Author Topic: [IC] GMK Paper (Black on White) [GMK Renders In]  (Read 64728 times)
Offline zumu
  • Professional Typist
« on: Sat, 26 May 2018, 02:28:41 »
What is GMK Paper?
A classy black (CR) on white (WS1) cherry profile set with clean legends (graciously borrowed 9009).
Why?
With all the colorful new keebs coming out (M60-A anyone?), I thought people might love a nice neutral GMK set.
Renders
I got excited and ordered some renders from janglad. I have since collaborated with jebbra on some of the kit, so these are mostly just for show -- there will be more keys in the actual base set.
A copy of 9009's base kit in WoB
Also, as some people have pointed out, the renders might a tad creamier than actual WS1. Here's a link to a WS1 (Blue on White) set for comparison. https://geekhack.org/index.php?topic=82308.msg2252234#msg2252234
Proposed Kits
These are screenshots copied from KLE -- the actual legends will be match the renders (9009 style Icon/Text mix).
Base (Updated 6.3)
Tried to support a variety of layouts since this is such a standard color way. NOTE: the 2u, 2.25u and 2.75u spacebars*
*sumbitted for quotes to GMK along with a few other options. See the kits submitted here https://imgur.com/a/gZNQz5w
Accent
Mostly Jebbra's creation, this accent kit is inspired by color proofing, tying into the loose 'Paper' theme. It leverages the fact CMYK mods and spacebars are already widely available (I believe Originative often has them in stock). The keys will be N5 (cyan) MG1 (magenta) CV (yellow) and CR (black). The legend will be CR for all. NOTE: The legends are currently incorrect, and I think we will need to tweak the CR on CR some.
Also, if there's enough demand, I'd like to see about adding a watser to this kit, or perhaps a set of CMYK on White watsers... ;) (Have not heard demand, so I'm tabling the issue)
What next?
  • Gather feedback / judge interest Currently, tweaking the base kit -- updated layouts soon!
  • Submit the proposed kits to GMK for pricing -- We are currently waiting for quotes from GMK! See the album of proposed kits here https://imgur.com/a/gZNQz5w
  • Discuss timing -- I know there's a lot of cherry profile running right now, so we can postpone til a dry season if necessary
Anyway, thanks everyone for taking a look. Feedback is welcome!
P.S. Shoutout, to janglad, fishpod and jebbra for helping make this IC happen :)
« Last Edit: Mon, 11 June 2018, 12:31:28 by zumu »
Offline hineybush
  • student of error
    • hineybush keyboards
Re: [IC] GMK Paper (Black on White)
« Reply #1 on: Sat, 26 May 2018, 02:34:37 »
small suggestions:
actual division and multiplication symbols on the numpad (burgundy r2, fishbed, others)
no front print on the numpad (looks much cleaner)
WS1 is SUPER white. perhaps look at other whites that GMK supplies. WS1 isn't bad, but I don't know how well it'll be received.
CMY kit is unique and different than the others that've happened. if there was a seperate Esc pack, I'd get it for sure.
otherwise it's perfect imo, kit seems complete
Offline zumu
« Reply #2 on: Sat, 26 May 2018, 02:44:09 »
This is the feedback I got from Jebbra as well. Is this the new standard? My goal was to keep things classic, but I'm not a numpad user so I am very receptive to people's opinions.
Ditto the above. But to clarify, do you mean sublegends instead or neither?
This set was somewhat born out of the thread for the last BoW-ish set (GMK Pristine), where there was a strong segment pushing for WS1.
Thanks for the input!
« Last Edit: Sat, 26 May 2018, 03:03:42 by zumu »
Offline quaddepos
« Reply #3 on: Sat, 26 May 2018, 04:48:57 »
Do I see a row 2 backspace over there?
Offline Parva Ovis
« Reply #4 on: Sat, 26 May 2018, 07:00:11 »
Any chance for scooped homing keys or split spacebars (including convex 2u)?
I second having the division, etc, symbols. No sublegends on the numpad would be my preference.
Offline schmoktopus
« Reply #5 on: Sat, 26 May 2018, 07:05:21 »
Are there any more kits planned? I could use norde support.
Offline Vigrith
« Reply #6 on: Sat, 26 May 2018, 09:30:24 »
Great kit, I've been waiting for a proper BoW set to come out for a while now since Stormtrooper is fairly ancient now and between Pristine, the new KBDfans epbt and this, the choice is very easy.
I'm all for pursuing colour kits of sorts, CMYK or otherwise, too. Far as suggestions go I'd just like to see smaller space bars somewhere; as in 2.25, 2.75 and 1.25, in my case.
Nice work!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Sat, 26 May 2018, 09:56:48 »
Yes
OP: there won't be a dry season per se. There's an interest check every couple of weeks. I also suggest a spacebar kit as Vigrith mentioned.
« Last Edit: Sat, 26 May 2018, 09:58:21 by LightningXI »
Offline gnunin
« Reply #8 on: Sat, 26 May 2018, 10:38:01 »
This is great. Much needed.
Offline vtachkov
« Reply #9 on: Sat, 26 May 2018, 10:50:34 »
I'm glad someone is finally going through with the proper BoW with ws1. Will this include the icon only mods in the render or text in the layout screenshot?
Offline donut_sauce
« Reply #10 on: Sat, 26 May 2018, 17:33:40 »
I would be up for this for sure.
Offline kmba
  • Formerly tameone
« Reply #11 on: Sat, 26 May 2018, 18:21:51 »
Stormtrooper was CP, and looks great. WS1 is super white. I have a feeling a lot of people haven't seen stormtrooper or know what a full ws1 set would look like. Just my opinion though. Pristine is L9 which is basically beige, not white.
keyboards.
Offline ideus
  • Björkö.
« Reply #12 on: Sat, 26 May 2018, 18:37:33 »
I'd be all over it if it were L9. The idea is very good though. Godspeed.
Offline amnesia0287
  • Formerly Amnesia
« Reply #13 on: Sat, 26 May 2018, 19:32:04 »
So you mean, if it was gmk pristine, the set currently in stock on zfrontier?
Why would he run another pristine when it’s still available???
Offline OracleKev
« Reply #14 on: Sat, 26 May 2018, 20:53:05 »
This is what WS1 keycap set looks like http://kbdlab.co.kr/index.php?document_srl=3904226 (with V4 legends).  They are sterile white, gives unnatural bleached look.
My personal preference is CP over WS1.
« Last Edit: Sat, 26 May 2018, 21:16:42 by OracleKev »
Offline itsaferbie
« Reply #15 on: Sat, 26 May 2018, 22:10:17 »
I would be in for a set for sure
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #16 on: Sat, 26 May 2018, 22:16:37 »
Looks good IMO.
Offline flyingpike
« Reply #17 on: Sat, 26 May 2018, 22:26:17 »
Slight preference for CP but not a big deal personally. Only primary legends on numpad.
Would be in for sure if text only modifier legends were offered. Too many icon only on offer lately.
Offline ullr
« Reply #18 on: Sat, 26 May 2018, 22:37:51 »
Skipped Pristine for this exact set. Glad to see there is still demand.
Offline AlexAtPanc
    • Panc Interactive
« Reply #19 on: Sat, 26 May 2018, 22:40:49 »
Stormtrooper on a completely white board still looks stellar imo, but there is a difference. I believe the WS1 for GMK Paper will look great as well.
Offline ideus
  • Björkö.
« Reply #20 on: Sat, 26 May 2018, 23:21:07 »
I was not aware of it. But thank you for the reference, I will check it, thank you.
Offline Peiweisgreat
« Reply #21 on: Sun, 27 May 2018, 00:47:55 »
Just when I was thinking I need a keyset that can go on any keyboard. Lets get this show on the road my dude.
Offline zumu
« Reply #22 on: Sun, 27 May 2018, 01:16:23 »
Hey guys, loving all the feedback! Let me try and answer the outstanding questions / send a few more your way.
There's a 1.5u R2 (ala HHKB), a 1u R2 and a 1.75u R2. The legends will be the ICON arrow legend.
I was planning on including both scooped and bars. Also, there are 2.25u and 2.75u spacebars on the right side of the kit. Does this fulfill the split spacebar requirement?
Sounds like we will be changing the symbols.
No further kits planned, but I'd love to offer a norde kit if there's enough demand. Can you link me to what a proper norde kit might look like?
There's a 2.25u and 2.75u spacebar on the right side of the kit. I was hoping this would cover most use cases. Would you guys rather a separate kit? My main concern is MOQ for smaller kits. We could also try throwing a 2u into the base kit.
Icon, sorry for the confusion. I'll bold that part in the original post.
As for all the CP vs WS1 discussion, I'd like to push this forward as a WS1 set, though I agree CP looks stellar as well. Honestly, I initially got the renders in both CP and WS1 for comparison and opted to pursue WS1 because
  • I saw a lot of vocal demand here on GH
  • It has never been run before afaik
  • I thought the WS1 render looked awesome
« Last Edit: Sun, 27 May 2018, 22:17:16 by zumu »
Offline Koatl
  • Kozahtli on reddit, etc.
« Reply #23 on: Mon, 28 May 2018, 02:15:02 »
Been interested in something exactly like this. Count me in!
Offline glack23
« Reply #24 on: Mon, 28 May 2018, 02:51:21 »
definitely interested in this but i remember the runner for GMK pristine will follow up with WS1 with no mention of timeline?
Offline zumu
« Reply #25 on: Mon, 28 May 2018, 03:28:08 »
I spoke with fishpod (GMK Pristine runner), and they gave me the go ahead to run this IC/GB.
Offline glack23
« Reply #26 on: Mon, 28 May 2018, 03:35:07 »
hopefully this gather enough support , pass on pristine coz it not WS1
Offline avid
« Reply #27 on: Mon, 28 May 2018, 04:03:35 »
WS1 is the best white. CP is more beige, GMK stormtrooper color is perfect (WS1)
Offline jebbra
  • jebbra.net
« Reply #28 on: Mon, 28 May 2018, 06:38:00 »
Glad I can help this set! I will still help zumu until this project come to fruition :thumb:
Stormtrooper is CP tho ;)
Offline gnunin
« Reply #29 on: Mon, 28 May 2018, 06:42:39 »
Do we have any estimates on the GMK queue times? I mean, a lot of sets are coming out right now. Are we looking at a summer -19 release at this point for sets running now?
Offline kmba
  • Formerly tameone
« Reply #30 on: Mon, 28 May 2018, 07:46:01 »
No.  GMK has been pumping sets out pretty quickly.  Stock color sets have been around 3 months for production lately.
keyboards.
Offline OracleKev
« Reply #31 on: Mon, 28 May 2018, 07:58:20 »
WS1 probably is fine, but I'd suggest taking a look at a WS1 set.  Just to make sure and avoid an unexpected surprise at the end.
It feels quite different in person from the rendering. (I own a WS1 set--Blue on White run by Cocobrais).
Offline kmba
  • Formerly tameone
« Reply #32 on: Mon, 28 May 2018, 08:29:55 »
The render is indeed way too tinted.  WS1 is much brighter and whiter.
keyboards.
Offline avid
« Reply #33 on: Mon, 28 May 2018, 10:03:45 »
Ops, the GMK blue-white is the WS1 set i was thinking of!
Offline Dennyroxsox
  • a.k.a. Lollipopsaurus
« Reply #34 on: Mon, 28 May 2018, 12:37:23 »
I think the concept is really neat. Are the accent kits going to be like a classic #2 pencil and eraser color? I think that would be interesting. Or are you sticking to CMYK?
Offline doostin
« Reply #35 on: Mon, 28 May 2018, 13:52:16 »
Definitely in if 2u spacebar is included; would be great for EM7, Alice, etc.
Offline Trousers
« Reply #36 on: Mon, 28 May 2018, 17:03:08 »
Offline bthezebra
« Reply #37 on: Mon, 28 May 2018, 18:47:08 »
I am looking forward to a good clean base set in WS1.
Offline rfindra
« Reply #38 on: Mon, 28 May 2018, 21:42:38 »
great, now I have to stop thinking of buying that pristine. And dont need use shift key for split spacebar  ;D
Offline ideus
  • Björkö.
« Reply #39 on: Mon, 28 May 2018, 21:46:12 »
Offline hineybush
  • student of error
« Reply #40 on: Mon, 28 May 2018, 23:22:46 »
I feel like it should be the new standard if it isn't yet. It's more correct, at least.
No sublegends. Take a look at burgundy (same as the first suggestion, lol) for an idea
Offline rmendis
  • Artisan addict
« Reply #41 on: Tue, 29 May 2018, 02:44:14 »
So nice to see WoB finally done properly with WS1
Offline stxfreak
« Reply #42 on: Tue, 29 May 2018, 03:07:50 »
I really like this. I know it will never happen, but maybe add WoB modifiers as a set?  ;D
TGR Jane V2
Offline jebbra
  • jebbra.net
« Reply #43 on: Tue, 29 May 2018, 04:00:22 »
The accent derived from CMYK printer's mark in offset printing industry. Because this set is white as paper, I thought any accent/novelties related to printing will be neat. Here's some example of printer's mark:
196583-0
196585-1
196587-2
I'm thinking to add the registration mark too as the novelties, what do you think?
196590-3
Some of the split-spaced keyboard use 2u + 1.25u to accomodate middle fn (which is nice!).
How about taking out the split spacebars and 40s from basekit, and making a kit consisting of complete split-spacebars (1u convex 1.25, 2u convex, 2.25, 2.75), 40s, and some keys for ortholinear board? Some people advising me about this on Slack.
« Last Edit: Tue, 29 May 2018, 04:04:25 by jebbra »
Offline SolidCactus
« Reply #44 on: Tue, 29 May 2018, 14:12:36 »
Can’t believe I didn’t spot this one earlier! I have been waiting for a WS1 set! Count me in
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #45 on: Tue, 29 May 2018, 14:23:45 »
Man I wish I had the money for this :/
I don't have a GMK set, but this is certainly one I would buy in a heartbeat
Offline hervuli
« Reply #46 on: Tue, 29 May 2018, 15:55:08 »
Bonus: WS1 will also combo nicely with GMK Metaverse if it happens
JD40v2 MX Grey | HHKB BKE Heavy | E6-V2 78g Tealios | ZealX60 72g MX Zilent | TGR 910 RE 78g MX Zilent | Singa Vintage MX Black | Octagon V2 MX Grey | Orion V2 MX Clear | Novatouch BKE Extreme
Offline KawabataLuis
« Reply #47 on: Tue, 29 May 2018, 16:42:40 »
hervuli, Damn, I wasn't that interested on this set. But I really want Metaverse to work. Now I can't take what you said out of my mind.
Offline Dennyroxsox
« Reply #48 on: Tue, 29 May 2018, 21:30:57 »
Oh wow, that's really cool. Apologies for not realizing that earlier. I'm on board now. =D
Offline soupymeatballs
« Reply #49 on: Tue, 29 May 2018, 21:36:45 »
This set is so clean. Hope we make it to GB.
