.Software support Win7,Win10.
11.Firmware will be update and more function will come
195892-0
195894-1
195896-2
195898-3
195900-4
195902-5
A87 size:122.79*347.66 mm
195945-6
B87 size:115.76*344.66 mm
195947-7
195949-8
We also provide to make PC plate.(Please provide CAD file.Please remove all logo on the plate) We have Moon/Mira/Mira Se plate Cad file for now.
Please email CAD file to this address:794982897@qq.com(please leave your GH ID in the mail)
Software:https://www.dropbox.com/s/39lz76iebgbji5i/C%C2%B3-LDN%20RGB%2080%20PCB.zip?dl=0
Quick Guide:https://www.dropbox.com/s/7eikoug6omp82xe/C%C2%B3-LDNrgb80pcb%20Quick%20Guide.pdf?dl=0
Price:
1 PCB:$50(Pcb)+$25(shipping+fee)=$75
2PCb:$100+$40=$140
3PCB:$150+$50=$200
4PCB:$200+$60=$260
5PCB:$250+$70=$320
More than 5 please pm for price.
PC plate:$20
Shipping will be use EMS or DHL or other shipping company depend on location. All traceable and ship by air.
Leadtime: 70 days after GB close
GB time:
Invoice will sent from:20th May-3rd June
Payment deadline:5th June
All unpaid order will be canceled at 23:59 5th June(Beijing time)
Form Here: https://goo.gl/forms/IhJegixYl3er1Cep2
« Last Edit: Mon, 12 August 2019, 09:54:18 by C³—Ears »
Offline C³—Ears
Re:  C³-LDN RGB80% PCB
« Reply #1 on: Sat, 19 May 2018, 11:55:03 »
Saved!
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Sat, 19 May 2018, 14:25:55 »
Approved :)
Very busy with studies atm.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #3 on: Sat, 19 May 2018, 15:06:37 »
Could you explain the form question about USB placement?  Isn’t that standardized for A.87 and B.87?
Offline kawasaki161
« Reply #4 on: Sat, 19 May 2018, 16:40:59 »
Some makers used the A.87 size but either used a cable that's attached via a JST connector (no usb option) or placed the usb on the other side of the board for some reason. Usually it's on the top for A.87.
What I'm more interested in is why this is offered in B.87 size when B.87 has the USB on the left
Offline ika
« Reply #5 on: Sat, 19 May 2018, 18:47:27 »
Is this going to be using custom firmware? Or something existing
Offline C³—Ears
« Reply #6 on: Sun, 20 May 2018, 00:38:44 »
some pcb changed a little using usbport under pcb. we want to fit as many case as possible so there's that option :thumb:
Offline C³—Ears
« Reply #7 on: Sun, 20 May 2018, 00:42:17 »
Most of the case we know using usb port on the right side so we do it on the right. Our goal is to fit most case on this round since we don't provide a case at the moment.  ;D ;D ;D
Offline C³—Ears
« Reply #8 on: Sun, 20 May 2018, 00:42:49 »
We make our own software and firmware. ;D ;D ;D
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #9 on: Sun, 20 May 2018, 00:50:08 »
I made a mistake an had to order again ¯\_(ツ)_/¯
Offline YisSerL
« Reply #10 on: Sun, 20 May 2018, 01:38:22 »
If I want to order this PCB for a Mira SE, which option should I choose?
Offline Walkerstop
« Reply #11 on: Sun, 20 May 2018, 01:38:37 »
You are planning on selling a case to go with this pcb at some point? Any idea how soon?
Offline maximm
« Reply #12 on: Sun, 20 May 2018, 02:01:50 »
I want to order this for the Moon, what options should i choose?
Offline Blackhawk
« Reply #13 on: Sun, 20 May 2018, 04:49:16 »
Might be interested in picking up a pcb + PC plate. Is the PC transparent or frosted?
Offline faxe
« Reply #14 on: Sun, 20 May 2018, 07:02:35 »
Which cases does this pcb fit?
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline C³—Ears
« Reply #15 on: Sun, 20 May 2018, 09:22:11 »
Frosted. :thumb: :thumb: :thumb:
Offline C³—Ears
« Reply #16 on: Sun, 20 May 2018, 09:26:12 »
B87 size. Choose PC plate if you needed. ;D
Offline C³—Ears
« Reply #17 on: Sun, 20 May 2018, 09:27:40 »
A kit is being designed. But using type-c port.I'd say it will need at least 2 months. :thumb: :thumb: :thumb:
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #18 on: Sun, 20 May 2018, 10:39:42 »
Hi could you let us know how thick the polycarbonate plates are?
Offline C³—Ears
« Reply #19 on: Sun, 20 May 2018, 11:38:13 »
Sorry it's 1.5mm thick. Most tkl case use thick.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #20 on: Sun, 20 May 2018, 12:09:28 »
Wait, really? I thought both the MIRA SE and the MOON had A87 ports (on the right side of the board between the main section and the navigation cluster).
Offline kawasaki161
« Reply #21 on: Sun, 20 May 2018, 13:38:57 »
This is exactly the problem I was going for when I asked.
It seems that they only used the B.87 size and stabilizer orientation but not the port-placement. Which makes this distinction almost useless because 95% of boards fit both without any issues. If you have the choice get B.87 size because the spacebar stabilizer orientation leads to less wobble.
Offline stepstone82
« Reply #22 on: Sun, 20 May 2018, 21:15:08 »
hello, which will fit for orion v2 and lz-fe?
It is hard to find the information by myself
나의 LGM-G600S 의 Tapatalk에서 보냄
Offline C³—Ears
« Reply #23 on: Sun, 20 May 2018, 22:47:28 »
Yeah...For a lot of case, the usb port is the right. If you see the picture we post it's on the right side. And the in video we use mire se to test it and it worked.
Offline C³—Ears
« Reply #24 on: Sun, 20 May 2018, 22:49:43 »
Sorry we don't have duck orion v2 and lz-fe.
You can measure it yourself.
1,overall size
2,Esc and number row
3,usb on the upper side or under
Offline Etherealsound
« Reply #25 on: Mon, 21 May 2018, 00:33:28 »
Wait, so is this for certain because I want to make sure that if I get the B.87 for my Mech27v1 it will fit properly.
Offline C³—Ears
« Reply #26 on: Mon, 21 May 2018, 00:37:37 »
If the usb port on right side it may fit. We put the usb port on the right for B.87 since most the case we know using right side usb. Plus you should see the size picture and measure it for sure.
Offline Walkerstop
« Reply #27 on: Mon, 21 May 2018, 01:53:42 »
That's awesome can't wait!
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #28 on: Mon, 21 May 2018, 06:32:36 »
Hi C3, what should I be selecting if I need a pcb to replace Moon TKL? Will the pcb fit exactly on Eve Moon?
Offline C³—Ears
« Reply #29 on: Mon, 21 May 2018, 09:07:31 »
B.87 with no usb port.You have to use the daughter board in the Moon Kit. :thumb: :thumb: :thumb:
« Reply #30 on: Mon, 21 May 2018, 12:16:56 »
Thank you!
Offline Blackhawk
« Reply #31 on: Mon, 21 May 2018, 13:32:05 »
Thanks! Is it possible to order two different plates with one pcb?
Offline iNViSiBiLiTi
« Reply #32 on: Mon, 21 May 2018, 15:24:54 »
Is the spacebar wire above or below the switch? I think the TX87 is above, but other PCBs have it above.  Will that affect what plates are compatible?
Also I'm confused on the B.87 and A.87 size.  What's the difference? I want was looking for a pcb that is the same size as the Leeku L3 pcb (TX87).  That pcb fits the Mira, Jane, and Mech27.
nevermind I figured it out.  A.87 has spacebar wire above.  B.87 has spacebare below.  USB port is in the same place.
« Last Edit: Mon, 21 May 2018, 16:32:59 by iNViSiBiLiTi »
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline C³—Ears
« Reply #33 on: Tue, 22 May 2018, 00:08:05 »
Yes,sir. We test B.87 on Mira and Moon. It all worked.
Offline C³—Ears
« Reply #34 on: Tue, 22 May 2018, 00:09:36 »
Yes, please wirte in the form or PM me about what PC plates you want. :thumb: :thumb: :thumb:
Offline C³—Ears
« Reply #35 on: Tue, 22 May 2018, 10:04:50 »
196041-0
196043-1
Offline roostrc0gburn
  • its just plastic
« Reply #36 on: Tue, 22 May 2018, 11:22:35 »
is either pcb compatible with SK0G?
Offline C³—Ears
« Reply #37 on: Tue, 22 May 2018, 11:28:45 »
A87 fit Skog. ;D ;D ;D ;D
  • its just plastic
« Reply #38 on: Tue, 22 May 2018, 11:37:25 »
nice! is the plate confirmed to fit the bolt pattern also?
Offline corygrapher
« Reply #39 on: Tue, 22 May 2018, 14:27:27 »
Which one should I buy for Fox Labs TIME TKL/WKL keyboard? Should I go with B87 & USB port up? Thank you.
FYI: Here is a close look at that PCB of TIME TKL (@36:00 of the video):
« Reply #40 on: Tue, 22 May 2018, 19:34:05 »
A87 but yeah
« Reply #41 on: Tue, 22 May 2018, 20:06:38 »
Because I'm lazy, will this work with a Jane r1?
« Reply #42 on: Tue, 22 May 2018, 20:26:29 »
yep
a87 top usb
« Reply #43 on: Tue, 22 May 2018, 21:26:01 »
yep
a87 top usb
Thanks! That's what I thought. Now to get a plate...
Offline C³—Ears
« Reply #44 on: Tue, 22 May 2018, 22:46:28 »
B.87 with top usb port. I am sure of this....
Offline C³—Ears
« Reply #45 on: Tue, 22 May 2018, 22:48:50 »
A87 but yeah
Thank you Puddsy,you are such a nice guy. But time do use a B87 size,this is the reason we make B87 usb port on the right side,since we know most of the B87 is using right side port...at least that's what happens in China.... :p :p :p
Offline C³—Ears
« Reply #46 on: Tue, 22 May 2018, 22:50:07 »
yep
a87 top usb
I am not sure about Jane.But we can make PC plate if you are interested(Cad file needed). ;D ;D ;D
« Reply #47 on: Tue, 22 May 2018, 23:02:12 »
A87 but yeah
ah damn, someone told me wrong then
« Reply #48 on: Tue, 22 May 2018, 23:27:14 »
yep
a87 top usb
just FYI, both their B.87 and A.87 have the usb on the right side, only difference is the dimensions of the edge of the pcb.  B.87 has the spacebar wire under the switch, A.87 above the switch.  I would double check what you're Jane has.  If it's using a TX87 (Leeku), it should be bottom spacebar wire like my Mech27 is.  So you'd have to choose B.87
« Reply #49 on: Tue, 22 May 2018, 23:38:51 »
yep
a87 top usb
Yeah, it uses the Leeku TX87 PCB--which I'm not a fan of...
